Lpc2000
Problem with watchdog
2005-12-06 by Ake Hedman, eurosource
Hi all.
I am trying to enable the watchdog but the result is a total hang of the
board. Not even the bootloader is possible to reach after the crash and
I have to reapply power with P0.14 low to get access to the botloader
again. Reset is not enough.
The code to initialize the watchdog is
    // initialize the watchdog timer
    WDTC = 0xffffffff; // 15000000;                        // One second
= 15000000
    WDMOD = WDEN | WDRESET;                    // Activate watchdog
    WDFEED = 0xAA; WDFEED = 0x55;
I must have misunderstood the WD functionality. What am I doing wrong?
In the above code the watchdog should not trigger until 5 minutes
elapsed so even if a vector should be wrong the code that follow should
run for a while but as soon as I write to the WDMOD register I get a hang.
/Ake
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavägen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 84 84 102
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
Re: [lpc2000] Problem with watchdog
2005-12-06 by Jim Parziale
Assuming you have the correct definitions for your symbols, the only thing I
can think of is setting the timeout to the largest integer like that.  Maybe
you could try a different large integer?
These are what you should be using:
WDEN = BIT(0) = 0x00000001
WDRESET = BIT(1) = 0x00000002
WDMOD  = (uint8_t *)(0xE0000000)
WDTC      = (uint32_t *)(0xE0000004)
WDFEED = (uint8_t *)(0xE0000008)
Jim Parziale
Email: nuncio.bitis@...
Malden, MA
On 12/6/05, Ake Hedman, eurosource <akhe@...> wrote:
>  Hi all.
> = 15000000
> /Ake
> thing I
> Maybe
Jim,
yes my defines are the same and yes I have tested with other values for
the watchdog period. According to the manual the watchdog timer should
start when the 0xaa, 0x55 sequence is written but my problems are occurs
as soon as I write to the WDMOD register.
What situations can prevent the bootloader from working after a reset?
/Ake
> Jim Parziale
> Email: nuncio.bitis@gmail.com
> Malden, MA
> >  Hi all.
> > = 15000000
> hang.
> > /Ake
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
I have found part of this problem. The GNU compiler translates
to
710 04c4 8E22A0E3         mov    r2, #-536870904
711 04c8 5530E0E3         mvn    r3, #85
712 04cc 0030C2E5         strb    r3, [r2, #0]
713 04d0 8E22A0E3         mov    r2, #-536870904
714 04d4 5530A0E3         mov    r3, #85
715 04d8 0030C2E5         strb    r3, [r2, #0]
i.e. just writing 0x55.    This is done even if compiled with
optimization of.
Anyone know how to work around this?
Watchdog registers are currently defined as
// Watchdog
#define WDMOD          (*((volatile unsigned char *) 0xE0000000))
#define WDTC           (*((volatile unsigned long *) 0xE0000004))
#define WDFEED         (*((volatile unsigned char *) 0xE0000008))
#define WDTV           (*((volatile unsigned long *) 0xE000000C))
/Ake
Ake Hedman, eurosource wrote:
> > thing I
> > Maybe
> Jim,
> /Ake
> > Jim Parziale
> > Malden, MA
> > On 12/6/05, Ake Hedman, eurosource <akhe@brattberg.com> wrote:
> > >  Hi all.
> of the
> crash and
> second
> > > = 15000000
> should
> > hang.
> > > /Ake
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
2005-12-06 by Bill Knight
Actually it is writing 0xAA then 0x55.  The second line of the
disassembly is mvn (move negative).  It loads the inverted value
of 85=0x55 (0xFFFFFFAA) into r3.  The next line stores the low
order byte WFEED (-536870904=0xE0000008).
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
>to
>optimization of.
>// Watchdog
>/Ake
>> > thing I
>> > Maybe
>> Jim,
>> /Ake
>> > Jim Parziale
>> > Malden, MA
>> > >  Hi all.
>> of the
>> crash and
>> second
>> > > = 15000000
>> should
>> > hang.
>> > > /Ake
>> > YAHOO! GROUPS LINKS
>> SPONSORED LINKS
>> Microprocessor
>> 	Microcontrollers
>> 8051 microprocessor
>> YAHOO! GROUPS LINKS
>Yahoo! Groups Links
2005-12-06 by Tom Walsh
>to
>optimization of.
do you have WDFEED declared as "volatile"?  This tells gcc not to
optimize out accesses to that memory, that the memory location may
change between readings (as in the case of an interrupt writing to that
location).
example:
volatile char * WDFEED;
>// Watchdog
>/Ake
>>>thing I
>>>Maybe
>>Jim,
>>/Ake
>>>Jim Parziale
>>>Malden, MA
>>>> Hi all.
>>of the
>>crash and
>>second
>>>>= 15000000
>>should
>>>hang.
>>>>/Ake
>>>>eurosource, Brattbergav\ufffdgen 17, 820 50 LOS, Sweden
>>>YAHOO! GROUPS LINKS
>>SPONSORED LINKS
>>Microprocessor
>>	Microcontrollers
>>8051 microprocessor
>>YAHOO! GROUPS LINKS
Ah!  Didn't notice that, you are correct.  Reading ARM asm still makes
my head hurt!
TomW
>Regards
>-Bill Knight
>R O SoftWare &
>>to
>>optimization of.
>>// Watchdog
>>/Ake
>>>>thing I
>>>>Maybe
>>>Jim,
>>>/Ake
>>>>Jim Parziale
>>>>Malden, MA
>>>>> Hi all.
>>>of the
>>>crash and
>>>second
>>>>>= 15000000
>>>should
>>>>hang.
>>>>>/Ake
>>>>YAHOO! GROUPS LINKS
>>>SPONSORED LINKS
>>>Microprocessor
>>>	Microcontrollers
>>>8051 microprocessor
>>>YAHOO! GROUPS LINKS
>>Yahoo! Groups Links
>Yahoo! Groups Links
RE: [lpc2000] Problem with watchdog
2005-12-07 by Dan Beadle
Are  you "tickling" the watchdog?  Once enabled, you must reset the timer regularly - to tell the WDT that life is good.  Otherwise it will bite you by resetting (in a loop)
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf Of Jim Parziale
Sent: Tuesday, December 06, 2005 7:37 AM
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] Problem with watchdog
Jim Parziale
Malden, MA
>  Hi all.
> = 15000000
> /Ake
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web.
	 lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
  _____
2005-12-07 by Ake Hedman, eurosource
Ooops..! Thanks a lot. wishful thinking from my part I guess. ;-)
I'm back on square one then. hmmm...  I really need to solve this.
I have done a small program that initialize the watchdog as of my
previous example and then just loop while "feeding the dog"  just after
a debug output on the serial channel. But the result is the same. No
output and I have to hold p0.14 low and re power the board to be able to
bootload it.
/Ake
> Regards
> -Bill Knight
> R O SoftWare &
> >to
> >optimization of.
> >// Watchdog
> >/Ake
> >> > thing I
> that.
> >> > Maybe
> >> Jim,
> occurs
> >> /Ake
> >> > Jim Parziale
> >> > Malden, MA
> >> > >  Hi all.
> >> of the
> >> crash and
> botloader
> >> second
> >> > > = 15000000
> wrong?
> >> should
> get a
> >> > hang.
> >> > > /Ake
> >> > YAHOO! GROUPS LINKS
> >> SPONSORED LINKS
> >> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>>
> >>       Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>>
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>>
> >> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>>
> >> YAHOO! GROUPS LINKS
> >Yahoo! Groups Links
> YAHOO! GROUPS LINKS
> >to
> >optimization of.
> location).
> example:
Thanks Tom,
Yes its defined as
forgetting volatile have bite me so many times during the years.
/Ake
Hej Dan,
yes I feed the dog. I have also just tried to write a loop where I do
nothing else then feeding the watchdog but I'm still seem to have the
problem. Initialized with the largest watchdog timeout value (about 5
minutes) I should have no problem with this for the first time. But in
my case nothing works after the initialization.
As no one seem not to have problems with this I must do something
stupid. I must be missing something.
The program works perfect until I initialize the watchdog BTW.
/Ake
I am still trying to solve my problems with the watchdog.
I have now scaled away most stuff of my application and can see that the
problem occurs when either of three interrupts occur (UART0/UART1/I2C0)
in the system. Without the watchdog everything works fine but if I
enable the watchdog everything crashes. I have tried to just enable and
trig one of the interrupts in turn but the situation is the same.
I'm totally out of clues at the moment so any (also things that might be
considered dumb) are very welcome.
/Ake
> Hej Dan,
> /Ake
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
Re: Problem with watchdog
2005-12-07 by alberto
I have the same problems, when I try to insert WD function it doesn't
work anything, the compiler expands code in the same manner as you
explains. register are defined as volatile. But PLL_FEED doesn't work
in the same mode?
Alberto
Re: [lpc2000] Re: Problem with watchdog
What device are you using?
Have you tried just a loop where you feed the watchdog just after you
enable it? This works for me as long as I don't have any interrupts
enabled.
As it only happens when interrupts are enabled for me and therefore my
working theory at the moment is that something is wrong happens in the
interrupt routines after all. Have no clue why this should manifest
itself when the watchdog is enabled. With the lack of responses on my
cry for help on this issue from other list members no one else does
either. ;-(   or? ;-)
/Ake
alberto wrote:
> Hi,
> in the same mode?
> Alberto
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
2005-12-07 by dr_danish_ali
Ok Ake, here's my dumb suggestion:
Try enabling the watchdog, but just to interrupt not reset?
You'll need an interrupt handler / VIC channel to do it - can you spare one?
