Lpc2000
Amontec Chameleon
Amontec Chameleon
2005-05-26 by Leon Heller
A long time ago Amontec gave me one of their Chameleon units to try with my
LPC210x board. I couldn't get it to work. I thought I'd try it again with
the latest software, but still can't get it to work in either Wiggler or
Raven mode, even at very low speeds. A genuine Wiggler works fine, of
course. Has anyone got the Chameleon to work with the Philips ARM chips?
Leon
Leon Heller, G1HSM
http://www.geocities.com/leon_heller
Re: [lpc2000] Amontec Chameleon
2005-05-26 by Marko Panger
The same was happening to me. When I was conntacting Amontec for support they said that it should work. I have tried almost everything but with no success. After a couple of mails they stopped to reply to my support requests...
br,
marko
> Od: "Leon Heller" <leon.heller@...>
> Datum: 2005/05/26 \ufffdet PM 01:45:07 CEST
> Za: <lpc2000@yahoogroups.com>
> Zadeva: [lpc2000] Amontec Chameleon
> Leon
> Leon Heller, G1HSM
2005-05-26 by Bill Knight
I've used it in both WIGGLER and Raven modes with the LPC.  I use an
older version of OCBLibRemote with the following command lines:
  OcdLibRemote.exe -c ARM7 -p 1000 -d WIGGLER -s 4
or
  OcdLibRemote.exe -c ARM7 -p 1000 -d RAVEN -s 4
The 's' param may be a bit slow but is the setting for the project on
which I am currently working.  I typically use the RAVEN mode except
when using CrossWorks which only supports the WIGGLER mode (they may have
RAVEN mode now, not sure).  Also, the code for the Chameleon itsself has not
been updated from their web site in some time.
-Bill Knight
R O SoftWare &
http://www.theARMPatch.com
Leon
To: <lpc2000@yahoogroups.com>
Sent: Thursday, May 26, 2005 2:03 PM
Subject: Re: [lpc2000] Amontec Chameleon
> or
> not
I'm using OCD Commander. I've downloaded OCDRemote for Windows and installed
it, but can't run it and can't find the executable.
Leon
On Thu, 26 May 2005 14:40:01 +0100, Leon Heller wrote:
>----- Original Message -----
>From: "Bill Knight" <BillK@...>
>> or
>> not
IIRC it is in Cygwin\usr\local\bin
I usually create a Windows link to it in my project directory setting the
parameters correctly, then just double-click it when it is needed.
-Bill
Sent: Thursday, May 26, 2005 2:54 PM
>>> or
>>> have
>>> not
>>installed
Nothing in my Cygwin directory! I think I'll forget about it. It didn't cost
me anything, anyway. 8-)
Leon
>>> or
>>> have
>>> not
>>installed
Sorry, I found it where you said.
I'll see how I get on with it.
Leonv
Sent: Thursday, May 26, 2005 3:46 PM
>>>> or
>>>> have
>>>> has
>>>> not
>>>installed
Same error (43) as with OCD Commander. I think I'll admit defeat and give up
trying to get it to work.
Leon
2005-05-26 by Aalt Lokhorst
Hello Leon,
Some info just from my memory and from dark archives so be carefull...
In the past I have used ocdremote for a few days and there were some
issues with the different speeds. Below you find a snip from a message
from that time.
'start of snip'
Strange enough you
need to do dummy connect to a RAVEN device first. This wil fail but it
leaves the interface in the correct state to connect properly for
WIGGLER. I am using now the next two commands and this works a lot
better (commands are for WIGGLER at LPT1)
ocdremote -cARM7TDMI-S -dRAVEN -a1 -s1   (results in Internal error 43)
ocdremote -cARM7TDMI-S -dWIGGLER -a1 -s1 (connects correctly)
'end of snip'
I was using your JTAG design so probably my info is completely useless
for your situation.
At the moment I use the CrossWorks software from Rowley in combination
with your JTAG design and this works very nice. (After replacing the
buffer by a LVC device for 5V tolerant inputs)
Best Regards
Aalt
> From: "Leon Heller" <leon.heller@...>
>  >>>> or
>  >>>> have
>  >>>> has
>  >>>> not
>  >>>installed
> setting the
> give up
> Leon
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
>       http://groups.yahoo.com/group/lpc2000/
>     * To unsubscribe from this group, send an email to:
>       lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Aalt Lokhorst
Schut Geometrische Meettechniek bv
Duinkerkenstraat 21
9723 BN Groningen
P.O. Box 5225
9700 GE Groningen
The Netherlands
Tel: +31-50-5877877
Fax: +31-50-5877899
E-mail: Lokhorst@...
