Lpc2000
JTAG Programmer Confusion - Noob Question
2005-12-03 by sixtyfivebit
Hi all,
I want to get into the LPC2106 or similar mcu, and i'm moving from the
AVR world. I've read many things about how you need some bootloader or
something working on the mcu to receive data from the jtag, etc.
is there some detailed explanation regarding this issue and how to
solve it? Also, I'm looking for a programmer to build for the LPC2106.
I see several schematics listed in the files, which one would you guys
recommend? The standard wiggler? I found these ones online as well:
http://home.comcast.net/~staskh/projects/tools/
http://www.adilam.com.au/ARM/arm.html
Sorry if these questions are stupid and I missed something very obvious.
sixtyfivebit
Re: [lpc2000] JTAG Programmer Confusion - Noob Question
2005-12-03 by Tom Walsh
sixtyfivebit wrote:
>Hi all,
The LPC2000 series have their own builtin bootloaders.  Part of the
Flash memory is protected and that is where it resides (8K).  A
bootloader utility can be found on
http://www.standardics.philips.com/support/techdocs/microcontrollers/
it is called "LPC2000 Flash ISP Utility".
JTAG is not a "programmer", it is a test interface (Joint Test Action
Group == JTAG).  Most of the people here use simple wigglers, they can
give you information as to that, or search the messages for "JTAG" and
"wiggler".  That should get you a lot of hits.
For myself, I've found wigglers to be slow, unstable, and, at times,
unpredicatable to get working right.  For my current project (dual CPU
board: LPC2106 + LPC2138), I chose to spend the money ($2700) and
purchase an Abatron BDI2000.  I've not been unhappy with it!  It can
also program the Flash of the controllers as well as give me a stable
JTAG interface to gdb + Insight.  That being said, you can whip up a
wiggler in about an hour and a few dollars expendature, then use a
software TCP server which you can download and compile yourself.
The BDI2000 is fast when programming the Flash memory.  For example, a
34K file would take about 10 seconds to prgram using the serial utility
only takes about 3 seconds with the BDI2000, and it does it via the JTAG
with two commands.  While 10 seconds is not a lot of time, I expect my
program to get a lot larger than 34K!
TomW
2005-12-03 by Leon Heller
Leon Heller, G1HSM
leon.heller@...
http://www.geocities.com/leon_heller
To: <lpc2000@yahoogroups.com>
Sent: Saturday, December 03, 2005 9:29 AM
Subject: [lpc2000] JTAG Programmer Confusion - Noob Question
> Hi all,
My interface is in jtag.zip, it works fine with the Crossworks tools.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
2005-12-03 by Arie de Muynck
Hi Tom,
Do you have an URL for that software TCP server?
Arie de Muijnck
Arie de Muynck wrote:
>From: "Tom Walsh" <tom@...>
>Hi Tom,
I haven't used it or checked it out, but it looks pretty good.
http://gdb-jtag-arm.sourceforge.net/
TomW
>Regards,
>Arie de Muijnck
>Yahoo! Groups Links
2005-12-03 by Dominic Rath
Hello,
gdb-jtag-arm doesn't support ARM7 targets, only ARM9TDMI. The ARM9 code has
bugs, and I wouldn't count on its operation.
Macraigor (the company that sells the original "Wiggler") allows you to
download their on-chip debug software for free. I used it with an Amontec
Chameleon in its Wiggler configuration, but only on windows, the wiggler
isn't supported by their linux version.
Dominic
> TomW
Leon Heller wrote:
>Leon Heller, G1HSM
>leon.heller@...
>----- Original Message -----
>From: "sixtyfivebit" <sixtyfivebit@...>
>>Hi all,
That is a wiggler, we were talking about a JTAG gdb-server.
TomW
>Leon
>Yahoo! Groups Links
2005-12-04 by Bertrik Sikken
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dominic Rath wrote:
> Hello,
How hard would it be to make it work? Something like this:
* fix existing bugs (what bugs do you know of?)
* replace pp.c (linux parallel port io) with a windows equivalent
* add support for LPC specific registers
I got my wiggler clone today (an olimex arm-jtag cable, the "new model"
with pin 8 and 15 connected on the PC side) and here what I found out
so far:
I tried both ocdcommander and ocdremote and as far as I understand now,
the big problem with these is that they cannot set breakpoints in flash.
Besides, these programs and some wiggler clones don't seem to be
completely compatible with each other (my cable only works at the lowest
speed setting, 4 kHz, unless I perform some tricks.)
The debugger from http://www.devlf.com/armdbg.html can actually set
breakpoints/singlestep in flash, but it is a completely stand-alone
program. Also I have not been able to find out if it supports
debugging at the C-source level.
Bertrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDkjTuETD6mlrWxPURApPSAKCjLtFo1gzn1pB8Lj+LWG9N6REUkQCfaPXZ
iz4ahVE/euURkaA0wwsy2Po=
=bEzj
-----END PGP SIGNATURE-----
2005-12-04 by Scott Newell
What?  Under OCD Commander, the HBR command doesn't work for you?  That's
very odd.
I've used hardware breakpoints before, and if you really want to get
tricky, you can access the ICE-breaker registers from OCD commander as well.
newell
2005-12-04 by Leon Heller
Sent: Sunday, December 04, 2005 12:14 AM
Subject: Re: [lpc2000] JTAG Programmer Confusion - Noob Question
> Hash: SHA1
> Dominic Rath wrote:
>> Hello,
>> has
> so far:
My interface works at full speed, perhaps I have a better PCB design. I
wasn't very impressed by the layout on the genuine Wiggler I have, and mine
is faster than that.
Leon
Re: JTAG Programmer Confusion - Noob Question
2005-12-04 by ntfreak2000
--- In lpc2000@yahoogroups.com, Scott Newell <digital.pickle@g...>
understand now,
flash.
That's
> very odd.
get
commander as well.
> newell
Newer versions of ocdremote support the hbreak command, they have
also added another monitor command:
monitor softbkpts off
this means that all breakpoint requests by insight/gdb will be set
as hardware breakpoints, which means when enabled stepping etc works
correctly in Flash.
to resume the default behaviour type monitor softbkpts on
Hope this helps.
sjo
2005-12-04 by lynchzilla
May I add some additional points about the wiggler-jtag isssue.
I wrote a tutorial titled "ARM Cross Development with Eclipse" that
is referenced in the "links" section of this message board. This
tutorial shows in excessive detail how to set up a free GNU compiler
set for the ARM using the Eclipse/CDT IDE and how to use the Eclipse
debugger with the wiggler. Hopefully, you have had a look at that.
The obvious shortcoming is that it couldn't debug in FLASH memory.
I'm now furiously working on a revision to this tutorial that does
show how to debug in FLASH. Thanks to the genius of my new co-
author, Norwegian engineer Kjell Eirik Andersen, we now have a
simple utility program, RSPBreakout.exe, that reads all commands
intended for the Macraigor OCDRemote and converts all Z0,addr,length
commands (software breakpoints) into Z1,addr,length commands
(hardware breakpoints). As long as you limit yourself to setting no
more than two breakpoints at a time, it will properly break in FLASH
and all single-stepping, variable inspection, etc works
magnificently. This requires Macraigor's OCDRemote version 2.14
which supports -Z2 GDB remote serial protocol commands.
Not the ultimate solution, but a great breakthrough for a completely
free development system nonetheless.
One last point, I can get the Olimex Wiggler to run at speed 3 (140
khz) using the latest OCDRemote ver 2.14
However, I found that certain Windows applications, such as my
beloved SKYPE internet phone system, used so much of my CPU
resources that the speed that the Wiggler could run was severely
degraded (to the lowest speed). I suggest that you bring up Windows
Task Manager and make sure that you don't have any applications like
that running. Remember that the OCDRemote/wiggler is ssentially "bit-
banging" the parallel port and this LPT1 port probably has a much
lower priority on the Windows driver pecking order.
I hope to have the tutorial finished in the next several days. I'm
also hoping that the Eclipse foundation may accept my tutorial as an
official Eclipse Corner article.
Jim Lynch
RE: [lpc2000] Re: JTAG Programmer Confusion - Noob Question
2005-12-04 by Michael Rubitschka
Dear Jim
Your Eclipse-Arm tutorial is magnificent.
Thank you verry much for this great
work.
Cheers
Michael
>From: "lynchzilla" <lynchzilla@...>
>Reply-To: lpc2000@yahoogroups.com
>Subject: [lpc2000] Re: JTAG Programmer Confusion - Noob Question
>Date: Sun, 04 Dec 2005 16:20:59 -0000
>Cheers,
>Jim Lynch
Re: [lpc2000] Re: JTAG Programmer Confusion - Noob Question
2005-12-04 by Ake Hedman, eurosource
Michael Rubitschka wrote:
> Dear Jim
> work.
> Cheers
> Michael
I think we all can agree on that. Superb!
/Ake
> >Cheers,
> >Jim Lynch
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavägen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 84 84 102
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
2005-12-05 by Bertrik Sikken
Leon Heller wrote:
> From: "Bertrik Sikken" <bertrik@...>
>> Hash: SHA1
>> Dominic Rath wrote:
>>> Hello,
>>> has
>> so far:
The weird thing is, getting ocdremote to recognise the cable is the
hard part, once that works it seems to run fine.
