What to do with a partially disabled 1160
2005-08-12 by Peter Marquis-Kyle
I have a 1160 that has come back from my local Epson technician with the
news that the magenta head is, indeed, hopelessly blocked. I also have a
bunch of spongeless carts, bottles of MIS UT-quad inks, and QuadToneRIP.
I still want to make prints. I'd appreciate your comments on what I
should do. So far, I have thought of these options:
1
Have the print head replaced. This is likely to cost as much as the
printer is worth, and I'm not inclined to do that...
2
Just load the eboni K and enjoy the BO experience. An easy option...
3
Load the M ink in the Y chamber of the carts. Make a new QTR curve based
on the UT-EEnhMatte-warm curve, but with the M ink curve assigned to the
Y channel. I don't know exactly how to do this, but I guess it should
not be beyond me, though the results are too warm for my taste. This
seems like a bit of farting around, for a result I don't really want...
4
Give up...
Your comments please, or other suggestions?
Peter Marquis-Kyle
www.marquis-kyle.com.au
Re: What to do with a partially disabled 1160
2005-08-12 by Steven Karafyllakis
Peter;
My suggestion would be a variant of # two, but if the LK ink is too
warm, re-mix it to give you a good match for Eboni. I'm on my second
itteration (not complete enough to give details) of this, but the first
one consisted of: two parts UT-7 LK, one part standard MIS LK, and 1ml
magenta per 30ml of mix to take the yellow green out of it. Changing
the curve to use the Y channel is drop-dead easy, You'll figure it out
in half-hour tops, including reading time. You could coceivably use the
remaining channel for a LLK and have a K3 setup. or you could keep a
warm ink in it to give you sepia when needed. Have a go at it!
Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter Marquis->
based
want...
RE: [Digital BW] What to do with a partially disabled 1160
2005-08-12 by Paul Roark
The 1160 does not need the FS-Y (lightest) ink to be smooth.  FS-M is
sufficient.  So, I'd go with option #3.
Note that the 1160 variable-tone curves are based on using a toner in the Y
spot.  The M spot then has a light ink that is about half way between the FS
Y and M inks.  In the variable tone inksets, this light gray is pure carbon,
so you might not want to use it.  The variable-tone warm curve, that cuts
out the toner, will give you an idea of what a curve that just uses 3 inks
would look like.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Peter
> Marquis-Kyle
> Sent: Friday, August 12, 2005 2:38 AM
> Subject: [Digital BW] What to do with a partially disabled 1160
> 1
> 2
> 3
> 4
> Give up...
> Peter Marquis-Kyle
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
2005-08-14 by m87507
Peter, I also had a really bad clog on my 1160 Ultratone ink 'M' head
the other day, and thought it was all over, but I reverted back to
the windex fix, and it worked just fine (didn't even have to wait
over night, just a few minutes of soaked paper towel under the
heads)...then proceeded to print a number of flawless prints w/o any
cleaning cycles. If you aren't familiar with this windex fix, try
search for "clog from hell" or some such...I think it was posted on
this forum a couple years ago, but can't remember for sure. Good
luck, Mark
with the
have a
QuadToneRIP.
> 1
> 2
> 3
based
to the
should
This
want...
> 4
> Give up...
> Peter Marquis-Kyle
