Epson Ultrasmooth Fine Art, VFA, HPR . .
2005-11-13 by wwodets
Having tested a number of papers over the last month, I'd settled on
VFA for tonal scale, but hoped to find something with less texture
and similar tonal performance.  My final candidate (after testing the
HPR/Red River Dourian, Hawk Mountain Condor, Arches, Crane and a few
others) was the Epson USFA.  Note that all my work is done with the
K3 inks.
I've profiled the paper and done several test prints, and here are my
impressions:
1.  The paper does not have nearly the dmax of the VFA (about 1.75/L*
14.23), but approximately the dmax of HPR (1.657/L* 16.53).  The USFA
measures 1.660/L* 16.44.
2.  In looking at just the shadow areas of the USFA and HPR, they are
essentially indistinguishable.  Neither has the very strong blacks of
the VFA and this is a very apparent difference visually.
3.  In looking at the whole print, which has a wide tonal scale, the
shadows look stronger on the USFA than on the HPR.  I believe this is
becaused the dmin of the USFA is considerable better than the HPR
(.014/L* 98.72 vs. .027/L*97.64).  The greater contrast of the USFA
gives the visual impression of better shadows and a "punchier" tonal
scale (though there is no shadow compression in the USFA, probably
less than the HPR).
4.  Although the USFA looks warm, it is not as warm, yellow or creamy
as the Crane or Arches papers.  Like those two, it contains no OBAs.
Both HPR and VFA contain OBAs, the latter more in my impression.
Despite being cooler in color, a sheet of the HPR looks dingy and
gray held alongside the USFA and the HPR prints look flat and a bit
dingy in comparison.
5.  The USFA is a very luxurious paper in the hand, equalled only by
the Arches to my taste.  It is about 350gsm and it is beautifully
packed with an oversize box with a styrefoam "ring" to protect the
corners and edges.  It is a very high grade, Ph-buffered paper.  The
USFA costs less than the Arches, but slightly more than the HPR.  The
USFA is, however, double-sided, which should save some money in
botched test prints.  I have heard suggested that the USFA is
actually Premeier Hot Press Fine Art, which might be less expensive.
6.  Although I am disappointed in the dmax, this paper would be my
second choice after the VFA, particularly where the VFA texture might
be objectionable (although I don't find that the VFA texture
interferes with detail unless the print is lit at an angle).
7.  Finally, I am guessing the tonal performance of the VFA is partly
a product of the texture, rather than incidental to it.  Perhaps the
textured surface can hold more ink or reflects light differently.
The VFA is unrivalled in my experience for a full-scale matte print
with the K3 inks.
So, I think the USFA is quite good, but not the smooth-VFA panacea
I'd hoped for.
Walt
Re: Epson Ultrasmooth Fine Art, VFA, HPR . .
2005-11-13 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "wwodets"
<odets@c...> wrote:
> ...Finally, I am guessing the tonal performance of the VFA is partly
> textured surface can hold more ink or reflects light differently. ..
Walt, I think you have something there. While I doubt the texture is
actually responsible for better dmax in this instance ( I suspect VFA
has a better coating), I have found it to increase that impression.
Here, all of the Hahnemuhle papers have the same dmax (well, so close
it's down to measurement error, or so close as to be visually the
same) but the more textured surfaces seem to have blacker blacks than
PhotoRag. I speculate this is because a smoother surface may begin to
have a slight bit of actual though very diffuse reflection or sheen of
the ambient light in the room. William Turner, German Etching, and
White Velvet being more textured might break that up more. You know,
like those good old Elvis velvet paintings.
Anyway, the effect is slight, and dependent on the lighting in the
room. Also, again, it's an impression not a measurable reality.
By the way, I'm not sure White Velvet is getting the attention it
deserves, very nice.
Tyler
Epson Ultrasmooth Fine Art, VFA, HPR ...and Merlin Natural
2005-11-13 by Clayton Jones
Hello Walt,
>after testing the HPR/Red River Dourian
Did you get the same measurememnts on these?
>I have heard suggested that the USFA is actually Premeier Hot
>Press Fine Art,
Same here, but I have only tested PHP (with slightly different
results, see below).
>USFA - does not have nearly the dmax of the VFA...but approximately
>the dmax of HPR...
>of the VFA and this is a very apparent difference visually.
>Note that all my work is done with the K3 inks.
