Article on Digital Printing and Walker Evans
2006-08-25 by Doug Fisher
I thought others here in the digital black and white printing group might
find this NYT article on digitally printing Walker Evans' images to be
rather interesting (you may have to reconstruct the long link):
http://www.nytimes.com/2006/08/25/arts/design/25evan.html?_r=1&oref=login&pa
gewanted=all
Doug
BetterScanning.com - Innovative Accessories for Better Film Scanning
http://www.BetterScanning.com/
Re: [Digital BW] Article on Digital Printing and Walker Evans
2006-08-25 by Mark Savoia
That looks like a good one to see. Any guesses on printer, RIP,
paper, and inks that were used?
Mark
> might
> _r=1&oref=login&pa
> gewanted=all
> Doug
UT-2 vs. UT-FS / FSN
2006-08-25 by Craig Roberts
I've been using MIS UT-2 inksets with Paul's workflows and curves in my
Epson 1280 and am very pleased with the results.  I was wondering,
however, if  -- flexibility of tone aside -- what the difference between
a UT-2 and an UT-FS or FSN inkset is.  Are the resulting prints the same
with regard to range and longevity?
Craig
Washington, DC
RE: [Digital BW] UT-2 vs. UT-FS / FSN
2006-08-25 by Paul Roark
The FS inksets (now called UT-FS) are monotone inksets that were made as
clones of the PiezoBW inksets such that they could be used with that driver,
which I once used.  The light inks (M & Y positions) are not Epson standard
densities, and particularly the M position ink is an odd-ball density that I
don't think makes sense with modern printers.  (The Y position ink still is
useful in the 3000 and 7000 class of printers.)  The UT-FS inksets use the
same basic pigments as the UT2 (aside from the UT2 sepia, which includes
some yellow, which is a relative weakling), and would, thus, be about as
archival as the UT2 inkset when all but the sepia curves are used.  There is
no FS-Carbon, however.  The warmest the FS inkset can go is medium warm.
The FS has 50% of the cool pigments in it as the FSN.
I at one point made monotone curves so that the FS inksets could be used on
many hextone printers.  It was an early attempt at an easy-to-use inkset.  I
would not do that now with the 1280.
I do not have a 1280, but I would seriously consider the UT-R2 inkset for it
if you don't need sepia.  The UT-R2 is intended as the "EZ" inkset for all
hextone and above Epson printers.  For most people a monotone inkset that
can be used with either the Epson sliders or the Epson driver with a simple
monotone curve or ICC made with Roy's "Create ICC" program makes the easiest
to live with system.  The use of all of the inks (as opposed to the sepia
(Y) ink being shut off) also will produce a better print on many printers.
I don't know what MIS sales look like, but if I were running that company
I'd seriously consider stopping selling all UT-FS inksets except bulk Y
position for the older printers.  (Perhaps special order pints or more of
the others.)  The R2 in bulk can do almost everything.  A 1280 with
spongeless cart and R2 inks might be an interesting affordable 13" solution.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Craig
Roberts
Sent: Friday, August 25, 2006 9:38 AM
Subject: [Digital BW] UT-2 vs. UT-FS / FSN
Craig
Washington, DC
Re: [Digital BW] UT-2 vs. UT-FS / FSN
2006-08-25 by Michael Kitei
What a disappointment. When I saw the FSN UT set I assumed that it
was the solution to a totally neutral grey. Then when I saw that you
had created a downloadable curve for it I figured you supported it,
so I bought two sets. I guess there's a lesson there.
Mike
> made as
> that driver,
> standard
> density that I
> still is
> use the
> includes
> about as
> There is
> warm.
> used on
> inkset. I
> inkset for it
> for all
> that
> a simple
> the easiest
> sepia
> printers.
> company
> bulk Y
> more of
> solution.
> Paul
> _____
> Craig
> Roberts
> in my
> between
> same
> Thanks,
> Craig
> Washington, DC
The FS curves are still there.  I just would do something different today.
You'll be able to make fine prints with it.  However, I suspect the number
of old Piezo software users and users of printers that need the light inks
is shrinking substantially.
