Doepfer
A-190 trouble
A-190 trouble
2006-10-09 by maise3000
hello everybody,
i have some troubles with my A-190, maybe someone can help me...
the problem is:
my a-190 doesn´t give any gate information...
the clock and the reset function are still working, but there is no other midi-information
given to the outputs.
is the another way to reset it (not mentioned in the manual-pdf) ?
if not what chip(s) do i have to change?
any advice would be very helpfull...
thanks
maise
AW: [Doepfer_a100] A-190 trouble
2006-10-09 by hardware@doepfer.de
Questions for further help:
Does the Gate LED work ?
Does the CV output work ?
Have you tried to change the Midi channel (of the Midi transmitter or the
A-190) ?
Is the bus connection (CV and Gate) of the A-190 interrupted ? This is
required only if another module that accesses the bus is used on the same
bus board (e.g. A-185) ?
If the Gate LED and the CV output are working but there is no Gate output
the module has probably to be repaired (provided that no other module has
access to same the bus).
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von maise3000
> Gesendet: Montag, 9. Oktober 2006 09:42
> Betreff: [Doepfer_a100] A-190 trouble
> hello everybody,
> the problem is:
> thanks
> maise
Re: A-190 trouble
hello Dieter Doepfer,
the gate LED does not work...
the cv output does work.
Midi settings are correct (i tried every channel...)
my a-110 is getting voltage from the bus (CV), but my adsr has no jumper (so i don´t
know).
it seems there is no gate-function at all.
clock works as it should.
thanks for the help...
best regards
maise
> A-190) ?
> Best wishes
> Dieter Doepfer
> > hello everybody,
> > the problem is:
> > thanks
> > maise
> > Yahoo! Groups Links
AW: [Doepfer_a100] Re: A-190 trouble
Very strange behaviour. I'm not the A-190 specialist in the company.
Matthias Marass is the man who is responsible for final check and repair of
the A-190. You may contact him directly: keyboards@doepfer.de. Maybe he has
an idea what can be done before sending in the device for repair.
Best wishes
Dieter Doepfer
> Gesendet: Montag, 9. Oktober 2006 15:41
> Betreff: [Doepfer_a100] Re: A-190 trouble
> jumper (so i don´t know).
> best regards
> maise
> transmitter or the
> > A-190) ?
> on the same
> Gate output
> module has
> > Best wishes
> > Dieter Doepfer
> > > hello everybody,
> > > the problem is:
> > > thanks
> > > maise
> > > Yahoo! Groups Links
