MIS Pro Inks - color printing
2007-04-25 by Louis Dina
I know this is a B&W forum, but I know some of you use the MIS Pro Inks
as a replacement for the Epson UC inkset.  Love the price, and my
printer seems to clog less than it used to.  Perhaps it is the
cartridge design or the inks themselves.
Those of you who roll your own profiles, how do the MIS Pro inks
compare in terms of Dmax and color gamut?  I am using a 4000 and
testing these inks currently on Epson EEM and VFA to get a comparison.
So far, my tests show less gamut and Dmax on both papers compared to
profiles built with UC inks and the same 918 patch test target
(ProfileMaker5 and an Eye One Pro).  Viewed in ColorThink, the gamuts
are definitely a little smaller and Dmax is also less.
Targets were printed at 1440 dpi, SuperX turned off, No Color
Adjustment, slow speed, and all other check boxes turned off.
Any feedback or suggestions?
Lou Dina
Re: [Digital BW] MIS Pro Inks - color printing
2007-04-25 by Tom Baker
Lou  -
  At this time I actually have a mixture of MIS and EPSON UC inks in my 9600.  Partly this is due to making a gradual move to the MIS.  I will end up with - unless the MIS magentas get better, using all MIS except for the magentas, which will stay as Epson UC.
  Consequently, I don't have any valid comparisons between the UC profiles and the MIS/EPSON profiles.  However, I do not SEE any difference in the color gamut when I compare older prints of the same image with newer ones.  The biggest bang for the buck came from doing my own profiles (Xrite Pulse).  Then I got a quite noticeable improvement in the reds.
  As for dmax, it will vary, depending on the particular paper.  Eboni is better on some, not quite so good on others.  So far, the difference has not been enough to warrant changing out the blacks to match paper.  I don't know if there is a difference in the PK's.
  Don't know that this helps, but these are my observations.
  Tom Baker
Lou Dina
2007-04-25 by Ernst Dinkla
> Thanks,
> Lou Dina
Lou,
I have used them on an Epson 10000 and a friend has used
them on a 9600 and still uses them on a 9800. The MIS 7600
version instead of the MIS Pro but there isn't much
difference in the pigment load. (we tested the MIS Pro but
there were some problems with printing on canvas: after
varnish was applied it turned more to yellow than the MIS
7600 did, probably the different ink base). The MIS Pro
should be better suited for the Epsons though, less clogging
and pigment settling. The MIS magenta pigment is like the
9600 UC magenta but MIS can not get the 9800 K3 magenta
pigment. On the 10000 the gamut increased with MIS 7600, on
the 9600 there was hardly a difference, on the 9800 some
gamut loss in the reds mainly. The last more a result of the
lower inklimits of the 9800 and its red biased magenta, the
Dmax is also lower on the 9800 with Eboni black printed on
Epson coatings but shouldn't be less on HM coatings. With
the 10000 and the 9600 the Dmax has been higher with Eboni
black on HM coatings than with the Epson inks. My friend
used the slider in the 9800 driver to increase the inkload
but that's a gamma thing only so does nothing on the Dmax.
His reference for the 9800 has been what he could achieve on
the 9600's, less to what could be made with the 9800 K3
inks. With the 4000 you are more in 9600 UC than in 9800 K3
territory. What used to be a problem was some inconsistency
between batches of MIS LM inks, a bit too much coloring
difference in our experience, MIS considered them to be
within specs. Not so nice when you order a gallon from the
US to see that you can profile again to get some
consistency. I have to say that they did send new jars every
time we complained about that issue.
You could try to use high speed instead for better Dmax,
sounds strange but a bit of bleeding may make the black
patch a bit more homogene and by that your readings may go
up. Any other gain has to come from the paper setting
choices, we did HM papers only and the watercolor paper
choice was actually the best choice on all three models.
With the HP Z3100 here the 10000 isn't used anymore, the HP
is hard to beat on Dmax and by and by I get an increased
gamut on HM PhotoRag (Bright White) (finding the right paper
settings + the firmware upgrades). Better than the Epson
4000 gamut on EEM as I'm printing big prints these days with
small Epson 4000 UC proofs for reference. Next to other
advantages the ink used goes for 99% on the paper which is
something we couldn't achieve with any Epson so far. Carts
are almost dry inside when empty. That compensates the lower
cost of the MIS inks. I'm not going back.
Met vriendelijke groeten,  Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Thanks Ernst.  Good report.
I will try the high speed setting.  It never occurred to me that it
might actually increase the Dmax.
Regards, Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
<E.Dinkla@...> wrote:
Pro Inks
comparison.
to
gamuts
> > Thanks,
> > Lou Dina
> Lou,
> |             ( unvollendet )            |
Tom, thanks for the response.
