Re: [Digital BW] Re: 'Possible idea on hoped for avail ability of MIS 2400 inks
2005-10-08 by Paul Aparycki
Uhhh, pardon my lack of knowledge on this piece, but why not try a little dollop of 5 minute epoxy? (my experience says to really, truly leave it for many hours just to be sure . . . but). This is supposed to be a technical list, certainly something as simple as jury-rigging permanently a couple of doo-dads shouldn't be that difficult? Paul Aparycki
>>Perhaps those of us that have 2400's could use the chips that are >>on the existing original Epson (and easily spent) cartridges, use >>MIS 2400 inks, and reset the existing 2400 chips with the chip >>resetter, unless they are un-rest-able. >This is possible, I've done it. There is only one potential problem - >the Epson 2400 chips (which ARE resettable), do not fit perfectly in >the MIS carts. It seems that the hollow space under the chip is not >deep enough for the little lump of plastic on the underside of the >chip. The result is that it doesn't seat firmly and wobbles around a >bit. However, the little blob of sticky stuff does prevent it from >falling off and it worked fine when I put it in the printer. >Regards, >Clayton
