Auto Test Printing during a long shutdown
2007-12-04 by David H. Miller
I'm using QTR with Jon Cone's piezography, a combination working well
for me.
But I'm going to be on a long trip in March/April and don't want my
inks to dry out.  Jon suggested there was a program to automatic print
a test sheet everyday to keep the heads unclogged, a Windows XP based
routine which is the basis of my computer.
Does anyone know about this and/or use it?  It would be very useful as
I could load in a lot of plain paper sheets and just let it run.
Other suggestions for a long shutdown would be welcomed.
Dave
Re: [Digital BW] Auto Test Printing during a long shutdown
2007-12-04 by Ernst Dinkla
> for me.
> Dave
www.inksupply.com has it on the site. MIS
Met vriendelijke groeten,Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Re: Auto Test Printing during a long shutdown
2007-12-04 by Will Clark
Dave,
  I have no direct experience with Jon Cone's inks in a long-shutdown
situation, but I can say that with Epson pigment inks in Epson
printers, it is worth my time to keep the workroom humidity adequate.
 That's not easy where I live!  I strive for a print-room humidity of
50% year-around.  It keeps the inks and paper stocks happy.
  I also make a point to not position a printer where sunlight through
a window strikes the machine causing it to heat up and dry out.
Enjoy your trip!
Bill Clark
2007-12-04 by Michael Hung
I have posted AutoNozzleCheck.zip in the Epson Wide Format group (file
area) that will trigger the Auto Nozzle Check function in Epson 4800.
I have no idea if auto nozzle check works with other inks or if the
file works with other Epson printers..
I basically created a schedule in Windows that runs every 2 days when
I am off for a long time, etc.
- M
2007-12-04 by ferdinand_paris
I read somewhere (either here or the Epson group) that wrapping the
(desktop) printer in a big plastic bag was a good idea, as humidity in
the bag should be more or less constant.  You can also include a bowl
with a wet sponge inside the bag, as long as it does not come in
contact with the printer.
I've not yet tried this for a long period, but I can't seem that it
would do any harm to the printer, and might work.
F_P
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David H. Miller"
2007-12-05 by scott_now_coming
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Michael Hung"
> - M
Hi Michael,
After extracting the files, in what folder do I install them?
I don't understand how your program work. Can you please be more
specific?
Scott
2007-12-05 by Michael Hung
There is no installer (sorry). You can extract the files in any
directory such that the file won't be removed later on..
Then start Windows scheduler and make a schedule.
The program runs as:
RawPrint.exe "printer name" AutoNozzleCheck4800.bin
(You can try type that into a Command Line window and see if it works.)
My command is:
RawPrint.exe "EPSON Stylus Pro 4800" AutoNozzleCheck4800.bin
Michael
> > - M
> Hi Michael,
> specific?
> Thanks,
> Scott
Thanks Michael, I'll give it a try. :>)
Scott
works.)
> My command is:
> Michael
Hung"
group (file
4800.
days when
> > > - M
> > Hi Michael,
> > specific?
> > Thanks,
> > Scott
