Hands-on impressions K3/ABW versus K7/QTR
2006-10-19 by wwodets
I have spent the last 12 months doing a lot of printing on a 4800
with the Epson K3 inks and the ABW driver – about 600, mostly Super
A3, prints.  I have used some Velvet Fine Art for its excellent dmax
(routinely in the 1.75 density range), but mostly Epson Ultrasmooth
Fine Art for its superb consistency and quality, lack of OBA's and
smooth surface (with a dmax around 1.69).  Having been a black and
white printer for almost 40 years, I found the results with this
setup excellent.
A few months ago I began to think about Cone's K7 inks and finally
decided to try them with either Studioprint or QTR.  I was persuaded
by one of our luminaries on the board to go with QTR and that's what
I did.   My motivation to try the K7 system was influenced by the
excellent visual reports of experienced printers; by the possibly
greater stability (permanence) of the K7s; and because of my
discomfort with the *idea* of color dots in the highlights with K3
(visible only at 7X or more magnification in my experience).  All
more-or-less in that order.  The K7 is also slightly cheaper than the
Epson inks, but not much ($600 vs. $655 for a full set of 220ml
carts, the Epson inks purchased from IT Supplies).
I have used QTR Create ICC profiles with both setups, and here are my
impressions to date.
1. The changeover of inks was relatively easy and the Cone people
were extraordinarily responsive on the few issues I need clarified.
2. The Cone profiles for QTR are excellent, obviously very carefully
done.  In measuring targets for ICC profiles, they are ruler straight
(very linear) and almost obviate the need for ICC profiling.
3. The provided profiles cover a decent range of papers, but not the
two I've used with the K3 inks.
4. The dmax of the K7 fall measurably and visibly short of what I'm
used to with the Epson ink/paper combinations.  On HPR, the
K7/Cone/QTR turns in about 1.656 and EEM (which I use only for
proofing) about 1.572.  I find the HPR figure acceptable, but not the
best.
5. The K7's do a have a smooth, "photographic" look that makes the
Epson system look a very, very tiny bit artificial compared to a
silver print.  This is an extremely small difference.
6. The highlights of the K7's seem a bit dull compared to the K3
prints.   I am guessing that this is a product of one of
the "advantages" of the K7: because of the extra ink tones, the
highlights are composed of a more even inking (less dottiness) than
the Epson system.  The K3 highlights allow some paper to show
through, creating a slight split-toning effect because of the
different grays of ink and paper.  At the moment, I visually favor
the Epson look in this regard.   The print is simply livlier and more
nuanced.  The K7/HPR prints seems a little dead in comparison, but
probably more like a silver print.
7. The highlight issue (in #6) is the biggest difference between
visual observation of the two systems.   Otherwise the results are
very, very similar.
8. My impressions are influenced by use of different papers with the
two ink sets.  With the K3 inks, HPR was never one of my favorites.
It seemed mediocre compared to the two Epson papers.  Dmax for the
K3/HPR typically ran about 1.657 (which is virtually identical to
what I get from the K7/HPR) and it displayed no other special
virtues, other than its name, to my eyes.
9. Producing custom profiles for the QTR/K7 setup looks like a lot of
work, particularly because of the number of inks.  For me this
suggests staying with Cone-produced profiles.
So at this point I'm going to stay with and work with the K7's for a
while (the ink changeover wasn't *that* easy).   The K7 prints look
excellent alone or compared to a silver print, but not compared to a
K3 print.
Good wishes,
Walt
Re: Hands-on impressions K3/ABW versus K7/QTR
2006-10-20 by Clayton Jones
Hello Walt,
Thanks for the detailed report.  I have some sample K7 prints someone
sent me awhile back, and your observations are right in line with my
own impressions: beautiful smoothness, but slightly less dmax and
slightly duller highlights.  The K3 prints do have a more "alive"
look, and I agree it's because of the bare paper showing between the
dots.  You know how much I love the BO luminance, and I was very
pleasantly surprised with the K3 look - much better than most full ink
systems I've seen.  I have been convinced for a long time that the
full ink "dotless" systems dulled the highlights.
