Plextor PX-W124TSe (Plexwriter 12/4/32)
2011-10-26 by Adam
2011-10-26 by Adam
The site says it is compatible with the EMAX II. Who said this? Just bought one from Ebay for quite some money and it does NOT appear to be compatible. I'd appreciate the comments of one who had success with this one. thanks!
2011-10-26 by esynthesist
Adam, I honestly think your Emax-II has a problem. - You have tested the Teac CDROM (mentioned on this site) and it didn't workon your Emax-II... while it works perfectly on my Emax-II as you know. - Now you have tested the Plextor and it doesn't work neither... while this one also works perfectly on my Emax-II. I have just tested it on each of my four Emax-II samplers and it worked well on all of them. The jumpers are set as follows: 1 - on (prty) 2 - on (term) 3 - off 4 - on (block) 5 - off (?) The drive is a November 2000 edition in external case. --- In emax@yahoogroups.com, "Adam" <fake@...> wrote:
> > The site says it is compatible with the EMAX II. Who said this? Just bought one from Ebay for quite some money and it does NOT appear to be compatible. > > I'd appreciate the comments of one who had success with this one. > > thanks! >
2011-10-26 by Matthew
Some suggestions... 1. Try using a different SCSI cable to rule out the possibility that your cable is bad. 2. Try using the Plextor with and without termination. 3. Try using the Plextor with nothing else connected to the Emax 2 via SCSI. 4. Try booting the Emax 2 from floppy and then trying to access the Plextor.
2011-10-26 by Adam
ok. so i have TWO emax II's that behave the same. things like on-off termination has been tested. the Plextor behaves just like the apple cd300plus cd rom which is not supposed to work anyway. both emax ii's have internal disk: one has an apple scsi hd, the other has a syquest. now if i attached syquest external drives to either of these, everything works perfect. as soon as add a cdrom drive either alone or before or after the external syquest, the system wont boot ! the cables i used with the cd rom works with the syquest. i am going to repeat all the test tomorrow, but if you had better ideas, please let me know. this is really odd! adam --- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote:
> > Adam, > > I honestly think your Emax-II has a problem. > - You have tested the Teac CDROM (mentioned on this site) and it didn't workon your Emax-II... while it works perfectly on my Emax-II as you know. > - Now you have tested the Plextor and it doesn't work neither... while this one also works perfectly on my Emax-II. I have just tested it on each of my four Emax-II samplers and it worked well on all of them. > The jumpers are set as follows: > 1 - on (prty) > 2 - on (term) > 3 - off > 4 - on (block) > 5 - off (?) > The drive is a November 2000 edition in external case. > > > --- In emax@...m, "Adam" <fake@> wrote: > > > > The site says it is compatible with the EMAX II. Who said this? Just bought one from Ebay for quite some money and it does NOT appear to be compatible. > > > > I'd appreciate the comments of one who had success with this one. > > > > thanks! > > >
2011-10-27 by Matthew
The only other thing I can think to suggest is to make sure the Plextor has a different SCSI ID than the internal drive.