That ISR need just raise a flag for now.
Once the watchdog is fed and running happily, you might then be able to enable resets on
it.
Hope this helps,
Danish
> Regards
> /Ake
2005-12-07 by 3gpabko
Hi there,
there is a note in the UM about the feeding sequence
of the PLL which says that the writing of 0xAA and
then 0x55 must be two consecutive VPB cycles. No
interrupts between them. For the WDT the text is
different it says that after feeding 0xAA "...the next
operation in the Watchdog register space should be a
WRITE (0x55) to the WDFEED register otherwise the
Watchdog is triggered."
May be the dog doesn't like to be interrupted when
feeding.
--- "Ake Hedman, eurosource" <akhe@...>
wrote:
> Hi all.
> a total hang of the
> after the crash and
> to the botloader
>       // One second
> = 15000000
> Activate watchdog
> am I doing wrong?
> until 5 minutes
> that follow should
> /Ake
__________________________________________
Yahoo! DSL \ufffd Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
Hi Danish,
Not dumb a *very good* suggestion. Not  dumb or not matters now. I will
try every suggestion at this stage... Everyone who have done some
projects know the feeling. Everything in place. The product  ready to be
sent to the customer.... Just have to enable that tiny little thing
also.....  ;-)
Back to work!
/Ake
> spare one?
> to enable resets on
> it.
> Hope this helps,
> Danish
> the
> might be
> > Regards
> > /Ake
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
thanks for the suggestions. Also well worth a try. I will report my
findings back.
I would like to thank you and everyone else who have responded to this
problem. Your suggestions, questions are very valuable and I hope I can
give something back in the future.
/Ake
3gpabko wrote:
> Hi there,
> feeding.
> Regards
> --- "Ake Hedman, eurosource" <akhe@brattberg.com>
> wrote:
> > Hi all.
> > a total hang of the
> > after the crash and
> > to the botloader
> >       // One second
> > = 15000000
> > Activate watchdog
> > am I doing wrong?
> > until 5 minutes
> > that follow should
> > /Ake
> Yahoo! DSL - Something to write home about.
> dsl.yahoo.com
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
WD story update
I changed the code to have the watchdog raising an IRQ instead of a
RESET.  I initialize stuff and then go in in a while loop.
1.) With interrupts enabled but no interrupt channel active this will
not trigger the watchdog. Why?
2.) With one of the interrupt channels active ( UART0 writing some
characters ) the watchdog works. Without a dog feed the watchdog is
triggered and with a feed it runs fine. However what I initialize WDTC
with does to seem to matter. I always get about 4 ms period when I
toggle a pin in the WD interrupt (60MHz clock).
Is this behaviour recognized by anyone? Please!
BTW the chip is LPC2138
/Ake
> spare one?
> to enable resets on
> it.
> Hope this helps,
> Danish
> the
> might be
> > Regards
> > /Ake
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
2005-12-08 by brendanmurphy37
Ake,
I can almost feel your frustration: we've all been there!
I'm very interested in the outcome of this, as our own task for next
week is to get the watchdog working on our own LPC2134-based system.
I'm a bit surprised that no one has volunteered some working code.
Surely someone out there is using this?
Unfortunately, as we haven't got there yet, I've nothing specific to
suggest, other than a general strategy of getting something simple
working first, and then building up to where you are. For example:
1. As simple as possible startup, initialisation (all peripherals
disabled, all interrupts off etc.) and an application that
initialises the watchdog and uses GPIO to signal what it's doing (and
maybe reads to indicate whether or not the watchdog should be fed).
In other words, the simplest possible program with a working
watchdog.
2. Same program, but with your normal initialisation and setup code,
added incrementally. Still working?
3. Compare and contrast with your real application, particularly in
how peripherals, interrupts etc. are managed.
In other words, get something simple working first, and build up from
there. It'll take time, but maybe less time then starting from a
larger system that doesn't work.
Hopefully, somewhere along the line, all will become obvious.
By the way, are you running your code using an emulator connected?
I've seen strange behaviour in the past with watchdogs enabled. Try
running stand-alone, if you haven't done so already.
As a final suggestion, based on what you say below, I'd look very
carefully at every location interrupts are enabled/disabled (at the
peripheral level, at the VIC and at the CPSR). Also at your startup
and IRQ dispatch code. Maybe the processor is resetting and re-
initialising stuff without you realising? maybe throwing an exception
you haven't noticed?
As a final comment: 'though no doubt it feels like it, it's not time
wasted: you'll know way more about the watchdog and processor at the
end of all this then when you started.
Good luck!
Brendan
wrote:
> WD story update
will
WDTC
> /Ake
> > spare one?
able
> > to enable resets on
> > it.
> > Hope this helps,
> > Danish
<akhe@b...>
that
> > the
(UART0/UART1/I2C0)
if I
enable and
same.
> > might be
> > > Regards
> > > /Ake
> > SPONSORED LINKS
> > Microprocessor
J9hJ5qyXg0WPR0l6g>
> > 	Microcontrollers
1nxwg>
6LyBvUqVQ>
> > 8051 microprocessor
lekkDP-A>
> > YAHOO! GROUPS LINKS
2005-12-08 by Ake Hedman, eurosource
Thanks Brendan,
This is the right approach surely. I'm at that state now and have no
other alternative then to back a bit and go through this "the right
way". I just have myself to blame. Have used watchdogs for many years on
PIC, AVR and other processors and expected no problem there except for
the usual forgetting to feed it in certain places. Oh well it's my first
project on this processor family so this makes me learn useful stuff
just as you write (just a bit hard to appreciate that right now ;-) ).
Really need the watchdog to work in this application though so there is
no shortcut.
I just debug using GPIO pins and one of the serial ports at the moment
so there is no emulator connected now.
Thanks for your tips, suggestions and moral support. I report my
findings back.
/Ake
brendanmurphy37 wrote:
> Ake,
> watchdog.
> Good luck!
> Brendan
> wrote:
> > WD story update
> will
> WDTC
> > /Ake
> > > spare one?
> able
> > > to enable resets on
> > > it.
> > > Hope this helps,
> > > Danish
> <akhe@b...>
> that
> > > the
> (UART0/UART1/I2C0)
> if I
> enable and
> same.
> > > might be
> > > > Regards
> > > > /Ake
> > > SPONSORED LINKS
> > > Microprocessor
> J9hJ5qyXg0WPR0l6g>
> > >       Microcontrollers
> 1nxwg>
> 6LyBvUqVQ>
> > > 8051 microprocessor
> lekkDP-A>
> > > YAHOO! GROUPS LINKS
> YAHOO! GROUPS LINKS
Ake,
Thanks for your comments.
I'm not sure if you want to hear this or not, but we've just put in
support for the watchdog. It worked first time, with no problems.
Code is below: two functions, one called as part of startup sequence,
the other called from a watchdog task that's scheduled every second.
If we spin in a loop locking out all other tasks, the system is reset
as expected.
Our system has several sources of interrupt enabled (both UARTs, I2C
etc.): it works regardless of what's happeneing elsewhere.
By the way, we use GCC 3.3.1 with -O2 to compile.
Brendan
CODE STARTS HERE:
#define REG(addr) (*(volatile unsigned int *)(addr))
#define WDOG_BASE    (0xE0000000)
#define WDOG_WDMOD   (0xE0000000)
#define WDOG_WDTC    (0xE0000004)
#define WDOG_WDFEED  (0xE0000008)
#define WDOG_WDTV    (0xE000000C)
/* define basic watchdog timeout value as 100 ms */
#define	WATCH_TIMER_100MS (250000) /* 10 MHz / 4 is i/p clock */
 * Configure and start watchdog
static
void	watchdog_init(void)
  /* set the watchdog timer constant */
  REG(WDOG_WDTC) = WATCH_TIMER_100MS * (50); /* 5 seconds for now */
  /* set mode to reset on underflow */
  REG(WDOG_WDMOD) = 0x3;
  /* feed watchdog to start it off */
  REG(WDOG_WDFEED) = 0xaa;
  REG(WDOG_WDFEED) = 0x55;
  return;
 * Feed the watchdog to prevent us from being reset
void	HwWatchdogFeed(void)
  /* write the magic sequence to keep the dog happy */
  return;
END OF CODE
wrote:
> Thanks Brendan,
no
years on
for
first
stuff
there is
> no shortcut.
moment
> findings back.
> /Ake
> > Ake,
next
system.
to
(and
fed).
> > watchdog.
code,
in
from
Try
startup
exception
time
> > Good luck!
> > Brendan
<akhe@b...>
> > wrote:
> > > WD story update
of a
> > will
some
watchdog is
initialize
> > WDTC
when I
> > > /Ake
you
> > > > spare one?
be
> > able
> > > > to enable resets on
> > > > it.
> > > > Hope this helps,
> > > > Danish
> > <akhe@b...>
see
> > that
> > > > the
> > (UART0/UART1/I2C0)
but
> > if I
> > enable and
> > same.
that
> > > > might be
> > > > > Regards
> > > > > /Ake
> > > > SPONSORED LINKS
> > > > Microprocessor
> > J9hJ5qyXg0WPR0l6g>
> > > >       Microcontrollers
> > 1nxwg>
> > 6LyBvUqVQ>
> > > > 8051 microprocessor
> > lekkDP-A>
> > > > YAHOO! GROUPS LINKS
Terms of
> > YAHOO! GROUPS LINKS
Brenda*n,*
thanks. It's really good to here that.  Even if 99.999% of the problems
comes from the code we write ourselves it is still nice to take away
that 0.0001% that comes from problems in hardware.
I'm in the process of doing a new test project at the moment to try to
trace this down under a more controlled environment.