The trick I mentioned is to first tell ocdcommander that a raven cable
is connected, let it fail, then tell it to look for a wiggler. If I do
that, the wiggler is recognised fine, even at the highest speed.
Bertrik
> understand now,
> flash.
> That's
>> very odd.
> get
> commander as well.
Thanks for the correction, the HBR command works fine.
> correctly in Flash.
Ah nice, thanks for the tip.
I tried this in gdb console and indeed it works (have not been
able to also get it to work with insight source level debugging yet).
Kind regards,
Bertrik
2005-12-06 by ntfreak2000
compiler
Eclipse
Z0,addr,length
FLASH
completely
like
ssentially "bit-
an
> Cheers,
> Jim Lynch
You mention a utility RSPBreakout.exe that converts the soft
breakpoint requests to hardware for the ocdremote, this is what the
new monitor softbkpts command does.
As single stepping/stepping and breakpoints within insight work
fantastic with monitor softbkpts off command.
sjo
2005-12-06 by lynchzilla
that
> compiler
> Eclipse
does
> Z0,addr,length
no
> FLASH
> completely
(140
Windows
> like
> ssentially "bit-
I'm
> an
> > Cheers,
> > Jim Lynch
> Regards
> sjo
Thanks, Sjo.
Is that an OCDRemote command, GDB command or Insight command? Where
is it documented? It may be just what I've been looking for.
Jim Lynch
> that
This
> > compiler
> > Eclipse
that.
memory.
> does
commands
> > Z0,addr,length
setting
> no
> > FLASH
2.14
> > completely
> (140
severely
> Windows
applications
> > like
> > ssentially "bit-
much
> I'm
as
> > an
> > > Cheers,
> > > Jim Lynch
> > Regards
> > sjo
> Thanks, Sjo.
Where
> Jim Lynch
It is a ocdremote command, added in 2.14 release.
to treat all soft breakpoints requests as hardware use:
use monitor help to list all other ocdremore commands.
help on individual commands can be seen by typing:
eg, monitor help softbkpts
Hope this helps
sjo
2005-12-06 by Tom Walsh
Are you debugging from Windows or Linux with the wiggler?
TomW
RE: [lpc2000] JTAG Programmer Confusion - Noob Question
2005-12-07 by Bruce Paterson
> PCB design.
> >>I wasn't very impressed by the layout on the genuine
> Wiggler I have,
> >>and mine is faster than that.
> raven cable
> wiggler. If I do
I was able to run at full speed 0 with the Chameleon Pod pretending to
be a Macraigor Raven (sexier wiggler)....until I moved to a faster PC
where I had to drop to speed 3. Looks like processor speed is a variable
you need to take into account with the wiggler speed.
Cheers
Bruce
2005-12-07 by Bertrik Sikken
Hash: SHA1
> mine
I am trying to debug from Windows (with cygwin).
I also tried the gdb-arm-jtag package you mentioned earlier. I replaced
the pp.c file with an implementation that uses libieee1284 instead
of directly accessing /dev/parport0 and tried to get jtag-arm to
work under both windows and linux, but I'm getting no data back
yet.
Kind regards,
Bertrik
iD8DBQFDlpmTETD6mlrWxPURAtULAJ9mpL/l6JoamKBTJ/B5RIk9/A75+gCgs+Mz
1t39Nq2Uaht986PZKiwsN8k=
=404D
2005-12-07 by Tom Walsh
>Hash: SHA1
>>mine
>yet.
I dragged out my old wiggler clone and tried the gdb-jtag-arm working.
It does connect to the ARM7TDMI cpu and identifies it as an ARM7TMDI.
But the gdb-remote won't work with the ARM7 processor.  No register are
dumped. I tried with the jtag-arm tool and it comes back with all
registers as 0xffffffff.
I'm sure it prolly has something to do with the length of the SCANCHAIN
between an ARM9TDMI vs ARM7TDMI.  It was interesting to tinker with, but
I went back to my other unit (BDI2000).
TomW
2005-12-07 by Rob Jansen
Not only may the length of the scan chain differ, the depth of the
prefetch buffer is different which will result in wrong data returned
(reading at the wrong clock tick on the data bus).
Defenitely a nice starting point for someone who starts writing his/her
own JTAG arm7tdmi-s code.
Please note: the scan chains for the ARM7TDMI and the 7TDMI-S are
different...
     Rob
Hash: SHA1
>>yet.
Hi Tom,
Thanks for going through the trouble of trying out your wiggler clone.
