Picture of board done with HP presentation paper
2009-08-11 by michael tenore
Hi! I scanned one of my recent boards to the Photo section! This was done with HP Presentation paper and applied to the Board with a GBC H535 Laminator Board is 4.5 x 6.5 inches .062 thick.. http://groups.yahoo.com/group/Homebrew_PCBs/photos/album/1613902738/pic/1067172535/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc The board has been etched and drilled but the toner was not stripped off yet.. I will post again when I strip the toner! You can see how nice it came out. regards mike..
2009-08-11 by Mike Phillips
Hi Mike, That 535 laminator has 4 rollers and can go up to 40 feet/min. I have some questions about your process. 1) How long does it take to pass a letter size sheet of paper through lengthwise? My 310 takes 51 seconds. 2) How many passes did the board require through the laminator? 3) Any mods to the laminator? 4) Is the board double sided copper? 5) What temp did your laminator show on the LCD at the time of laminating? 6) Ever measured the roller temperatures? Thanks! Mike --- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@...> wrote:
> > > Hi! > > I scanned one of my recent boards to the Photo section! > This was done with HP Presentation paper and applied to the Board with a GBC H535 Laminator > Board is 4.5 x 6.5 inches .062 thick.. > > http://groups.yahoo.com/group/Homebrew_PCBs/photos/album/1613902738/pic/1067172535/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc > > The board has been etched and drilled but the toner was not stripped off yet.. > > I will post again when I strip the toner! You can see how nice it came out. > > regards > > mike.. >
I meant 40 inches per minute.... Mike --- In Homebrew_PCBs@yahoogroups.com, "Mike Phillips" <mikep_95133@...> wrote:
> > Hi Mike, > > That 535 laminator has 4 rollers and can go up to 40 feet/min. I have some questions about your process. > > 1) How long does it take to pass a letter size sheet of paper through lengthwise? My 310 takes 51 seconds. > > 2) How many passes did the board require through the laminator? > > 3) Any mods to the laminator? > > 4) Is the board double sided copper? > > 5) What temp did your laminator show on the LCD at the time of laminating? > > 6) Ever measured the roller temperatures? > > Thanks! > > Mike > > > > --- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@> wrote: > > > > > > Hi! > > > > I scanned one of my recent boards to the Photo section! > > This was done with HP Presentation paper and applied to the Board with a GBC H535 Laminator > > Board is 4.5 x 6.5 inches .062 thick.. > > > > http://groups.yahoo.com/group/Homebrew_PCBs/photos/album/1613902738/pic/1067172535/view?picmode=&mode=tn&order=ordinal&start=1&count=20&dir=asc > > > > The board has been etched and drilled but the toner was not stripped off yet.. > > > > I will post again when I strip the toner! You can see how nice it came out. > > > > regards > > > > mike.. > > >
2009-08-11 by DJ Delorie
Interesting question - strip toner first, or drill first? I'd think the burrs from the drilling would interfere with the toner removal.
Ok I use the slowest speed. a full sheet takes about a minute I used 10 -11 passes thru the laminator the laminator is not modified the board is single sided g-10 .062 thick 4.5x 6.5 inches .these boards dissipate a lot of heat so more passes with the board being re-fed through is necessary to keep the board temp up. I have some .032 boards but I have not put them through it yet. My LCD says 328 degrees .I have not measured the temp as I do not have a temp probe. regards mike ________________________________
Sent: Tuesday, August 11, 2009 11:50:33 AM
Subject: [Homebrew_PCBs] Re: Picture of board done with HP presentation paper
Mike
--- In Homebrew_PCBs@ yahoogroups. com, "Mike Phillips" <mikep_95133@ ...> wrote:
> Hi Mike,
> Thanks!
> Mike
> --- In Homebrew_PCBs@ yahoogroups. com, michael tenore <wb2lcw@> wrote:
> > Hi!
