Magenta cast on UTFSN prints...
2006-08-27 by Andre Vallejo da Silva
SO I came back printing BW with UT-FSN inks on an Epson 1160. Using photo black in both Matte and Ilford Smooth Pearl, with eather QuadToneRip set to 1160-UT ou QImage, I get this annoying magenta cast... Image were set to grayscale in QImage and gs and rgb in QTR... How can it be? Any ideas on how to go back to neutral prints???
2006-08-27 by Paul Roark
If the printer had been sitting idle for a while, there could have been some separation. Normal printing will agitate the ink in the cart reservoirs (if easy-refill types), but some may need to be purged from the carts. If the ink is a new batch, well. you understand one reason for the UT-3D inkset and the new QC procedures MIS is trying to implement. Paul www.PaulRoark.com <http://www.paulroark.com/> _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Andre Vallejo da Silva Sent: Sunday, August 27, 2006 7:29 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Magenta cast on UTFSN prints... SO I came back printing BW with UT-FSN inks on an Epson 1160. Using photo black in both Matte and Ilford Smooth Pearl, with eather QuadToneRip set to 1160-UT ou QImage, I get this annoying magenta cast... Image were set to grayscale in QImage and gs and rgb in QTR... How can it be? Any ideas on how to go back to neutral prints??? [Non-text portions of this message have been removed]
Humm,I see...Does it mean that it's a known problem of this inkset? Pity, 'cose I still have half a set of bottles in use and a whole new one waiting...it will take some time till it runs out and I have to buy new ones... Do you think it could be nanaged by decreasing the magenta position somehow in your curves for the EAM for example? Thakns, André --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > If the printer had been sitting idle for a while, there could have been some > separation. Normal printing will agitate the ink in the cart reservoirs (if
> easy-refill types), but some may need to be purged from the carts. > > > > If the ink is a new batch, well. you understand one reason for the UT-3D > inkset and the new QC procedures MIS is trying to implement. > > > > Paul > > www.PaulRoark.com <http://www.paulroark.com/> > >
> Humm,I see...Does it mean that it's a known problem of this inkset? No, it means I think there is a lot of room for improvement with the entire inkjet industry. Then again, color photo materials used to also require that every batch be re-profiled, and of course, every film and paper had it's own characteristics. So, between ink variances and paper differences, it's difficult to get and keep the exact look one prefers. If a blended monotone or even variable-tone ink is too magenta or too green for a certain paper, there is little one can do about it. The 3D approach was, in part, to allow one to adjust for these differences. It's odd that the inkset at issue here is the UT-FSN. It actually has the least magenta mix of the toned grays. (The issue is actually the ratio between the cyan and R800 blue -- looks like grape juice -- that is used to cool down the carbon.) The glossy paper you're using may be the source of the magenta look. The older glossy papers were the worse that way. If you try a Kirkland glossy for drafts and a Crane Silver Rag for the final print, I'd guess the look would be quite different. One of the reasons the amount of "magenta" in the toned inks differ is that I mix them to a specific set of papers. That set of papers changes with time. Crane Silver Rag did not exist when the UT-FSN formula was made. On the other hand, the older glossy papers were becoming good enough to use. Now, however, I think it is critical that an inkset print well on CSR, and I recommend people move away from the older, acidic glossy paper technologies. Paul www.PaulRoark.com
2006-08-27 by Shilesh Jani
Paul, When UT-FSN was first released, I wanted to switch away from the original FSN I was using. With much trepidation, I made the switch to get better lightfast inkset. Alas, I found excatly the same thing; UT- FSN was definitely magenta heavy. The regular FSN was better at the cool end of neutral. I spoke to Bob at MIS, and he was adamant that UT-FSN and FSN should have similar color. I just gave up at that point. I think 3rd party solutions have become better in the 5 years I have been at it. But, it is still a crap-shoot. So my standard advice to newcomers is to get the Epson 2400. Personally, I like the ability to have greater control than ABW provides, so I mix my own inksets from the K3 and the R1800 inks. It is much more control than MIS seems capable of. The all-carbon (warm) inks from 3rd party sources are a better bet than the toned inks. Shilesh --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > > Humm,I see...Does it mean that it's a known problem of this inkset? > > No, it means I think there is a lot of room for improvement with the entire > inkjet industry. Then again, color photo materials used to also require > that every batch be re-profiled, and of course, every film and paper had > it's own characteristics. > > So, between ink variances and paper differences, it's difficult to get and > keep the exact look one prefers. > > If a blended monotone or even variable-tone ink is too magenta or too green > for a certain paper, there is little one can do about it. The 3D approach > was, in part, to allow one to adjust for these differences. > > It's odd that the inkset at issue here is the UT-FSN. It actually has the > least magenta mix of the toned grays. (The issue is actually the ratio > between the cyan and R800 blue -- looks like grape juice -- that is used to > cool down the carbon.) The glossy paper you're using may be the source of > the magenta look. The older glossy papers were the worse that way. If you > try a Kirkland glossy for drafts and a Crane Silver Rag for the final print, > I'd guess the look would be quite different. > > One of the reasons the amount of "magenta" in the toned inks differ is that > I mix them to a specific set of papers. That set of papers changes with > time. Crane Silver Rag did not exist when the UT-FSN formula was made. On > the other hand, the older glossy papers were becoming good enough to use. > Now, however, I think it is critical that an inkset print well on CSR, and I > recommend people move away from the older, acidic glossy paper technologies.
