2400 Lights flashing
2007-11-13 by rebphoto
Hi Gang............
  Here is where I am at..............
  I ran out of yellow and light black ink in my Epson 2400.
  The printer sat for a few days (it was turned on) before
  I installed new inks.
  I am using OEM Epson ink cartridges.
  Instead of charging the inks,
  the printer is rapidly flashing the lights
  on the top two buttons.
  I have turned it off for a few minutes
  and I have tried un plugging it.
  They are still flashing.........
  HELP!
  Russ
  R.E. Baker
  Photography
  rebphoto@...
  Feed a Cat...
  Starve a Fever........
Re: [Digital BW] 2400 Lights flashing
All is well
One of the cartridges wasn't all the way in
Russ
R.E. Baker
Photography
rebphoto@...
Feed a Cat...
  Sent: Monday, November 12, 2007 11:51 PM
  Subject: [Digital BW] 2400 Lights flashing
  Hi Gang............
  HELP!
  Russ
  R.E. Baker
  Photography
  rebphoto@...
  Feed a Cat...
2007-11-13 by Harry Lockwood
Russ,
I had exactly the same experience.  The flashing lights are known as a
³fatal error.²   I hope your printer is under warranty.
The message that comes up in this condition is that there may be a foreign
object blocking travel of the print head; I assume that this is not true in
your case.  No missing socks, right?  There is one other possibility that
Epson doesn¹t mention.  Check that the ink cartridge cover is firmly snapped
in place.  If it is not, the head cannot return to its proper position.
If you¹ve passed this test, there is only one way forward: call Epson for a
replacement.  Under warranty, they will immediately ship a new
(refurbished?) printer, instructions and all materials for returning, via
FedEx, the faulty one.  Be aware that they will hold your credit card
hostage until they receive the faulty one.  I found that process
straightforward.
Good luck.
Harry
On 11/12/07 11:51 PM, "rebphoto" <rebphoto@...> wrote:
>  Hi Gang............
> HELP!
> Russ
>  R.E. Baker
>  Photography
>  rebphoto@... <mailto:rebphoto%40stny.rr.com>
> Feed a Cat...
Harry F. Lockwood
2007-11-13 by Charlie Thomson
This also occurs after a number of cleanings. The ink pad counter shuts the printer down. There is a program to reset the counter. Contact Ron at efillink for assistance. I can look it up for you. The software cost about $12.00.
Ron Luk
E-mail Address(es):
  efillinkcis@...
Charlie
  Sent: Tuesday, November 13, 2007 8:27 AM
  Subject: Re: [Digital BW] 2400 Lights flashing
  Russ,
  straightforward.
  Good luck.
  Harry
  > Hi Gang............
  > HELP!
  > Russ
  > R.E. Baker
  > Photography
  > Feed a Cat...
  Harry F. Lockwood
  Checked by AVG Free Edition.
  Version: 7.5.503 / Virus Database: 269.15.30/1125 - Release Date: 11/11/2007 9:50 PM