>>>>> or
>>>>> have
>>>>> has
>>>>> not
>>>>installed
This SOUNDS like the error that newer versions of OcdLibRemote return
when they find a non-standard WIGGLER.  I believe Macraigor's products
have a jumper between a couple of the parallel port pins that the
newer versions of code are checking.  I do not know if Amontec has
added that functionality to the FPGA firmware.  Others on the mailing
list might be able to confirm either or both.  If that is the problem,
you could either acquire an older version of OcdLibRemote or build a
db-25 adapter to add the jumper.
-Bill
Sent: Thursday, May 26, 2005 5:03 PM
>>>>>> or
>>>>>> have
>>>>>> has
>>>>>> not
>>>>>installed
>>>> the
>>up
The link beween pins 8 and 15? That might be the cause of the problem. I'll
remove it from my I/F and see if I get the same error.
Leon
Leon
Re: Amontec Chameleon
2005-05-26 by soren_t_hansen
> >From: "Leon Heller" <leon.heller@d...>
> >> From: "Bill Knight" <BillK@t...>
use an
> >>>>> or
project on
except
(they may
> >>>>> have
itsself
> >>>>> has
> >>>>> not
> >>>>installed
setting the
and give up
> -Bill
I've just bought 4 Chameleons, and are using them together with
OCDRemote 2.12 and Eclipse vith the Zylin CDT plugin. This is working
just fine, and I'm using the Chameleon as a Raven_All_Speeds and
connects with speed = 4.
/Søren
Re: [lpc2000] Re: Amontec Chameleon
Sent: Thursday, May 26, 2005 5:36 PM
Subject: [lpc2000] Re: Amontec Chameleon
use an
> >>>>> or
project on
except
(they may
> >>>>> have
itsself
> >>>>> has
> >>>>> not
> >>>>installed
setting the
and give up
> -Bill
Perhaps mine is faulty. It was OCDremote 2.12 I tried.
Leon
[snip]
> and give up
> > -Bill
> Leon
How is your LPT1 set up? Mine is configured to EPP mode, but the other
day I ran on another machine that wasn't. You could try to see if that
did the trick.
/Søren
Sent: Thursday, May 26, 2005 6:00 PM
[snip]
> and give up
> > -Bill
> Leon
did the trick.
That was the first thing I checked.
Leon
Leon Heller, G1HSM
2005-05-26 by Arie de Muynck
up
Hi Leon,
If you really give up I'd like to buy it and give it a try.
I've got access to a logic analyzer, a real Raven and my own Perfect Wiggler
;-) to compare against.
Arie de Muynck
You can also reply to the temporary chameleon@...
2005-05-27 by JM
Dear friends,
I buy ChameleonPOD from second hand. Configuration for Xilinx, Altera,
Lattice, Atmel, ARM work fine.
Now i wont program MSP430 and PSD chips from ST, but i dont know if it is
possible with ChameleonPOD.
In configuration SW i see "amt_chm_080_st_psd_flashlink" but pinout i dont
know. And in any mailing list users
talk about configutation for MSP430.
Iam contact Amontec (Laurent Gauch) and receive this answer"
>>Yes, I can help you to use the Chameleon POD for PSD and MSP430.
>>Actually, I am not in my office. I will send you a new email when I will
>>be back to me office tommorrow.
and nothing more, Amontec stop all communications with me :-((
Can anybody help me?
Can anybody send me actual configurations and coresponding pinouts?
king regards
J.Masek
2005-05-27 by Bruce Paterson
Yep works fine in Raven mode with a lpc2124. Never tried Wiggler mode.
There is a special Chameleon target for Philips LPCs in particular you
must use, not the generic JTAG one that comes in the bundle. Grab off
their website.
Lack of good h/w breakpoint support when used with ocdremote and Insight
still very annoying.
I'm using the latest ocdremote.
Agreed. I think I also managed to get it with a laptop that had a
Parallel port that didn't configure from BIOS properly into the right
mode. This was back when I was mucking about with a home made wiggler,
so it may not be relevant to the Chameleon.
Bruce
     /\\\/\\\/\\\    /   /      Bruce Paterson
    /  \\\ \\\ \\\  /   /    Senior Design Engineer
   /   /\\\/\\\/\\\/   /   8 Anzed Court, Mulgrave, Vic, 3170
  /   /  \\\ \\\ \\\  /  PO Box 4112, Mulgrave, Vic, 3170, Australia
/   /    \\\/\\\ \\\/   Ph: +61 3 8561 4232   Fax: +61 3 9560 9055
       Tele-IP Ltd.      Email: bruce@...    Icq: #32015991
                         WWW:   http://www.tele-ip.com       VK3TJN
2005-05-27 by Leon Heller
Sent: Friday, May 27, 2005 8:27 AM
> their website.
Where is that? I can't find it.
Leon