One problem I've had with the early inksets is that all that light ink
overloads the glossy papers.  In fact, I just had to re-do my 7500 FSN+
profile for Premier Art 205 because it was overloading that paper, which I
happen to like.  The UT2 also came out of the experience with the UT1
overloading papers.  Too much light ink is a problem for many papers.
On my web page, the newer inksets tend to be those on the top of the index.
Given the progress that is being made in this technology, I'd tend to favor
the new over the old.  I don't know how the FS even with PK will do on Crane
Silver Rag, but I, personally, would definitely want an inkset that does
well on that paper.
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Michael
> Kitei
> Sent: Friday, August 25, 2006 10:50 AM
> Subject: Re: [Digital BW] UT-2 vs. UT-FS / FSN
> Mike
> > made as
> > that driver,
> > standard
> > density that I
> > still is
> > use the
> > includes
> > about as
> > There is
> > warm.
> > used on
> > inkset. I
> > inkset for it
> > for all
> > that
> > a simple
> > the easiest
> > sepia
> > printers.
> > company
> > bulk Y
> > more of
> > solution.
> > Paul
> > _____
> > Craig
> > Roberts
> > in my
> > between
> > same
> > Thanks,
> > Craig
> > Washington, DC
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the
> membership without notice.
> printing. Users who persistently make off-topic posts may be removed from
> the membership.
> guidelines, and to abide by the actions and decisions of the group Owner
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
> OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
> UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
> YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
2006-08-25 by Howard Shaw
I'm using UT-FS & UT-FSN sets in both my 2200 and R220 controlled by
qtr. I find that UT-FS is as warm as I want to go and FSN as neutral. In
a post a few months ago Paul described a recipe for darkening the M
position inks and the sets are now nicely distributed similar to UT7
which I used previously. This means it's easy to swap inks in and out
with for example the UT7 sepia or carbon LC if you want to go warmer.
They also work well on the new generation of fibre glossy papers.
I hope MIS do not phase them out.
Howard
> Paul
>   _____
> Roberts
> Thanks,
> Craig
> Washington, DC
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
2006-08-26 by gilbert Draper
Gil
> printer, RIP,
> Mark
> > might
> Evans' images to be
> the long link):
> > _r=1&oref=login&pa
> > gewanted=all
> > Doug
2006-08-26 by Bob Michaels
Mike: I can assure you the FSN inkset in a 1280 is very good. Yes,
there are better now but there's nothing wrong with what you have. Use
it and enjoy your prints.
Bob Michaels
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Michael Kitei
> Mike
2006-08-26 by Michael Kitei
Thanks to all for the reassurance. I have gotten some very nice
prints off using Photo Black and Innova Fiba Gloss.
Mike
> Bob Michaels
> > Mike
2006-08-26 by dlruckus
Hello Paul.
I would hope support for the old 3000 wasn't dumped. It is too much of
a reliable workhorse for 16x20s to give up. Likewise the old 7000/7500
machines are now working their way down to non power users who for
various reasons cannot justify new large machines. It would be a shame
to narrow the playing field IMO.
As the topic is the UTFS&N inks, I have a question in relation to the
Photo Black inks for these sets. Are the UTFS PK and the UTFSN PK  the
same ink or do they have differences?
Duane
today.
number
light inks
which I
index.
to favor
on Crane
> well on that paper.
> Paul
> www.PaulRoark.com
Michael
> > Kitei
> > Mike
> > > made as
> > > that driver,
> > > standard
> > > density that I
> > > still is
> > > use the
> > > includes
> > > about as
> > > There is
> > > warm.
> > > used on
> > > inkset. I
> > > inkset for it
> > > for all
> > > that
> > > a simple
> > > the easiest
> > > sepia
> > > printers.
> > > company
> > > bulk Y
> > > more of
> > > solution.
> > > Paul
> > > _____
> > > Craig
> > > Roberts
> > > in my
> > > between
> > > same
> > > Thanks,
> > > Craig
> > > Washington, DC
resources as
wish to
this same
> > page.
to keep
> > them short.
flames.
digital B&W
removed from
> > the membership.
Owner
> > section:
PRINT
LIABLE TO
BEEN
THE USE
DATA; (iii)
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