> > http://groups. yahoo.com/ group/Homebrew_ PCBs/photos/ album/1613902738 /pic/1067172535/ view?picmode= &mode=tn& order=ordinal& start=1&count= 20&dir=asc
> > regards
> > mike..
[Non-text portions of this message have been removed]2009-08-11 by michael tenore
I usually drill before stripping ! It makes it easier to spot center the hols when I drill with my dremel drill stand.. ________________________________
Sent: Tuesday, August 11, 2009 12:00:41 PM
Subject: Re: [Homebrew_PCBs] Picture of board done with HP presentation paper
[Non-text portions of this message have been removed]2009-08-11 by Mike Phillips
Your laminator has a lot of heat capacity compared to mine. I use double sided boards that take longer to heat. Although 10 passes might render any differences a mute issue. My latest board is about 4 x 5. So we have about the same heat load minus one side of copper. My Model Aviation magazine paper and the Presentation paper I've tried end up about the same quality. The magazine paper dissolves easier since it's so much thinner. Have you ever tied any Photographic paper? Mike --- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@...> wrote:
> > Ok > > I use the slowest speed. a full sheet takes about a minute > > I used 10 -11 passes thru the laminator > > the laminator is not modified > > the board is single sided g-10 .062 thick 4.5x 6.5 inches .these boards dissipate a lot of heat so more passes with the > board being re-fed through is necessary to keep the board temp up. I have some .032 boards but I have not put them through it yet. > > My LCD says 328 degrees .I have not measured the temp as I do not have a temp probe. > > regards > > mike > > > > > > > ________________________________ > From: Mike Phillips <mikep_95133@...> > To: Homebrew_PCBs@yahoogroups.com > Sent: Tuesday, August 11, 2009 11:50:33 AM > Subject: [Homebrew_PCBs] Re: Picture of board done with HP presentation paper > > > I meant 40 inches per minute.... > > Mike > > --- In Homebrew_PCBs@ yahoogroups. com, "Mike Phillips" <mikep_95133@ ...> wrote: > > > > Hi Mike, > > > > That 535 laminator has 4 rollers and can go up to 40 feet/min. I have some questions about your process. > > > > 1) How long does it take to pass a letter size sheet of paper through lengthwise? My 310 takes 51 seconds. > > > > 2) How many passes did the board require through the laminator? > > > > 3) Any mods to the laminator? > > > > 4) Is the board double sided copper? > > > > 5) What temp did your laminator show on the LCD at the time of laminating? > > > > 6) Ever measured the roller temperatures? > > > > Thanks! > > > > Mike > > > > > > > > --- In Homebrew_PCBs@ yahoogroups. com, michael tenore <wb2lcw@> wrote: > > > > > > > > > Hi! > > > > > > I scanned one of my recent boards to the Photo section! > > > This was done with HP Presentation paper and applied to the Board with a GBC H535 Laminator > > > Board is 4.5 x 6.5 inches .062 thick.. > > > > > > http://groups. yahoo.com/ group/Homebrew_ PCBs/photos/ album/1613902738 /pic/1067172535/ view?picmode= &mode=tn& order=ordinal& start=1&count= 20&dir=asc > > > > > > The board has been etched and drilled but the toner was not stripped off yet.. > > > > > > I will post again when I strip the toner! You can see how nice it came out. > > > > > > regards > > > > > > mike.. > > > > > > > > > > > > > [Non-text portions of this message have been removed] >
Yes! I have used Staples photo basic gloss works well also bu it is harder to get off than the HP paper ________________________________
Sent: Tuesday, August 11, 2009 12:44:47 PM
Mike
--- In Homebrew_PCBs@ yahoogroups. com, michael tenore <wb2lcw@...> wrote:
> Ok
> regards
> mike
> ____________ _________ _________ __
> From: Mike Phillips <mikep_95133@ ...>
> To: Homebrew_PCBs@ yahoogroups. com
> Mike
> > Hi Mike,
> > Thanks!
> > Mike
> > > Hi!
> > > regards
> > > mike..
