Lpc2000
VSS and VDD lines
VSS and VDD lines
2005-02-08 by Owen Mooney
I hope this question is not too ignorant!
Is it necessary to link to all the VSS and VDD lines in the chip?
I'm working on a tight 2 layer layout.
Why are there so many?
Owen Mooney
Re: [lpc2000] VSS and VDD lines
2005-02-08 by Robert Adsett
I haven't seen any indication otherwise.
So many?  I only counted 4 (well 3 1/2) sets (one per side for the 2106).
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
2005-02-08 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Tuesday, February 08, 2005 8:59 PM
Subject: [lpc2000] VSS and VDD lines
I wouldn't just tie them together, I'd decouple each Vdd pin with its own
capacitor. That's why they are brought out to separate pins.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.8.6 - Release Date: 07/02/2005
Re: VSS and VDD lines
2005-02-08 by lpc2100_fan
Owen,
if anything the LPC2000 devices do not have enough VDD/VSS pairs. If
you do not connect them all the chip MIGHT still run but usually the
pairs are responsible to provide power to logical blocks close to the
pins. Internally power is usually connected but you might loose some
voltage along the internal power traces.  If you do so, you reduce the
possible performance of the chip.
As a result you could see random effects of some stuff not working or
temperature dependencies, almost impossible to find with debugging.
To avoid this trouble either for you and / or your customers, you
really want to connect all VDD/VSS pairs. For a clean power you should
also follow Leon's proposal to decouple each pair.
hth, Bob
--- In lpc2000@yahoogroups.com, "Leon Heller" <leon.heller@d...> wrote:
> From: "Owen Mooney" <ojm@s...>
its own
> Leon
2005-02-08 by tonalbuilder2002
A quad package on a 2 layer board is one of the more annoying layout
problems, except just be glad you're not dealing with a BGA.
On the chip side, fan out all the traces at least 1 cm away from the
chip, terminating at vias...consider the vias to be the start of your
routing, not the pins on the chip.  Don't bring out any logic vias
under the chip, this leaves you maneuvering room.  Run wide VSS and
VDD traces on the non-chip side of the board to a 10 to 50 ufd
Tantalum located right under the chip.  From the leads of the
Tantalum, spider out individual traces to each of the VDD/VSS pairs,
with at least a 100nf capacitor located as near as possible to each
pair. This individual decoupling of each VDD/VSS pair is essential.
Remember your reputation rides on your product, take whatever time
needed to do it right.
A major point is to try to mount all the discretes on the side
opposite the chips, this makes your topside fanouts and routing a lot
easier to deal with, and the board fab will love you much more if
you're going that route.
Bill T.
http://www.kupercontrols.com
Re: [lpc2000] Re: VSS and VDD lines
2005-02-08 by Robert Wood
If you're struggling for space, why not use 0603 or smaller caps?
Owen,
hth, Bob
its own
> Leon
Yahoo! Groups Links
2005-02-09 by Owen Mooney
Thanks for the replies on this. I'm a software engineer learning hardware...
But the suggestion:
"On the chip side, fan out all the traces at least 1 cm away from the
routing, not the pins on the chip. "
Would actually make some of the vias off the board!! -
I will certainly add some capacitors - I should be able to get at least 3 under the chip.
Owen
2005-02-09 by Rick Collins
hardware...
> But the suggestion:
< long post >
I'm not trying to put anyone down, but software people normally need
to learn a lot before attempting to do a hardware design.  Power
decoupling is one of the areas where there are a lot of misconceptions
and the board can be very unforgiving.  Most of the newer ARM chips
use a separate voltage for the core and the IO drivers.  This is good
for decoupling because they have different problems.  The IOs need to
be well decoupled because driving external lines can require large
transient currents during switching.  If the decoupling between Vdd
pins and Vss pins is not up to snuff, you will see this current
produce a large voltage on the ground and power pins.  This can cause
errors because the chip sees incorrect voltages between the grounds
and the signals.  It can even cause the clock to double strobe.
The core supply is also important to decouple because of the higher
clock rates and edge rates inside the chip.  If you get voltage spikes
on the Vcore rail, you can see transient errors in calculations and
execution.  This will be *VERY* hard to debug.
So do not skimp on the decoupling.  You may get away with it, or you
may end up with a flakey board that is nearly impossible to debug.
Now for the correct (or maybe ideal) decoupling method...  Use one 0.1
uF ceramic cap per Vdd pin.  Route the other side of the cap to the
nearest Vss pin with as short a loop area as possible.  The area of
the loop is what is important since the goal is to minimize inductance
and that depends on the area of the loop.  Don't underestimate the
importance of this since the edge rates are the culprit here, not the
clock speed and edge rates can be very high (>500 MHz easily) Each
voltage rail should also have at least one healthy tantalum or
electrolytic cap, 10 uF or larger.  This will help with droop
(frequencies lower than the clock speed).  I made a board once where I
used 10 uF and had an analog circuit that was very sensitive to power
noise.  The DSP was in a 300 Hz loop passing blocks of data to and
from the codec.  Guess what, I got a low level 300 Hz hum in the
audio.  The real problem was the audio component that had exactly 0 dB
of PSRR, but a larger cap would have masked the problem adequately.
Hope I didn't over load anyone with a long post.
2005-02-09 by Jan Szymanski
Is this a serious design or just to play with the chip ?
If it is for playing than it is cheaper to buy an eval board (see
Olimex)
If it is serious, with 2 layer, you have very little chance to go
through EMC aprovals. Check what is the difference in price between 2
and 4 layer pcb and compare it to the value of your time.
(see other email for the rules of decoupling)
good luck
Jan
> Owen Mooney
2005-02-09 by tlarson_greatnotions
Jan,
In our case, using a LPC2214 and a two layer board. We had
no problems with compliance testing.  In fact our very first
board using this part, passed with quite a wide margin.
In our experience, it's rarely the cpu that causes problems
with EMC, but all the other stuff that's on the board, or
what the board connects to.
Do to the volumes we produce, we always start with two layers,
and all parts on one side.  We only go to more layers if we
have to...
From the manufacturing costs, two layer and all parts on one
side is the cheapest board to build.
Tim Larson
> Olimex)
between 2
> good luck
> Jan
> > Owen Mooney
Re: VSS and VDD lines // EMC
2005-02-09 by lpc2100_fan
Tim,
my experience with CPUs as major cause for trouble in EMC testing
seems a little different. Fortunately the LPC2000 devices have a slew
rate of 10 ns, this makes the bus rather non-critical for EMC. Many
devices drive the bus with "all they have got" in the drivers and this
generates massive EMC problems.
Cheers, Bob
--- In lpc2000@yahoogroups.com, "tlarson_greatnotions" <tlarson@g...>
wrote:
> Jan,
> have to...
> Tim Larson
> > Olimex)
> between 2
> > good luck
> > Jan
> > > Owen Mooney
