Doepfer
5V Low-Cost Adapter questions
2007-12-14 by jalmari3
I have two 5V Low-Cost Adapters (A-100AD5). I have previously used them
with A-113 and A-190 installed in separate A-100G6 cabinets.
Now I am going to put A-113 and A-190 into same cabinet. Looking at the
power consumption figures it appears, that two A-100AD5 are still
needed. Just to make to make sure, I would like to ask, how should the
A-100AD5:s be installed, when
- A-113 and A-190 are in the same row/power rail.
- A-113 and A-190 are in different rows.
Jari Jokinen
Re: 5V Low-Cost Adapter questions
2007-12-14 by selfoscillate
hello chuck,
only one ad5 is allowed per row.
as long as the total 5 volts consumption of the modules
doesn't exceed 100ma you can use more than 1 module
with the ad5. in the example below (a113 and a190)
the 5 volts consumption is 150 ma, therefore you need
two ad5.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "charles graef"
<vogelscheiss@...> wrote:
> Sorry, I'm confused -- you're saying that the A-100AD5 will only
permit one
> 5V module in the row in which it's installed?
> --Chuck
> From: Doepfer_a100@yahoogroups.com
[mailto:Doepfer_a100@yahoogroups.com] On
> Behalf Of hardware@...
> Sent: Friday, December 14, 2007 10:12 AM
> To: Doepfer_a100@yahoogroups.com
> Subject: AW: [Doepfer_a100] 5V Low-Cost Adapter questions
used them
at the
should the
> Sorry, that's not possible as only one A-100AD5 is allowed for each
bus
> board.
> That's the right solution. Simple connect one A-100AD5 on each bus
board.
> Best wishes
> Dieter Doepfer
2007-12-14 by hardware@doepfer.de
Sorry, that's not possible as only one A-100AD5 is allowed for each bus
board.
That's the right solution. Simple connect one A-100AD5 on each bus board.
Best wishes
Dieter Doepfer
Thank you for the quick replies.
Best regards
Jari Jokinen
--- In Doepfer_a100@yahoogroups.com, Florian Anwander
<Florian.Anwander@...> wrote:
> Hi
> one could add a larger cooling device to the regulator, but I
assume
> this would cause mechanical problem in transport (too much mass).
> Florian
> selfoscillate wrote:
> > hello chuck,
> > two ad5.
> > best wishes
> > ingo
> > permit one
> >>--Chuck
> >>-----Original Message-----
> >>Behalf Of hardware@
> > used them
> > at the
> > should the
each
> > bus
> >>board.
bus
> > board.
> >>Best wishes
> >>Dieter Doepfer
> > Yahoo! Groups Links
> Florian Anwander                  |ConSol
> Tel.   +49(89)45841-133           |Consulting&Solutions Software
GmbH
> Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669
München
> email: florian.anwander@... |http://www.consol.de
RE: [Doepfer_a100] 5V Low-Cost Adapter questions
2007-12-14 by charles graef
Sorry, I'm confused -- you're saying that the A-100AD5 will only permit one
--Chuck
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On
Behalf Of hardware@doepfer.de
board.
Best wishes
Dieter Doepfer
fs: A-188 tapped bbd module also a-171, a-118, a-138, a-138c
2007-12-14 by Ancient Eyeball Recipe
Excellent condition ­ I¹ve been stupid and need to round up some $.
Sells new for $290. I¹ll ship it to you (continental US) for $235.
I also have the a-171 vc slew limiter, a-118 noise/random voltage, a-138
mixer, a-138c polarizing mixer up for grabs ­ too rushed at the moment to
look up all of the new prices ­ if you can offer me about 80% of the new
price, I¹ll ship it to you for that.
Gene
Re: [Doepfer_a100] Re: 5V Low-Cost Adapter questions
2007-12-14 by Florian Anwander
Hi
one could add a larger cooling device to the regulator, but I assume
Florian
> hello chuck,
> two ad5.
> best wishes
> ingo
> permit one
>>--Chuck
> used them
> at the
> should the
> bus
>>board.
> board.
>>Best wishes
>>Dieter Doepfer
Tel.   +49(89)45841-133           |Consulting&Solutions Software GmbH
Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
bus board.
