On Oct 21, 2012, at 9:44 PM, Bill Brandom wrote:
> Hi Carol,
> This is the piano with PWM OVER message, not the HS GS message. I think athomik is correct in his assessment.
> Bill
> On Oct 21, 2012, at 6:34 PM, Carol Beigel <carol@...> wrote:
>> I think Bill Brandom is on the right track. Probably the key sensor is bent of fell off the key. A piano technician could pull the action and check. Do a Record and Playback test and see if the note records. Play back transposing one note to be sure. Does the note play when a Yamaha Pianosoft disk is played? Transpose? Then maybe the solenoid is sticking. When the piano action is out of the piano, pull it out, wipe it off with a dust free clean cloth and put it back. Also check for foreign objects that fell into the piano action.
>> Carol Beigel
>> On Oct 21, 2012, at 4:22 PM, athomik wrote:
>>> You will need to get an engineer to have a look at the piano. There is probably a fault with the key or pedal drive (e.g. solenoids, drive circuits, etc)
>>> athomik
>>> On Oct 21 2012, mhuss1 wrote:
>>> >Don't know if this will help troubleshoot---I do get the following message when I turn on the control unit: "Piano Power Off! (PWM Over)" Does this ring a bell with anybody? Thanks!
>>> >--- In disklavier@yahoogroups.com, "mhuss1" wrote:
>>> >> Julien, Thanks much for the tip. I did disconnect the power, but, unfortunately, no "playing" when I powered everything back up.
>>> >> --- In disklavier@yahoogroups.com, Julien Roche wrote:
>>> >> > Disconnect completly the piano from electricity, wait 1 minute and connect again ! Goo luck ...
>>> >To Post a message to the group, send it to: disklavier@...
>>> >To Post a private message to Todd Muncy, the group's founder and moderator, send it to:
>>> >disklavier-owner@...
>>> >To reach our group's web site go to:
>>> >http://Yahoogroups.com/group/disklavier
>>> >THINKING OF LEAVING THE GROUP?
>>> >If you are thinking of unsubcribing because you are getting too much mail, go the the web site and change your email delivery option instead. That will fix the problem, while maintaining your access to the group. If you insist on leaving us completely send a blank email to:
>>> >disklavier-unsubscribe@...
>>> >Know someone who wants to join? Have them send a blank email to:
>>> >disklavier-subscribe@... or give them this link:
>>> >http://Yahoogroups.com/group/disklavier/join
>>> >Yahoo! Groups Links
