frankg_photo
Sent: Sunday, January 24, 2010 12:21 PM
Subject: [Digital BW] Re: Scanning B&W
Yes, it's an hourly rental.And yes, all time is charged including writing
the files (to cd).
"-120 being the actual off setting or true 0" - I wonder if anyone with an
Imacon (848) and Flexcolor 4.6 can verify this?
"a little above and below clipping points dmax and dmin" - do you mean to
keep the triangles a little off the edge of the histogram ?
Is there a place to set the gamma/midpoints other than the middle triangle
of the histogram ?
Frank
--- In DigitalBlackandWhit
eThePrint@yahoogroups.com, "E.Neilsen" <e.neilsen2@...> wrote:
> Frank, I am assuming this is an hourly rental or a day structure; 1/2 or
> full day. Besides the scanning time, are you also being charged to write
> your files to your own media? or are you hooking up your own external
drive?
> Did you give your self some test files to play with at various setting
> keeping the scanned area at the same ppi? This allows you to run a few
sets
> of tests to see what those scan software setting are doing to your images.
> I remember it (-120) being the actual off setting or true 0. I typically
> give my self a little above and below clipping points dmax and dmin, and
> highly recommend it on a rented scanner to avoid clipping. See what they
> have defaults set to but you don't want to waste time rescanning only
> because you clipped your detail some place.
> Eric Neilsen
> Eric Neilsen Photography
> 4101 Commerce Street, Suite 9
> Dallas, TX 75226
> www.ericneilsenphotography.com
> skype me with ejprinter
> _____
> From: DigitalBlackandWhit
> frankg_photo
> Sent: Saturday, January 23, 2010 8:18 AM
> We live and learn.
> I rented time and the scans are ok, but not great.
> I'll do better next time now that I'm more familiar with the interface and
> will be less panicked about maximizing my rental time at the lab. I could
> use a little more clarification from users please:
> Re: USM at -120
> I had the usm palette boxes all set to 0 (one of the usm settings, I
forget
> which, kept defaulting to 1) and indeed the grain is pronounced in some
> negs.
> Is -120 a general consensus done by empirical testing, or a rcommendation
by
> flexcolor ?
> Using photokit after - do you change mode to rgb> select Capture
sharpeer>35
> fast negative (as appropriate) > medium edge sharpen (as appropriate ?
> AF icon (auto focus?) - there is a little AF icon/button - should this be
> 'dark' or 'light/faded' ? Some scans appear a tad soft?
> Gamma - is there a place to set this to 2.2 ?
> I used the levels histogram, and found that the A (auto) worked well to
> bring the white and black points to the edges of the histogram. I could
> manually change them as well as the midpoint. And I could also change the
> midtones with Gradations/curves. But...my scans are still mostly too light
> and flat.
> I selected Greyscale 16 bit B&W negative. I figured that the film grain
> would overide a bit of noise and the benefit of rgb. The files were 100mb
> anyway as GS.
> What is the maximum Optical (non interpolated) res of the Imacon (848) - I
> used 6300ppi.
> Unfortunately there was no-one to train me just a young person that
clearly
> didn't know the answers to any of this.
> Thanks for any further clarification.
> Frank
> eThePrint@yahoogrou <mailto:eThePrint%40yahoogroups.com> ps.com, Paul Kohl
<pkohl@> wrote:
> > I use an Imacon Flextight regularly and have done tests on black and
> > white negative scanning. My results are that scanning as a greyscale
> > positive gets me the most efficient and tonally comprehensive scans,
> > as another poster recommended. One important thing is to set the
> > Texture/Unsharp masking sharpening setting to -120 or else the
> > software will sharpen the image. This sharpening will increase grain
> > presence in the image.
> > I sharpen later in PS using the Photokit sharpened plug-in.
> > The Imacon is a great machine.
> > Good luck with it.
> > Paul