Also same for HPR - very nice, but lacks the nice "edge" that VFA has.
 I haven't tried the Ultrasmooth, but have heard many good reports.
Have you used QTR with K3?  If so, how do you like it compared to ABW?
Clayton
Re: [Digital BW] Re: Hands-on impressions K3/ABW versus K7/QTR
2006-10-20 by Michael King
Very interesting thread, as I have been thinking about experimenting with
Cones K7. Thanks for sharing Walt.
I am using K3 on Silver Rag and the challange I find with ABW is the amount
of colour it uses.
This can cause a "rainbow effect" under directional lighting. I have found
that Imageprint uses much less colour.
Though it has its own challanges, mainly the tendency to close up the
shadows. Solved that by a combination of lowering the gamma and adjusting
the black point slider.
Mike
On 20/10/06, Clayton Jones <cj@...> wrote:
>   Hello Walt,
> Regards,
> Clayton
2006-10-20 by wwodets
Richard, Clayton and Michael--
Thanks for the input.
At this point I have a few other thoughts and items on the K7
experiment.
1.  Short of doing my own QTR profiles, using the K7 means using a
paper that Cone has provided profiles for.  So I'm going to give a
few of the profiled Innova and Ink Press papers a try and see how
they look.  I don't believe the dmax will improve over what I've seen
on HPR, but perhaps the "livliness" will.
2.  Cone may provide a custom profile service, but is not doing so
right now.  I tried both VFA and Ultrasmooth with a few "likely"
existing Cone profiles and the results are dismal.  The QTR profiling
is very specific.
3.  While the Cone QTR profiles for the K7/4800 are excellent and
pretty much make obviate the the need for ICC profiling, I did not
find this with the K3/ABW.  I think this Epson system pretty much
needs ICC profiling for both best results and an easy, reliable,
consistent workflow image to image.  I know that Clayton and others
do PS curves for this purpose, but this seems like an ongoing hassle
to me.  The ICC profiles are a do-it-and-forget-it deal and are very
accurate and I would highly encourage it.  The need to do this (and
to own a densitometer) is the weakness of the K3/ABW system in my
appraisal.
4.  I am struck at this point about the amount of apparently
reflexive prejudice against Epson materials and processes.  With an
ICC profile, this is a remarkably good system and at least
competitive with the K7s.  In discussing these issues with a Cone
representative this morning, he informed me that the K3/VFA/USFA
figures I report are because Epson is using dyes in these inks.  I
don't think that's true and I hope that the Cone people can be a
little more constructive.
5.  In 50 years we'll know if the color content of the K3 system is
an issue, but I don't think we know that right now.  The K7 system is
a better idea, but I don't know if it is actually a better process in
terms of longevity.
Good wishes,
Walt
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael King"
experimenting with
the amount
> of colour it uses.
have found
adjusting
> Mike
2006-10-20 by Bruce Watson
wwodets wrote:
> ...the K3/VFA/USFA
I believe the Cone conjecture is correct. The Epson inks do not appear
to be 100% pigment inks. I don't believe that Epson claims that they are
either. I suspect that Epson uses a statistically significant amount of
dyes in the K3 inks. You can of course do some analysis and determine
the truth yourself.
The problem with using color inks to make B&W prints, as I see it, is
that the color inks can introduce problems like subtle color casts,
color shifting from dark to light, and color casts due to differential
fading (different colors fade at different rates). While the prints
might look fine today, what will they look like tomorrow?
It's not worth the risk to me. Clearly, YMMV.
Bruce Watson/
Hello Walt,
I also don't think there are dyes in K3 inks.  I've been doing
windowsill torture rests of various inks for several years now, and I
know what happens to inks containing dyes in just a short period. A K3
print has been on my windowsill (unprotected and with some direct
sunlight every day) for over a year now, and I can detect only the
barest hint of change in a middle gray area.