What types of problems are you having with the MIS magenta ink?
Saturation, density, permanence, consistency?
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker
<tbaker1328@...> wrote:
> Lou  -
>   Tom Baker
the MIS Pro Inks
comparison.
to
gamuts
> Thanks,
> Lou Dina
Lou  -
  I'm really basing this on what a coule of others have found.  Ernst's comments seem to indicate that the MIS Pro is the same magenta as the Epson UC.  If that's the case, there would be no need to avoid the MIS.  I do use the MIS magentas on my smaller printers.  I haven't actually seen any difference.  But, I've only been using the MIS inks for about a year.
  Tom Baker
Lou
> Lou -
> Tom Baker
the MIS Pro Inks
comparison.
to
gamuts
> Thanks,
> Lou Dina
Ernst,
I tried the High Speed setting and actually did get an improvement in
Dmax.  Thanks for the great tip.  I still find that turning SuperX
microweave off gives me better density.  And I know it shouldn't make a
difference, but increasing the ink density slider by 10% actually
improved the Dmax just a little more.
I ran an experiment and printed a QTR calibration test chart on EEM
using UC inks before the changeover, and again with MIS inks after
conversion so I could see the individual ink positions and measure
them.  The Eboni and the MK were pretty close, but all the other inks
share a common characteristic.  The UC inks print darker toward the
100% ink density patch, but they have a little less saturation.  The
MIS inks seem to actually have more chroma, but have a higher L* value
at the 100% ink patch.  Of course the higher chroma may be due to lower
density at that point.
Still is hints that perhaps the MIS inks might benefit from bumping up
the ink density slider a little bit.
Thanks for the tips.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
> Regards, Lou
2007-04-25 by CDTobie@aol.com
In a message dated 4/25/07 4:03:41 PM, lou@... writes:
Okay, just to quantify the compulsion for deeper blacks, could you specify
just how much deeper (in Visual Density units or L* units) your blacks are using
Highspeed, and using +10 density?
thanks,
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
2007-04-25 by john dean
I tested all my Epson printers recently with several media and the
Water Color media setting DOES give the best dmax. It was
significantly darker than the Smooth Fine Art media settings,
especially on the 10K with NK6 and Hahnemuhle papers.
That is very interesting that you see a better dmax on Epsons by
leaving high-speed on. I am going to try that with the 8 pass mode and
see if that works, with 4 pass on the 10K I would just give me banding.
John
| ( unvollendet ) |
RE: [Digital BW] MIS Pro Inks - color printing
2007-04-25 by Paul Roark
Ernst,
>... The MIS 7600 version instead of the MIS Pro
> but there isn't much difference in the pigment load.
They are now, apparently, the same inks.
The early versions appeared to have a more yellow base.  The latest base is
closer to neutral.
Have you seen any evidence that the Epson k3 magenta is better or worse than
the k2 magenta with respect to lightfastness?
It sounds like you're becoming an HP fan.  A service bureau I know here is
becoming a fan of Canon.  It sounds like Epson is losing market share.
Re: MIS Pro Inks - color printing
2007-04-25 by Andre Moreau
Hello Paul,
Seems like the competition is making gains. Two locals electronics
stores used to carry several Epson consumers printer models. Nowadays,
they only carry one model each while the aisles are full of Canon and
HP printer models.
Someone I know recently acquired a Canon iPF5000 printer for b&w
printing. Epson wasn't even on his list of potential printer models.
I'm pretty sure that Epson's ink clogging problems are a factor here.
And today I'm reading that Mike Johnston of the T.O.P. website is
saying that he "wouldn't choose any other printer" when speaking of
the HP B9180 printer.
http://tinyurl.com/26xrva
Andre
www.andremoreau.com
> closer to neutral.
Paul,
On the Roma canvas we used then + Lascaux varnish (from the
bottle sprayed or rolled) the shift to yellow was just too
much. A pity they couldn't inform us of possible changes in
the base then. There was another issue if I recall it
correctly: the MIS Pro magenta for the 9800 had another
pigment load (but the same pigment) than the MIS 7600
magenta for the 9600 had, you couldn't make the same gamut
the K3's made and you couldn't get the same gamut the 9600
with UC or MIS 7600 had.
The time the K3 inks were used was very limited. My friend
bought the 9800 and within maybe a month it was loaded with
MIS inks. The same method that I used to convert the 10000
carts for refilling was used on the 9800 carts, similar
design but smaller parts. MIS actually didn't know then that
the Epson 9800 carts needed conversion and I guess the very
first 9800 MIS clone ink in quantity went to Europe, the
rest was only used for 2400's in the US then. That was our
impression when we contacted MIS with questions.