In my visual comparisons of HPR, VFA and PHP I get slightly different
results (VFA and HPR both in the 5 group with PHP lagging behind in
the 4 group).  I'm wondering if the difference is because PHP is
actually different than USFA or because I use a different ink (Eboni
BO) for my tests...or maybe just differences in production batches
(because my VFA and HPR look about the same).
Anyway, the PHP I tested is very bright as you say for USFA,
remarkable for a non-OBA paper.  Nice stuff.  A lot of people favor it.
In a similar vein, I recently took a chance on a box of Merlin Natural
because I was impressed with it's look last summer when I reviewed it.
It turns out to work really nicely with K3 inks and I have moved it
to my A-List.  In particular, at ABW 2h,10v it resembles my old
favorite darkroom paper, Ilford MGFB II.  By itself a print looks
neutral, but put it next to a cold tone print and you see it's slight
warmpth.  I loved that paper and this is the closest I've come to it's
look so far.  Also, at ABW 0h,0v, it comes as close to a true
uncolorized neutral black as I've seen so far on any paper (an elusive
goal with K3)...Hmmm, I just had a thought: maybe that's why it seems
like such a good fit with K3 inks; if the neutral setting gives a
truly neutral tone then maybe somehow it's in synch with the K3 system
(I always use the VFA paper setting).  What do you think?  Anyway,
it's really nice stuff and I'm looking forward to doing more work with
it.
I'm appreciating more and more ABW's ability to so easily fine tune
the tone.  I'm finding that every paper has it's "sweet spot", a
setting that is particularly harmonious and photographically
convincing.  Sometimes changing just a single ABW unit makes a big
difference and some obvious tinge disappears (sometimes I think single
ABW units are too coarse, and wish we could enter decimal values like
12.3).
I know these aesthetic things are hard to describe and probably
aren't quantifiable, but Merlin Natural seems to fit more comfortably
with K3 inks than some other papers do.  With some it's been a
struggle to find a good ABW setting that really clicks into place (for
example I have yet to find a setting for Condor BW that I'm fully
satisfied with).  Are you experiencing this?
Clayton
Re: [Digital BW] Re: Epson Ultrasmooth Fine Art, VFA, HPR . .
2005-11-13 by Steve Kale
Has anyone tried Eboni ink on Ultrasmooth?
> From: Tyler Boley <tyler@...>
> Date: Sun, 13 Nov 2005 02:17:03 -0000
> Subject: [Digital BW] Re: Epson Ultrasmooth Fine Art, VFA, HPR . .
> Tyler
For Tyler Re: Epson Ultrasmooth Fine Art, VFA, HPR . .
Yes I can see the "sheen" you talk about, which I would describe as
a "milkiness" that reduces the impression of black.  Speaking of
Hahnemuhle, Cary Grant once said that with a tuxedo one wore very
dark blue socks, rather than black, because the blue ones had less
sheen and looked darker.
And what do you think of my speculation on the dmin and USFA?  I
think the (relative) dinginess of the HPR makes the blacks look dingy
too.
This all brings up the issue of *comparative* evaluations and how
much weight should be given them.  Of the three top papers (for me),
the HPR black problem is the only one that bothes me seen alone.  The
USFA blacks look fine if I don't compare them side-by-side to the
VFA.
Also, I looked up White Velvet and apparently Hahnemuhle has stopped
making it.  I gather you mostly use the Hahnemuhle papers.  Is that
correct?  And what would you go to without the White Velevet?
Walt
--- In Dig
italBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@t...>
partly
differently. ..
VFA
close
than
to
of
> Tyler
For Clayton Re: Epson Ultrasmooth Fine Art, VFA, HPR ...and Merlin Natural
Yes, I find the HPR and R.R. Dourian measure almost identically
(certainly within the range of measurement error).  The ICC profiles
QTR generates can be laid on top of each other and are also
essentially identical.
On your observations about HPR and VFA, I find (don't forget, with
the K3 inks) that VFA has consistently much better dmax over many
batches of both papers, each in two different sizes.  This is very
apparent in just looking at the images and in measurement.  The L*
measures for VFA run in the low 14's, for HPR in the mid to high
16's.  I have only the single Super A3 box of the USFA for
comparison.  In the shadows, it seems identical visually to the HPR
and measures essentially the same.  The USFA, however, shows better
shadow separation, spanning the 90-100 densities from L* 26.98 to
16.44.  The HPR is 24.52-16.53.  This separation could make the USFA
look weaker, but then you need a PS curves adjustment to get any
compression you want.  The Eboni could also change the results for
sure.  So I don't know if the USFA is PHP because you tested one
paper and ink and I've tested another paper and ink.  We'd have to
control *one* of the variables!