2011-10-27 by esynthesist
What do you mean by "the system won't boot" ? Is the Emax-II going through an endless SCSI chain loop ? (showing all SCSI ID's in a loop without recognizing the internal HD with the OS on it ?) I thought your Emax-II was actually able to boot but just didn't accept the cdrom drive when you change the SCSI device with the Drive Select button. What happens if you disconnect the internal HD's and connect the CDROM drive as the only SCSI device to the Emax-II ? Can it boot from floppy in that case ? Can it boot from the CDROM if you enter a CD containing the OS ? (you can create such CDROM image with EMXP and then burn this .EZ2 image to a CD by replacing the extension .EZ2 with .ISO and burning it with your favourite CD burning software) --- In emax@yahoogroups.com, "Adam" <fake@...> wrote:
> > ok. so i have TWO emax II's that behave the same. > > things like on-off termination has been tested. > > the Plextor behaves just like the apple cd300plus cd rom which is not supposed to work anyway. > > both emax ii's have internal disk: one has an apple scsi hd, the other has a syquest. > > now if i attached syquest external drives to either of these, everything works perfect. > > as soon as add a cdrom drive either alone or before or after the external syquest, the system wont boot ! > > the cables i used with the cd rom works with the syquest. > > i am going to repeat all the test tomorrow, but if you had better ideas, please let me know. > > this is really odd! > > adam > > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > Adam, > > > > I honestly think your Emax-II has a problem. > > - You have tested the Teac CDROM (mentioned on this site) and it didn't workon your Emax-II... while it works perfectly on my Emax-II as you know. > > - Now you have tested the Plextor and it doesn't work neither... while this one also works perfectly on my Emax-II. I have just tested it on each of my four Emax-II samplers and it worked well on all of them. > > The jumpers are set as follows: > > 1 - on (prty) > > 2 - on (term) > > 3 - off > > 4 - on (block) > > 5 - off (?) > > The drive is a November 2000 edition in external case. > > > > > > --- In emax@yahoogroups.com, "Adam" <fake@> wrote: > > > > > > The site says it is compatible with the EMAX II. Who said this? Just bought one from Ebay for quite some money and it does NOT appear to be compatible. > > > > > > I'd appreciate the comments of one who had success with this one. > > > > > > thanks! > > > > > >
2011-10-29 by Adam
Ok, i spent some more time evaluating what's going on, and there are plenty of issues to cover. I am going to compile a list of the results of various conditions, but it seems like that the SYQUEST EZ SCSI 135 is not happy with the Teac CD-ROM, and it's not about termination. the cd roms are also very picky about having parity and OTHER (!) jumpers set correctly. eg the Plextor works fine ONLY if the block jumper is short. So, once i connect the Syquest with the Teac to the same chain, the Emax will not boot, just keeps scanning for the SCSI devices. (the disk i have in the Teac has no system to boot, only sounds). If i replaced the Syquest with an SCSI HD, it will work under certain conditions i am not going to list yet, because i have to do further tests. My question now, if anyone knew something about the Syquest vs. CDROM realation regarding the Emax II! thanks! --- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote:
> > What do you mean by "the system won't boot" ? > Is the Emax-II going through an endless SCSI chain loop ? (showing all SCSI ID's in a loop without recognizing the internal HD with the OS on it ?) > I thought your Emax-II was actually able to boot but just didn't accept the cdrom drive when you change the SCSI device with the Drive Select button. > What happens if you disconnect the internal HD's and connect the CDROM drive as the only SCSI device to the Emax-II ? > Can it boot from floppy in that case ? > Can it boot from the CDROM if you enter a CD containing the OS ? (you can create such CDROM image with EMXP and then burn this .EZ2 image to a CD by replacing the extension .EZ2 with .ISO and burning it with your favourite CD burning software) > > --- In emax@yahoogroups.com, "Adam" <fake@> wrote: > > > > ok. so i have TWO emax II's that behave the same. > > > > things like on-off termination has been tested. > > > > the Plextor behaves just like the apple cd300plus cd rom which is not supposed to work anyway. > > > > both emax ii's have internal disk: one has an apple scsi hd, the other has a syquest. > > > > now if i attached syquest external drives to either of these, everything works perfect. > > > > as soon as add a cdrom drive either alone or before or after the external syquest, the system wont boot ! > > > > the cables i used with the cd rom works with the syquest. > > > > i am going to repeat all the test tomorrow, but if you had better ideas, please let me know. > > > > this is really odd! > > > > adam > > > > > > > > > > > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote: > > > > > > Adam, > > > > > > I honestly think your Emax-II has a problem. > > > - You have tested the Teac CDROM (mentioned on this site) and it didn't workon your Emax-II... while it works perfectly on my Emax-II as you know. > > > - Now you have tested the Plextor and it doesn't work neither... while this one also works perfectly on my Emax-II. I have just tested it on each of my four Emax-II samplers and it worked well on all of them. > > > The jumpers are set as follows: > > > 1 - on (prty) > > > 2 - on (term) > > > 3 - off > > > 4 - on (block) > > > 5 - off (?) > > > The drive is a November 2000 edition in external case. > > > > > > > > > --- In emax@yahoogroups.com, "Adam" <fake@> wrote: > > > > > > > > The site says it is compatible with the EMAX II. Who said this? Just bought one from Ebay for quite some money and it does NOT appear to be compatible. > > > > > > > > I'd appreciate the comments of one who had success with this one. > > > > > > > > thanks! > > > > > > > > > >