Hmm... I guess I could still put both A-113 and A-190 into (say) the
upper row, if I get power for the other module from the lower bus board
(with a longer cable, if needed). Or is there something wrong with that?
Re: A-107 multitype morphing filter question
2007-12-15 by David Bulog
http://www.doepfer.de/a107.htm
Sorry poorly worded question before
is the quality of the A-107  module good compared to Oberheim Matrix
12 which sounded a bit to thin amd digital to my ears
thanks David
On 15/12/2007, at 8:59 AM, David Bulog wrote:
> This lots really interesting---can any members give me a review
> thanks in advance
> David
Re: [Doepfer_a100] A-111-1 High-End VCO vs A-110 Standard VCO
2007-12-15 by Denis Gökdag
this depends on what you think of as "better".
the 111 is somewhat cleaner sounding and can be used at higher
frequencies more reliably. it features soft-sync and linear FM (but
you can "hack" a 110 to sport these features too, they're available
on the PCB). the 110 on the other hand has a higher output level and
a rougher sound, which can result in more "phat" at times.
personally i'm quite happy to have both in my rack.
On 15. Dec 2007, at 2:18 AM, David Bulog wrote:
> How much better is the High-End VCO compared to the standard
> thanks David
Re: A-111-1 High-End VCO vs A-110 Standard VCO
2007-12-15 by levka0
IMO, pwm in the hi freq. ranges sounds much sweeter with the A-111
For the rest, the differences apear not that great to me.
> thanks David
2007-12-15 by magneteyez
> with the ad5.
If I get this right I can use an A-190 en A-191 (total powercons. 100
mA) on one ad5 adapter without problems?
2007-12-15 by selfoscillate
> > with the ad5.
100
yes, thats how i have it in my system and it works perfectly.
best wishes
ingo
Re: [Doepfer_a100] Re: A-107 multitype morphing filter question
2007-12-17 by Florian Anwander
HI David
The filter itself is similar, but not completely identical. The
                                           "weakness" of the Matrix was
determined also by the DCOs, whilest the A100 always works with VCOs and
software-envelopes.
Florian
2007-12-17 by p. hendricks
I kinda agree, if you don't like the M12/Xpander, you may not like the 107.
I didn't care for my Xpander too much--at least for the price and space...
and same for the 107, it does a lot has a lot of potential of course, but
just didn't like it's sound either.  It's not bad, but, to many filters I'd
prefer over it.
best,
phil
> thanks David
Best practice to remove modules
2007-12-17 by David Bulog
Hi is there any documentation that tells you a safe way to unplug
modules
apart from earthing yourself the ribbon cable connection to the bus
looks quite tricky--how do I safety unplug and plug back in
thanks in advance
Dave
2007-12-17 by Bakis Sirros
hello Florian,
the A100 always works with software- envelopes?
Florian, you must have been thinking of something
else, obviously...    :-)
best regards,
Bakis.
--- Florian Anwander <Florian.Anwander@consol.de>
wrote:
> HI David
> to Oberheim Matrix
> ears
> identical. The
> works with VCOs and
> software-envelopes.
> Florian
[Doepfer_a100] group owner
http://www.myspace.com/interconnectedmusic
http://www.myspace.com/memorygeist
http://www.DiN.org.uk
http://www.musicamaximamagnetica.com
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
AW: [Doepfer_a100] Re: 5V Low-Cost Adapter questions
2007-12-17 by hardware@doepfer.de
> > with the ad5.
Yes.
Best wishes
Dieter Doepfer
> bus board.
That's possible as this module then belongs to the other bus board.
Best wishes
Dieter Doepfer
AW: [Doepfer_a100] Best practice to remove modules
> Hi is there any documentation that tells you a safe way to unplug modules
> thanks in advance
> Dave
www.doepfer.com > MANUALS > A-100 Introduction (A100_intro_e.pdf) > page 4-5
Best regards
Dieter Doepfer
Hi Bakis
 >>identical. The
 >>works with VCOs and
 >>software-envelopes.
You are right; it should read like:
"The 'weakness' of the Matrix was determined also by the DCOs (whilest
the A100 always works with VCOs) and by its software-envelopes."
Florian