Yes the USFA is very bright for a non-OBA paper, and I looked at it
under a black light: it is dead silent.  The HPR glows like it just
flew in from Mars by comparison.  The USFA is also just very pleasing
in color: neither yellow nor dingy, etc.
I will look at your review of the Merlin Natural.  Tuning the color
with ABW is very nice.  With the USFA I am using a -12 -16 adjustment
which nicely neutralizes the warmth of the paper color.  Oddly, it
even seems to cool down the highlights.
Yes, I think the way a paper "falls" in the ABW does have a big
effect on our perception of it, which is probably one of the reasons
the Epson papers have been looking good to me.  "Photographically
convincing" is a good phrase and one I think of often in looking at
these paper/ink combinations.  In part, this means to me that I do
not see the paper or ink, but the photograph, that the media is a
transparent conveyor of the image.  With all the detailed contol and
endless permutations we have with this digital process it's very easy
to lose sight of this.  I've spent more time looking at *paper* in
the past six or eight months than I did in my previous 40 years of
photography.
I should mention that moving the ABW color selector can substantially
changes both the profile of the paper and the dmax.  In general, any
adjustment lowers dmax a bit.  So, I've been doing an ICC profile for
any given ABW setting, which has proven quite worthwhile.
I will look at the Merlin issue.
Best,
Walt
<cj@c...> wrote:
> Hello Walt,
> >Press Fine Art,
approximately
> >the dmax of HPR...
different
it.
Natural
it.
slight
it's
elusive
seems
system
with
> it.
single
like
> 12.3).
comfortably
(for
> Regards,
> Clayton
RE: [Digital BW] Re: Epson Ultrasmooth Fine Art, VFA, HPR . .
2005-11-13 by Paul Roark
Steve,
Yes, it and Permajet (not MIS) Alpha have been my standard papers for
several years.  I think they are the best non-brightened papers.
UltraSmooth usually has a bit less dmax than Alpha, but a brighter base.
The k3 drivers favor UltraSmooth relative to the Innova coatings (which
includes Alpha) when Epson MK is used.  However, there is less of this
relative change with Eboni.
I think one has to be careful to profile UltraSmooth carefully.  It has a
slightly different contrast distribution, and can have a bit too cool
shadows for me with some inksets if not carefully profiled.
PremierArt Hot Press 205 is the bargain route to the same basic paper.  I
the U.S. www.Atlex.com is probably the low price leader on PA 205.  MIS also
sells it and will ship overseas.  So, it's cheap to give the paper or
coating a try.
Sure wish they could kick the dmax up to 1.75.
> Paul
> www.PaulRoark.com
Me too.  The VFA reliably measures exactly that (1.752 last time I
looked).  It is a surprising difference.
I also notice that the USFA is by far the most difficult to reliably
profile for ICC profiles with the i1.  I've been doing several readings
and then averaging them.  I am a bit puzzled by this.  Is the
i1 "expecting" OBAs?
Walt
Walt,
> ... The VFA reliably measures ... 1.75 ...
I like a smooth surface, but I'll definitely be giving VFA a try.
I doubt it is expecting OBAs, but I don't know.
I've been playing with Roy's "Create ICC" (which I may use with the R220 EZ
system as a first test).  I'm not sure if what I'm seeing is similar to what
you're describing, but I've noticed that the ICC outputs are affected by the
character of the input file.  I'm using an X-Rite and manually inputting
only 21 steps.  There seem to be a lot of variables that can affect these
things.
One factor appears to be the extent of contrast in the input file's shadows.
It may be that low input contrast, noise and other factors result in some
output inconsistencies.
I'm not that far down the learning curve yet, but from what I see, a system
will benefit from having enough manual controls that one can tweak the input
and output characteristics in addition to having the ICC.  With the ICC in
the "Print with Preview" workflow (now integrated into the standard "Print"
workflow of Elements 4), I'll be using the Epson driver and keeping the
Color Controls activated to help deal with some of these problems.