Thanks for taking the time to sharing this info. Much appreciated!
Cheers
/Ake
> Ake,
> as expected.
> Regards
> Brendan
> CODE STARTS HERE:
> static
>   return;
>   return;
> END OF CODE
> wrote:
> > Thanks Brendan,
> no
> years on
> for
> first
> stuff
> there is
> > no shortcut.
> moment
> > findings back.
> > /Ake
> > > Ake,
> next
> system.
> to
> (and
> fed).
> > > watchdog.
> code,
> in
> from
> Try
> the
> startup
> exception
> time
> the
> > > Good luck!
> > > Brendan
> <akhe@b...>
> > > wrote:
> > > > WD story update
> of a
> > > will
> some
> watchdog is
> initialize
> > > WDTC
> when I
> > > > /Ake
> you
> > > > > spare one?
> be
> > > able
> > > > > to enable resets on
> > > > > it.
> > > > > Hope this helps,
> > > > > Danish
> > > <akhe@b...>
> see
> > > that
> > > > > the
> > > (UART0/UART1/I2C0)
> but
> > > if I
> > > enable and
> > > same.
> that
> > > > > might be
> > > > > > Regards
> > > > > > /Ake
> > > > > SPONSORED LINKS
> > > > > Microprocessor
> > > J9hJ5qyXg0WPR0l6g>
> > > > >       Microcontrollers
> > > 1nxwg>
> > > 6LyBvUqVQ>
> > > > > 8051 microprocessor
> > > lekkDP-A>
> > > > > YAHOO! GROUPS LINKS
> Terms of
> > > YAHOO! GROUPS LINKS
> YAHOO! GROUPS LINKS
2005-12-09 by Robert Adsett
>no shortcut.
One thought that occurs to me, and I have no idea whether it is an issue
with this processor, is that some watchdogs must be cleared before they are
enabled or you run the risk of them firing as soon as you enable
them.  Whether or not they do depends on when you start them and how the
registers initialize etc...
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-12-09 by Ken Wada
Basically, your method works fine...
UNTIL: you start adding interrupt service routines!
This is why:
void WDOG_pet()
WDFEED = 0xAA;
/*             Interrupt occurs here...> dog will NOT pet properly!!!
WDFEED = 0x55;
/**** example uses Keil compiler directives ***/
/********** The following is what I wound up doing, (gotta avoid that
spurious interrupt issue with the ARM also!!! ***/
/**** The actual interface that everybody uses ***/
void WDOG_pet (void)
    SYSSWI_service (12,0,0,0);
/***** How the SYSSWI_service works, (based on SWI) ***/
unsigned SYSSWI_service (SYSSWI opcode, int id, void *pObj, unsigned
_user1) __swi(12)
    switch (opcode)
      case SYSSWI_WDOGPET:
        SYSSWI_watchDogPet ();
        break;
    return (0);
/***** How the SYSSWI_watchDogPet () works ***/
static void SYSSWI_watchDogPet (void)
    ARM_disableFIQ ();                /* make sure FIQ is disabled
    WDFEED  = 0xAA;
    WDFEED  = 0x55;
    ARM_enableFIQ ();                 /* re-enable the FIQ
/***** The IRQ is automatically disabled by vectoring to the SWI...
however, you need to make the operation atomic with respect to FIQ,
which is NOT disabled ***/
PUBLIC  ARM_disableFIQ?A ; interface is ARM mode
ARM_disableFIQ?A  PROC  CODE32
      MRS   R0,CPSR
      ORR   R0,R0,#0x0040                   ; Mask just the FIQ
      MSR   CPSR_c,R0
      BX    R14
      ENDP
PUBLIC  ARM_enableFIQ?A ; interface is ARM mode
ARM_enableFIQ?A  PROC  CODE32
      MRS   R0,CPSR
      BIC   R0,R0,#0x0040                   ; Enable just the FIQ
      MSR   CPSR_c,R0
      BX    R14
      ENDP
END
wrote:
> Hi all.
and
botloader
second
> = 15000000
wrong?
should
hang.
> /Ake
2005-12-09 by Ake Hedman, eurosource
> >no shortcut.
> they are
> Robert
Good thought! Sadly it did not help on my problems. But I agree this is
probably something one should do. The watchdog is  initialized to 0xff
on reset according to the manual. The question here is if it is updated
while disabled or will stay at 0xff until enabled. Have to test that.
Thanks!
/Ake
> restrictions,   be
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
2005-12-09 by brendanmurphy37
Ken,
Can you explain why you think there's a problem with an interrupt
between the two writes?
According to the User Manual: "Once 0xAA is written to
the WDFEED register the next operation in the Watchdog register space
should be a WRITE (0x55) to the WDFFED register otherwise the
watchdog is triggered."
I take this to mean that the next write to the WDFEED register has to
be 0x55 following the 0xaa: why should it matter if this is one cycle
on, or 1000 cycles on (e.g. to take account of any interrupt)? I'm
assuming here that the interrupt itself doesn't go near the watchdog.
Also, for disabling interrupts, why not just disable IRQ and FIQ in
the same write to the CPSR? Is there some problem with this?
regards
Brendan
> This is why:
> void WDOG_pet()
> WDFEED = 0xAA;
properly!!!
> WDFEED = 0x55;
that
unsigned
> _user1) __swi(12)
>     switch (opcode)
>         break;
>     return (0);
disabled
>     WDFEED  = 0xAA;
>     WDFEED  = 0x55;
FIQ
>       MRS   R0,CPSR
>       MSR   CPSR_c,R0
>       BX    R14
>       ENDP
>       MRS   R0,CPSR
>       MSR   CPSR_c,R0
>       BX    R14
>       ENDP
> END
<akhe@b...>
> wrote:
> > Hi all.
of
> the
crash
> and
> botloader
> second
> > = 15000000
watchdog
> wrong?
> should
get a
> hang.
> > /Ake
Ken,
yes this is probably it (as zdravko_k_d@... also pointed out
earlier).  Strange not to have an atomic feed. First time I have come
across that. I have the code taken apart now to try to track this down.
But all the symptoms of the problems I have match what should be
expected from the watchdog triggering from something else then not just
lack of feed.
What happens if the watchdog is feed with the wrong sequence? Is it
triggered or does it just ignore it?
Appreciate your input Ken.
/Ake
> This is why:
> void WDOG_pet()
> WDFEED = 0xAA;
> WDFEED = 0x55;
> _user1) __swi(12)
>     switch (opcode)
>         break;
>     return (0);
>     WDFEED  = 0xAA;
>     WDFEED  = 0x55;
>       MRS   R0,CPSR
>       MSR   CPSR_c,R0
>       BX    R14
>       ENDP
>       MRS   R0,CPSR
>       MSR   CPSR_c,R0
>       BX    R14
>       ENDP
> END
> wrote:
> > Hi all.
> the
> and
> botloader
> second
> > = 15000000
> wrong?
> should
> hang.
> > /Ake
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
From extensive testing...I have found that the LPC22xx just ignores an
invalid feed.
I have come across this in Motorola's Power PC chip also.
Ken Wada
wrote:
> Ken,
> yes this is probably it (as zdravko_k_d@y... also pointed out
come
down.
just
> lack of feed.
> /Ake
> > This is why:
> > void WDOG_pet()
> > WDFEED = 0xAA;
properly!!!
> > WDFEED = 0x55;
that
unsigned
> > _user1) __swi(12)
> >     switch (opcode)
> >         break;
> >     return (0);
> >     WDFEED  = 0xAA;
> >     WDFEED  = 0x55;
FIQ,
> >       MRS   R0,CPSR
> >       MSR   CPSR_c,R0
> >       BX    R14
> >       ENDP
> >       MRS   R0,CPSR
> >       MSR   CPSR_c,R0
> >       BX    R14
> >       ENDP
> > END
> > wrote:
> > > Hi all.
hang of
> > the
crash
> > and
> > botloader
One
> > second
> > > = 15000000
watchdog
> > wrong?
minutes
> > should
get a
> > hang.
> > > /Ake
> > SPONSORED LINKS
> > Microprocessor
> > 	Microcontrollers
> > 8051 microprocessor
> > YAHOO! GROUPS LINKS
--- In lpc2000@yahoogroups.com, "brendanmurphy37" <brendan.murphy@i...
> wrote:
> Ken,
space
to
cycle
watchdog.
It makes a bit difference! If you WRITE (0x55), the processor expects
a WRITE(0xAA) on  the very next cycle. If this is done outside an
interrupt context, the interrupt service routine will pretty much
guarantee that this condition is violated!
Yep...huge problem. Actually, you will see this type of problem with
many processors/especially DSP's with fully pipelined architecture.
The Philips User manual calls this the spurious interrupt problem.
Actually, Philips basically took their cautionary note directly from
the ARM users guide.
Gone are the good-old days of doing something like EA=0, as per 8051..
.these pipelined architectures are a bit different when it comes to
instruction processing.
Fortunately, all of these modern architectures give you a way to do
these types of operations, (albeit with a bit more effort), via some
software interrupt (SWI) instruction.
My 1st encounter with this was with the Intel 80386 chip. This chip
had an instruction pipeline, and I had to use the int86() SWI command
in order to properly code up the atomic sections.
Ken Wada
> regards
> Brendan
> > This is why:
> > void WDOG_pet()
> > WDFEED = 0xAA;
> properly!!!