> > > Paul > www.PaulRoark.com >
2006-08-28 by Daniel Staver
I have the same experience with the FSN inks I bought for my 3000 printer. The C is greenish, the M is purplish and has almost the same density as Y, and Y is also too purplish, but much closer to neutral than M. Basically the inkset as I received it is useless. I've told MIS about it, and I'm returning them samples of the inks now so they can do some testing. I have to agree with you, pure carbon inks seems like a better idea at this point. -- Daniel Staver http://daniel.staver.no
> When UT-FSN was first released, I wanted to switch away from > the original FSN I was using. With much trepidation, I made > the switch to get better lightfast inkset. Alas, I found > excatly the same thing; UT- FSN was definitely magenta heavy. > The regular FSN was better at the cool end of neutral. I > spoke to Bob at MIS, and he was adamant that UT-FSN and FSN > should have similar color. I just gave up at that point.
2006-08-28 by Paul Roark
>I have the same experience with the FSN inks I bought for my 3000 printer. >The C is greenish, the M is purplish and has almost the same density as Y, >and Y is also too purplish, but much closer to neutral than M. UT-FSN-C uses more cyan to blue than do the M and Y. This was intentional due to the exaggerated response many papers have in the deep shadows. This was mostly the older glossy papers. The R2 neutral C and M use a more "normal" ratio. I've abandoned the FSN-C in favor of the R2. My FSN-Y, by the way, is greenish on the papers I use, so I use R2 Neutral light diluted 1:1. (The my 7500 I then mix this with 25% warm UT-FS-Y to get the hue I want.) I use 2 spectros to measure these things, because these spectros also don't read the same. It's real hard to control things as accurately as we'd like to in B&W. There is simply no way I am aware of with current technology to make a neutral ink that will have the same Lab A on all papers. In general, I want a positive Lab A in a "neutral" print. But, I, too, have seen batches of inks that are way more magenta than the original targets. (Using the CMY density readings, the target for "neutral" was C=Y, and M=C+0.01. This was taken from my lightly selenium tones silver prints -- Kodak Polymax Fine Art developed in Dektol.) The closeness of the M to Y is the old PiezoBW formula. The standard mid-tone dilution for adjacent inks is 0.3. But FS/Piezo Y=0.5 M, and up at that dilution the curve is starting to get rather non-linear. So, the M and Y are just not that different. The original UT-Y (lightest carbon) was half way between the Y and M. I've abandoned the old FS-M density for my 7500, which is the only printer I have now that needs a super-light ink. The middle densities are now the R2 N Light and UT7 LC (or UT2 LM). This is a standard density that is half way between C and Y. My frustration with the fixed-tone inks obviously goes way back. The variable tone inks give one axis control, but that is obviously not adequate to take care of the Lab A being at a place you don't want it. The UT-3D is my hope to get full Lab control in the neutral range. We'll see. My frustration with the fact that few of the inks actually reflect the original design targets is also becoming obvious with my postings on the issue on this forum. Needless to say, sellers don't like to see any dirty laundry being aired in public. Again, we'll see if it gets results or backfires. > pure carbon inks seems like a better idea at this point. You'll notice the 2400 experiment I posted. MIS pure carbon and Epson color -- not blended -- may be the way I'll be with large format. I have an experiment going now to see if I can stop the large format separation problem. We'll see. However, the flip side of all this is that I'm also getting almost perfect C88 prints with the simple MIS EZ inks. The MIS inks are just un-beatable bargains for lots of people. The C88 Crane SR prints I'm getting with High Speed checked are only matched by the 2400 at RPM. No other printer and ink combo I've see can match these two under a loupe. I'm not even sure a silver print can match this output. And the C88 and MIS EZ inks are dirt cheap. Paul www.PaulRoark.com
2006-08-28 by Andre Vallejo da Silva
Thanks a lot.I'll save this for further reference... André --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > > Humm,I see...Does it mean that it's a known problem of this inkset? > > No, it means I think there is a lot of room for improvement with the entire > inkjet industry. Then again, color photo materials used to also require > that every batch be re-profiled, and of course, every film and paper had > it's own characteristics. > > So, between ink variances and paper differences, it's difficult to get and > keep the exact look one prefers. > > If a blended monotone or even variable-tone ink is too magenta or too green > for a certain paper, there is little one can do about it. The 3D approach > was, in part, to allow one to adjust for these differences. > > It's odd that the inkset at issue here is the UT-FSN. It actually has the > least magenta mix of the toned grays. (The issue is actually the ratio > between the cyan and R800 blue -- looks like grape juice -- that is used to > cool down the carbon.) The glossy paper you're using may be the source of > the magenta look. The older glossy papers were the worse that way. If you > try a Kirkland glossy for drafts and a Crane Silver Rag for the final print, > I'd guess the look would be quite different. > > One of the reasons the amount of "magenta" in the toned inks differ is that > I mix them to a specific set of papers. That set of papers changes with > time. Crane Silver Rag did not exist when the UT-FSN formula was made. On > the other hand, the older glossy papers were becoming good enough to use. > Now, however, I think it is critical that an inkset print well on CSR, and I > recommend people move away from the older, acidic glossy paper technologies.