>I think this Epson system pretty much needs ICC profiling for both
>best results and an easy, reliable, consistent workflow image to
>image.  I know that Clayton and others do PS curves for this purpose,
>but this seems like an ongoing hassle to me...The need to do this
>(and to own a densitometer) is the weakness of the K3/ABW system in
>my appraisal.
I just want to say that I don't consider it a hassle at all.  The PS
curves are very simple and quick, and once done they are saved with
the image and reused.  There is a great freedom in being able to
quickly try various papers and do experiments without having to use a
densitometer to make an icc curve for every ink/paper combination.  I
find this approach to be very simple and efficient.
I hope this won't become a debate.  I respect your views and
understand what you are saying re the need for icc profiles, and don't
really disagree - just that you and I are working with slightly
different perspectives and preferences.  I am responding to this only
to ensure that some reader who is new to all this might not get a
wrong impression that the non-icc workflow produces inferior results.
The results are top notch: excellent dmax, open shadows, luminous
highlights.  It's just a different preference for how one wishes to
work.
Same here.  I find the Epson papers I use to be very fine, and the
inks are stable.  Withstanding a year on the windowsill with some
direct south Florida sunlight every day without fading or color
shifting is a remarkable feat, and Wilhelm rates K3/ABW from 110 -
300+ years, depending on conditions.  That's pretty impressive.
Clayton
2006-10-20 by CorrPro96@aol.com
In a message dated 10/20/2006 12:35:03 P.M. Eastern Daylight Time,
odets@... writes:
appraisal.
Hi Walt:
I've been using the ColorVision PrintFixPro for profiling my color  printers,
and I'm waiting for their v 2.0 software to release which will give us  B/W
profiling capability as well.
Perhaps CD Tobie will add to this very interesting thread to give us his
perspective on what the future holds. This is a low-cost system that does an
excellent job without the hassle and expense associated with the Hi-end
software-hardware products out there.
Although I've been able to make prints that I find comparable to the same
negative printed in my old darkroom and exhibited years ago, there is a need to
be able to adjust print quality to lighting in exhibition spaces, just as we
had  to do before. My biggest adjustment was to accept the matte paper look
(I'm  still tempted to apply a coat of wax to some prints, remember the green
boxes?).  The gloss finish papers are even harder to adjust to. They call them
photo  papers, but they fall short of the selection we had available in the
darkroom.  The Luster papers seem to offer the best finish, but they are too thin
and  creases are too easy to make if you don't mount them quickly. I just
wish that  Bill Atkinson would make profiles for the 4800 K 3 ABW, and Epson
would add some  weight to their Prem Luster.
Richard (Brooklyn)
2006-10-21 by joemulligan_68
From my limited experience with K7 (four months), I find the hghlights too light.  K7 has
problems with high contrast images that have a quick transition from shadow to highlight.
Even though the transtiions are quick they still should be smooth.  K3 has no problem with
this but K7 does.  I'm wondering if anyone else has noticed this.
I would like to see more ink thrown down on the highlights and midtones but Cone profiles
are hotwired into QTR so I have no idea how to alter them.  Does anyone know how to alter
the Cone profiles or are we stuck with creating our own?  I threw this question out at the
Piezography list but no one could respond.  Ditto at the QTR list.  Maybe the luminarites here
could shed some light.
Thanks in advance.
2006-10-21 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "joemulligan_68"
> Thanks in advance.
I don't use either the inks or the RIP, but is making the profiles
that hard?
If you aren't getting the results you need, then maybe try something
like IJC/OPM. In either case if you really want to take full advantage
of the software and inks, you really need to make your own configurations.
RE: [Digital BW] Re: Hands-on impressions K3/ABW versus K7/QTR
2006-10-21 by Eric Neilsen
Richard,  I would add that there are some that always pick up the same box
of paper and try and make it work for a particular image, rather than pick
up the more appropriate box and let it do the work.
