Xtreme Analog, anyone?
2003-12-29 by Kendall Simpson
I use the EXSP24 and was wondering if anyone uses (and likes) the
Xtreme Analog collection/samples from Emagic. I  am in a debate over
whether to  add an ES1 to my Logic Gold set up or just add the Xtreme
Analog samples .
Thanks, Kendall
Re: [EXS] Xtreme Analog, anyone?
2003-12-29 by Hendrik Jan Veenstra
>Analog samples .
I have the Xtreme Analog library...  Haven't used it much yet, but
it's pretty good -- within the limitations of a sample library, that
is.  It's no substitute for a real analog synth obviously, since it's
less 'tweakable' because of it's being sample-based.  On the other
hand, the range of sounds they used is quite broad, and covers most
'classical' analog sounds.  So if you're looking for e.g. a fat
Moog-bass, chances are good you'll find it in the library.
If I had to put it in one sentence, the verdict would be "a good
general purpose library with a broad range of analog sounds for
people who don't want to spend too much time tweaking their own
sounds".  If you want to turn 10 knobs and faders simultaneously to
achieve that whizz-bang weirdness-extravaganza effect you're after,
then you're better of getting a real synth.
Regarding the ES1: I've used it a bit in Logic-4 days and was _not at
all_ impressed by it.  House-techno-dance basses and base drums:
fine.  But for the rest...???  I don't know if it has changed much
since v4, but if not, I would never consider spending money on it.
Seems to me that the ES2 would be a better option.  Or, if you're
really into wild sounds and extreme flexibility, get NI's Absynth for
example.  For classical analog there's NI's Prophet 5 emulation, the
Pro-53.  OTOH, I've heard bad things about NI support and their
AU-conversions, so I don't know if anyting NI-related is a good idea
at this point in time.
Hendrik Jan Veenstra   h @ k n o w a r e . n l
Omega Art: http://www.omega-art.com/
2003-12-29 by Eli Krantzberg
> Analog samples .
I really like the XTreme Analoge sounds. They are nice rich fat juicy analog
type sounds. And the sampler instruments are set up and organized well.  And
they are set up nicely to easily sync filter sweeps or other parameters to
tempo if you want to, without too much tweaking necessary.
I have the ES1 as well. I like it but admittedly don't use it too much
anymore. It isn't really that "sophisticated" a plugin compared to what else
is out there these days. But it's still fun to play around with. And it's
got a nice big fat sounding filter that you can use as a sidechain to run
other audio through if you want to. It's also fairly easy to sync various
parameters to tempo if you like that sort of sound.
Eli Krantzberg
Nightshift orchestra / Almat Productions
http://www.nightshiftorchestra.com
RE: [EXS] Xtreme Analog, anyone?
2003-12-29 by Adam Pendse
analog
And
I second that. I've had many a good starting point from that set.
Quite unbelievably Emagic give it away free with the Big Box thingy!
Adam