> > WDFEED = 0x55;
> that
> unsigned
> > _user1) __swi(12)
> >     switch (opcode)
> >         break;
> >     return (0);
> disabled
> >     WDFEED  = 0xAA;
> >     WDFEED  = 0x55;
> FIQ
FIQ,
> >       MRS   R0,CPSR
> >       MSR   CPSR_c,R0
> >       BX    R14
> >       ENDP
> >       MRS   R0,CPSR
> >       MSR   CPSR_c,R0
> >       BX    R14
> >       ENDP
> > END
> <akhe@b...>
> > wrote:
> > > Hi all.
hang
> of
> > the
> crash
> > and
> > botloader
One
> > second
> > > = 15000000
> watchdog
> > wrong?
minutes
> > should
> get a
> > hang.
> > > /Ake
2005-12-09 by David Hawkins
Hi guys,
The uCOS-II RTOS port for the ARM processor defines an
OS_ENTER_CRITICAL and OS_EXIT_CRITICAL pair of macros,
inside which you can perform atomic (well, non-interruptible
operations). These aren't just limited to the RTOS
though.
The code snippet below is based on:
http://www.atmel.com/dyn/resources/prod_documents/DOC1156.PDF
Perhaps you want to add something like this to
protect your watchdog code.
Dave
from the UCOS-II os_cpu.h header:
#define  OS_ENTER_CRITICAL()  {cpu_sr = OS_CPU_SR_Save();}
#define  OS_EXIT_CRITICAL()   {OS_CPU_SR_Restore(cpu_sr);}
from the UCOS-II os_cpu_a.asm code:
@                                   CRITICAL SECTION METHOD 3 FUNCTION
@ Description: Disable/Enable interrupts by preserving the state of
interrupts.  Generally speaking you
@              would store the state of the interrupt disable flag in
the local variable 'cpu_sr' and then
@              disable interrupts.  'cpu_sr' is allocated in all of
uC/OS-II's functions that need to
@              disable interrupts.  You would restore the interrupt
disable state by copying back 'cpu_sr'
@              into the CPU's status register.
@ Prototypes :     OS_CPU_SR  OS_CPU_SR_Save(void);
@                  void       OS_CPU_SR_Restore(OS_CPU_SR cpu_sr);
@ Note(s)    : 1) These functions are used in general like this:
@                 void Task (void *p_arg)
@                 #if OS_CRITICAL_METHOD == 3          /* Allocate
storage for CPU status register */
@                     OS_CPU_SR  cpu_sr;
@                 #endif
@                     OS_ENTER_CRITICAL();             /* cpu_sr =
OS_CPU_SaveSR();                */
@                     OS_EXIT_CRITICAL();              /*
OS_CPU_RestoreSR(cpu_sr);                */
@              2) OS_CPU_SR_Save() is implemented as recommended by
Atmel's application note:
@                    "Disabling Interrupts at Processor Level"
@                 p328 of the ARM System Developers Guide has the first
three asm statements and
@                 does not use the check.
@                 NOTE: the flags can ONLY be modified by a priviledged
mode, so if you accidentally
@                 call this function from user-mode, the processor will
lock up (in the loop check).
         .text
         .arm
	.align	2
	.func	OS_CPU_SR_Save
OS_CPU_SR_Save:
         MRS     R0,CPSR                     @ Set IRQ and FIQ bits in
CPSR to disable all interrupts
         ORR     R1,R0,#I_Bit|F_Bit
         MSR     CPSR_c,R1
         @ Interrupt disable check:
         @ This is a slight variation on the Atmel app note code,
         @ as it checks that both FIQ and IRQ disable bits get set.
         MRS     R1,CPSR                     @ Confirm that CPSR
contains the proper interrupt disable flags
         AND     R1,R1,#I_Bit|F_Bit
         CMP     R1,#I_Bit|F_Bit
         BNE     OS_CPU_SR_Save              @ Not properly disabled
(try again)
         MOV     PC,LR                       @ Disabled, return the
original CPSR contents in R0
	.endfunc
         .text
         .arm
	.align	2
	.func	OS_CPU_SR_Restore
OS_CPU_SR_Restore:
         MSR     CPSR_c,R0
         MOV     PC,LR
	.endfunc
Ken,
I'm still curous about your statement "the processor expects
a WRITE(0xAA) on the very next cycle". Where is this documented? It
may be true, but if so, I'd say it contradicts the quote I took from
the User Manual (for the LPC213x parts). Or am I misreading what it
says?
It's a fairly important point: if the feed has to be done in two
adjacent CPU cycles, you're forced to use assembler apart from
anything else, in order to do the back-to-back write reliably (I've
checked the assembler o/p from our own code, and it does, but you
can't rely on this: all you need is to change the revision of the
compiler or have a new optimsaition setting and thinmgs can fall
apart).
On the other point: you're quite right - there's plenty of "gotchas"
with ARM interrupts. It's been a while since I looked at this, but I
seem to recall spending at least a few days armed with a stack of
ARM books/manuals etc. (if you'll forgive the pun) to get our
interrupt handling code to a state we were happy with it. Funny how
you forget such things... I think what prompted my question was the
implication that you somehow couldn't set both bits at the same
time. As the other response on this points out, you can of course,
and it works, but maybe not in quite the way you'd expect.....
I'd apreciate an answer on the watchdog issue though, as it's very
much a live issue with us at the moment.
Brendan
> > wrote:
> > Ken,
interrupt
> space
has
> to
> cycle
I'm
> watchdog.
expects
in
with
architecture.
from
8051..
to
do
some
chip
command
> Ken Wada
> > regards
> > Brendan
> > > This is why:
> > > void WDOG_pet()
> > > WDFEED = 0xAA;
> > properly!!!
> > > WDFEED = 0x55;
avoid
> > that
> > unsigned
> > > _user1) __swi(12)
> > >     switch (opcode)
> > >         break;
> > >     return (0);
> > disabled
> > >     WDFEED  = 0xAA;
> > >     WDFEED  = 0x55;
> > FIQ
SWI..
> FIQ,
> > >       MRS   R0,CPSR
> > >       MSR   CPSR_c,R0
> > >       BX    R14
> > >       ENDP
> > >       MRS   R0,CPSR
FIQ
> > >       MSR   CPSR_c,R0
> > >       BX    R14
> > >       ENDP
> > > END
> > <akhe@b...>
> > > wrote:
> > > > Hi all.
> hang
> > of
> > > the
> > crash
> > > and
> > > botloader
15000000;                        //
> One
> > > second
> > > > = 15000000
> > watchdog
doing
> > > wrong?
> minutes
follow
> > > should
I
> > get a
> > > hang.
> > > > /Ake
Ken,
If you follow workaround 1 in the ATMEL app note (and some of the
examples in some of the ARM documentation) referred to in the other
response to this, you can simplify greatly the code for what you're
trying to achieve in relation to locking out both IRQ and FIQ
interrupts.
As I mentioned in my previous response to this, we spent a lot of
time looking into this whole area. We ended up writing our own IRQ
pre-amble and post-amble code to ensure we had the correct
environment i.e. no modification of the SPSR, interrupts disabled
for the minimum length of time, ability to call standard 'C'
function as the main body of the interrupt handler (i.e. no need for
special __interrupt modifier of any kind etc. etc.)
I say "writing our own", but it was pretty much a copy of an ARM
example, which we modified to load the 'C' handler from the VIC. I
don't have the particular document to hand, but it's available from
the ARM Web site.
As you say, it was all a lot easier in the 8-bit world, but given
the choice, I know which I'd take....
Brendan
> > wrote:
> > Ken,
interrupt
> space
has
> to
> cycle
I'm
> watchdog.
expects
in
with
architecture.
from
8051..
to
do
some
chip
command
> Ken Wada
> > regards
> > Brendan
> > > This is why:
> > > void WDOG_pet()
> > > WDFEED = 0xAA;
> > properly!!!
> > > WDFEED = 0x55;
avoid
> > that
> > unsigned
> > > _user1) __swi(12)
> > >     switch (opcode)
> > >         break;
> > >     return (0);
> > disabled
> > >     WDFEED  = 0xAA;
> > >     WDFEED  = 0x55;
> > FIQ
SWI..
> FIQ,
> > >       MRS   R0,CPSR
> > >       MSR   CPSR_c,R0
> > >       BX    R14
> > >       ENDP
> > >       MRS   R0,CPSR
FIQ
> > >       MSR   CPSR_c,R0
> > >       BX    R14
> > >       ENDP
> > > END
> > <akhe@b...>
> > > wrote:
> > > > Hi all.
> hang
> > of
> > > the
> > crash
> > > and
> > > botloader
15000000;                        //
> One
> > > second
> > > > = 15000000
> > watchdog
doing
> > > wrong?
> minutes
follow
> > > should
I
> > get a
> > > hang.
> > > > /Ake
Asynchronously turning off and on interrupts in the main body of your
code is problematic. Instead of tempting fate; I decided to play the
overly-cautious role. It is the following excerpt from the Philips
User Manual that gave me pause:
"Although the example shows both IRQ and FIQ interrupts being
disabled, similar behavior occurs when only one of the two
interrupt types is being disabled. The fact that the core processes
the IRQ after completion of the MSR instruction which disables
IRQs does not normally cause a problem, since an interrupt arriving
just one cycle earlier would be expected to be taken. When
the interrupt routine returns with an instruction like:
SUBS pc, lr, #4
the SPSR_IRQ is restored to the CPSR. The CPSR will now have the I bit
and F bit set, and therefore execution will continue
with all interrupts disabled."
So....instead of taking the 'easy way' I decided to create a system
where I had a reasonable, (probably overkill), that the system would
work under all circumstances.
I really hate debugging spurious stuff. I have done this too many
times on those fully pipelined DSP architectures...and did not want to
tempt it this time with the ARM7TDMI.
