Re: [Digital BW] PrintFIX PRO,1160 and MIS FSN
2007-07-02 by CDTobie@aol.com
In a message dated 7/1/07 7:16:21 PM, mastologia@... writes:
> I've searched here and didn't find comments on this specific combo so
> would anybody know if PrintFIX PRO would be able to profile a 1160
> that I print with MIS FSN Inks? How well would it work? Would the
> GretagMacbeth counterparte do any better for the extra 450 bucks?(the
> combo with the spider,I mean) I already have the old ColorVison spyder...
There are actually more B&W specific functions in PrintFIX PRO than in other
color profiling products. Since these inks can be used with the RGB driver, in
appropriate color order, it should be possible to profile them with PrintFIX
PRO, though that won't control the tone of non-toned inks like FSN. I have not
heard (that I recall, at least) from anyone using your specific combination,
but its certainly worth trying. Personally, I'd recommend the MIS UT3D inks,
as they profile very nicely with PrintFIX PRO, and give you a nice range of
controllable tints and crosstints via a PFP profile.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
2007-07-02 by James Irelan
>  Would the
I have not used PrintFix, but I have used earlier Colorvision
products going back a number of years, and was always pleased with
the results. A few years ago Gretag had a special on ProfileMaker,
and I went for it, thinking that a much more expensive product must
be even  better.  I have not found this to be the case.  My testimony
is entirely anecdotal, and limited to color profile generation,  so
keep that in mind, and it is true that I am now getting good profiles
with PM 5 (seems better than 4), but is PM worth the extra money?
Not that I can see. Maybe it has more elaborate features for tasks
like profiling presses etc- I don't know.  It does seem to have lots
of options.  But just for generating profiles for home fine art
printing, my guess would be that your extra $450 could be much better
spent on ink or paper etc.
I have a question re: generating profiles for a split tone ink set
such as one of the new K6 Cone split tone sets.  Does the aspect that
the inks vary in color have any bearing?  Or are the profiles based
on density only, and therefore unaffected?  I have not yet generated
any black and white profiles yet so I'm unfamiliar with the process,
but I'm gearing up to do so, and thinking about a split set on a 9500.
James Irelan
In a message dated 7/2/07 1:25:54 PM, james@... writes:
PrintFIX PRO profiles are capable of controlling tints as well as densities,
when used with a driver or RIP that allows the profile to do so. So if you
profile a grayscale driver, you'll only get density, as the a*/b* components will
be ignored, while profiling a color driver will allow you control of color
tints as well as density. A 9500 will require a custom inkset to do good B&W
printing. If you choose a profilable singletone or adjustable tone inkset, then
you can profile it with PrintFIX PRO. That profile will then allow you to tell
what is, and is not, in the gamut of that inkset, for the adjustable B&W sets,
and preview the results at various tints and crosstints. For the single tone
B&W inkset, a PFP profile will preview that tone, and allow you to adjust
densities with a live preview of the results; but the tone will be fixed, and will
vary a bit from paper to paper.
For more info, download the PrintFIX PRO 2.1   UserGuide.pdf at
colorvision.com, under Support >User Guides. The tutorials on B&W, as well as the screen by
screen help, will tell you more about the process.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
> densities,
Immediately I'd be using QTR and profiling with ProfileMaker.  If
PrintFix would be preferable for the purpose I'd look at it for the
future, but right now I need to stick with what I have.  I have QTR
but haven't used it yet, so I don't know what it's capable of.
James
In a message dated 7/2/07 2:47:17 PM, james@... writes:
> > densities,
That will work (EyeOne and QTR), but the thread was about PrintFIX PRO, so
that was what I assumed you were asking about...
C. David Tobie
Datacolor Inc.
CDTobie@colorvision.com
www.colorvision.com
 See what's free at
http://www.aol.com.
> PRO, so
Sorry to get a little off thread.  I was really asking just generally
about split tone sets, and if they could be profiled the same way a
mono set could, or if some special techniques were needed.
James
In a message dated 7/2/07 3:36:22 PM, james@... writes:
Can't comment on how ProfileMaker deals with profiles for tinted B&W inks, it
doesn't actually have features designed for that, but custom targets are an
option in high end software like that, so what it does automatically, and what
its capable of, with advanced twiddling, are different things.
What you typically do is to NOT use ProfileMaker to build the profiles if you
are using QTR; you use the EyeOne (or a PrintFIX PRO spectro, same general
process) to take measurements for QTR linearization, and for CreateICC grayscale
profiling. This does not automatically make tinted profiles, you have to get
more advanced for that.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
 See what's free at
http://www.aol.com.
2007-07-03 by Andre Vallejo da Silva
Thanks C.D. for the answer.I'll have to saty with this inks,because I
think the 1160 won't run the UT3D. But I'll probably buy the PFP when
I go to NYC in September...
André
in other
driver, in
PrintFIX
I have not
combination,
UT3D inks,
range of
> C. David Tobie
> Datacolor Inc.
> CDTobie@...
> www.colorvision.com
>  See what's free at
> http://www.aol.com.
