Transitions
Transitions
2006-05-12 by Brian Chapman
In a previous post I mentioned the "stepped" transitions between areas
of light and dark in some of the images I have tried printing.
Here's a link to one of the previous messages:
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/7715
1
Some additional experimenting and learning has led me to believe that
the transitions between dark and light in a general sense were only
part of what I was seeing.  The real issue is between different
densities of dark where the mixes of ink changes.  When I printed out
the step wedges from Paul's site (on EEM using Pauls profile for EEM
and Gamma 2.2 for the printer driver gamma setting) I noticed there
are a couple of "transition" density levels where the different mixes
of ink show up more obviously than others - between 70 & 80% and again
between 80 and 90%.
For 99% of images this isn't an issue but in images where the sky is
very dark and therefore has large areas where those transitions
mentioned above occur it becomes visible - almost like a line across
the page wherever those transitions occur.  (It's much easier to see
the transitions on wide areas where it occurs - I didn't notice it
when I was printing test strips (1"x8") from the center of the image
below.  This result doesn't occur with BO printing because it's all
the same ink.
Here is an example:
http://www.flickr.com/photos/brianechapman/75838437/
Does anyone have any suggestions to reduce the effect?
Sorry for the long post, I just wanted to make sure I gave enough info!
Thanks!!
Brian
http://www.brianchapmanphotography.com
RE: [Digital BW] Transitions
2006-05-13 by Paul Roark
Brian,
I'm not real sure what workflow you're using.  But, it sounds like the
problems could be with the dark ink(s) being injected by the printer before
there is enough of the lighter ink to hide them. If the problem is due to
the dark grays, I'd expect them to show up closer to 60%.  If they were both
being injected at about the same time due to a grayscale workflow, some RGB
curves might be able to separate where in the image the crossover occurs.
Since the problem area is further down, I'd guess it's the black ink being
injected before the dark grey inks can hide it.  If the workflow you're
using includes the driver being set to "Color Controls" I'd consider
switching that to No Color Adjustment.  That allows the midtones to go all
the way up to their maximum ink limit.  The print might be too dark, so a
grayscale curve or using Create ICC to linearize the system might be needed.
This is sort of a guess, but it might be worth a try.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Brian
> Chapman
> Sent: Friday, May 12, 2006 10:17 AM
> Subject: [Digital BW] Transitions
> 1
> between 80 and 90%.
> the same ink.
> Here is an example:
> Thanks!!
> Brian
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See “Group Topic, Rules and Guidelines” in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
> “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
Re: Transitions
2006-05-14 by Brian Chapman
Hey Paul,
Thanks for the info.  The workflow I'm using is:
1.  Open image in 16 bit RGB (Adobe 1998) from the RAW file
2.  Make adjustments including channel mixing for conversion to B&W
3.  Flatten the image
4.  Convert to Greyscale (current profile is DG20 for default)
5.  Print with Preview using printer driver gamma 1.8 and the EEM 2.2
profile (the results are pretty close with or without the profile in
this case).
I have had much better results in the last couple of days assinging
the Gray Gamma 2.2 profile (which displays darker on my monitor) and
then adding an adjustment layer (levels) and increasing brightness to
gamma 1.25 (from 1.00) and then printing using the EEM 2.2 profile and
printer driver gamma 2.2.  The results are much smoother and more how
I expect (want) them to look.
It's somewhat confusing though because 'assigning' the profile doesn't
really do anything except let me look at the image darker on screen -
the real difference in the print is from using the darker printer
gamma (2.2) and the adjustment layer prior to printing...is this
correct?  If it works better this way does it mean that something else
is not configured correctly somewhere else in my workflow?
I don't use any of the color controls - I mean they're "on" but all at
zero.
Again, many thanks!!!
Brian
<paul.roark@...> wrote:
> Brian,
before
due to
were both
some RGB
occurs.
being
go all
so a
needed.
> Paul
> www.PaulRoark.com
Brian
> > Chapman
> > 1
> > between 80 and 90%.
> > the same ink.
> > Here is an example:
info!
> > Thanks!!
> > Brian
resources as
wish to
this same
> > page.
to keep
> > them short.
flames.
digital B&W
removed from
> > the membership.
Owner
> > and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> > section:
PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO
> > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE
BEEN
THE USE
DATA; (iii)
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
RE: [Digital BW] Re: Transitions
2006-05-15 by Paul Roark
Brian,
(Catching up on the e-mails here ...)
With respect to the workflow, I was just looking at the printing.  It sounds
like you're using "Color Controls" set to 0.  It also sounds like when you
print in Gamma 2.2 the problem is less.  That might be consistent with my
thoughts.