<paul.roark@v...> wrote:
Paul,
As I said earlier, the VFA texture does not seem to interfere with
detail unless the lighting on the print is at an acute angle.  But
that was true with matte silver papers too, even worse.  Perhaps the
physical feel of the paper is an issue, but most people seem to find
that the texture bespeaks a better paper.  I like the physical feel
of a smooth paper.  The other downside of the VFA is the OBAs (which
are fairly high I think), but I don't know how seriously to take
that.  Certainly the Wilhelm figures substantially favor the USFA
over the VFA.
On the ICC profiles, I was talking about variations in the raw
numbers read off the paper.  Given a set of raw numbers, I don't see
inconsistencies in the output of the profiles.  The program will,
however, produce erroneous (and unusable) profiles unless there is a
linear progression in the shadows.  Any two adjacent same readings or
reversals in the progression will not produce a usable profile.  On
the 2400 this made HPR unusable with Create ICC (slight reversals),
but the 4800 has corrected that.
Best,
Walt
> Walt,
reliably
readings
R220 EZ
similar to what
affected by the
inputting
these
> things.
shadows.
in some
a system
the input
ICC in
standard "Print"
> Paul
> www.PaulRoark.com
Hello Walt,
Does the Dourian look the same?  Does HPR and/or Dourian "glow" any
more or less than other papers with OBAs?
Clayton
2005-11-13 by Tom Baker
I've profiled USFA for color profiles using the Xrite Pulse system (UV filter version).  Perfect.  I also use it to create the 'profiles' for USFA for IJC/OPM.  Again, perfect.  I am profiling both OBA and non-OBA papers without any problems.
Tom Baker
Paul Roark <paul.roark@...> wrote:
Walt,
things.
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
YAHOO! GROUPS LINKS
    Visit your group "DigitalBlackandWhiteThePrint" on the web.
2005-11-13 by john dean
That has been my experience also. William Turner and G. Etching
"appear" to produce deeper richer blacks, especially with monochrome,
than smoother excellent fine art papers, although they don't measure
that way. The reflection theory makes total sense to me and although I
have thought about that, I've  never heard anyone actually articulate
it in regard to the various coatings of matte textures. I guess that
could be a characteristic of all types of printmaking media, but
especially coated stock.
Also, if we really want to take this further (I don't really) this
visual-psychological aspect of print tonality is AS important or more
important than densitometer readings of dmax values when evaluating
any papers shadow rendition when exibited in the real world. It is
unsetteling, but true. And, we also have the glass, plexiglass that
changes things too.
I do belive people have talked about this reflection phenomena that
may render a glossy prints shadow less dense visually than one on a
good matte rag, while showing a far greater dmax when measured
scientifically. When you get these glossy prints in a gallery or
museum you are talking about even more surface reflections and
scattered light.  That is one of the reasons I never get hung up on
dmax numbers and when I hear them I take them with a grain of salt. I
think they are just one thing to look at among many, even the scale of
an image should be taken into account.
John
By the way, that Crane MMax is certainly not revolutionary like they
claimed. I kind of expeced that was all hype, and its not that bright
either. It is really where they should have been 5 years ago.
John
Ink Lines on print-- C86 EZ inks
2005-11-13 by Peter De Smidt
Occasionally I've had drop of ink mar a print, but only when the ink in
the cartridges got really low. Recently, though, I've gotten horizontal
lines of pure ink, about 1 to 2 mm in thickness on EPSM.  There are
twelve lines. One goes for about 2 inches. The others are mainly one
inch, and a few are .75 inch long. They start on the right edge of the
print. I've checked the cartridges, and they're nearly full.  Has anyone
experienced this, or have a theory as to what the problem is?  I made
sure that I got a good nozzle check before making the print.
2005-11-13 by dlruckus
The standards set up for densitometric instruments took precisely the
glossy reflective characteristics into account. Otherwise the
instruments would have given very poor readings of such samples. Hence
the 45 degree angle required between illumination  of the sample and
sensor position. That also gives glossy samples an edge in readings
over matt ones because you are actually getting more specular surface
reflections making it to the sensor from matt samples and thereby
degrading the results. [ and doing so very scientifically ;') ]
Real world eyeballs however are forced to take real world conditions
as they are and not as we might wish them to be. ( Well, I should
strike that I suppose. The mind and emotions are known to interpose
between sight and interpretation on occasion I'm told.)
Duane
> changes things too.
> John
> John
Exactly.
As I have said before, it would be interesting to see comparative
measurements from an integrating sphere spectrophotometer.  Surely there is
someone on this list that has one of those babies tucked away somewhere.