Epson needed good competition, I do not underestimate
Epson's skill to deliver better printers in the future but
when you control the market there's no urge to do major
upgrades in technology or to change the service policies.
Even if you have enough innovations up your sleeve. It is
just a matter of staying a nose length in front and you keep
the biggest share with the least effort. Every 3 years a new
generation that had just enough appeal to attract buyers but
nothing else. The 3800 gloss / matte black ink selection has
nothing revolutionary, it could have been done years ago
(and better) but would have cut ink consumption then. Epson
got that lead 10 years ago. It milked the cow but was asleep
when Canon and HP entered the arena.
Apart from all the nice HP Z3100 features there's something
else that makes HP interesting: it is all over the place in
the printing world right now: The Scitex inkjet wide formats
(UV curing inks, solvent inks), the HP 9000 etc solvent
models (Konica piezo heads),  the new stackable HP pi\ufffdzo
heads for similar inkjet models, the single array head /
ultra fast printers based on the same thermo head design the
Z3100 has, the Indigo printer and there's more. A much wider
field it wants to play on than Epson (including Seiko) and
Canon want to play on. There are high volume Canon
electrostatic printers (not comparable with the Indigo
though) but it doesn't do anything in the sign market. Epson
  and Seiko have sold some head designs in the sign market
but there's no big market share and they are losing ground
against Xaar, Spectra and Konica heads. And unlike Kodak,
Fuji, Agfa, Oc\ufffd, that all want to play in that wider field
HP is developing the high tech parts itself to replace what
it now buys from companies like Xaar. This isn't a half
hearted attempt, it will stay in this market.
|             ( unvollendet )            |
In a message dated 4/25/07 4:40:46 PM, paul.roark@... writes:
Its like Apple and the iPod market; everyone keeps predicting they'll crash
and burn, because when you have a huge monolopy in a market, there's no place
to go but down. However, if unit sales keep increasing in this market, "down"
in percentage points may still be "up" in number of units sold. Besides, Canon
and HP have had their shots at a next generation device. Next it will be
Epson's turn again, and they don't tend to let much grass grow under their feet.
C. David Tobie
ColorVision Business Division
DataColor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
Andre, I think you have a good point.  I have had such problems with
clogging and some of Epson's self serving policies, that I will
seriously look at other manufacturers before considering an Epson for
my next printer.  The market is flattening out and printers, even
archival ones, will soon be a commodity.  It happens in every market
as it matures, then it becomes a price war and a features game since
the differences are too slight to quibble over.
It always pays in the long run to take care of your customers, even
at the risk of losing a little revenue over the short run.  Customer
loyalty means a lot, especially in this day and age.  It costs a
whole lot more to get a new customer than it does to hold onto
existing ones.  Having spent a long career in sales and marketing, I
have seen it time and again.  Epson had better be careful, or they
could get hurt very quickly and profoundly.  I'm far from alone in my
attitude toward Epson.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andre Moreau"
> Hello Paul,
Nowadays,
and
> HP printer models.
here.
> Cheers,
> Andre
> www.andremoreau.com
Re: [Digital BW] Re: MIS Pro Inks - color printing
2007-04-26 by Tom Baker
I've had very good results/luck with my 9600.  No clogging problems, turn it on and it prints.  It does everything expected/promised, and I'm completely happy with it.  I didn't upgrade to the x800 series because I had no need.  I still don't have the need.  So, I will need to see visably better results from a new printer to upgrade.  And, when I do upgrade, assuming that reliability is there, I won't care what label is on the printer.
  I agree that Epson has rather ignored the future value they may have gained from giving up a little on the profilt margin in the short run.
  Tom Baker
Lou
> Hello Paul,
Nowadays,
and
> HP printer models.
here.
> Cheers,
> Andre
> www.andremoreau.com
2007-04-26 by Paul Grant
I would imagine that since the new Epson 3800 has auto switching of the
black inks.....I would assume that the new larger formats would have the
same plus other new features.
Anyone out there have experience wit the 3800 for b/w.   I am thinking of
upgrading from my 2200.  I would appreciate any comments.
On 4/25/07 6:29 PM, "john dean" <deanwork2003@yahoo.com> wrote:
> Well, as someone who has a house full of Epsons and has used them
> daily for 7 years..if their next large format machine doesn't
> incorporate auto switching between mk and pk they might as well hang
> it up.
> john
> Next it will be
> under their feet.
>> > C. David Tobie
>> > DataColor Inc.
>> > CDTobie@...
