Epson R300 as B&W Printer
2009-04-12 by None
Does anyone have experience using an Epson 300 as a B&W Printer? I did not find much direct info searching the archives. On the MIS site they sell cartridges for the 200/220 and I believe they are roughly the same class of printer.
The QuadtoneRip site mentions the R300 but only in conjunction with the
Mediastreet Quadblack inks which I do not think are available any longer.
Any advice or thoughts on using this printer are welcomed.
Thank you.
Scott
Re: Epson R300 as B&W Printer
2009-04-13 by Roger
I believe it's the same printer as the R220 but accepts memory cards directly and has a screen on it.
I use the R220 myself with Paul Roark's UTR2 inkset and recommend it.  The Epson driver works fine- you don't need QTR.  If you go this route, I recommend keeping two of the slots for a warm (vs a neutral) ink as 6 neutral look quite cool to me, especially on glossy paper.
You also don't need to buy the whole inkset- buy bottles of photo black (PK), Eboni (MK), one warm and cool dark (magenta or cyan) and one warm and cool light (LC, LM) and that's all you need.
The R220 refillable carts should work- MIS' website lists all the compatible models.
Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "None" <nospam@...> wrote:
> Thank you.
> Scott
RE: [Digital BW] Re: Epson R300 as B&W Printer
2009-04-14 by nospam
Rodger,
Thank you. This is exactly the kind of information I was looking for.
Scott
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Roger
Sent: Sunday, April 12, 2009 11:12 PM
Subject: [Digital BW] Re: Epson R300 as B&W Printer
models.
Roger
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , "None"
printer.
> Thank you.
> Scott
