Emax
New member : ) - Questions...
2008-04-12 by nung242
Hello all,
 I am a new member and new owner of an EMAX 2 SE keyboard.
I found EMXP and was able to create an o/s disk with 2.14. I had to replace the floppy drive ( I re-soldered a new floppy to DS00 like the post described ) it works great. Here are my problems:
I can boot the EMAX and access the menus and such. But when I try to format a new disk with the EMAX, it says " Different software rev."
I have tried to copy the poly800 EMAX bank to a floppy with EMXP, but it says that the disk was not formated for that type of file. ( I made sure to specify the type of sampler in the menu before I formated the floppy.) I am using dd/ds 720k verbatim floppies.
Thanks for any help, I know you guys are the masters of this wonderful sampler.
Jason
Do You Yahoo!?
http://mail.yahoo.com
Re: New member : ) - Questions...
2008-04-12 by esynthesist
Hi there, welcome in the wonderful EMAX world !
So you have an EMAX 2 SE. Mmmm, either you have an EMAX SE (EMAX 1)
or you have the EMAX-II (which always includes SE, so it's not
specified in the type name).
Since the menus seems to work on your EMAX with OS 2.14, you probably
have an EMAX-II.
I assume you don't have a harddisk ? This means the EMAX needs to
access the floppy disk all the time to load pieces of the OS which
are required for the menu items you request. You know, the EMAX
doesn't keep its full OS in memory, it only loads parts of it,
depending of the function you request in the menu.
So when you boot the EMAX-II with an OS 2.14 disk, and then you want
to format another disk, make sure you keep the OS 2.14 floppy disk in
the drive until the moment of actual staring to format the other
disk. Because the EMAX first has to load the software module for
formatting disks from the original OS 2.14 disk. When you already
switched disks too early (with the one to be formatted) the EMAX
tries to find its OS on the new disk, doesn't find it of course, and
hence thinks the disk contains a wrong OS and can not load its
software. That's probably the cause of the error message.
When you want to copy the POLY800 bank to a disk with EMXP, make sure
that the disk in the PC's floppy drive has first been formatted for
EMAX usage before copying banks to it. You can do that with EMXP
itself (another menu item) of on the EMAX-II (but hey, you tried that
already... unsuccessfully :-)
I hope this helps !
///E-Synthesist
--- In emax@yahoogroups.com, nung242 <nung242@...> wrote:
> Hello all,
wonderful sampler.
> Jason
> Do You Yahoo!?
Re: [emax] Re: New member : ) - Questions...
Yes, its an emax 2, sorry about the verbage. hehe
I cant get past picking format disk, it gives me the
error on "bird run", and a few other choices it say "
different software rev. "
I formated the disk with EMXP, and I have a question
about that. Can I use the EM1/EB1 format directly in
the EMAX 2, or do I need to use the converter in EMXP
to change it to a EM2/EB2? I format the disk in EMXP,
then when I try to copy a an image to the floppy, it
stops after a second and says " this disk is most
likely not formatted to the specified sampler format"
 ( I made sure to specify EMAX 2  at the beginig)
Sorry to be such an newb.
I have an internal HD ( scsi quantum/apple 250mb set
as scsi1, but it keeps saying its not an emax disk
when I use drive select to chose it, the person I
bought it from said it was set up as an emax disk
already with sample banks pre installed.)  go figure.
Thanks! PS - My day job is IT, you can get deeper
technically if need be. hehe
> EMAX SE (EMAX 1)
> so it's not
> 2.14, you probably
> have an EMAX-II.
> EMAX needs to
> of the OS which
> know, the EMAX
> parts of it,
> and then you want
> 2.14 floppy disk in
> format the other
> software module for
> When you already
> formatted) the EMAX
> it of course, and
> not load its
> message.
> been formatted for
> that with EMXP
> hey, you tried that
> I hope this helps !
> ///E-Synthesist
> wrote:
> > Hello all,
> keyboard.
> with 2.14. I had to
> floppy to DS00 like
> problems:
> But when I try
> floppy with EMXP,
> type of file. ( I
> before I
> floppies.
> masters of this
> wonderful sampler.
> > Jason
> > Do You Yahoo!?
> protection around
> removed]
Do You Yahoo!?
2008-04-13 by nung242
Ok, I have answered most of my questions with persistance, hehe.
It does read EM1 files, the HD that I have is not formated, and EMXP is working for me. : )
I have loaded some banks from the file downloads here, and have a big, happy smile.
Another happy EMAX owner...
