it is the jumper closest to the connections that chooses between ID0 and
ID1.
But you must have a jumper for it....
On Mon, Jun 4, 2012 at 1:34 PM, freddy1771994 <freddy1771994@...>wrote:
> OK:
> I found out how to change the id.
> Let's say you're looking on it from its backside.
> On the left there are the possiblities to change the write protection (no
> jumpers set) - That's not needed
> On the right are the id jumper settings. It looks like this ::
> The top two pins are the termination; it is switched on with one of these
> jumpers, but i don't know which conection I have to make to select the
> correct id. Furthermore I have no jumpers at home....
> Thank you!
> --- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote:
> > Depends on the drive model
> > On Mon, Jun 4, 2012 at 1:20 PM, freddy1771994 <freddy1771994@...>wrote:
> > > Thank you for the fast answer. Where can I change the jumper?
> > > --- In emax@yahoogroups.com, Ted Summers <djtbs1@> wrote:
> > > > Emax 1 uses SCSI ID 0 for the CF drive.
> > > > Emax 2 uses SCSI ID 1 or higher- did you change the jumper?
> > > > If not- that would be a reason why.
> > > > On Mon, Jun 4, 2012 at 12:50 PM, freddy1771994 <freddy1771994@
> >wrote:
> > > > > Hi,
> > > > > I bought an Emax 1 with cf card reader and slim floppy drive from
> group
> > > > > member jammie.emma which works fine. But in consideration of the
> fact
> > > that
> > > > > I have 5gb of emaxII (working with zip100 can be annoying then),
> but
> > > only a
> > > > > few hundred mbs of emaxI sounds (the internal ZIP I bought doesn't
> work
> > > > > eiter - but that's a different sory) I wanted to mount the cf card
> > > reader
> > > > > into the emaxII.
> > > > > I did so, but it doesn't work.
> > > > > It's easy to describe:
> > > > > 1) The emaxII simply does not see it or react on it, if the cable
> is
> > > right
> > > > > round on the pcb.
> > > > > 2) I hoped, "ok maybe it's the other way round than I used to have
> it
> > > > > installed when the harddrive was in." I did it and now all the
> lights
> > > were
> > > > > continously lit. After having it switched on and booting from the
> > > floppy
> > > > > the display completely refused any kind of work and it's turns
> black
> > > after
> > > > > the "Loading Software" message.
> > > > > No worries; I didn't mess it up. When I put it into the emax I
> angain
> > > it
> > > > > worked fine.
> > > > > Do you have any ideas where this problem might result from?
> > > > > Thank you very much!!!!
> > > > > Freddy
> > > > [Non-text portions of this message have been removed]
