bcr2000 problem in cubase. Please help me.
2008-09-03 by joakim777el
I have a problem, houston!
I program a plugin (f.ex a blockfish) with genetic remote. And I
export it(just to make sure it dont go away). And I have choosen the
settings to be selectable so I can use the blochfish on several
tracks wit the same controls. As long as I have choosen that track.
And it works pretty well.
But when I close the project and enter another one, I open the
blockfish and it says not assigned on the control I JUST assigned.
Very irritating..
And is it a way that when I have two instances of blochfish on two
differerant tracks. That the lightsdiods/settings can follow when I
switch tracks. It`s not so cool to turn the knobs and you want to
make a minor adjustment and it suddenly jumps to the settings in the
previous track.
Got the bcr2000 yesterday and I like it!
Guess I just have to learn how to use it properly.
Peace!
Joakim
Re: bcr2000 problem in cubase. Please help me.
2008-09-04 by joakim777el
Was the question to stupid?
Could not find the answer searching the forum.
Any links replys would be nice.
> Very irritating..
> previous track.
> Peace!
> Joakim
2008-09-04 by rpcfender
Hi Joakim
Sorry about the silence, I guess there aren't many Cubase users out
there so I have a stab at the problem.
Unfortunately I don't use Cubase or Blockfish (free VST Compressor),
but it sounds like a problem with Cubase or the VST not the BCR.
Does Cubase set the controller on a project by project basis?
If this is true then you should set up a template that has all the
stuff connected and when you want to start a new piece load it and do
a Save As before you start doing any thing else. (Backing it up is
also probabaly a good thing as well)
Royce
> the
> > Very irritating..
> the
> > previous track.
> > Peace!
> > Joakim
2008-09-08 by joakim777el
Well. Thank you for answering anyway!
I have gotten things to work like I wanted now. So that is cool.
Exept ONE thing. Programming VST`s..
If I set up a voxengo gliss eq on slot 1 in the cubase insert. And
program it so everything works. I can still just control the eq while
it is in slot 1. This can be a problem for me since I almost never
use the same plugins after eachother. Sometimes I compress before eq,
and sometimes the other way.
So my question is.. How can I program a plugin to work in slots 1-8
on the insert? And then I mean with the same controls.
thank you so much!
Joakim
--- In bc2000@yahoogroups.com, "rpcfender" <rpcfender@...> wrote:
> Hi Joakim
do
> Royce
I
choosen
> > the
track.
assigned.
> > > Very irritating..
two
when I
to
in
> > the
> > > previous track.
> > > Peace!
> > > Joakim
2008-09-09 by goyya76
Hi Joakim (and Royce) - Cubase user here, i ran into the same problem
lots of time ago and....unfortunately there's no way to overcome it
with cubase ONLY!
When you set up the Generic Remote using plugin XYZ (say, with 10
parameters) on slot 1, you are actually assigning CCs to the first
ten parameters of WHATEVER plugin you load in insert 1 - if you
replace XYZ with plugin ABC (for example, with 12 parameters) , the
map you created for XYZ will control the first 10 parameters ONLY of
plugin ABC.
If you have a look at the .xml file created when you save the generic
remote, you will see there's no reference to XYZ, but only to slot 1 -
 cubase actually assigns controllers to param 1,2,...,N of
the "generic" plugin loaded in insert 1 (N being...for example, the
32 knobs, or whatever!).
You could create eight Generic Remote banks (INS1, INS2 etc), which
is pretty simple if you look&edit the xml file (much better than
using the setup page for the Generic Remote....)
CCs can be assigned to bank up/bank down commands and also to
SPECIFIC banks (so you could use BCR buttons to select the correct
bank) - also, you can set up TWO generic remotes with the same set of
CCs: this way you can assign the SAME controller to different action
(so the same button can OPEN the vst GUI and at the same time select
the correct bank)
The remaining issue is that a knob's "name" depends on the plugin:
encoder 1 may be threshold for the compressor on slot 1 and chorus
rate on slot 2, or threshold for compressor X and make up gain for
compressor Y....and of course each plugin has his own list of
parameters, and two FX of the same kind often have different
parameters - almost always in a different order!
that's the workaround i found: use www asseca com mGUI to wrap your
vst (youcan give them a new BCR like GUI and change the order of
parameters, so you get everything done with visual feedback)...
i hope it helps, at the moment i'm at work so....i'll tell you about
mGUI in episode 2!
Take care,
Francesco
while
eq,
> thank you so much!
> Joakim
> --- In bc2000@yahoogroups.com, "rpcfender" <rpcfender@> wrote:
> > Hi Joakim
out
Compressor),
and
> do
> > Royce
And
> I
> choosen
> > > the
several
> track.
> assigned.
> > > > Very irritating..
on
> two
> when I
want
> to
> in
> > > the
> > > > previous track.
> > > > Peace!
> > > > Joakim
2008-09-10 by joakim777el
Thank you so much!!
This is awsome information!
Have`nt had a chance to try it out yet, but I will let you know when
I have.
Peace!
Joakim
problem
> with cubase ONLY!
of
> plugin ABC.
generic
1 -
of
action
select
> the correct bank)
about
> mGUI in episode 2!
> Take care,
> Francesco
And
> while
never
> eq,
8
> > thank you so much!
> > Joakim
> > > Hi Joakim
> out
> Compressor),
> and
> > do
is
> > > Royce
> And
> > I
> > choosen
> > > > the
> several
that
> > track.
> the
> > assigned.
> > > > > Very irritating..
> on
> > two
follow
> > when I
> want
> > to
settings
> > in
> > > > the
> > > > > previous track.
> > > > > Peace!
> > > > > Joakim
2008-09-11 by goyya76
i'm happy to see it's useful...it took me months to understand and
set up things on cubase, it's time to share the info (unfortunately i
couldn't find the time to write something more comprehensive about
it)!
also you can give a look at www.midevice.com - they too have a
wrapper, i tried the first version and didn't like it, but the new
one could deserve a try (just my opinion, of course!)
good luck :)
> Thank you so much!!
when
> I have.
> Peace!
> Joakim
> problem
it
> > with cubase ONLY!
first
> of
> > plugin ABC.
> generic
slot
> 1 -
which
correct
set
> of
> action
> select
> > the correct bank)
plugin:
chorus
for
your
> about
> > mGUI in episode 2!
> > Take care,
> > Francesco
> And
> > while
> never
before
> > eq,
1-
> 8
> > > thank you so much!
> > > Joakim
> > > > Hi Joakim
users
> > out
> > Compressor),
BCR.
all
> the
it
> > and
> > > do
up
> is
> > > > Royce
remote.
> > And
> > > I
> > > choosen
> > > > > the
> > several
> that
> > > track.
open
> > the
> > > assigned.
> > > > > > Very irritating..
blochfish
> > on
> > > two
> follow
> > > when I
> > want
> > > to
> settings
> > > in
> > > > > the
> > > > > > previous track.
> > > > > > Peace!
> > > > > > Joakim
