Doepfer
Re: A-185
Re: A-185
2005-09-27 by selfoscillate
hello bryan,
from my experience you need the a185 only when sending a
pitch cv to multiple origins, lets say you send a quantized
voltage to three vco's and a filter. as long as you use a
buffered multiple like the a185 you will be fine, but when
using an unbuffered multiple like a180 the cv voltage will
drop at a certain point and maybe your vco's will be out
of tune then.
the a185 feeds the system buss of the a100, so if you want
to use the system buss, you need the a185.
to shortly answer your question, you do not necessarily need
an a185, but sometimes it makes life a lot easier
if you have one.
hope this helps
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "Bryan E Cornell" <bcor@l...>
wrote:
> I was looking around on the Doepfer site and I noticed the a185 Bus
Access module.  I'm not clear on what it does.  If I send my Doepfer
lfo to a bunch of different sources, will the signal somehow
degrade?  I have a Doepfer suitcase system and I'm always sending the
cv's to a multiple and then off to other places in the Doepfer system
and to my other racks of Blacet/Wiard modules.  I haven't noticed
that this is a problem, but I'm not always very scientific about
analyzing my patches.
> As my modular grows will I need the a185?
> Thanks for any advice.
>  Bryan
A-185
2005-09-27 by Bryan E Cornell
I was looking around on the Doepfer site and I noticed the a185 Bus Access module.  I'm not clear on what it does.  If I send my Doepfer lfo to a bunch of different sources, will the signal somehow degrade?  I have a Doepfer suitcase system and I'm always sending the cv's to a multiple and then off to other places in the Doepfer system and to my other racks of Blacet/Wiard modules.  I haven't noticed that this is a problem, but I'm not always very scientific about analyzing my patches.
 Bryan
RE: [Doepfer_a100] A-185
2005-09-27 by unknown freak
You wouldn't use it for an LFO because the CV input on the VCOs would be
unattenuated.  For that purpose you'd use multiples.  The purpose of the 185
is to send gates to multiple EGs or a common unattenuated CV to a maximum,
probably, of 2 VCOs, e.g. from a sequencer or keyboard.  The affected
modules need to be on the same row, or you'll need a little cable that
connects the buses for two rows.
--Chuck
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On
Behalf Of Bryan E Cornell
Sent: Tuesday, September 27, 2005 10:03 AM
Subject: [Doepfer_a100] A-185
 Bryan
Re: A-185
2005-09-28 by selfoscillate
hello zoran,
the only module which uses the buss too is the a190,
but this module writes the buss instead of reading it.
basically all modules can use the system buss, but you
need a different ribbon cable and you have to solder
a connection between the cv/gate buss and the jack sockets
in question.
i own an a143/2 which responds to the gate buss,
but it is not the standard version, i ordered it
with this modification.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "Zoran Bosnjak" <dj_allin@h...>
wrote:
> Hello,
> this is a question I always wanted to ask about bus module
functionality:
> beside A-110, A-111, and A-140, are there any other modules that
can use it
> (get the signal from the bus)?
> Regards,
> Zoran
> >From: "selfoscillate" <synaptic_music@y...>
> >Reply-To: Doepfer_a100@yahoogroups.com
> >Subject: [Doepfer_a100] Re: A-185
> >Date: Tue, 27 Sep 2005 14:41:42 -0000
> >hello bryan,
> >of tune then.
> >if you have one.
> >hope this helps
> >best wishes
> >ingo
Bus
Doepfer
system
> > >  Bryan
RE: [Doepfer_a100] Re: A-185
2005-09-28 by Zoran Bosnjak
Hello,
this is a question I always wanted to ask about bus module functionality:
beside A-110, A-111, and A-140, are there any other modules that can use it
Zoran
>From: "selfoscillate" <synaptic_music@yahoo.com>
>hello bryan,
>of tune then.
>if you have one.
>hope this helps
>best wishes
>ingo
> >  Bryan
AW: [Doepfer_a100] Re: A-185
2005-09-29 by Dieter Doepfer
No. But on the A-100 DIY page you find a description how to obtain CV or
Gate from the bus for other modules.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Zoran Bosnjak
> Gesendet: Mittwoch, 28. September 2005 14:56
> Betreff: RE: [Doepfer_a100] Re: A-185
> Hello,
> can use it
> Regards,
> Zoran
> >hello bryan,
> >of tune then.
> >if you have one.
> >hope this helps
> >best wishes
> >ingo
> > >  Bryan