[Non-text portions of this message have been removed]2009-08-14 by William Alford
http://www.instructables.com/id/Sponge-Ferric-Chloride-Method-Etch-Circuit-Bo/ William Alford GI Motility Medical Research Page http://alford.grimtrojan.com/ [Non-text portions of this message have been removed]
2009-08-14 by sailingto
I usually drill a few holes before etching to allow getting the backside lined up good (on double sided boards), then drill all the other thru holes after etching. I leave a small "etched" space in the center of each pad that will have a hole drilled - this seems to help center the drill point for drilling. 73 de Ken H> --- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@...> wrote:
> > I usually drill before stripping ! It makes it easier to spot center the hols when I drill with my dremel drill stand.. > > ________________________________ > From: DJ Delorie <dj@...> > To: Homebrew_PCBs@yahoogroups.com > Sent: Tuesday, August 11, 2009 12:00:41 PM > Subject: Re: [Homebrew_PCBs] Picture of board done with HP presentation paper > > Interesting question - strip toner first, or drill first? I'd think > the burrs from the drilling would interfere with the toner removal.
2009-08-14 by roycepipkins
The article doesn't say it, but the extreme speed only works with 1/2 oz boards. I tested the method on my 1 oz copper and found that it shaved only a few minutes off the etch time for a *whole lot* more work in scrubbing than just watching the boards agitate. For 1 oz copper, I found that the increased work overshadowed the minor speed increase for a net negative experience. Regards, Royce --- In Homebrew_PCBs@yahoogroups.com, William Alford <walford@...> wrote:
> > > http://www.instructables.com/id/Sponge-Ferric-Chloride-Method-Etch-Circuit-Bo/ > > William Alford > > GI Motility Medical Research Page > http://alford.grimtrojan.com/ > > [Non-text portions of this message have been removed] >
2009-08-14 by DJ Delorie
William Alford <walford@...> writes: > http://www.instructables.com/id/Sponge-Ferric-Chloride-Method-Etch-Circuit-Bo/ Yup, this is the standard Pulsar method (as noted in the instructable), and the whole reason behind the Green TRF. With preheated FeCl, a sponge, and 1/2oz copper, I can etch a board in about 45 seconds. You can also focus on underetched parts so you don't have to overetch elsewhere to get good results. My way was to half fill a 1 gal bucket with hot tap water, slightly loosen the cap on the FeCl bottle (to allow for air expansion), and put the bottle in the bucket. By the time I'm done putting the resist on, the FeCl is hot, and I pour it into my usual etch tray. I then hold the board over the tray and dip the sponge into the etchant, wipe a few times, dip, wipe (not scrub!), etc. The dipping replaces the used etchant with fresh etchant, and keeps the sponge warm.
2009-08-14 by Mike Phillips
Great info DJ, thanks! Mike --- In Homebrew_PCBs@yahoogroups.com, DJ Delorie <dj@...> wrote:
> > > William Alford <walford@...> writes: > > http://www.instructables.com/id/Sponge-Ferric-Chloride-Method-Etch-Circuit-Bo/ > > Yup, this is the standard Pulsar method (as noted in the > instructable), and the whole reason behind the Green TRF. With > preheated FeCl, a sponge, and 1/2oz copper, I can etch a board in > about 45 seconds. You can also focus on underetched parts so you > don't have to overetch elsewhere to get good results. > > My way was to half fill a 1 gal bucket with hot tap water, slightly > loosen the cap on the FeCl bottle (to allow for air expansion), and > put the bottle in the bucket. By the time I'm done putting the resist > on, the FeCl is hot, and I pour it into my usual etch tray. I then > hold the board over the tray and dip the sponge into the etchant, wipe > a few times, dip, wipe (not scrub!), etc. The dipping replaces the > used etchant with fresh etchant, and keeps the sponge warm. >
2009-08-14 by Malcolm Parker-Lisberg