I have not used the K7 or K6 inks and only dabbled with QTR. I have been
using the ABW on my 4800 with K3 for almost a year now. I can certainly see
where it fails and where it works great. I also run the Piezotone Sepia set
with a 7000 and Image Print and have been using that set up for coming up on
4 years.  The set ups certainly have their sweet spots, just like a film and
paper combination did from years ago. It is tough getting a sweet spot as
there are a lot more choices in this arena than in the old days, of 4 or 5
major flavors.
The older printers need more help, and I don't consider the X600 that old.
The biggest problem that exists is the Dmax melt down. This is where the
Epson driver just pours down the black, hiding the detail you tried so hard
to maintain. And it is not restricted to Epson drivers, but also to those in
pursuit of the ultimate Dmax. My reason for staying away from the K7, is
that it just doesn't have the color I need or at least I have not seen it.
But back to the paper in a box,.   Matching scene to paper is quite
important as is ink to paper and scene. We all have a lot of playing to do
for a few years.
Eric Neilsen Photography
4101 Commerce Street
Suite 9
Dallas, TX 75226
http://e.neilsen.home.att.net
Skype ejprinter
  _____
CorrPro96@...
Sent: Friday, October 20, 2006 5:36 PM
Subject: Re: [Digital BW] Re: Hands-on impressions K3/ABW versus K7/QTR
odets@comcast. <mailto:odets%40comcast.net> net writes:
appraisal.
Hi Walt:
to
them
thin
Richard (Brooklyn)
2006-10-21 by John Moody
I hope this does not sound to silly, but make absolutely certain the correct
ink is in each slot.  Call support to be sure.
K7 _is_ smooth, so there must be some issue with your setup or workflow.
If the K7 is setup and working correctly, then what you are describing is a
monitor to print matching problem.  You will find lots of information on how
to address that in past messages.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of
joemulligan_68
Sent: Friday, October 20, 2006 8:28 PM
Subject: [Digital BW] Re: Hands-on impressions K3/ABW versus K7/QTR
light. K7 has
to highlight.
problem with
Cone profiles
how to alter
question out at the
luminarites here
Thanks in advance.
2006-10-21 by CDTobie@aol.com
In a message dated 10/20/06 5:19:07 PM, bwyg@... writes:
The quantity of color ink used in the latest "two gray" printer's drivers is
minimal, and the pigment inks involved are very stable. So both illuminant
metamerism and color shift over time are also very minimal. And the issue of
"color casts" is the strength as well as the weakness of these systems: you can
potentially control that subtle color, and make it do what you want.
C. David Tobie
Product Technology Manager
ColorVision Business Division
DataColor Inc.
CDTobie@...
www.colorvision.com
2006-10-21 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody"
correct
describing is a
information on how
Or that the printer is far enough away from the printer that made the
linearization that the prints are coming out with a big flat spot. I
know everyone wants a simple prepackaged solution, but the truth is
that you really need to take the next step and go through
linearization and set up for each printer in use.
2006-10-21 by Paul Roark
>... In discussing these issues with a Cone
> the K3/VFA/USFA figures I report are because Epson is using
> dyes in these inks.
I do not think the Epson UC K2 or K3 inks have dyes in them, at least in the
meaning of the term as it is usually used.  The comment above about the
numbers presumably is about the dmax.  Epson matte black in the k3 printers
gets an outstanding dmax on some papers, and not so great on others.  It
appears to be not only because of the quality of the ink, but also because
Epson has done an excellent job of matching the printer's characteristics --
dither and ink loading -- to the papers Epson thinks are most important.
In fade testing the Epson MK, like MIS's Eboni, did very well.  If I wanted
the most lightfast print possible, regardless of smoothness or tone, a black
only print using one of these inks would probably be the route I'd take.
