JTAG CONNECTOR
2005-03-25 by Micron Engineering
The standard 2x10 JTAG connector is very space consuming, is there any other standard configuration suggested for JTAG connector? Massimo Manca, Micron Engineering -- Internal Virus Database is out-of-date. Checked by AVG Anti-Virus. Version: 7.0.308 / Virus Database: 266.7.4 - Release Date: 18/03/2005
2005-03-25 by leon_heller
--- In lpc2000@yahoogroups.com, Micron Engineering <micronpn@t...> wrote: > The standard 2x10 JTAG connector is very space consuming, is there any > other standard configuration suggested for JTAG connector? > Massimo Manca, Micron Engineering Only seven connections are in fact used for the LPC2000. I'd select a suitable small connector and make an adaptor for it, interfacing to the standard connector. This sort of arrangement is quite common for other MCUs that use a JTAG connector, like the MSP430. That actually uses a 2x5 header as standard, but that is too big for some people. Leon
leon_heller wrote: >--- In lpc2000@yahoogroups.com, Micron Engineering <micronpn@t...> >wrote: > > >>The standard 2x10 JTAG connector is very space consuming, is there >> >> >any > > >>other standard configuration suggested for JTAG connector? >>Massimo Manca, Micron Engineering >> >> > >Only seven connections are in fact used for the LPC2000. I'd select a >suitable small connector and make an adaptor for it, interfacing to >the standard connector. This sort of arrangement is quite common for >other MCUs that use a JTAG connector, like the MSP430. That actually >uses a 2x5 header as standard, but that is too big for some people. > > 2x5 may be ok for me. May you send me the pinout? Best regards, Massimo Manca, Micron Engineering >Leon > > > > > > >Yahoo! Groups Links > > > > > > > > > > > ---------- Internal Virus Database is out-of-date. Checked by AVG Anti-Virus. Version: 7.0.308 / Virus Database: 266.7.4 - Release Date: 18/03/2005 [Non-text portions of this message have been removed]
2005-03-25 by Leon Heller
From: "Micron Engineering" <micronpn@...> To: <lpc2000@yahoogroups.com> Sent: Friday, March 25, 2005 2:01 PM Subject: Re: [lpc2000] Re: JTAG CONNECTOR > > leon_heller wrote: > >>--- In lpc2000@yahoogroups.com, Micron Engineering <micronpn@t...> >>wrote: >> >> >>>The standard 2x10 JTAG connector is very space consuming, is there >>> >>> >>any >> >> >>>other standard configuration suggested for JTAG connector? >>>Massimo Manca, Micron Engineering >>> >>> >> >>Only seven connections are in fact used for the LPC2000. I'd select a >>suitable small connector and make an adaptor for it, interfacing to >>the standard connector. This sort of arrangement is quite common for >>other MCUs that use a JTAG connector, like the MSP430. That actually >>uses a 2x5 header as standard, but that is too big for some people. >> >> > 2x5 may be ok for me. May you send me the pinout? > Best regards, Sorry, I was wrong. It's actually 2x7 and that's probably too big for you. Only seven pins are actually used, though. I'd just use 2x5 with your connection arrangement. Leon
2005-03-25 by Onestone
I use a 1.25mm pitch SMD or through hole part from Molex. cvomes in vertical or 90 degree, very compact, single or dual row, and around $0.20 in bulk from Taiwan. Up to 20 connectors. They're so tiny and cheap most of my boards get one. I posted the Farnell part number here a few weeks ago. have a look, if they suit you I can find out where in taiwan my contact gets them from Al Micron Engineering wrote:
