Emax
Emax Rack - no sound..or barely any
2010-02-25 by leavesstillgreen
So I just purchased an Emax SE HD rack.
Problem -
When amplified an enormous amount I can hear what sounds like samples playing and the pitch tracks with the midi notes, but it is barely audible.
The volume slider has no effect on the barely audible noises I'm hearing.  (calibrated volume slider with no results)
I've plugged an external synth into the sample input and can also barely hear it when the emax is amplified a lot.  Interestingly, I can still hear this even when the emax is not turned on.
So are there any tests I can do to diagnose the exact problem?
When plugging into the sample input, should I be able to hear whatever is being fed into it easily?  I'm very unfamiliar with how one should work.
Is it possible one of the foot pedal inputs is affecting the volume at all times even for the sample input?  (I had an issue like this with my memorymoog)
These functions seem to be working...
- loads up from floppy disk and loads presets (hard drive doesn't work)
- ran midi diagnostics and it is receiving midi correctly
- all buttons on front panel are working properly
Thanks in advance for any help!  I really really appreciate it!
-RJ
Re: [emax] Emax Rack - no sound..or barely any
2010-02-25 by jammie
it sounds like the voice board is shot needs servicing
this needs to be examined by a repair tech as there are many things that could be wrong and neads extensive testing on conponent level
  To: emax@yahoogroups.com
  Sent: Thursday, February 25, 2010 5:25 PM
  Subject: [emax] Emax Rack - no sound..or barely any
  Problem -
  -RJ
  Checked by AVG - www.avg.com
  Version: 8.5.435 / Virus Database: 271.1.1/2708 - Release Date: 02/24/10 19:34:00
Re: Emax Rack - no sound..or barely any
yikes..exactly what i didn't want to hear :(
How would a synth tech diagnose it?  Is it something I could try to do with a voltmeter?
>   ----- Original Message -----
>   From: leavesstillgreen
>   Problem -
>   -RJ
Re: [emax] Re: Emax Rack - no sound..or barely any
yes and no you need an oscillascope and a logic anyliser to make sure all the logic chips are working properly and the oscilascope for testing waveforms and power functions i can help a bit when things are specific like with the control off the filters recently were i said it was the cv dac that was at fault
but he had full sound just no control with yours it could be various things there a lot of logic chips for the control of the analog voice board but also theres the 12bit dacs that could be at fault i would need to have the machine for testing to
diagnose properly
  Sent: Thursday, February 25, 2010 6:37 PM
  Subject: [emax] Re: Emax Rack - no sound..or barely any
  > Problem -
  > -RJ
  Version: 8.5.435 / Virus Database: 271.1.1/2709 - Release Date: 02/25/10 07:34:00
Ok, thanks.  Know of anyone in the Los Angeles area who has done work on these?  How much should I expect to pay for repair?
I'm wondering if it would be better to just sell it and let somebody else deal with the problem...
> diagnose properly
>   > Problem -
>   > -RJ
in the usa your looking at $70 per hour  for a good reputable synth repair tech
some i can recomend for usa is thesonic he,s my counter part in the usa
you could ask ted or myself who repair ted lives in the usa i live in the uk
or you could sell it as spare parts i buy broken boards and scavenge the parts to repair other emaxes as there are some chips that you just cant buy any more the synth chip is 1 they are rare as are some custom ic,s produced by emu
ill buy if you decide to part it
or if you decide to fix it i can help there to
  Sent: Thursday, February 25, 2010 6:58 PM
  > diagnose properly
  > > Problem -
  > > -RJ
2010-02-25 by Ing. Andrés Cortez Acereto
Hi, I live in Chula Vista Ca.  area and I have taken to repair a Roland JD-800 and my ENSONIQ ESQ-1 to a repair shop that some friends recommended me in L.A., I saw there a lot of Vintage keyboards such as Emax's, Akai's, Moog's, Roland's that they were working on them.
My two synthezisers are working good since that, the ENSONIQ just needed a new internal battery and son keys adjustment and the JD-800 was a full recover!!, It works 100% now and looks so great, tey changed all keys, sliders, buttons, display...
By the way, I don't obtain any gain with recommending them.
I hope this will help.
