CMYK color separation to print in Black on clear film for positive
2015-07-06 by sunnyalanoly@...
2015-07-07 by donsbryant@...
2015-07-08 by sunnyalanoly@...
2015-07-08 by Roy Harrington
---In QuadtoneRIP@yahoogroups.com, wrote :>>>Yes it is possible to print CMYK separations in QTR. Of course the separations will have to be generated in Photoshop. Assuming you start with a negative image you will need to Invert the original file to a positive before generating the CMYK files.<<<<
Photoshop has limited infrastructure for RIPing, color-separating work. Hence ppl use specialised RIP software to RIP CMYK images.
But to color-sep the CMYK file in to 4 positives of C, M,Y and K, in deep black color tonal range, we need a SOftware.
I thought this Forum must have solutions and QTR an all black system, will have specific steps to color-sep a normal CYMK file to half tone positives.....
I request more insights in this field, how it can be done.
Thank you dongba...
2015-07-09 by sunnyalanoly@...
2015-07-09 by Ernst Dinkla
Hi Roy,
Thank you for coming for help.
If you couldnt understand my requirement, please take a minute to read the below description on "FilmMaker" RIP of Cadlink Corporation. It is just for informative purpose alone.
Yes, you are correct, it involves separating of CMYK channels in HALFTONE dot pattern, and get those 4 channels printed on clear film using an Epson Sylus printer in maximum Depth of BLACK, to be used to expose screen frames for silk screen printing.
Here, there must be provision for different sizes/ shapes and diff. angles and sharpness of dotes.
I dont know, how far QTR can deliver, but I am sure if you give a try to streamline these features too, so that you can get another set of customer base: CMYK halftone printing clients: they are in 10000s + !!
The FilmMaker Difference | CADlink Technology CorporationThe FilmMaker Difference | CADlink Technology Corpor...The FilmMaker Difference The latest version of FilmMaker provides the best quality and value in the inkjet film separation RIP software category. No o...Preview by Yahoo
2015-07-09 by Roy Harrington
Hi Roy,
2015-07-10 by Sunny Alan
Your observation is correct in terms if you want to stick on with Inkjet printing only, yes QTR is made for it and fulfilling its mission as a gift, as a low cost solutio
Halftone printing is for mass-production printing.
My attempt is if I can make use QTR to print black half-toned channels. But think half toning is not in the purview of it, no algorithm for this end with it. Natural, when considering its fiefdom.
I looked at FilmMaker a little. It's pretty different. Inkjet printers really aren'tfor Halftones -- they do stochastic (random) dots to produce levels of gray/color.Seems FilmMaker simulates halftones but at a loss of resolution and levels.If that's what you want then I guess the easiest is buying FilmMaker. Mostdrivers aren't going to go that route.RoyOn Thu, Jul 9, 2015 at 12:50 AM, sunnyalanoly@... [QuadtoneRIP] <;QuadtoneRIP@yahoogroups.com> wrote:
Hi Roy,