I think I'm making some progress with my (olimex) wiggler clone
and the gdb-arm-jtag sources. It appears I can at least get the
JTAG id code now. I get 4F1F0F0F for an LPC2148, which looks similar
to the 7F1F0F0F default code that I see in the ARM7TDMI-S docs from ARM.
Do you remember which idcode you got?
I needed to do two things to make gdb-arm-jtag work so far:
1) wait a bit after the device is reset before accessing JTAG
2) make sure that parallel port bits DATA4 and DATA7 are set
Regarding 2), I see that these pins are going somewhere in
the olimex wiggler clone, but I can't clearly see where
(could be the output enables or perhaps some kind of power pins)
All the best,
Bertrik
iD8DBQFDl1uOETD6mlrWxPURAuV1AJ9Sn4bVE4x3HTEBxJfLx3yrIYO+igCgm1Xz
dJY3PpzOkLPwuj4AnGWCcoc=
=mt+C
2005-12-08 by sixtyfivebit
I'm glad this thread is helping other people, and after some research
things are a bit more clear...
Since I really don't want to buy a wiggler and would rather build one
my self (for experience, learning, etc.), is there any particular
schematic I should go with?
Leon_Heller, nice site and I saw your prototype page earlier
(bookmarked it), but I couldn't find your jtag.zip. I went through
most of the pages on your site but didn't see it... did I miss something?
lynchzilla, I'm eager to read your guide and I will wait till you post
the revision (so I don't confuse myself)... please do let everyone
know when you post the revision (if you haven't already) (no pressure,
of course :-) ).
It looks like the combination of Leon_Heller's wiggler and
lynchzilla's guide may be the clear solution for me... everything is
compatible and stuff, right?
Thanks.
2005-12-08 by Leon Heller
Sent: Thursday, December 08, 2005 7:35 AM
> Hi,
It's in this groups Files area.
Leon
2005-12-08 by Dominic Rath
Hello,
On Wednesday 07 December 2005 23:00, Bertrik Sikken wrote:
> Hi Tom,
The 0x4f1f0f0f is what I get on my lpc2294, so this should be fine.
That's because of Philips' code protection. The test logic is forced into
reset state whenever the chip is reset, making it impossible to debug right
out of reset.
Data4 should be the system reset. Not sure what Data7 is.
> All the best,
> Bertrik
You should be aware that debugging an ARM7 is different from an ARM9. The
debug scan-chain of the arm7 has only 33 bits, 32 bit data/address bus + one
control bit, while the arm9 has 67 bits, 32 bit data, 32 bit address and
three control bits. Also, the ARM7 has a different pipeline design than the
ARM9 (3 stages arm7 vs. 5 stages arm9).
If you're interested in working on this topic mail me off-list, I've been
working on a debugger with a gdb interface for quite some time now, it just
needs some finishing touches.
Dominic
2005-12-08 by Bertrik Sikken
Hash: SHA1
Hi Leon,
Sorry if I'm asking a stupid question (I'm not a hardware designer),
but is your circuit safe for the parallel port?
As far as I can see the 74HC244 takes its VCC from the 3.3V from
the target board while the 5V parallel port signals are directly
connected to the inputs of the HC244. In the HC244 datasheet I
notice that there are protection diodes between the inputs and
Vcc / ground.
It looks like there is a current path from the 5V parallel ports pins
through the HC244 protection diodes into the target 3.3V without any
obvious current limit. Doesn't this risk blowing out the parallel port
drivers? Also, wouldn't this lift the 3.3V on the target to a possibly
dangerous voltage?
Bertrik
iD8DBQFDmJY9ETD6mlrWxPURAhJEAJ4kuW6nwVKRxmHsXdKdG2ejIoooMgCeMv+r
ahAx0FVIvPtuTdOupedxOcA=
=b2cL
Sent: Thursday, December 08, 2005 8:23 PM
Subject: Re: [lpc2000] Re: JTAG Programmer Confusion - Noob Question
> Hash: SHA1
>>> something?
> Hi Leon,
> Vcc / ground.
> dangerous voltage?
It would be better to use a 74AC244, but I don't have any problems with it
as it is.
Leon
2005-12-08 by leon_heller
--- In lpc2000@yahoogroups.com, "Leon Heller" <leon.heller@b...>
wrote:
> From: "Bertrik Sikken" <bertrik@z...>
> > Hash: SHA1
> >> From: "sixtyfivebit" <sixtyfivebit@y...>
research
build one
particular
through
> >>> something?
> > Hi Leon,
designer),
> > Vcc / ground.
pins
any
port
possibly
> > dangerous voltage?
with it
> as it is.
I should also have said that parallel port outputs don't generate 5V
signals (I think they are TTL), and they are protected.
Leon