Andres,
8665 Venice Blvd.
West Los Angeles,CA 90034
Mon-Fri 10am-6pm Sat 12pm-5pm
310-559-3157 310-559-3157
www.advancedmusical.com
De: leavesstillgreen <errorspending@gmail.com>
Para: emax@yahoogroups.com
Enviado: jueves, 25 de febrero, 2010 10:58:32
Asunto: [emax] Re: Emax Rack - no sound..or barely any
> diagnose properly
> To: emax@yahoogroups. com
> > Problem -
> > -RJ
      Encuentra las mejores recetas en Yahoo! Cocina.
http://mx.mujer.yahoo.com/cocina/
2010-02-25 by RJ
how much would you buy it for?
> tech
> uk
> by emu
> To: emax@yahoogroups.com <emax%40yahoogroups.com>
> --- In emax@yahoogroups.com <emax%40yahoogroups.com>, "jammie"
> was at fault
> > diagnose properly
> with a voltmeter?
> > > To: emax@...m <emax%40yahoogroups.com>
> > > Problem -
> memorymoog)
> > > -RJ
> 02/24/10 19:34:00
> 07:34:00
> 07:34:00
2010-02-25 by RJ
and how many hours would it take to diagnose and likely fix such a problem?
>> tech
>> uk
>> by emu
>> was at fault
>> > diagnose properly
>> with a voltmeter?
>> > > Problem -
>> memorymoog)
>> work)
>> > > -RJ
>> 02/24/10 19:34:00
>> 07:34:00
>> 07:34:00
dont know depends on how fast you find the problem
the way i do it is first i swap boards out to get the machine running once i
have diagnosed which board is causing the problem then i work on that board
at the componant level
using my digital volt meter then using the oscillascope and logic anilyser i
test the good board first and do all my measurements then i test the bad
board for the same measurements from this i can tell which chips are acting
up
To: <emax@yahoogroups.com>
Sent: Thursday, February 25, 2010 8:28 PM
Subject: Re: [emax] Re: Emax Rack - no sound..or barely any
> problem?
>>> repair
>>> tech
>>> the
>>> uk
>>> buy
>>> produced
>>> by emu
>>> else
>>> like
>>> that
>>> was at fault
>>> board
>>> have
>>> > diagnose properly
>>> with a voltmeter?
>>> > > Problem -
>>> > > samples
>>> audible.
>>> still
>>> > > whatever
>>> work.
>>> > > at
>>> memorymoog)
>>> work)
>>> > > -RJ
>>> 02/24/10 19:34:00
>>> > 02/25/10
>>> 07:34:00
>>> 07:34:00
> http://www.silveriafamily.comYahoo! Groups Links
07:34:00
Thanks!  I've actually used them before for an RE-201.  They are good, though kind of expensive.  I'm going to see if I can find a place that's cheaper..especially for the diagnosis.  They have a $100 min just to look at it.
--- In emax@yahoogroups.com, Ing. Andrés Cortez Acereto <ingcortez2000@...> wrote:
> Andres,
> 8665 Venice Blvd.
> De: leavesstillgreen <errorspending@...>
> Â
> > diagnose properly
> > > Problem -
> > > -RJ
2010-02-25 by Dave Sotnick
On Thu, Feb 25, 2010 at 9:25 AM, leavesstillgreen
This doesn't address the other symptoms you describe, but to clarify:
The sample input does not mirror its input signal to any outputs. If you
want to monitor the sample input, you must monitor it at the source. You can
only hear the sample input after it is sampled and you hit a key to play it
back.
-Dave
2010-02-26 by leavesstillgreen
Thanks! I was still wondering about that.
So, then I have no idea why i can kind of hear the sample input coming out of the mono output, granted this is only by amplifying the singal a ton!
Anyone have an explanation for this?  or why I can hear sounds that are tracking with the midi input, but only barely hear them?
So sad this doesn't work :/  I was so excited for it!   I wish I had room for the keyboard version...those are so plentiful it seems.
It is pretty strange that I can hear the sample input barely when amplifying the sig
> back.
> -Dave
2010-02-26 by RJ
So now it works... i got lucky...
I had looked inside before and nothing seemed loose, but I decided to take
off the analog board to look underneath it at the traces and solder points
and when I reconnected the analog board I noticed I could push the connector
farther than it had been on before!
Thanks for the help though guys
I guess the lesson is always check all the connectors thoroughly..disconnect
and reconnect!  whoot whoot!
On Thu, Feb 25, 2010 at 7:31 PM, leavesstillgreen
> amplifying the sig
> --- In emax@yahoogroups.com <emax%40yahoogroups.com>, Dave Sotnick
> is
> can
> it
> > back.