I am sure, that over time, doing the simple turning interrupts on and
off at will may work, with little detrimental effect...however, from
what I read in the ARM website, and the Philips User Manual...
Let us say, I am pretty sure that the methods I proposed...albeit a
bit more long-winded and non-trivial; are assured to work in all
cases.
So far; I have not been called in on any suspected crashes, system
glitches, and intermittent Watchdogs...and this on equipment that is
operating 24x7 with full status monitoring for DOG events.
Ken Wada
> wrote:
> Ken,
> interrupts.
> the ARM Web site.
> Brendan
> > > wrote:
> > > Ken,
> interrupt
> > space
> has
> > to
> > cycle
> I'm
> > watchdog.
> expects
> in
> with
> architecture.
> from
> 8051..
> to
> do
> some
> chip
> command
> > Ken Wada
> > > regards
> > > Brendan
> > > > This is why:
> > > > void WDOG_pet()
> > > > WDFEED = 0xAA;
> > > properly!!!
> > > > WDFEED = 0x55;
> avoid
> > > that
> > > unsigned
> > > > _user1) __swi(12)
> > > >     switch (opcode)
> > > >         break;
> > > >     return (0);
> > > disabled
> > > >     WDFEED  = 0xAA;
> > > >     WDFEED  = 0x55;
> > > FIQ
> SWI..
> > FIQ,
> > > >       MRS   R0,CPSR
FIQ
> > > >       MSR   CPSR_c,R0
> > > >       BX    R14
> > > >       ENDP
> > > >       MRS   R0,CPSR
> FIQ
> > > >       MSR   CPSR_c,R0
> > > >       BX    R14
> > > >       ENDP
> > > > END
> > > <akhe@b...>
> > > > wrote:
> > > > > Hi all.
> > hang
> > > of
> > > > the
> the
> > > crash
> > > > and
> > > > botloader
> 15000000;                        //
> > One
> > > > second
> > > > > = 15000000
> > > watchdog
> doing
> > > > wrong?
> > minutes
> follow
> > > > should
> I
> > > get a
> > > > hang.
> > > > > /Ake
2005-12-09 by Karl Olsen
---- Original Message ----
To: <lpc2000@yahoogroups.com>
Sent: Friday, December 09, 2005 9:02 PM
Subject: [lpc2000] Re: Problem with watchdog
>> watchdog.
Not according to the LPC214x manual.  The second feed cycle write does not
need to be the very next processor cycle, just the next access to the
watchdog register space, which is 0xE000 0000 - 0xE000 3FFF.  So you can
write 0xAA to WDFEED, handle an interrupt that does lots of things (provided
it doesn't access any watchdog registers, or take too long), and back in the
main program write 0x55 to WDFEED.  If you write 0xAA to WDFEED, and then
write something other than 0x55 to WDFEED, or access another watchdog
register, then you have a feed error which gives an immediate reset.
The manual mentions two unrelated kinds of spurious interrupts.  One where a
peripheral asserts an interrupt source but deasserts it again when the
program has entered the IRQ handler and asks the VIC about the interrupt
source, and one where an IRQ occurs during an MSR instruction that disables
both IRQ and FIQ.  In the latter case, FIQs are disabled during the whole
IRQ handler, and this might be inacceptably long since the foreground
program only expected FIQs to be disabled for a few cycles before reenabling
them.  Can be solved by disabling IRQs and FIQs separately.
In the ARM7TDMI without memory protection, there is little reason to use
other modes than System, IRQ, and FIQ.  Disabling all interrupts is just a
matter of
  msr cpsr_c, #0xDF    /* Set System mode, IRQ and FIQ disabled */
or, if it is a problem that FIQs can be disabled for the duration of the IRQ
handler:
  msr cpsr_c, #0x9F    /* Set System mode, IRQ disabled */
And enabling them:
  msr cpsr_c, #0x1F    /* Set System mode, IRQ and FIQ enabled */
Other than this specific case, the pipelining itself is very invisible to
programs.  The PC appears to be 8 ahead of the current instruction if you
read the PC register, and when returning from a FIQ or IRQ handler, you must
subtract 4 from the LR.
SWI can be useful in Thumb mode because it only takes two bytes vs. four
bytes for a BL, and it can be a win when a function is called from many
places.  It isn't necessary for doing critical sections.
Karl Olsen
Karl,
Thanks for this: I was worried I'd been misreading the manual in
someway, or missing something.
We don't turn interrupts off to feed the watchdog, as both
conditions (short interrupts and not touching the watchdog registers
in any interrupt handler) are both met. Our watchdog time is 1
second, by the way: if an interrupt ran for this length of time, I
think it would deserve to be kicked!
I'd also agree on the interrupt points: provided you're careful with
your interrupt dispatch code (which can be quite simple if you stick
to supervisor, IRQ and FIQ modes as you suggest), you shouldn't have
problems. Pipelining, as you also suggest, is pretty much
transparent to almost all code.
As an aside, it's probably worth looking at the original ARM
documentation if you need to look at CPU registers/interrupts in
detail: it's much more comprehensive that that provided by Philips
on the topic.
Brendan
> From: "Ken Wada" <kwada@a...>
interrupt
space
has to
cycle
I'm
> >> watchdog.
expects
does not
you can
(provided
back in the
and then
watchdog
reset.
FIQ in
with
architecture.
problem.
from
One where a
interrupt
disables
the whole
foreground
reenabling
8051..
to
to use
is just a
> matter of
of the IRQ
> handler:
> And enabling them:
invisible to
if you
handler, you must
do
some
vs. four
many
> Karl Olsen
ok...
I can surely tell you this...
I had the Watchdog working perfectly, until I started adding interrupt
support, (mainly device drivers for the UART). After days of pulling
my hair out, and interpreting the UM for the LPC2214 as a lawyer would
do; it occured to me that the UM says 'feed 0x55 then 0xAA' It made
absolutely no mentioned about what may happen if the process got
preempted by an interrupt...
Then alas; when I installed my 1st interrupt service routine; all
worked fine, for a few hours, and sometimes for a couple of days...
Then my clients started complaining about 'these spurious reset
events'. They demanded that I fix the problem right away.
SO...
I came to this forum: AND I saw this:
message #5470 ---> Please also read all the threads that spawned from
this message.
Quickly, I wrappered the WDOG pet thing with my over-engineered SWI
service...(to keep any chance of those spurious interrupts thing from
happening)
AND...
It has been working fine now with no glitches for about 9 months now.
As a side note: from what I can see, you my be able to disable and
enable interrupts from the main body of your code by writing to the
CPSR...
The big problem I have with this is that when you execute the MSR
instruction...the ARM architecture manual clearly states that there
may be a chance of the CPSR contents being copied into the interrupt
service CPSR_shadow with both the IRQ and FIQ bits disabled.
You know...the probability of this type of occurence happening, in a
real system, is practically nil.
Therefore, I decided to use the more ioctl() style of interfacing to
the device drivers using the SWI mechanism... and letting the ARM
pipeline and state machine sort out all the details... in terms of
queueing and such.
The counter-side to my over-engineered approach is that it requires a
bit more code, and is implemented more like a immutable IOCTL() device
driver.
The flipside to this argument, is that the IOCTL() SWI protected thing
is pretty much guaranteed to work...
Yes, I know that what I am doing is not elegant, and perhaps a bit
over-engineered and maybe, in the long run unnecessary....
But, I have been bitten too many times with issues such as this;
thereforem my cautious approach.
So...you are quite correct Brendan; there really is nothing
specifically staing the fact that you need to stuff those two WDT
values back-to-back in the Philips UM.
However, this appears to not be a new issue within this forum. In
fact, this is how I found out that this is an issue to begin with.
Through this forum!!! There appears to be many other 'real world'
users out there that have had exactly the same experience as I have on
regards to this issue.
Again...about the interrupts...basically I am coding all my protected
stuff using the well-known IOCTL() model wrappered within an SWI
interface...Instead of 'trying' different things...There was enough
stated in the ARM reference manual, and the Philips UM that got me
really paranoid about the whole thing....> so...> I decided that
caution was the best approach, and took the more circuitous...but
guarranteed to work approach for affecting the driver interface to an
ISR.
By the way; if you look at the Philips interrupt-driven UART ISR,
(here in this forum, under files); they took exactly the same approach
in interfacing the main thread with the UART variables....They
protected it using an SWI wrapper!!!
If it is good enough for Philips...I guess it probably is good enough
for me
Besides; I already understand and know the IOCTL()/SWI model; this
approach to device drivers is well established and well known.
My 1st exposure to this model came from analyzing all of that Borland
MSDOS code that ran on those old x86 machines!
Ken Wada
> wrote:
> Ken,
> says?
> apart).
> Regards
> Brendan
> > --- In lpc2000@...m, "brendanmurphy37"
> > > wrote:
> > > Ken,
> interrupt
> > space
> has
> > to
> > cycle
> I'm
> > watchdog.
> expects
> in
> with
> architecture.
> from
> 8051..
> to
> do
> some
> chip
> command
> > Ken Wada
> > > regards
> > > Brendan
> > > > This is why:
> > > > void WDOG_pet()
> > > > WDFEED = 0xAA;
> > > properly!!!
> > > > WDFEED = 0x55;
> avoid
> > > that
> > > unsigned
> > > > _user1) __swi(12)
> > > >     switch (opcode)
> > > >         break;
> > > >     return (0);
> > > disabled
> > > >     WDFEED  = 0xAA;
> > > >     WDFEED  = 0x55;
> > > FIQ
> SWI..