2006-08-29 by Paul Roark
Some have wondered why the "neutral" inksets tend to have dark inks that have a less magenta or more greenish (which I try to avoid) bias than the lighter inks. My response has been that most papers tend to print more magenta in the shadows. This can be seen in the tones of the C88, which has only one midtone ink density and tone. See graph #4 in this PDF regarding that inkset: http://home1.gte.net/res09aij/C88_EZ_CSR_SPECTRO.pdf When the inkset is profiled to give an equal Lab B through the midtones, Lab A rises as the densities increase, even though there are no cross-overs to a different toned ink in the midtones. Whether this is good or bad may be subjective, but if one wants the Lab A & B curves to both be flat, the ratio of cyan to R800 blue (or magenta) in the toned (blended) ink must increase with increasing density. Paul www.PaulRoark.com
2006-08-30 by Michael Kitei
For what it's worth, I'm using the utfsn with innova fiba gloss and so far have not detected any color cast. It does appear to print neutral. A little light, but I'm attributing that to the curve I'm using which is not specifically for this paper. Mike On Aug 29, 2006, at 12:25 PM, Paul Roark wrote: > > > Some have wondered why the "neutral" inksets tend to have dark inks > that > have a less magenta or more greenish (which I try to avoid) bias > than the > lighter inks. My response has been that most papers tend to print more > magenta in the shadows. This can be seen in the tones of the C88, > which has > only one midtone ink density and tone. See graph #4 in this PDF > regarding > that inkset: http://home1.gte.net/res09aij/C88_EZ_CSR_SPECTRO.pdf > > When the inkset is profiled to give an equal Lab B through the > midtones, Lab > A rises as the densities increase, even though there are no cross- > overs to a > different toned ink in the midtones. Whether this is good or bad > may be > subjective, but if one wants the Lab A & B curves to both be flat, > the ratio > of cyan to R800 blue (or magenta) in the toned (blended) ink must > increase > with increasing density. > > Paul > www.PaulRoark.com > > > [Non-text portions of this message have been removed]
2006-08-30 by John Custodio
I also have found the MIS FSN inks now to be useless. From my post of June 3, 2006: Epson 4000, FSN C, M, Y on the left side, FS C, M, Y on the right side (in the LC, LM, LK positions), Eboni Black. Using QTR. Hahnemuehle Photo Rag 308. QTR ink separation page printed at 100%. Eye One spectro. 100% densities read: Eboni 1.71 FSN-C 1.24 Lab a=-0.5 b=-0.2 FSN-M .53 Lab a=0.3 b=-6.7 FSN-Y .36 Lab a=0.2 b=-4.4 FS-C 1.31 FS-M .49 FS-Y .36 I've used FSN and FS on this machine before with no problem. What seems wrong is: The FSN-M and Y seem too blue (note high negative b numbers) while the FSN-C is close to neutral. The dark grays for both FSN and FS should be darker (density around 1.5?). Also for both FSN and FS it seems there should be more of a density difference between the light grays and middle grays (M and Y). ----- I contacted MIS after having sent them samples of the ink. They told me everything was normal. My main concern here was the visible (and measured) blueness of the M and Y inks in the FSN. -John --- Daniel Staver <daniel@...> wrote: > I have the same experience with the FSN inks I > bought for my 3000 printer. > The C is greenish, the M is purplish and has almost > the same density as Y, > and Y is also too purplish, but much closer to > neutral than M. Basically the > inkset as I received it is useless. I've told MIS > about it, and I'm > returning them samples of the inks now so they can > do some testing. > > I have to agree with you, pure carbon inks seems > like a better idea at this > point. > > -- > Daniel Staver > http://daniel.staver.no > > > > When UT-FSN was first released, I wanted to switch > away from > > the original FSN I was using. With much > trepidation, I made > > the switch to get better lightfast inkset. Alas, I > found > > excatly the same thing; UT- FSN was definitely > magenta heavy. > > The regular FSN was better at the cool end of > neutral. I > > spoke to Bob at MIS, and he was adamant that > UT-FSN and FSN > > should have similar color. I just gave up at that > point. > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