> > -Dave
2010-02-26 by jammie
well i do no fix no charge if it cant be fixed then i dont charge you i do a resonable £30 per hour and my work comes with a 1 years warranty
it might mean a board change i have a few spare good boards for this as well i keep the old 1 for spare parts
if it cant be fixed i can just post it back at your cost only
  Sent: Thursday, February 25, 2010 10:01 PM
  > Andres,
  > 8665 Venice Blvd.
  > Â
  > > diagnose properly
  > > > Problem -
  > > > -RJ
great news you did not even look i thought the way you were saying that was
not working after inspection
it means that some has taken the hood of and pull the ribbon cable and did
not notice they most proberly did this when trying to get the hd working
Sent: Friday, February 26, 2010 4:34 AM
> connector
>> out
>> for
>> amplifying the sig
>> > > whatever
>> is
>> > > work.
>> > you
>> > You
>> can
>> > play
>> it
>> > back.
>> > -Dave
07:34:00
EMax I -> No sound, but filter/ADSR and appegiator working! Sampler output makes very quiet blubb blubbs ... :-)
2010-02-26 by Tracer Y / Goetz Kretschmann
Hello to all,
I´m very glad to find such a very nice mailing list here.
I very much hope, you could help me!
A friend of mine makes me a very nice present, an EMax I.
The broken disk drive was fixed, but the sound output is broken.
The sampler is booting from disk at startup,
teh presets are loaded.
Special -> Midianalysis is showing midi activity if I play a midi keyboard
connected to the emax Midi in.
I couldn´t hear the sample playback, but if I raise the gain on the emax
outputs connected to my mixer,
I could hear a blubb on every midi note, seems to be the adsr and or filter
section,
furthermore, if I select a preset using the appegiator and I keep the midi
key pressed, I could hear the appegiator working continously in blubb blub
blub blubb blubbs .. ;-) very nice.
I did a Special -> RAM and ERAM check without problems.
I open the sampler, and lift all socket ICs a bit and repress them into the
socket.
I also did this with the cable connector.
I rechecked the sampler without any success.
I checked a lot of reports in this mailing list back to 2007, but cannot
find a problem similar to mine.
Is there anything I could check for, I own an oscilloscope and some
voltmeters and are being familar to basic servicing.
Any help would be very appreciated.
Thanks in advance,
greetings to you all,
Goetz from Wonderlandstudio
Goetz Kretschmann
Tracer Y`s  Wonderlandstudio
www.wonderlandstudio.de
write to: tracery@...
Check Fruehstuecks-Beat, die wichtigste Mahlzeit am ganzen Tag
http://www.myspace.com/fruehstuecksbeat
Re: [english 100%] [emax] EMax I -> No sound, but filter/ADSR and appegiator working! Sampler output makes very quiet blubb blubbs ... :-)
2010-02-26 by Malte Krug
did you check the presets from various disks? If it's not happening with
all sounds you loaded, I would guess that the AMP- or Filter-Envelopes are
closing very fast.
Try to load a sound and raise the sustainlevels from the envelopes and
listen for changes.
Just a guess....
cu
Malte (Gr��e aus Braunschweig)
Am 26.02.2010, 14:42 Uhr, schrieb Tracer Y / Goetz Kretschmann
<tracery@...>:
> Hello to all,
> I�m very glad to find such a very nice mailing list here.
> keyboard
> I couldn�t hear the sample playback, but if I raise the gain on the emax
> filter
> section,
> midi
> blub
> the
> socket.
> Thanks in advance,
> Goetz Kretschmann
Re: [emax] EMax I -> No sound, but filter/ADSR and appegiator working! Sampler output makes very quiet blubb blubbs ... :-)
2010-02-26 by RJ Kaufman
Pretty bizarre that I just had the same problem, though my lack of
sound was just caused by a slightly loose connection. The connector to
the analog board is kind of difficult to attach.  I had to hold the
board from underneath and press pretty hard to get it properly
connected and I couldn't tell that it was loose when I first
disconnected the board..
Other than that I don't have any suggestions. Sorry :(
On Feb 26, 2010, at 5:42 AM, "Tracer Y / Goetz Kretschmann" <tracery@...
 > wrote:
> Hello to all,
> keyboard
> emax
> filter
> section,
> the midi
> blubb blub
> into the
> socket.
> cannot
> Thanks in advance,
> Goetz Kretschmann