> > FIQ,
> > > >       MRS   R0,CPSR
FIQ
> > > >       MSR   CPSR_c,R0
> > > >       BX    R14
> > > >       ENDP
> > > >       MRS   R0,CPSR
> FIQ
> > > >       MSR   CPSR_c,R0
> > > >       BX    R14
> > > >       ENDP
> > > > END
> > > <akhe@b...>
> > > > wrote:
> > > > > Hi all.
> > hang
> > > of
> > > > the
> the
> > > crash
> > > > and
> > > > botloader
> 15000000;                        //
> > One
> > > > second
> > > > > = 15000000
> > > watchdog
> doing
> > > > wrong?
> > minutes
> follow
> > > > should
> I
> > > get a
> > > > hang.
> > > > > /Ake
2005-12-10 by Karl Olsen
Sent: Saturday, December 10, 2005 12:17 AM
> ok...
> SO...
> this message.
OK, it certainly looks like an interrupt between the feed writes will reset
the CPU.  All the manuals, including the new LPC2103 manual, have the same
wording about WDFEED.  philips_apps, is this a bug in the manuals or in the
chips?
Karl Olsen
2005-12-10 by Ken Wada
I have been wondering about that myself.
If you look very closely at the past threads, in this forum, others
have been wondering about this also.
I have scoured all the LPC2xxx errata; and I have found no mention of
this either.
It could very well be that certain revisions of the LPC22xx silicon
may have this feature, whereas the later revisions may not, or that
there is an errata in the UM.
In either case, I am very happy with the current state of affairs with
my customer's projects using the LPC22xx...In that they all work
pretty much flawlessly, (where the WDT is concerned).
To date, the best information I have gotten, on some of the 'features
of the LPC22xx' has come from this forum.
These caveats include:
1.  WDT issues
2.  PLL setup and the VPB divider errata
3.  Changing between default level-triggered vs. edge triggered
interrupts, (don't do this!)
4.  Changing between default low-level vs. high-level interrupt
source, (again, don't do this!)
5.  Of course, the oft-repeated spurious interrupt issue. There was
enough within the manuals, and this forum to scare me into doing
something over-engineered (in my opinion)...but is guaranteed to work.
What I have done, in general, is read all the threads on these various
topics, and try to ascertain how much trouble people out there are
having with the various LPC2xxx issues.
Ken Wada
> > ok...
interrupt
pulling
would
made
> > SO...
from
> > this message.
will reset
the same
in the
> chips?
> Karl Olsen
2005-12-10 by Robert Adsett
>SUBS pc, lr, #4
Which, of course,  is what it should do since that is what  was being asked
of it.
IE the sequence
disable interrupts
critical code
restore interrupts
will always result in the interrupts being re-enabled at the end.
The only problems that occur are if the code following the interrupt
disable sequence is using tricky flag manipulation to determine if it is in
an interrupt or not, or if you are using both IRQs and FIQs.  The later
case strikes me as far more likely and there are several simple
work-arounds for that. the simplest being to disable the IRQ and FIQ in
sequence rather than both at once where you need critical region protection.
However if you either don't use the FIQ or don't care if it is occasionally
disabled during an IRQ the status register manipulation should be safe.  I
don't see any reason for the interrupt detection code to be much more than
a parlour trick, although I could be convinced otherwise.
Robert
2005-12-10 by brendanmurphy37
Ken,
Thanks for the reference to the previous discussion on this: it's
exactly what I was looking for (confirmation/proof that there is
indeed a problem).
By the way, I think you may have misunderstood my comment on the
interrupt issue. No need to explain where you're coming from: far
from suggesting you change, I'd strongly advise keeping what you
have, if it works and causes no problems. I've seen too many cases
of (inexperienced) engineers tweaking something that works to "make
it more efficient", only to see it explode in people's faces further
down the line. As you point out, there's nothing better then the
knowledge of maybe tens or hundreds of thousands of units in the
field to focus the mind on reliability as THE primary consideration.
It was more for the benefit of others who may be reading to point
out there are much simpler ways of working around the quirks of ARM
interrupts (which also give 100% reliability). Personally, I find
this forum very useful, particularly in the mix of people
contributing, from hobbyists to professionals, each bringing a
particular perspective.
One thing I've learnt is that there is almost never one correct
solution to a problem. In fact, if you can't think of two or three
solutions to a particular problem, you probably don't understand it
well enough in the first place.
My own lesson from this is that I should really have searched the
message archive for watchdog issues before starting.
I think it's a big help too to have Philips actively monitor this
forum: I've no doubt they will react positively to this and other
issues, and provide ammended or new documantation to describe the
various issues with the parts.
Brendan
> ok...
interrupt
pulling
would
made
> SO...
from
> this message.
SWI
from
> happening)
> AND...
now.
> CPSR...
there
interrupt
a
to
> queueing and such.
requires a
device
> driver.
thing
have on
protected
enough
an
> ISR.
approach
enough
> for me
Borland
> Ken Wada
> > wrote:
> > Ken,
It
from
it
> > says?
(I've
you
> > apart).
of "gotchas"
but I
of
how
course,
very
> > Regards
> > Brendan
> > > > wrote:
> > > > Ken,
> > interrupt
register
> > > space
register
> > has
> > > to
one
> > > cycle
interrupt)?
> > I'm
> > > watchdog.
> > expects
an
much
FIQ
> > in
problem
> > with
> > architecture.
problem.
directly
> > from
per
> > 8051..
comes
> > to
to
> > do
via
> > some
> > chip
> > command
> > > Ken Wada
> > > > regards
> > > > Brendan
> > > > > This is why:
> > > > > void WDOG_pet()
> > > > > WDFEED = 0xAA;
> > > > properly!!!
> > > > > WDFEED = 0x55;
> > avoid
> > > > that
*pObj,
> > > > unsigned
> > > > > _user1) __swi(12)
> > > > >     switch (opcode)
> > > > >         break;
> > > > >     return (0);
> > > > disabled
> > > > >     WDFEED  = 0xAA;
> > > > >     WDFEED  = 0x55;
> > > > FIQ
> > SWI..
respect to
> > > FIQ,
> > > > >       MRS   R0,CPSR
> FIQ
> > > > >       MSR   CPSR_c,R0
> > > > >       BX    R14
> > > > >       ENDP
> > > > >       MRS   R0,CPSR
> > FIQ
> > > > >       MSR   CPSR_c,R0
> > > > >       BX    R14
> > > > >       ENDP
> > > > > END
> > > > <akhe@b...>
> > > > > wrote:
> > > > > > Hi all.
total
> > > hang
> > > > of
> > > > > the
after
> > the
> > > > crash
> > > > > and
> > > > > botloader
> > 15000000;                        //
> > > One
> > > > > second
> > > > > > = 15000000
Activate
> > > > watchdog
I
> > doing
> > > > > wrong?
5
> > > minutes
that
> > follow
> > > > > should
register
> > I
> > > > get a
> > > > > hang.
> > > > > > /Ake
2005-12-10 by Ake Hedman, eurosource
Hi and thankyou for this discussion.
I just want to confirm that my problems also go away when I turn of
IRQ's while feeding the dog. I have just tested it on a minimalistic
sample where I only have I2C and UART interrupts and where the problem
starts as soon as I add the I2C code.
I will try this on my real application and report back.
You are all worth a beer on me tonight  (if I only could reach you...).
Lets hope that Karma things works... :-)
/Ake
> Ken,
> indeed a problem).
> Brendan
> > ok...
> interrupt
> pulling
> would
> made
> > SO...
> from
> > this message.
> SWI
> from
> > happening)
> > AND...
> now.
> the
> > CPSR...
> there
> interrupt
> a
> to
> > queueing and such.
> requires a
> device
> > driver.
> thing
> have on
> protected
> enough
> an
> > ISR.
> approach
> enough
> > for me
> Borland
> > Ken Wada
> > > wrote:
> > > Ken,
> It
> from
> it
> > > says?
> (I've
> you
> the
> > > apart).
> of "gotchas"
> but I
> of
> how
> the
> course,
> very
> > > Regards
> > > Brendan
> > > > > wrote:
> > > > > Ken,
> > > interrupt
> register
> > > > space
> the
> register
> > > has
> > > > to
> one
> > > > cycle
> interrupt)?
> > > I'm
> > > > watchdog.
> > > expects
> an
> much
> FIQ
> > > in
> problem
> > > with
> > > architecture.
> problem.
> directly
> > > from
> per
> > > 8051..
> comes
> > > to
> to
> > > do
> via
> > > some
> > > chip
> > > command
> > > > Ken Wada
> > > > > regards
> > > > > Brendan
> > > > > > This is why:
> > > > > > void WDOG_pet()
> > > > > > WDFEED = 0xAA;
> > > > > properly!!!
> > > > > > WDFEED = 0x55;
> > > avoid
> > > > > that
> *pObj,
> > > > > unsigned
> > > > > > _user1) __swi(12)
> > > > > >     switch (opcode)
> > > > > >         break;
> > > > > >     return (0);
> > > > > disabled
> > > > > >     WDFEED  = 0xAA;
> > > > > >     WDFEED  = 0x55;
> > > > > FIQ
> the
> > > SWI..
> respect to
> > > > FIQ,
> > > > > >       MRS   R0,CPSR
> the
> > FIQ
> > > > > >       MSR   CPSR_c,R0
> > > > > >       BX    R14
> > > > > >       ENDP
> > > > > >       MRS   R0,CPSR
> the
> > > FIQ
> > > > > >       MSR   CPSR_c,R0
> > > > > >       BX    R14
> > > > > >       ENDP
> > > > > > END
> > > > > <akhe@b...>
> > > > > > wrote:
> > > > > > > Hi all.