> leon_heller wrote: > > >--- In lpc2000@yahoogroups.com, Micron Engineering <micronpn@t...> > >wrote: > > > > > >>The standard 2x10 JTAG connector is very space consuming, is there > >> > >> > >any > > > > > >>other standard configuration suggested for JTAG connector? > >>Massimo Manca, Micron Engineering > >> > >> > > > >Only seven connections are in fact used for the LPC2000. I'd select a > >suitable small connector and make an adaptor for it, interfacing to > >the standard connector. This sort of arrangement is quite common for > >other MCUs that use a JTAG connector, like the MSP430. That actually > >uses a 2x5 header as standard, but that is too big for some people. > > > > > 2x5 may be ok for me. May you send me the pinout? > Best regards, > > Massimo Manca, Micron Engineering > > > >Leon > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > ---------- > > Internal Virus Database is out-of-date. > Checked by AVG Anti-Virus. > Version: 7.0.308 / Virus Database: 266.7.4 - Release Date: 18/03/2005 > > > [Non-text portions of this message have been removed] > > > Yahoo! Groups Sponsor > ADVERTISEMENT > <http://us.ard.yahoo.com/SIG=129mm3o56/M=298184.6191685.7192823.3001176/D=groups/S=1706554205:HM/EXP=1111845768/A=2593423/R=0/SIG=11el9gslf/*http://www.netflix.com/Default?mqso=60190075> > > > > ------------------------------------------------------------------------ > Yahoo! Groups Links > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/lpc2000/ > > * To unsubscribe from this group, send an email to: > lpc2000-unsubscribe@yahoogroups.com > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > >------------------------------------------------------------------------ > >No virus found in this incoming message. >Checked by AVG Anti-Virus. >Version: 7.0.308 / Virus Database: 266.8.1 - Release Date: 23/03/2005 > >
--- In lpc2000@yahoogroups.com, Onestone <onestone@b...> wrote: > I use a 1.25mm pitch SMD or through hole part from Molex. cvomes in > vertical or 90 degree, very compact, single or dual row, and around > $0.20 in bulk from Taiwan. Up to 20 connectors. They're so tiny and > cheap most of my boards get one. I posted the Farnell part number here a > few weeks ago. have a look, if they suit you I can find out where in > taiwan my contact gets them from The 8-way Harwin M30-6100806 is available from Farnell (866118). I think those are the connectors Al referred to previously. I'll order a few next time I get some stuff from Farnell, although I have a feeling I've got some somewhere that I ordered a long time ago. I'll probably start using them myself. Leon
You're right Leon, I think it is Harwin. There are two suppliers. farnell only has the single row. My supplier gets them in double row too. Al leon_heller wrote:
> > --- In lpc2000@yahoogroups.com, Onestone <onestone@b...> wrote: > > I use a 1.25mm pitch SMD or through hole part from Molex. cvomes in > > vertical or 90 degree, very compact, single or dual row, and around > > $0.20 in bulk from Taiwan. Up to 20 connectors. They're so tiny and > > cheap most of my boards get one. I posted the Farnell part number > here a > > few weeks ago. have a look, if they suit you I can find out where > in > > taiwan my contact gets them from > > The 8-way Harwin M30-6100806 is available from Farnell (866118). I > think those are the connectors Al referred to previously. I'll order > a few next time I get some stuff from Farnell, although I have a > feeling I've got some somewhere that I ordered a long time ago. I'll > probably start using them myself. > > Leon > > > > > > > > Yahoo! Groups Sponsor > ADVERTISEMENT > <http://us.ard.yahoo.com/SIG=129n0d3fk/M=298184.6191685.7192823.3001176/D=groups/S=1706554205:HM/EXP=1111854094/A=2593423/R=0/SIG=11el9gslf/*http://www.netflix.com/Default?mqso=60190075> > > > > ------------------------------------------------------------------------ > Yahoo! Groups Links > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/lpc2000/ > > * To unsubscribe from this group, send an email to: > lpc2000-unsubscribe@yahoogroups.com > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > >------------------------------------------------------------------------ > >No virus found in this incoming message. >Checked by AVG Anti-Virus. >Version: 7.0.308 / Virus Database: 266.8.1 - Release Date: 23/03/2005 > >
