Re: Bass Guitar help needed
2003-07-23 by (no author)
References: <1058976284.9913.3018.m12@yahoogroups.com>
In-Reply-To: <1058976284.9913.3018.m12@yahoogroups.com>
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 8bit
User-Agent: Internet Messaging Program (IMP) 3.2.1
You can also select the zones in the instrument editor and move them. There
is a key command, look for something like 'shift zones' in the key commands
editor, that will move selected zones up and down the keyboard. I think this
should be more obvious... it'd be nice if you could just click and drag
zones around in the editor.
:: jamie ::
"A common mistake that people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete fools."
 - Douglas Adams
Re: [EXS] Another EXS limitation
2003-07-23 by Eli Krantzberg
Simone Coen wrote:
> Select by is assigned to Midi CC Controller in the 4 Groups
> It doesn't matter which Controller number you choose (I say 1 since it's
> modulation and it is easy to verify!)
> You assign Group 1 to be selected when CC is between 0 and 31
> You assign Group 2 to be selected when CC is between 32 and 63
> You assign Group 3 to be selected when CC is between 64 and 95
> You assign Group 4 to be selected when CC is between 96 and 127
> Now if you play a note on the keyboard you should hear the sample assigned
> to the group with CC 0-31
The note that sounds should be dependant on where you're mod wheel is,
according to your above example.
> What happens is that you can only switch between two samples (or groups
> which is more appropriate) for every CC.
I'm not quite sure I understand what you mean by this.
> What you were supposed to have was to switch between the 4 (or 8, or 16 or
> whatever) groups (with assigned samples)... this doesn't happen and makes me
> feeling very bad...
Are you sure that you are sending the appropriate CC1 messages along
with your note on events to switch the groups being triggered? What you
describe should work. The groups should change based on CC1 messages,
not velocity according to what you describe.
Eli Krantzberg
Nightshift Orchestra / Almat Productions
http://www.nightshiftorchestra.com
2003-07-23 by funkmaster1972
is,
Exactly...
groups
As soon as you add a third switch... it doesn't work anymore... it
anly switch between ONE group and ANOTHER... no more than two groups
at a time...
or 16 or
and makes me
> > feeling very bad...
along
you
messages,
I tried to send and configure at least 25 different Midi CCs before
giving up.. results are always the same...
This thing doesn't work on my Mac...
Velocity switch is ok... it Midi CC switch that's not working the way
it should be!
Best,
Simone
www.chocolateaudio.com