> total
> > > > hang
> > > > > of
> > > > > > the
> after
> > > the
> > > > > crash
> > > > > > and
> the
> > > > > > botloader
> > > 15000000;                        //
> > > > One
> > > > > > second
> > > > > > > = 15000000
> Activate
> > > > > watchdog
> I
> > > doing
> > > > > > wrong?
> 5
> > > > minutes
> that
> > > follow
> > > > > > should
> register
> > > I
> > > > > get a
> > > > > > hang.
> > > > > > > /Ake
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
2005-12-10 by Martin Maurer
Why Karma ? Use Paypal... :-)
        Martin
Sent: Saturday, December 10, 2005 2:22 PM
Subject: Re: [lpc2000] Re: Problem with watchdog
/Ake
> Ken,
> indeed a problem).
> Brendan
> > ok...
> interrupt
> pulling
> would
> made
> > SO...
> from
> > this message.
> SWI
> from
> > happening)
> > AND...
> now.
> the
> > CPSR...
> there
> interrupt
> a
> to
> > queueing and such.
> requires a
> device
> > driver.
> thing
> have on
> protected
> enough
> an
> > ISR.
> approach
> enough
> > for me
> Borland
> > Ken Wada
> > > wrote:
> > > Ken,
> It
> from
> it
> > > says?
> (I've
> you
> the
> > > apart).
> of "gotchas"
> but I
> of
> how
> the
> course,
> very
> > > Regards
> > > Brendan
> > > > > wrote:
> > > > > Ken,
> > > interrupt
> register
> > > > space
> the
> register
> > > has
> > > > to
> one
> > > > cycle
> interrupt)?
> > > I'm
> > > > watchdog.
> > > expects
> an
> much
> FIQ
> > > in
> problem
> > > with
> > > architecture.
> problem.
> directly
> > > from
> per
> > > 8051..
> comes
> > > to
> to
> > > do
> via
> > > some
> > > chip
> > > command
> > > > Ken Wada
> > > > > regards
> > > > > Brendan
> > > > > > This is why:
> > > > > > void WDOG_pet()
> > > > > > WDFEED = 0xAA;
> > > > > properly!!!
> > > > > > WDFEED = 0x55;
> > > avoid
> > > > > that
> *pObj,
> > > > > unsigned
> > > > > > _user1) __swi(12)
> > > > > >     switch (opcode)
> > > > > >         break;
> > > > > >     return (0);
> > > > > disabled
> > > > > >     WDFEED  = 0xAA;
> > > > > >     WDFEED  = 0x55;
> > > > > FIQ
> the
> > > SWI..
> respect to
> > > > FIQ,
> > > > > >       MRS   R0,CPSR
> the
> > FIQ
> > > > > >       MSR   CPSR_c,R0
> > > > > >       BX    R14
> > > > > >       ENDP
> > > > > >       MRS   R0,CPSR
> the
> > > FIQ
> > > > > >       MSR   CPSR_c,R0
> > > > > >       BX    R14
> > > > > >       ENDP
> > > > > > END
> > > > > <akhe@b...>
> > > > > > wrote:
> > > > > > > Hi all.
> total
> > > > hang
> > > > > of
> > > > > > the
> after
> > > the
> > > > > crash
> > > > > > and
> the
> > > > > > botloader
> > > 15000000;                        //
> > > > One
> > > > > > second
> > > > > > > = 15000000
> Activate
> > > > > watchdog
> I
> > > doing
> > > > > > wrong?
> 5
> > > > minutes
> that
> > > follow
> > > > > > should
> register
> > > I
> > > > > get a
> > > > > > hang.
> > > > > > > /Ake
> SPONSORED LINKS
> Microprocessor
> Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
Yahoo! Groups Links
/Ake
> Regards,
>         Martin
> From: "Ake Hedman, eurosource" <akhe@...>
> /Ake
> > Ken,
> > indeed a problem).
> > Brendan
> > > ok...
> > interrupt
> > pulling
> > would
> > made
> > > SO...
> > from
> > > this message.
> > SWI
> > from
> > > happening)
> > > AND...
> > now.
> > the
> > > CPSR...
> > there
> > interrupt
> > a
> > to
> > > queueing and such.
> > requires a
> > device
> > > driver.
> > thing
> > have on
> > protected
> > enough
> > an
> > > ISR.
> > approach
> > enough
> > > for me
> > Borland
> > > Ken Wada
> > > > wrote:
> > > > Ken,
> > It
> > from
> > it
> > > > says?
> > (I've
> > you
> > the
> > > > apart).
> > of "gotchas"
> > but I
> > of
> > how
> > the
> > course,
> > very
> > > > Regards
> > > > Brendan
> > > > > > wrote:
> > > > > > Ken,
> > > > interrupt
> > register
> > > > > space
> > the
> > register
> > > > has
> > > > > to
> > one
> > > > > cycle
> > interrupt)?
> > > > I'm
> > > > > watchdog.
> > > > expects
> > an
> > much
> > FIQ
> > > > in
> > problem
> > > > with
> > > > architecture.
> > problem.
> > directly
> > > > from
> > per
> > > > 8051..
> > comes
> > > > to
> > to
> > > > do
> > via
> > > > some
> > > > chip
> > > > command
> > > > > Ken Wada
> > > > > > regards
> > > > > > Brendan
> > > > > > > This is why:
> > > > > > > void WDOG_pet()
> > > > > > > WDFEED = 0xAA;
> > > > > > properly!!!
> > > > > > > WDFEED = 0x55;
> > > > avoid
> > > > > > that
> > *pObj,
> > > > > > unsigned
> > > > > > > _user1) __swi(12)
> > > > > > >     switch (opcode)
> > > > > > >         break;
> > > > > > >     return (0);
> > > > > > disabled
> > > > > > >     WDFEED  = 0xAA;
> > > > > > >     WDFEED  = 0x55;
> > > > > > FIQ
> > the
> > > > SWI..
> > respect to
> > > > > FIQ,
> > > > > > >       MRS   R0,CPSR
> > the
> > > FIQ
> > > > > > >       MSR   CPSR_c,R0
> > > > > > >       BX    R14
> > > > > > >       ENDP
> > > > > > >       MRS   R0,CPSR
> > the
> > > > FIQ
> > > > > > >       MSR   CPSR_c,R0
> > > > > > >       BX    R14
> > > > > > >       ENDP
> > > > > > > END
> > > > > > <akhe@b...>
> > > > > > > wrote:
> > > > > > > > Hi all.
> > total
> > > > > hang
> > > > > > of
> > > > > > > the
> > after
> > > > the
> > > > > > crash
> > > > > > > and
> > the
> > > > > > > botloader
> > > > 15000000;                        //
> > > > > One
> > > > > > > second
> > > > > > > > = 15000000
> > Activate
> > > > > > watchdog
> > I
> > > > doing
> > > > > > > wrong?
> > 5
> > > > > minutes
> > that
> > > > follow
> > > > > > > should
> > register
> > > > I
> > > > > > get a
> > > > > > > hang.
> > > > > > > > /Ake
> > SPONSORED LINKS
> > Microprocessor
> > Microcontrollers
> > 8051 microprocessor
> > YAHOO! GROUPS LINKS
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
OK Guys,
I can confirm that the WD problem is solved in my case. Thanks a lot
all!  (Description of solution below.)
I think this definitely should be mentioned in the err data sheets for
the affected processors (or clearly in the UM)  as the resulting
symptoms are such that the problem is very hard to debug..
Cheers
/Ake
How I solved it:
I have replaced all dog-feeds with
        mycpsr = disableIRQ();
        restoreIRQ( mycpsr );
where disableIRQ and restoreIRQ is from R O Software
 * $RCSfile: armVIC.c,v $
 * $Revision: 1.1 $
 * This module provides the interface routines for setting up and
 * controlling the various interrupt modes present on the ARM processor.
 * Copyright 2004, R O SoftWare
 * No guarantees, warrantees, or promises, implied or otherwise.
 * May be used for hobby or commercial purposes provided copyright
 * notice remains intact.
#include "types.h"
#include "armVIC.h"
#define IRQ_MASK 0x00000080
#define FIQ_MASK 0x00000040
#define INT_MASK (IRQ_MASK | FIQ_MASK)
static inline unsigned __get_cpsr(void)
  unsigned long retval;
  asm volatile (" mrs  %0, cpsr" : "=r" (retval) : /* no inputs */  );
  return retval;
static inline void __set_cpsr(unsigned val)
  asm volatile (" msr  cpsr, %0" : /* no outputs */ : "r" (val)  );
unsigned disableIRQ(void)
  unsigned _cpsr;
  _cpsr = __get_cpsr();
  __set_cpsr(_cpsr | IRQ_MASK);
  return _cpsr;
unsigned restoreIRQ(unsigned oldCPSR)
  unsigned _cpsr;
  __set_cpsr((_cpsr & ~IRQ_MASK) | (oldCPSR & IRQ_MASK));
  return _cpsr;
unsigned enableIRQ(void)
  unsigned _cpsr;
  __set_cpsr(_cpsr & ~IRQ_MASK);
  return _cpsr;
unsigned disableFIQ(void)
  unsigned _cpsr;
  __set_cpsr(_cpsr | FIQ_MASK);
  return _cpsr;
unsigned restoreFIQ(unsigned oldCPSR)
  unsigned _cpsr;
  __set_cpsr((_cpsr & ~FIQ_MASK) | (oldCPSR & FIQ_MASK));
  return _cpsr;
unsigned enableFIQ(void)
  unsigned _cpsr;
  __set_cpsr(_cpsr & ~FIQ_MASK);
  return _cpsr;
2005-12-11 by Tom Walsh
>OK Guys,
>Cheers
>/Ake
>How I solved it:
I've been following this thread with interest as I expected to use the
watchdog in my application.  The old design used a MAX690 where you
would toggle the input to keep the watchdog happy.  This worked well for
us as the foreground software would set the pin high and the interrupt
routines would reset it low.  This ensured that both sections of the
program were operating okay.  Foreground did non-time-critical tasks
while the background serviced realtime critical tasks & communications
over RS485.