>> > www.colorvision.com
>> >  See what's free at
>> > http://www.aol.com.
2007-04-26 by Ernst Dinkla
> C. David Tobie
> DataColor Inc.
> CDTobie@...
> www.colorvision.com
Apple made the right decisions in the last years to earn
their money in other markets building on the corporate's
image. The Apple trademark gets into the ranks of Gucci,
Porsche etc, that's one thing. The music distribution was a
good commercial decision where EMI, Sony, and others thought
that that industry didn't need to innovate itself. But if
you look at computer system sales Apple actually lost market
share. The iPhone doesn't look as promising as the iPod
turned out to be and the proprietary locks on both (music
format on the iPod, the limited access of third party
software developers on the iPhone + one provider only in the
US) will turn against Apple one day. Nothing new there. If
Epson is as flexible as Apple is now it will continue but in
a market that is changed.
HP's ultrafast Z6100 42" and 60" models are already
announced, replacing the 5500 but also a 60" competition for
Canon's iPF9000 and the rumored Epson 60". HP has to add a
17" model with roll and sheet feeding I think. I don't think
we saw all of the next generation from HP yet.
|             ( unvollendet )            |
2007-04-26 by CDTobie@aol.com
In a message dated 4/26/07 4:38:13 AM, E.Dinkla@... writes:
> But if
> share.
I certainly don't see that; quite the opposite! Every airport I walk through
is now full of Mac laptops, to the point that I see more of those than PC
laptops... but Apple was an analogy, not the subject of my post... <G>
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
2007-04-26 by john dean
I think in the states that is true. The dual core imac and the power
books are very popular indeed. However,in the rest of the world,
especially asia, the market share is really really low and they are
luxury items.
john
> > But if
> > share.
walk through
than PC
<G>
> C. David Tobie
> Datacolor Inc.
> CDTobie@...
> www.colorvision.com
>  See what's free at
> http://www.aol.com.
2007-04-27 by mkirschner
On a slight tangent, I'm very pleased with the MIS PRO color inks in
my Epson C86. I print on Kirkland Glossy using Epson driver glossy
settings, with no ICC's or other special adjustments.
2007-04-30 by shangheye
I recently bought the Pro 3800 (first time to use an Epson!), and I
can vouch for the quality of it's B&W prints. Like all printers an
important step is to make sure that you are using a well calibrated
screen, but I have found the printer profiles that come with the
printer have been excellent, and final prints match what I am
seeing. I am currently printing using the RGB mode (specifically
sRGB profiled images) matched with the Epson sRGB setting in the
Custom section of the print driver. This produces excellent neutral
prints (at least with the Epson papers)to my eye.  The Advanced
Black & White feature also produces excellent prints though to my
eye slightly warmer (only really detectable in the mid-tones)when
compared to the sRGB prints. The blacks are also deeper in the ABW
mode. I now print ABW mainly in lower contrast prints, where I need
slightly more dynamic range in the print (which is provided by the
darker blacks),a nd use the toning tool to add a little blue to get
a neutral print I like. Thouroughly recommend it as a printer, and
perfect size if you are limited in space and mainly print sheet
(needs more space if you are printing on Fine Art Paper etc, for the
front and rear feeders). Having come from Canon printers, I am
delighted with the idea of not having to switch inks! Rgds, K
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Paul Grant
of the
have the
thinking of
> Regards,
> Paul
hang
> > it up.
> > john
> > Next it will be
> > under their feet.
> >> > C. David Tobie
> >> > DataColor Inc.
> >> > CDTobie@
> >> > www.colorvision.com
> >> >  See what's free at
> >> > http://www.aol.com.
2007-04-30 by Paul Grant
Thank you so much for the helpful information on the 3800.  I have the 2200
and I have not been happy with the BW images. I am a traditional darkroom
guy so I am pretty picky.  I have not strayed from the standard Epson inks
and was hoping the 3800 would save me all the grief.
Sounds like it's the way to go.
I do appreciate the feedback.
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of shangheye
Sent: Sunday, April 29, 2007 9:19 PM
Subject: Re: [Digital BW] MIS Pro Inks - color printing
of the
have the
thinking of
> Regards,
> Paul
hang
> > it up.
> > john
> > Next it will be
> > under their feet.
> >> > C. David Tobie
> >> > DataColor Inc.
> >> > CDTobie@
> >> > www.colorvision.com
> >> > See what's free at
> >> > http://www.aol. <http://www.aol.com.> com.
2007-04-30 by Brian Ellis
"Thank you so much for the helpful information on the 3800.  I have the 2200
guy so I am pretty picky"
I too am a traditonal darkroom guy (20 years) and am pretty picky - 4x
enlargements of 4x5 negatives and 8x10 contact prints from 8x10 negatives).