2006-08-30 by Paul Roark
>... Hahnemuehle Photo Rag 308. >QTR ink separation page printed at 100%. >Eye One spectro. >100% densities read: >Eboni 1.71 >FSN-C 1.24 Lab a=-0.5 b=-0.2 >FSN-M .53 Lab a=0.3 b=-6.7 >FSN-Y .36 Lab a=0.2 b=-4.4 >FS-C 1.31 >FS-M .49 >FS-Y .36 >I've used FSN and FS on this machine before with no >problem. What seems wrong is: >The FSN-M and Y seem too blue (note high negative b >numbers) while the FSN-C is close to neutral. >The dark grays for both FSN and FS should be darker >(density around 1.5?). Also for both FSN and FS it >seems there should be more of a density difference >between the light grays and middle grays (M and Y). The blueness is probably the same issue that is plaguing the 3D inkset. I just received a new beta batch today for testing. The main problem I found is that the LK from the supplier is too light. MIS has been relying on the supplier for a standard LK. The light inks are the most affected because they use only the LK as the carbon input. The C and M are affected to a lesser extent because they also use PK. To get the too-light LK up to snuff, PK has to be added to it. Needless to say, doing this for every batch is time consuming. I don't know how far back the problem goes. It's possible I'll be able to come up with a correction procedure for existing inks, but no guarantees there. I'm not sure they have the information to know how far off the various back batches were. The closeness of the M and Y harks back to the Piezo days. All inksets I've been involved with since the UT2 have corrected this. If the FS-C has too low a Lab A for you, use the R2-N C or M (the same ink). That is what I now use in my 7500 instead of the FSN-C. MIS is in the middle on this one. The too-light LK is from the supplier. MIS is now going to have to QC every input and take corrective steps. I'm not sure how they can to that and not raise prices, but they say they will try. Paul www.PaulRoark.com
Thanks, Paul, for that information. -John --- Paul Roark <paul.roark@...> wrote: > >... Hahnemuehle Photo Rag 308. > > >QTR ink separation page printed at 100%. > >Eye One spectro. > >100% densities read: > > >Eboni 1.71 > >FSN-C 1.24 Lab a=-0.5 b=-0.2 > >FSN-M .53 Lab a=0.3 b=-6.7 > >FSN-Y .36 Lab a=0.2 b=-4.4 > >FS-C 1.31 > >FS-M .49 > >FS-Y .36 > > >I've used FSN and FS on this machine before with no > >problem. What seems wrong is: > > >The FSN-M and Y seem too blue (note high negative b > >numbers) while the FSN-C is close to neutral. > > >The dark grays for both FSN and FS should be darker > >(density around 1.5?). Also for both FSN and FS it > >seems there should be more of a density difference > >between the light grays and middle grays (M and Y). > > The blueness is probably the same issue that is > plaguing the 3D inkset. I > just received a new beta batch today for testing. > > The main problem I found is that the LK from the > supplier is too light. MIS > has been relying on the supplier for a standard LK. > The light inks are the > most affected because they use only the LK as the > carbon input. The C and M > are affected to a lesser extent because they also > use PK. To get the > too-light LK up to snuff, PK has to be added to it. > Needless to say, doing > this for every batch is time consuming. I don't > know how far back the > problem goes. It's possible I'll be able to come up > with a correction > procedure for existing inks, but no guarantees > there. I'm not sure they > have the information to know how far off the various > back batches were. > > The closeness of the M and Y harks back to the Piezo > days. All inksets I've > been involved with since the UT2 have corrected > this. > > If the FS-C has too low a Lab A for you, use the > R2-N C or M (the same ink). > That is what I now use in my 7500 instead of the > FSN-C. > > MIS is in the middle on this one. The too-light LK > is from the supplier. > MIS is now going to have to QC every input and take > corrective steps. I'm > not sure how they can to that and not raise prices, > but they say they will > try. > > Paul > www.PaulRoark.com > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