2005-03-25 by Richard
Keeping the 20-pin connector is nice as it gives a ground wire between the signal wires (ribbon cable). Check out this AMP connector available at Digikey: A3103-ND Richard --- In lpc2000@yahoogroups.com, Onestone <onestone@b...> wrote: > You're right Leon, I think it is Harwin. There are two suppliers. > farnell only has the single row. My supplier gets them in double row too. > > Al > > leon_heller wrote: > > > > > --- In lpc2000@yahoogroups.com, Onestone <onestone@b...> wrote: > > > I use a 1.25mm pitch SMD or through hole part from Molex. cvomes in > > > vertical or 90 degree, very compact, single or dual row, and around > > > $0.20 in bulk from Taiwan. Up to 20 connectors. They're so tiny and > > > cheap most of my boards get one. I posted the Farnell part number > > here a > > > few weeks ago. have a look, if they suit you I can find out where > > in > > > taiwan my contact gets them from > > > > The 8-way Harwin M30-6100806 is available from Farnell (866118). I > > think those are the connectors Al referred to previously. I'll order > > a few next time I get some stuff from Farnell, although I have a > > feeling I've got some somewhere that I ordered a long time ago. I'll > > probably start using them myself. > > > > Leon > > > > > > > > > > > > > > > > Yahoo! Groups Sponsor > > ADVERTISEMENT > > <http://us.ard.yahoo.com/SIG=129n0d3fk/M=298184.6191685.7192823.3001176/D=groups/S=1706554205:HM/EXP=1111854094/A=2593423/R=0/SIG=11el9gslf/*http://www.netflix.com/Default?mqso=60190075> > > > > > > > > ------------------------------------------------------------------------
> > Yahoo! Groups Links > > > > * To visit your group on the web, go to: > > http://groups.yahoo.com/group/lpc2000/ > > > > * To unsubscribe from this group, send an email to: > > lpc2000-unsubscribe@yahoogroups.com > > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > >------------------------------------------------------------------------ > > > >No virus found in this incoming message. > >Checked by AVG Anti-Virus. > >Version: 7.0.308 / Virus Database: 266.8.1 - Release Date: 23/03/2005 > > > >
From: "Richard" <richas@...> To: <lpc2000@yahoogroups.com> Sent: Friday, March 25, 2005 5:29 PM Subject: [lpc2000] Re: JTAG CONNECTOR > > > Keeping the 20-pin connector is nice as it gives a ground wire between > the signal wires (ribbon cable). Check out this AMP connector > available at Digikey: > > A3103-ND Most of the cable will be 20-way, with the grounds. It's only the last couple of inches that will be 8-way, if a suitable adapter is made. Leon
2005-03-25 by tsvetanusunov
--- In lpc2000@yahoogroups.com, Micron Engineering <micronpn@t...> wrote: > The standard 2x10 JTAG connector is very space consuming, is there any > other standard configuration suggested for JTAG connector? > Massimo Manca, Micron Engineering > > Hi, you can check this adapter http://www.tetc.co.jp/sica/e_sica.htm small and nice with 0.5 mm step Best regards Tsvetan --- PCB prototypes for $26 at http://run.to/pcb (http://www.olimex.com/pcb) PCB any volume assembly (http://www.olimex.com/pcb/protoa.html) Development boards for ARM, AVR, PIC, MAXQ2000 and MSP430 (http://www.olimex.com/dev)
2005-03-26 by tkreyche
Check out the .5 pitch DF-12 series of connector from Hirose Electronic Co. Ltd. - here's a typical example - Digikey part number H2756-ND I'm going to give this a try and build both connectors on a small pcboard as Leon suggested earlier. Tom --- In lpc2000@yahoogroups.com, "Richard" <richas@y...> wrote: > > Keeping the 20-pin connector is nice as it gives a ground wire between > the signal wires (ribbon cable). Check out this AMP connector > available at Digikey: > > A3103-ND > > Richard > > > --- In lpc2000@yahoogroups.com, Onestone <onestone@b...> wrote: > > You're right Leon, I think it is Harwin. There are two suppliers. > > farnell only has the single row. My supplier gets them in double row