Has anyone tried this method for chemical machining. I am making some encoder disks for the digital DC servos I am building and was going to use conventional dip FeCl bath. Is the undercutting any less? --- On Fri, 8/14/09, DJ Delorie <dj@...> wrote:
Subject: Re: [Homebrew_PCBs] instructables 1 min PC etch using sponge & FeCl
Date: Friday, August 14, 2009, 4:17 PM
William Alford <walford@dbtech. net> writes:
> http://www.instruct ables.com/ id/Sponge- Ferric-Chloride- Method-Etch- Circuit-Bo/
instructable) , and the whole reason behind the Green TRF. With
[Non-text portions of this message have been removed]2009-08-14 by Kim Vellore
Wondering why this would be faster than dipping the board in FeCl Kim
> > > --- In Homebrew_PCBs@yahoogroups.com, William Alford <walford@...> wrote: >> >> >> http://www.instructables.com/id/Sponge-Ferric-Chloride-Method-Etch-Circuit-Bo/ >> >> William Alford >> >> GI Motility Medical Research Page >> http://alford.grimtrojan.com/ >> >> [Non-text portions of this message have been removed]
"Kim Vellore" <kimvellore@...> writes: > Wondering why this would be faster than dipping the board in FeCl Read the Pulsar site for the full details, but basically, the key is that the "spent" FeCl is quickly replaced by "fresh" FeCl at the copper surface. You get similar results with spray etching, for the same reason. When FeCl hits copper, it quickly reacts - but leaves the spent FeCl there, blocking further reaction. The faster you can get the spent FeCl away from the copper, the faster the etch goes.
Malcolm Parker-Lisberg <mparkerlisberg@...> writes: > Has anyone tried this method for chemical machining. I am making > some encoder disks for the digital DC servos I am building and was > going to use conventional dip FeCl bath. Is the undercutting any > less? http://www.delorie.com/pcb/brass/
2009-08-15 by Malcolm Parker-Lisberg
Thanks for the link, so the speed is determined by presenting fresh etchant continuously. Any thoughts on what affects the undercutting? --- On Fri, 8/14/09, DJ Delorie <dj@...> wrote:
Date: Friday, August 14, 2009, 6:10 PM
Malcolm Parker-Lisberg <mparkerlisberg@ yahoo.com> writes:
> less?
http://www.delorie. com/pcb/brass/
[Non-text portions of this message have been removed]2009-08-15 by Adam Seychell
Kim Vellore wrote: > > > Wondering why this would be faster than dipping the board in FeCl > > Kim Unlike persulfates, the FeCl3 and CuCl2 etch reactions produce relatively insoluble copper(I) chloride at the surface, which acts as a barrier for further etching. Because its a precipitate (as opposed to ions), it doesn't easily diffuse into the bulk solution. You can see this copper(I) chloride as streaks of white solid when you pull the copper out of etchant and hold it for 30 seconds. From my experience, I found there isn't much speed improvement between decent bubble assisted agitation and manual brushing the PCB surface. Adam
2009-08-16 by DJ Delorie
Malcolm Parker-Lisberg <mparkerlisberg@...> writes: > Thanks for the link, so the speed is determined by presenting fresh > etchant continuously. Any thoughts on what affects the undercutting? Well, the metal is 2 mil thick, so you get 2 mil of undercutting. Once you've started etching through, the sides of the hole are exposed to etchant also. I suspect undercutting can be reduced by preferentially etching through rather than aside, such as a spray etcher or a float etch, which simply removes the spent etchant in "that" direction more than in the "other" directions. Etching from both sides can, of course, cut undercutting in half. If you can align the two masks properly.
2009-08-17 by Steve
Please start a new thread by starting a new message. When you try to start a thread by replying to another message, even when you delete everything visible from the old, it still contains unseen info that Yahoogroups links to the other thread. http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/23392 Steve Greenfield your friendly neighborhood moderator --- In Homebrew_PCBs@yahoogroups.com, William Alford <walford@...> wrote:
