Doepfer
Happy Holidays and a Great New Year!
2016-12-25 by Bakis Sirros
hi all,
just want to wish to all of you Happy Holidays and a Great New Year!
may the new Year be full of Peace, Health and Doepfer modular creativity! :-)
best regards,
Bakis. (the group Owner)
Re: [Doepfer_a100] Happy Holidays and a Great New Year!
2016-12-25 by Jacco Ville
Hi there,
Thank you.
Merry modular Xmas.
Jacco Ville
The Netherlands
Sent from my IPhone.
> Op 25 dec. 2016 om 09:22 heeft Bakis Sirros synth_freak_2000@yahoo.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> het volgende geschreven:
> hi all,
> best regards,
Deopfer / Grids sync problem.
2016-12-27 by Nicolaj
I own a Doepfer A-190-8 midi clock sync module, and a Mutable Instruments Grids drum sequencer.
For some reason I cannot get them to sync properly to the song tempo in Cubase.
Or in other words: the tempo sync ok, but the Grids module doesn’t start in time with Cubase.
I’m not sure if it’s a problem with the Doepfer module or the Grids module, or if it has something to do with the way I’ve set the communication up between them.
I recorded a video illustrating the issue. Any help is greatly appreciated as I’ve had this issue ever since I first bought these modules.
Best regards (and happy new year) from Nicolaj.
The video is here:
https://youtu.be/4mowzjWl9sg
Re: Deopfer / Grids sync problem.
2016-12-28 by karelvanbezooijen@yahoo.com
I had exactly the same issue when running a COTK Arpeggiator, Dark Time and MAQ together. Did you also activate the Midi Timecode Destinations for your Midi ports in Cubase? For me that solved this problem.
Good luck,
Karel.
Re: [Doepfer_a100] Deopfer / Grids sync problem.
2016-12-28 by Florian Anwander
I don't  own a Grid, but I think the problem is, that the Grids expects
a reset when the clock is stopped.
In the end you were on the right track, when you pressed the reset
button, while the clock was stopped, but you did not remove the yellow
cable which additionally caused a reset while the clock was running again.
If I am right then the correct handling is like this:
* press stop in Cubase and reset Cubase to zero
* connect clock out of the A-190-8 with clock in of the Grid
* press reset on the Grid
* press start in Cubase
I am not sure, but maybe it would work too if you connect the A-190-8
stop-output with the Grids reset-input. Should be worth the test.
Florian
> The video is here:
> Posted by: Nicolaj<etc@sidestuff.dk>
> Yahoo Groups Links
2016-12-29 by Nicolaj
Thanks for your input.
I’ll try your suggestions. Of course the nicer approach would be for the Grids to sync up automatically, without me having to press any buttons.
I’ll see what works and report back.
Br, Nicolaj.
> On 28 Dec 2016, at 11.29, Florian Anwander fanwander@mnet-online.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Florian
> On 27.12.16 20:50 , Nicolaj etc@sidestuff.dk <mailto:etc@sidestuff.dk> [Doepfer_a100] wrote:
> > The video is here:
> > https://youtu.be/4mowzjWl9sg <https://youtu.be/4mowzjWl9sg>
> > Posted by: Nicolaj<etc@sidestuff.dk <mailto:etc@sidestuff.dk>>
> > Yahoo Groups Links
2016-12-29 by Florian Anwander
Hi
> automatically,
Using the A-190-8stop-output with the Grids reset-input should work
automatically.
And another approach might be to delay the clock a little bit.
Roland demands for the DIN-Sync clock sender, that the first clock tick
must come 9ms after the rising slope of the start/stop-gate. They do
this because you always first want to reset the counter and then start
triggering the counter.
Florian
AW: [Doepfer_a100] Happy Holidays and a Great New Year!
2017-01-09 by yahoo@doepfer.de
Also from my side the best wishes for the new year (belatedly as I was on
holidays until yesterday)
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Sonntag, 25. Dezember 2016 09:23
> An: Doepfer A100
> Betreff: [Doepfer_a100] Happy Holidays and a Great New Year!
> hi all,
> creativity!     :-)
> best regards,
