> Well, when I printed some 4x5" test prints, there was no problems
> with loading.
> However, this morning when I loaded an 8.5x11" sheet, the R800 passed
> the paper through the printer without printing.
> Then, I reloaded the sheet and it started to print. Then the printer
> stopped printing after about being 3/4 done, and passed the sheet
> through the printer.
> So, I've un-installed QTR and then re-installed QTR.
> I haven't tried to make a print yet, but I'll let you know later
> today when I do.
> Quick question: If you lay side_by_side Enhanced Matte and PremierArt
> 210 Dual Sided Matte, which paper is warmer in tone?
> Thanks,
> Scott
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> <paul.roark@> wrote:
> > Scott,
> > >Gotta say I love the Arches #140 Bright White HP printed on a
> > >R800 with Eboni.
> > So, it must load OK for you.
> > >What paper comes close to giving the same look as this Arches?
> > Compare MIS Alpha (Innova Soft Texture) and Arches, the last two
> graphs at
> > http://www.paulroark.com/BW-Info/R1800-No-OBA-Paper.pdf This paper
> may be
> > cheaper, but I'm, again, not sure about how well it'll load.
> > Paul
> > www.PaulRoark.com