Only when the light source is fully diffuse do surface characteristics begin
equalise.  One could argue that matte papers would also have an advantage in
such lighting due to their ability to bounce photons inwards for another go
at absorption.  Maybe this is what we observe with more textured vs smoother
matte papers.  So there is the possibility that greater texture can lead to
a greater specular component but also lead to greater absorption. If the
extra texture is randomly dispersed, though, 0/45 degree geometry would
measure the difference.  So as Duane mentions the equipment we use
accommodates both potential phenomena.
At any rate, when I compare matte vs "photo" semi-matte prints in very
diffuse lighting the PK prints look considerably darker - consistent with
measurements.  I still think that's simply because those photon adsorbing
(carbon) molecules are simply less dispersed and can soak things up more.
To get a better matte ink you need either (a) much smaller photon absorbing
molecules such that their density once dispersed in paper is still high or
(b) a coating that doesn't disperse those molecules as much.  People are no
doubt working on both and the ideal would be to coordinate both at the same
time...
> From: dlruckus <dlruckus@...>
> sensor position.
2005-11-13 by dannysoar
I don't understand about 85% of what is said on this board. But I remember from
engineering skool, that the way scientist and engineers used to achieve almost
perfect blacks was thusly. They'd make a block of needles or razor blades on end
  and shine the light at the points. The light would bounce around heading down
and getting absorbed at every bounce. I think black velvet works the same way.
Could a coating be designed to sort of do this? Could a way be found to print on
black velvet? Perhaps by spraying a white pigment on all but the Zone 0 black.
David
> changes things too.
> John
> John
> same page.
> keep them short.
> and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
> \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> SPONSORED LINKS
> Digital wedding photography
> <http://groups.yahoo.com/gads?t=ms&k=Digital+wedding+photography&w1=Digital+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photography+course&c=6&s=188&.sig=Umur-3rsLOic7dZMwVL94w>
> 	Learn digital photography
> <http://groups.yahoo.com/gads?t=ms&k=Learn+digital+photography&w1=Digital+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photography+course&c=6&s=188&.sig=emApqtvj0kHQhppIzRrNgw>
> 	Digital photography college
> <http://groups.yahoo.com/gads?t=ms&k=Digital+photography+college&w1=Digital+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photography+course&c=6&s=188&.sig=aIiABJLTZsUnmWBs4mZwuA>
> Digital photography
> <http://groups.yahoo.com/gads?t=ms&k=Digital+photography&w1=Digital+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photography+course&c=6&s=188&.sig=pJmwqgVzec3JGBtWYlPbOg>
> 	Digital photography web site
> <http://groups.yahoo.com/gads?t=ms&k=Digital+photography+web+site&w1=Digital+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photography+course&c=6&s=188&.sig=BMII8rtDZlAtVdZsPhaZqw>
> 	Digital photography course
> <http://groups.yahoo.com/gads?t=ms&k=Digital+photography+course&w1=Digital+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photography+course&c=6&s=188&.sig=OrnrutXVhHZu-7E7ccLtuw>
> YAHOO! GROUPS LINKS
>     *  Visit your group "DigitalBlackandWhiteThePrint
>       <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint>" on
>       the web.
>     *  To unsubscribe from this group, send an email to:
>       <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "wwodets" <odets@c...> wrote:
> too.
Makes some sense of course. Anything that widens the scale from paper white to ink black
would help. On the other hand, sometimes some paper/ink just seem to have less life than
others for reasons hard to quantify.
I had no idea they dropped White Velvet, recently bought a bunch. Jimmy Doyle could tell
us more, it's still on his site.
I do use mostly H papers, but am moving toward some of the Innova paers as well. I'm
trying to drop PhotoRag entirely in favor of Innova PhotoSmooth. They are nearly
indistinguishable, with Innova perhpas a bit less flakey, and perhaps less pricey
stranglehold on the market. I'll test this new Crane also.
Personally I don't like these smooth papers, but clients do, so I must carry them.
Without White Velvet I would begin testing the VFA again, they have certain similarities,
and you and others are reporting good results.
But how it does with Piezotones is my concern. Before White Velvet we had nothing bright
white with a pretty tooth, so it's a good option.
Tyler
> any papers shadow rendition when exhibited in the real world. It is
> unsettling, but true.
Most definitely. I think the numbers help lead us, but the final judgement is a visceral
reaction to an object of art. I have a few I love here on uncoated papers with "bad"
numbers.