> too. > > > > Al
2005-03-26 by Leon Heller
From: "tkreyche" <tkreyche@...> To: <lpc2000@yahoogroups.com> Sent: Saturday, March 26, 2005 5:01 PM Subject: [lpc2000] Re: JTAG CONNECTOR > > > Check out the .5 pitch DF-12 series of connector from Hirose > Electronic Co. Ltd. - here's a typical example - Digikey part number > H2756-ND > > I'm going to give this a try and build both connectors on a small > pcboard as Leon suggested earlier. A similar (more ways) Hirose connector is used for inter-board connections on the tiny Gumstix PXA255 systems. One Gumstix user said he found them difficult to solder, but his technique might have been wrong. I haven't tried them yet as no-one has any stocks, and Hirose won't have any for a couple of months, at least. Leon
2005-03-26 by Joe Hlebasko
Checkout Samtec for connectors. They have a lot of interesting small pitch stuff. And they will send out samples VERY fast. Joe
> -----Original Message----- > From: Leon Heller [mailto:leon.heller@...] > Sent: Saturday, March 26, 2005 12:59 PM > To: lpc2000@yahoogroups.com > Subject: Re: [lpc2000] Re: JTAG CONNECTOR > > > ----- Original Message ----- > From: "tkreyche" <tkreyche@...> > To: <lpc2000@yahoogroups.com> > Sent: Saturday, March 26, 2005 5:01 PM > Subject: [lpc2000] Re: JTAG CONNECTOR > > > > > > > > Check out the .5 pitch DF-12 series of connector from Hirose > > Electronic Co. Ltd. - here's a typical example - Digikey part number > > H2756-ND > > > > I'm going to give this a try and build both connectors on a small > > pcboard as Leon suggested earlier. > > A similar (more ways) Hirose connector is used for > inter-board connections > on the tiny Gumstix PXA255 systems. One Gumstix user said he > found them > difficult to solder, but his technique might have been wrong. > I haven't > tried them yet as no-one has any stocks, and Hirose won't > have any for a > couple of months, at least. > > Leon > > > > > Yahoo! Groups Links > > > > > > > >
2005-03-26 by Anton Erasmus
On 26 Mar 2005 at 14:36, Joe Hlebasko wrote: > > Checkout Samtec for connectors. They have a lot of interesting small > pitch stuff. And they will send out samples VERY fast. > Some of their fine-pitch connectors are also available pre-soldered onto a flex PCB. This is much smaller then using 50 mil ribbon cable, or even 25 mil ribbon cable. We have found these flex PCBs also a lot more robust for general use than ribbon cable. Regards Anton Erasmus > > -----Original Message----- > > From: Leon Heller [mailto:leon.heller@...] > > Sent: Saturday, March 26, 2005 12:59 PM > > To: lpc2000@yahoogroups.com > > Subject: Re: [lpc2000] Re: JTAG CONNECTOR > > > > > > ----- Original Message ----- > > From: "tkreyche" <tkreyche@...> > > To: <lpc2000@yahoogroups.com> > > Sent: Saturday, March 26, 2005 5:01 PM > > Subject: [lpc2000] Re: JTAG CONNECTOR > > > > > > > > > > > > > Check out the .5 pitch DF-12 series of connector from Hirose > > > Electronic Co. Ltd. - here's a typical example - Digikey part > > > number H2756-ND > > > > > > I'm going to give this a try and build both connectors on a small > > > pcboard as Leon suggested earlier. > > > > A similar (more ways) Hirose connector is used for > > inter-board connections > > on the tiny Gumstix PXA255 systems. One Gumstix user said he > > found them > > difficult to solder, but his technique might have been wrong. > > I haven't > > tried them yet as no-one has any stocks, and Hirose won't > > have any for a > > couple of months, at least. > > > > Leon > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > -- A J Erasmus