I had expected to do something similar with the LPC2000 parts.  Feed the
watchdog with 0xaa from the interrupt layer and then feed it with 0x55
from the foreground.  It was expected that even if the watchdog received
something like this, it would still be fine:
0xaa, 0xaa, 0xaa, 0x55, 0xaa, 0xaa, 0xaa, 0xaa, 0x55 ....
What value is a watchdog that requires you to carefully feed it, it
sounds as if the watchdog is very fragile?  I noticed that Philips
Applications people studiously stayed out of this thread about the
watchdog!  I suspect that the watchdog is severly broken and they did
not want to comment on it?
TomW
2005-12-11 by Ake Hedman, eurosource
> over RS485.
> Regards,
> TomW
At least I would say that its a bit strange behavior for a watchdog.
Anyway there is a work around and it appears to work well (at least in
my case). I have only noticed this on the LPC2138 part so I don't know
if the same "problem" appears on other silicon. If it is that would have
been nice to now though.
/Ake
2005-12-11 by Robert Adsett
>over RS485.
Actually, that is rather the point.  The idea is to prevent being able to
accidentally satisfy the watchdog with writes from multiple places in the
program.  Watchdogs are supposed to be somewhat twitchy.  Even so an
internal watchdog doesn't usually catch events like loss of
oscillator.  The Philips watchdog also appears to allow the trip time to be
reprogrammed during operation which is a big weakness.
BTW this is not an unusual requirement for microcontroller based watchdogs,
at least in my experience.
You may find (if you haven't read it already) Jack Ganssle's article on
watchdogs interesting.  http://www.ganssle.com/watchdogs.pdf
Actually, from these accounts the watchdog is fine.  The documentation
needs to be updated though.  The line referring the watchdog register space
probably needs to be updated to match the wording used for the PLLFEED
register which explicitly refers to back to back VPB writes being
needed.  I expect the two peripherals are using identical logic.
I wouldn't mind that period hole being fixed though, and maybe even seeing
a minimum time between feeds enforced.
Robert
2005-12-11 by derbaier
received
> Regards,
> TomW
It sounds like you have described a really robust watchdog timer!!
It detects and stops fragile software.
It's function is NOT to make life easy for the software developer, it
is to make the system more reliable for the end user by forcing good
software and hardware design.  The watchdog kick should always be
cosecutive instructions to reduce the possibility of random events
from kicking the timer.
At least, that was the philosophy of the ASIC teams that I have worked
with.
--Dave
> the
> received
> > Regards,
> > TomW
> with.
> --Dave
The absolute majority of watchdogs, internal or external, function by
toggling a bit  from time to time. Where in the code  you do this
toggling is something you have to investigate for each project. The
common point in any case is that if the program pass a certain point in
the flow we allow the application to live for n milliseconds more.
The 0xAA, 0x55 sequence is nothing else either. It may look safer then
toggling a bit but false watchdog triggers have never been a problem for
an extended time during my years as an embedded developer. The chance
that your crashed program start to toggle a watchdog bit or write a
0xAA, 0x55 sequence is just minimal and in that light I think Tom's
reasoning is fully correct and would not make the watchdogs
functionality less good. At least IMHO.
But requiring the 0xAA,0x55 sequence is acceptable to of course. The
need to mask interrupts while doing it is not. Thats really bad.
/Ake
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavägen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 84 84 102
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
Umm minimal chances are what the watchdog is there to protect against.  If
the chance isn't minimal you can make a very good case that is should be
covered in your application code and dealt with there.
This is far from unusual.  To quote from the 8xc196MC user manual
"We recommend that you disable interrupts before writing to the watchdog
register.  If an interrupt occurs between two writes, the watchdog register
will not be cleared."
The Freescale M68HC11 family acts in the manner you suggest, while the
ST10/C167 family from ST and Infinion use a single 'protected instruction'
which is effectively two instructions in series to perform the
feed.  Effectively ST/Infinion have integrated the feed and interrupt
protection into a single instruction.  Note that the later family also
implements Oscillator watchdogs on many of the family members.
Robert
True enough.  :-)
for
Minimal is NOT zero, so conservative hardware design pratices dictate
erring on the side of caution.  IMHO, that reasoning makes the
software design task easier, but makes the watchdog less reliable when
atomic kick sequences are not required.
Bad is probably a matter of opinion?
More difficult, certainly.
The need for atomic code sequences is not all that unusual, so it is
just something that needs to be dealt with in the software design,IMHO.
-- Dave
2005-12-12 by brendanmurphy37
Robert,
Thanks for the reference to the watchdog paper - I hadn't seen it
before, and it's certainly very good i/p to watchdog design.
I'd agree with the argument that to be really robust, you need to
consider more than just an on-board watchdog with something giving it
a feed now and then.
Tom: putting together a system where the background does half the
watchdig task, and interrupts the other is a good idea in principle.
However, it does need careful thought as to the detail: I have seen
such a scheme fail: the watchdog needed to toggle a pin to be fed.
The main (system) loop put the pin one way and a timer interrupt put
it another. The problem was the system could get into a state (after
a very heavy burst of RF noise) where the watchdog was being fed, but
the system was effectively dead as not much else was running.
Jack Ganssle's paper gives one way out of this (a supervisory task
monitoring the health of all other tasks). There are alternatives.
For example, we have a watchdog message passed from one active task
to the other (if it's in a happy state): if it reaches the watchdog
task, the watchdog gets set (from one and only one location that's
not in a loop). A new message is then generated by the watchdog task
with a one second delay. In other words, for the watchdog to be fed,
all the system's tasks/components have to be in a "happy" state, task
scheduling, timers etc. all have to be working. It's really down to
balance between what gives good coverage to complexity of
implementation etc.
For what it's worth, my own view is:
- the LPC2000 watchdog is fine for an on-board watchdog (with
corrected documentation!)
- to detect all failures, you have to go to an off-chip watchdog (or
at least one that doesn't use ANY shared component - in particular
the clock)
- you need to put some thought into the software to drive it: simple
minded implementations will give better than nothing, but can be
greatly imrpoved on
- try not to feed a watchdog from a software loop: there's a chance a
wayword processor will end up in that loop
- the AA, 55 (or similar) feed sequence is better than the
alternative of not having one (but not by much!)
Brendan
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
well for
interrupt
tasks
communications
> >over RS485.
Feed the
0x55
received
able to
in the
an
time to be
watchdogs,
article on
did
documentation
register space
PLLFEED
seeing
> Robert
restrictions,   be
chew a
2005-12-12 by Ken Wada
>How I solved it:
> WDFEED = 0xAA; WDFEED = 0x55;
Precisely my point. It appears as if this is an extra undocumented
feature.
Ken Wada
> >OK Guys,
lot
for
> >Cheers
> >/Ake
> >How I solved it:
for
interrupt
communications
> over RS485.
0x55
received
did
> Regards,
> TomW
2005-12-13 by Robert Adsett
I first started using that technique about 10 years ago.  My usual way is
to have the watchdog supervisor in a periodic interrupt (sometimes the main
clock tick) watching a number of countdown watchdog timers and flags, one
of each for each task or process being monitored.  Each cycle of the
supervisor decrements the countdown timers and if none of them have overrun
feeds the watchdog.  As soon as one is no longer fed the watchdog no longer
gets fed.
As additional protection the task countdown timers are hamming protected so
overwrites are less likely to give valid results.  The flags usually are
required to have some sort of sequence or specific value (ie just setting
them to any old value is not sufficient).  As well the task timers are not
regarded as active until they have first been fed but they cannot be turned
off.
They can be made fancier from there but that is sufficient to put watchdogs
in as many periodic tasks and interrupts as you can afford the overhead
for.  In my systems that usually only amounts to a small handful that you
want to watch anyway.
Robert
2005-12-13 by brendanmurphy37
Robert,
What you suggest sounds like a good approach: the key thing that it
achieves is to get as much coverage as possible and minimise the risk
of false feeds to the watchdog. The challenge, as always, is to
balance this against complexity and time to implement.
A couple of other key ideas I'd add to the mix:
- Design the system as if there's no watchdog: if you don't do this,
you can get into the (lazy) mode of always saying "oh, the watchdog
will sort that out.....". This is one reason I tend to encourage
implementing the watchdog as the last feature, and not one that the
system depends on to do its basic function. That is, get your system
fully functional and reliable, and then add in a watchdog (after
fully testing it of course).
- I'd strongly agree with Jack Ganssle's paper that to be really
effective, a watchdog must reset the processor and all its
peripherals. I haven't come up against it on the LPC2000 series, but
other MCUs can get some of their peripherals into various locked
states that can only be removed by an external MCU reset (i.e. the
CPU can't clear it by resetting the device control registers). In
other words, a simple "jump to zero", and re-initialise peripherals
isn't guaranteed to work. It's this kind of stuff you really only
learn from experience (and forums like this): they don't tend to
mention it in device data sheets for some reason.
Brendan
way is
the main
flags, one
overrun
no longer
> gets fed.
protected so
usually are
setting
are not
be turned
> off.
watchdogs
overhead
that you
> Robert
restrictions,   be
chew a