> changes things too.
Yup, some of these differences disappear.
Darn, but I was not optimistic. I think we are up against the wall with ink and coating
technology. Until something significantly different comes along, we're all in the same
neighborhood with small differences.
Then again, where we are is certainly making for some lovely prints.
Tyler
2005-11-14 by dlruckus
I wouldn't be a bit surprised if the effect you are referring to
couldn't partly explain some of the d'max loss that occurs with ink
flooding on some papers ie: finding black lighter than darkest gray.
Maybe it just got all the holes between the needles filled in. :)
Duane
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, dannysoar
remember from
achieve almost
blades on end
heading down
same way.
to print on
Zone 0 black.
> David
2005-11-14 by wwodets
John-
Since I started this round of this perpetual ruckus, let me say that
how a print *looks* is certainly the only criterion.  To the extent
that measurements help us find the things that actually look better,
they are useful.  In my experience, the one standout among these
matte papers is VFA with K3 inks, in terms of how people actually see
it.  The most inexperienced viewer perceives that the blacks are
deeper than anything else I've put next to it.  The qualities of VFA
have also been apparent in the numbers, so the numbers here have been
useful to me.
Whether such comparative evaluations are the way to go is another
question.
Walt
monochrome,
although I
articulate
more
> changes things too.
I
of
> John
bright
> John
than
begin to
sheen of
know,
2005-11-14 by Carl Schofield
Walt,
I agree with your assessment of VFA.  Highest dmax of all the matte
papers and best looking prints with the k3 inks.
Carl
On Nov 13, 2005, at 9:13 PM, wwodets wrote:
> John-
> useful to me.
> question.
> Walt
> monochrome,
> although I
> articulate
> more
>> changes things too.
> I
> of
>> John
> bright
>> John
> than
> begin to
> sheen of
> know,
2005-11-14 by Clayton Jones
Hello Tyler,
>...sometimes some paper/ink just seem to have less life than
How true.  Eboni BO on PR just sings.  With K3 I'm having a harder
time finding a setting that I really like.  I'm close, but nothing yet
that gives me the same chills up my spine as the former.
>certain similarities, and you and others are reporting good results.
In the same vein as above, with Eboni BO VFA didn't excite me much,
but with K3 it has moved to my A-List.
>I'll test this new Crane also.  Personally I don't like these
>we had nothing bright white with a pretty tooth, so it's a good
>option.
It's worth trying Max, as it has a fine (as in tiny) texture.  And as
Walt has reported, it seems to be extremely scuff and burnish
resistant.  I dug into it with a thumbnail and still couldn't scrape
any ink off.
Clayton
2005-11-14 by Greg
> any ink off.
Similar to German Etching, but maybe slightly more rounded "bumps"
ABW Settings for VFA and other preferred papers.
2005-11-14 by rgoldman2
Very interesting discussion about these art papers.  What your your preferred ABW settings
for VFA (v, h, sh, and hi)?
In general, since the ABW system seems to be very sensitive to small increments and since
we are uncertain i guess about the logic that underlies the chooser (what are we calling the
circle thing?), it would be helpful to those of us considering a new paper to have
suggestions from those of you who are using it.
Thanks
RE: [Digital BW] For Tyler Re: Epson Ultrasmooth Fine Art, VFA, HPR . .
2005-11-14 by Jim Doyle
Well.. Thats a Real good question.. hahnemuhle hasnt confirmed that its been
discontinued yet..But I would guess that they will be making some changes as
they do every year at about this time..
as soon as I get word i'll make sure everyone knows!
Cheers
Jim Doyle
J. Doyle Enterprises LLC
114 Old Orchard Rd
Cherry Hill, NJ 08003
856-424-8660
http://www.shadesofpaper.com
AOL IM: Brokerup99
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Tyler
Boley
  Sent: Sunday, November 13, 2005 6:39 PM
  Subject: [Digital BW] For Tyler Re: Epson Ultrasmooth Fine Art, VFA, HPR .
  > too.
white to ink black
less life than
Doyle could tell
well. I'm
nearly
pricey
carry them.
nothing bright
  Tyler
page.
them short.
the membership.
  YAHOO! GROUPS LINKS
    a..  Visit your group "DigitalBlackandWhiteThePrint" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.13.0/167 - Release Date: 11/11/2005
Re: ABW Settings for VFA and other preferred papers.
