honestly I dont know for sure that you can put an internal drive in a emax,
Im pretty sure you can.
You could tell pretty quick by taking the cover off and seeing if there is a
power supply
and a 50 pin scci cable connector located near the internal floppy drive.
On the emax II the power suppy and connector were right there, all I had to
do was
un -band the power supply so I would reach the drive I put in. Incidently,
radio shack sells
a pc board type holder that is copper colored and a little wider than I cd
Jewel box.
This would act as a good HD holder to mount the drive to, youd have to drill
4 holes in
the plate to hold it inside the EMAX.
it sells for around $5 and again it is copper colored.
I did infact use a cd jewel box with drilled holes, but I bought the radio
shack contraption
intending to one day switch it out.
Matt
To: <emax@yahoogroups.com>
Sent: Wednesday, October 09, 2002 4:05 AM
Subject: [emax] Hard Drive in EMAX? Emax Upgrades?
> Hi,
> more silly newbie Emax questions here...
> I just aquired my original Emax (model 1020) last weekend...
> I heard you can put a SCSI hard drive in the Emax, but does that
> apply to my model (original model Emax)?
> Are there any upgrades available for the original Emax?
> What is the latest OS/Software version?
> Apparently mine has: "Software Rev 3.0"
> Are there any PC software apps that can edit/transfer Emax samples?
> http://www.silveriafamily.com