The Epson driver when set to "Color Controls" holds back some of the midtone
inks.  I've never tested it, but logically, if those inks are operating
under a lower ink limit, they may not cover the black ink dots as well when
that ink starts.  That's why I suggested you try the "No Color Adjustment"
driver setting.  It'll be too dark, but you can correct that with a
Photoshop curve or an ICC made with Roy's "Create ICC" program.  This latter
route would be what I recommend.  It would have the additional benefit of
making the print match the monitor.
> Chapman
> Sent: Sunday, May 14, 2006 11:16 AM
> Subject: [Digital BW] Re: Transitions
> Hey Paul,
> this case).
> zero.
> Brian
> > Brian,
> before
> due to
> were both
> some RGB
> occurs.
> being
> go all
> so a
> needed.
> > Paul
> > www.PaulRoark.com
> Brian
> > > Chapman
> > > 1
> > > between 80 and 90%.
> > > the same ink.
> > > Here is an example:
> info!
> > > Thanks!!
> > > Brian
> resources as
> wish to
> this same
> > > page.
> to keep
> > > them short.
> flames.
> digital B&W
> removed from
> > > the membership.
> Owner
> > > section:
> PRINT
> LIABLE TO
> BEEN
> THE USE
> DATA; (iii)
> > > PRINT YAHOO GROUP.
> > > Yahoo! Groups Links
> page.
> them short.
> the membership.
> section:
> PRINT YAHOO GROUP.
Re: Transitions
2006-05-18 by Brian Chapman
Paul,
I *finally* got around to trying your suggestion!  The result (with
no adjustment curve or icc) seemed like it was ok, but when I tried
to create curve to correct for the darker print it really looked bad
(very harsh transitions).  Obviously it wasn't as simple as I had
hoped :)  So I think I'm going to stop worrying about it until I get
the QTR program and have more control of what's happening!
One other thing...I've heard the term 'linearize' a lot recently but
I can't figure out what it means in the context of printing...can
anyone explain?  Is it basically creating a calibrated workflow all
the way through?
Brian
> Brian,
It sounds
when you
with my
> thoughts.
the midtone
operating
well when
Adjustment"
This latter
benefit of
> Paul
> www.PaulRoark.com
Of Brian
> > Chapman
> > Hey Paul,
B&W
EEM 2.2
profile in
> > this case).
assinging
and
brightness to
profile and
more how
doesn't
screen -
something else
all at
> > zero.
> > Brian
> > <paul.roark@> wrote:
> > > Brian,
like the
printer
> > before
problem is
> > due to
they
> > were both
workflow,
> > some RGB
crossover
> > occurs.
black ink
> > being
workflow you're
consider
midtones to
> > go all
dark,
> > so a
might be
> > needed.
> > > Paul
> > > www.PaulRoark.com
Behalf Of
> > Brian
> > > > Chapman
between areas
printing.
15
> > > > 1
believe that
were only
different
printed out
for EEM
noticed there
different mixes
and again
> > > > between 80 and 90%.
the sky is
transitions
line across
easier to see
notice it
the image
it's all
> > > > the same ink.
> > > > Here is an example:
enough
> > info!
> > > > Thanks!!
> > > > Brian
> > resources as
you
> > wish to
visiting
> > this same
> > > > page.
messages
> > to keep
> > > > them short.
or
> > flames.
from the
> > digital B&W
> > removed from
> > > > the membership.
rules and
group
> > Owner
the Files
> > > > section:
BW, THE
> > PRINT
THE "OWNER" AND
BE
> > LIABLE TO
CONSEQUENTIAL OR
LOSS OF
(EVEN IF THE
GROUP HAVE
> > BEEN
(i)
> > THE USE
GROUP; (ii)
> > DATA; (iii)
THE PRINT
DIGITAL BW, THE
> > > > PRINT YAHOO GROUP.
> > > > Yahoo! Groups Links
resources as
wish to
this same
> > page.
messages to keep
> > them short.
flames.
digital B&W
removed from
> > the membership.
and
group Owner
Files
> > section:
THE PRINT
AND
LIABLE TO
OR
LOSS OF
THE
HAVE BEEN
THE USE
(ii)
DATA; (iii)
PRINT
BW, THE
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
2006-05-19 by Paul Roark
The way it is used here refers to getting the printer to output a grayscale
that is visually even and smooth.  That is, if a 21-step test file is
printed, the steps should be visually even -- or, more accurately, coincide
with some pre-determined, standard distribution of values.  In fact, the
curve or grayscale "ramp" is not "linear" because our eyes don't react that
way to light.  So, in reality "linearization" means getting the printer to
produce an output that matches whatever standard we've selected.  I
currently favor the Gray Gamma 2.2 space and grayscale ramp.  However, the
95% to 100% step is way less separated visually than the 50% to 55% step,
but since my monitor displays this same distribution, it works well.