Hello,
I use the VFA with all ABW settings neutral.  On the USFA, I have
been using an h-12 v-16 and all other settings neutral.  The "circle
thing" on the USFA gives more or less the tonality of the VFA but
somewhat cooler and might be too cool for some people.  When a single
print or a set of similar prints are viewed (without side by side
comparisons) they tend to set their own whitepoint and look "right."
Lighting, which is highly variable in home, gallery and museum, also
dramatically changes the whitepoint but in a given situation we
adjust to that too.  So, unlike Clayton, I don't really pursue
a "certain look."  I prefer something transparent to the eye and in
wet printing never used toners, etc.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "rgoldman2"
new paper to have
> Thanks
VFA, no large sheets?
2005-11-14 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@c...> wrote:
Hi Clayton, I just read on another list that it's only available up to 13". I'll have to look into
that, it'll put it out of the running right off the bat.
Tyler
Innova Soft Texture - was For Tyler Re: Epson Ultrasmooth Fine Art, VFA, HPR . .
2005-11-14 by Paul Roark
> ...and much more expensive than Innova Soft Texture which I like better.
At first I thought Innova Soft Texture was going to be a good substitute for
the PermaJet Alpha that is no longer available in the U.S.  However, they
are not the same.  Alpha is cotton and prints very smoothly.  The last time
I used the Innova Soft Texture (alpha cellulose -- which I'm generally OK
with), it had blotchy dark tones.  So, I'm not sure if the printer and ink
make a difference, but I stopped using it with the MIS UT inks.
Re: VFA, no large sheets?
Tyler-
I believe this is true--should have mentioned that!
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
have
results.
much,
> Tyler
RE: [Digital BW] Re: ABW Settings for VFA and other preferred papers.
2005-11-14 by Steve Bye
Do you need to profile VFA for K3 inks to get neutral prints? What paper
setting do you use?
Steve
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of wwodets
Sent: Monday, November 14, 2005 7:54 AM
Subject: [Digital BW] Re: ABW Settings for VFA and other preferred papers.
Hello,
Walt
new paper to have
> Thanks
page.
them short.
the membership.
Yahoo! Groups Links
2005-11-14 by john dean
Paul,
That is interesting. I certainly hope that black motteling never
happens with me. I have done a lot of black and white and color work
with the Soft Texture including 40"x60" things with lot of black and I
have never experienced that. I usedd to use German Etching (also alpha
cellulose) for this moderately smooth range of texture and now I use
this. It had better not start screwing up with me.
John
better.
substitute for
they
last time
generally OK
and ink
> Paul
> www.PaulRoark.com
Steve-
If by profiling you mean ICC profiling, this shouldn't affect the
color neutrality of the prints.  Profiling (or curves) as with a RIP
will certainly affect neutrality, but you wouldn't use a RIP with the
ABW (which is essentially a RIP).  I have used the VFA setting in the
ABW driver with VFA.
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve Bye"
paper
> setting do you use?
> Steve
wwodets
papers.
> Hello,
The "circle
single
look "right."
also
> Walt
your
chooser
> new paper to have
> > Thanks
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
Owner and
section:
PRINT
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
2005-11-14 by Greg
> Paul,
Ink limits on the Innova papers are slightly more reserved. It doesn't
seem to handle gross amounts of over inking as well as other papers. If
you limits are in good order, there shouldn't be any problems like that
described. At least that is what I find with my inks.
RE: [Digital BW] Innova Soft Texture - was For Tyler Re: Epson Ultrasmooth Fine Art, VFA, HPR .
Improper ink loading may well have been what caused the mottling I
mentioned.  Since I most often use the Epson drivers, I'm usually restricted
to the media type settings they have.  Usually this is not a problem.
However, it can be.  I forget which printer I had the problem with --
perhaps the C86, which also has no media type setting that works well with
Moab papers.  I do recall my initial impressions of Innova Soft Texture were
positive.  I'll try a couple of other printers to see if the problem is
printer-specific.
Hi Paul,
I think Greg is correct here. I am working on a 24"x36" color print
right now today and the background is 100% black and it is rendering
very smooth and deep black tonality there with the Soft Texture. My
clients love it so far. I have only used this paper with a 9600 and UC
inks with QTR and Epson driver for color and on a 10K for color output.
John
papers. If
that
restricted
well with
Texture were
> printer-specific.
> Paul
> www.PaulRoark.com