I also used a 2200 until buying the 3800 just a few weeks ago (mainly to
gain the K3 inks and larger print size). I found that the 2200 with UC inks
made outstanding b&w prints if QTR was used. If your only reason for
thinking of a switch to the 3800 is unhappiness with the 2200 for b&w you
might consider trying QTR with your 2200 first  assuming you're not already
using it.
I haven't made enough b&w prints using Advanced B&W in the 3800 to form a
definite opinion but with the few I've made my impression is that Advanced
B&W in the 3800 does as good a job as the 2200 with QTR but if it's better
the difference hasn't yet shown up to my eyes without a side-by-side
comparison.
Sent: Monday, April 30, 2007 2:36 AM
Subject: RE: [Digital BW] MIS Pro Inks - color printing
of the
have the
thinking of
> Regards,
> Paul
hang
> > it up.
> > john
> > Next it will be
> > under their feet.
> >> > C. David Tobie
> >> > DataColor Inc.
> >> > CDTobie@
> >> > www.colorvision.com
> >> > See what's free at
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
Re: [Digital BW] MIS Pro Inks - color printing--Comments about the 3800
2007-04-30 by fredila2
I've been using the 3800 for about two weeks.  My previous printer
was the 2200 and I used it for about two years.  Most of my b/w
printing on the 2200 employed QTR and Qimage. I probably used Epson
Velvet Fine Art about 75% of the time. I was generally satisfied with
the output, most of which consisted of 12x18 prints.  I only print
about once a week and make about two or three "keeper" prints each
time.
I got the 3800 because of the wider carriage and what I had read
about the K3 inks.
So far, I have done mostly test prints on a wide variety of papers
and used the ABW settings as well as QTR.  Frankly, at this point, I
don't see much of a difference between the 2200 and the 3800 output.
Maybe I'm not picky enough or I just haven't got it hacked yet.  Who
knows, maybe I will change my opinion after a few more weeks.
Fred
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Brian Ellis
the 2200
darkroom
2007-04-30 by bwinkjet
Hi Fred,
I agree.  On matt paper, both produce wonderful prints.  On glossy
paper it is another story.  At least this has been my observation
using both printers and both matt and glossy stock.  The ABW feature
has enabled me not to have to order Image Print for my 3800.
HTH
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "fredila2"
with
> time.
> about the K3 inks.
I
output.
Who
> Regards,
> Fred
have
> the 2200
> darkroom
Hi Paul,
Thanks for the input...and good point.  I've avoided glossy paper
because of all the "historical" problems mentioned here and
elsewhere.  Maybe I should give it a second chance.
Fred
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bwinkjet"
<bwinkjet@...> wrote:
> Hi Fred,
feature
> HTH
> Paul
printer
Epson
> with
print
each
> > time.
> > about the K3 inks.
papers
point,
> I
> output.
> Who
> > Regards,
> > Fred
> have
> > the 2200
traditional
> > darkroom
2007-05-07 by Richard Smallfield
I've ordered some MIS Pro carts for my 2100 but am concerned about the magentas, too.
Two possibilities occur to me: one, switching back to the UC K2 carts only for display prints and two, using UC Magenta/Light Magenta as you use. That would mean less custom profiles as I'd only be using one set of inks.
My question is this: on lustre papers, what does a mix of MIS and UC have on  gloss differential? The MIS are less glossy than the UC so I'm concerned about having regional gloss differential where there is magenta ink.
The other thing is that I print 90% BW, so in those images I imagine the differences in gloss between using the two inksets at once would be much less evident - so it may not be a problem there.
I do like matte papers however (and they are all I currently use, due to the bronzing and gloss differential with UC K2 inks), so I suppose the simple solution is to stick to matte and enjoy the cost benefit of refilling five of my carts with MIS Pro inks.
Your thoughts would be appreciated, Tom.
thanks,
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com (Photos web site)
http://warkworth.vze.com/ (Warkworth photo essay)
http://picasaweb.google.com/rsmallfield/ (Recent work)
   "Now, now my good man, this is no time for making enemies."
   --Voltaire (1694-1778) on his deathbed in response to a priest
   asking that he renounce Satan.
2007-05-07 by Tom Baker
I use the MIS Pro ink with the glossy papers.  However, these prints are not for sale.  Just folks to hang family pictures on the wall.  But, the glossy prints are just fiine.  When viewed under normal conditions they are perfectly fine.  Not qjuite up to the Claria inks, but just fine.
  Tom Baker
thanks,
Richard