The hybrid pigment-dye blacks are obvious in fade testing.  They go through
a fast initial fade.  Then when the dyes burn off, they settle into a slower
fade rate for a long time.  Neither Epsom MK or Eboni show that fade
pattern.  In fact, both become a hair more dense at first.  Ironically, the
original Epson "Archival" black did act like a hybrid ink in fade testing.
The K3 "carbon" core pigments are actually about half carbon and half
"proprietary pigments and dyes."  (I think that is the catch phrase Epson
uses on its MSDSs.)  But, this phrase does not mean that there are dyes in
solution.   The color pigments we use are often referred to as "dye stacks."
They are often chemically the same as the dyes, but they do not dissolve in
the water base like the dyes that fade fast.  The dye stacks are solids in
suspension; they're legitimate pigments.  With respect to the carbon, I'm
not sure what Epson is doing.  Lots of the action is at the edges of the
graphite plates.  That is about the only place that form of carbon has any
open bonds, and they are used by the companies to give the pigments
favorable characteristics, like staying in suspension and not aggregating.
>The problem with using color inks to make B&W prints ... is
> casts, color shifting from dark to light, and color
> casts due to differential fading ...
Yes, which is why I always want the least amount of color and the most
carbon.  However, carbon is too warm for me in most instances.  So, the use
of some color pigments is necessary to get the tones I prefer.  Among the
color pigments, cyan is about the most lightfast.  I don't worry about if
fading from light, although air pollution might be a problem.  The magenta
is more of a concern.  I specified the MIS R800 Blue clone pigment in the
MIS mixes because it is more lightfast and stays in suspension better.  In
my new 7500 setup I'm using Epson UC LM.  I have some tests that suggest it
is very good.
C. David Tobie noted:
>drivers is minimal, and the pigment inks involved are very stable.
>So both illuminant metamerism and color shift over time are also
>very minimal. ...
To give some quantification of this, in the IJC curves used in my new 7500
setup, the highest ink load I use is 22 for the LK.  The LM and LC (at 50%
dilution) have ink loads of 3.
I sometimes wish we had a totally neutral, pure carbon, but as far as I can
tell, no one has developed one yet.  Some of the black inks will print cool
when they are applied in high loads, but in the midtones and when diluted,
they all are still warm as far as I know.  The k3 LK and LLK are less warm
than the MIS versions, but I think they're too green.  In most respects I
like the warmth of the MIS carbon.  It allows that ink to be used as a
low-gamut yellow in a CMY color space, and I like the ability to profile my
papers or choice to the tones I want.  The MIS carbon, LM and LC combination
gives me what I want from a B&W inkset.
2006-10-22 by wjlafever
> Thanks in advance.
This sounds like a profile problem. What's your workflow?
2006-10-22 by Roy Harrington
highlight.
with
profiles
alter
here
> Thanks in advance.
Unfortunately it's not possible to modify Cone's K7 QTR profiles.  However it's quite
easy to build onto them.  Use the QTR-Create-ICC feature to make custom B&W ICC
profiles.  This way you get the full color management capabilities of printing (matching
the source embedded space to the print space) and soft-proofing to show the print
ink tones on the screen.
The advantage is that you can use the existing smooth profiles for any paper since
the ICC profile gives another level of linearization/correction.
Roy
2006-10-22 by wwodets
In confirmation of what Roy has suggested here, I have actually had a
very good result using VFA with the Cone-supplied curve for HPR and
an ICC (QTR Create ICC) profile on top of that.  I am also using ICC
profiles for even the Cone-curved papers because this corrects small
differences in the individual printer, etc.
What was not obvious to me (but explained by Roy and others on the
board) is that before printing, the image needs to be *converted* to
the ICC profile and saved that way.  (With PS/Epson driver, this
conversion occurs automatically upon printing.)  The same image can
thus be used for any paper simply by converting to the profile for
that paper.  It doesn't matter what the embedded profile or workspace
is before conversion.
Walt
However it's quite
custom B&W ICC
show the print
any paper since
> Roy
