Hi, Terry!
The instructions would depend a lot on the sequencer you're using, and probably on the piano, too. I don't have one of those new Mark IV's with their fancy internet connections. :-). My connection to the computer is through wired MIDI. My XP sp2 computer has a MIDI interface that exposes a MIDI in & MIDI out. I connect my piano's MIDI out to the interface's MIDI in, and the piano's MIDI in to the interface's MIDI out. Then, from the sequencer, it sees the piano's MIDI connection like it would any other MIDI device. Is that similar to how your wireless connection works? Also, what kind of sequencer do you run? If it's not Cakewalk, I wouldn't be able to give you specific instructions that work for you.
Dave
From: disklavier@yahoogroups.com [mailto:disklavier@yahoogroups.com] On Behalf Of yeloc2
Sent: Sunday, August 31, 2008 10:56 AM
To: disklavier@yahoogroups.com
Subject: [disklavier] Re: Video of Disklavier with cool computer MIDI effects
Thanks for that video Dave. Can you post or send me step by step
instruction on how to do the midi tricks. I am connected via wireless
router, running xp sp2
Thanks
Terry
-- In disklavier@yahoogroups.com<mailto:disklavier%40yahoogroups.com>, David Broman <davbr@...> wrote:
> Hi, everybody.
> If you're curious what kinds of weird and fun things you can do
when you hook up your Disklavier to a computer, you might enjoy this
video I uploaded:
> http://www.youtube.com/watch?v=-OF-U744FqQ
> As I play each note, the MIDI out gets routed to a computer
sequencer, running a delay octave MIDI effect, with its MIDI out
routed back into the Yamaha Disklavier. This causes every keypress
to be duplicated down several octaves, with delays between each
note. I used Cakewalk Pro Audio 9 with one of its built-in MIDI
effects, but I'm sure most decent sequencers will be able to do this
and other fun things.Show quoted textHide quoted text
> Hope you enjoy!
> David Broman
