Timecode o Midiclock
2004-05-05 by Turby Schmidt
Midi Clock o Timecode
Hi, i\ufffdd like to sync my XX7 with Cubase/VSTack (XX7 as Master)
anybody has suggestions about it? I tried it out with Cubase as Master, XX7
set to external Song Start Accept, Tempo is set to match, it works, but it
doesnt sync perfectly, there is a little offset, lets say i work with 125
bpm XX7 runs at 124,91real tempo. I think i could manage the problem using
Timecode instead of Clock, but i don\ufffdt know if iys possible/how to set up...
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
Re: [xl7] Timecode o Midiclock
2004-05-06 by Wesley D
If it's SMPTE you're speaking of I don't believe the command station support it.  You might try something like MIDI offset on the part of Cubase.
speaking of which, does anyone know how or if it's possible to set MIDI offset on the command station to compensate for latency of externally sequence sound mods and or samplers?
-Wesley
Do you Yahoo!?
Win a $20,000 Career Makeover at Yahoo! HotJobs
Re: Timecode o Midiclock
2004-05-07 by wildstar_1701
--- In xl7@yahoogroups.com, "Turby Schmidt" <trabantmusic@h...> wrote:
> Hi, i´d like to sync my XX7 with Cubase/VSTack (XX7 as Master) ... I trie=
d it >
>out with Cubase as Master, XX7  set to external Song Start Accept, Tempo i=
s
>set to match,
this confused me a bit - which do you want as the timing master, your XX7 o=
r
Cubase?
if you want the tempos to match, then you need to set the XX7 base tempo to=
"ext" , external sync (if Cuabse is master), and configure Cuabse to send M=
IDI
clock to the XX7. i'm not a Cubase user, so i don't know how you do that. i=
f you
want the XX7 to be Master, then set the tempo for whatever you want and
configure Cubase to receive MIDI clock from the XX7.
manually setting the XX7 tempo to match will result in drift, sooner or lat=
er. this
is inevitable, no fault of the machine.
> Timecode instead of Clock, but i don´t know if iys possible/how to set up=
you could use Timecode to sync instead of MIDI Clock, but you'd need a
device to translate SMPTE into Beat Clocks, as the XX7 only receives Beat
Clocks. these devices can be pricey, and you don't really need it. Beat Clo=
ck
can work great.
i had timing sync problem a month or two ago, and solved it by using the
highest quality (and most expensive) MIDI cable i could find for the XX7's =
MIDI
In port. this was Realm's suggestion, and believe it or not, the cheapo MID=
I
cable was causing jittery tempo sync.
the tempo offset you mentioned is a bit strange. so it doesn't fluctuate, i=
t just
stays static at that difference? could it have to do with the frame rate Cu=
base
is set to? most sequencers have different frame rates to choose from in
syncing to film, and maybe that has something to do with it.
sorry to be so vague on the Cuabse stuff - i use DP (but am wanting to jump=
ship to Logic now!)
AW: [xl7] Re: Timecode o Midiclock
2004-05-08 by Frodo
The problem with Cubase as slave is, that it can't use MIDI clock as sync
reference. (As stated in the manual.)
I have the same problem since I want to have my XL-7 as master and Cubase as
slave.
Any suggestions ?
Is there a way to transform MIDI clock into Timecode ?
The problem with Cubase as master is, that it would not reset the XL-7 to
the starting position after pressing the stop button 2 times, but it does
function with XL-7 as a master. Then Cubase would stop the song after one
press on the stop button of the XL-7 and on the second press, Cubase would
reset to the starting position.
-----Ursprüngliche Nachricht-----
Von: wildstar_1701 [mailto:justinsamaha@...]
Gesendet: Freitag, 07. Mai 2004 15:14
An: xl7@yahoogroups.com
Betreff: [xl7] Re: Timecode o Midiclock
d it >
s
>set to match,
r
Cubase?
IDI
f you
er. this
ck
can work great.
MIDI
I
t just
base
ship to Logic now!)
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/xl7/
*	To unsubscribe from this group, send an email to:
<mailto:xl7-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
RE: AW: [xl7] Re: Timecode o Midiclock
2004-05-08 by Turby Schmidt
a friend of mine recomended to try out console, i have a look at it and then
tell about whats happend...
>From: "Frodo" <frodo@...>
>Reply-To: xl7@yahoogroups.com
>To: <xl7@yahoogroups.com>
>Subject: AW: [xl7] Re: Timecode o Midiclock
>Date: Sat, 8 May 2004 02:27:20 +0200
>as
>slave.
>Any suggestions ?
>-----Urspr\ufffdngliche Nachricht-----
> > Hi, i\ufffdd like to sync my XX7 with Cubase/VSTack (XX7 as Master) ... I
>trie=
>d it >
>i=
>s
> >set to match,
>o=
>r
>Cubase?
>to=
>M=
>IDI
>i=
>f you
>lat=
>er. this
>up=
>Clo=
>ck
>can work great.
>MIDI
>MID=
>I
>i=
>t just
>Cu=
>base
>jump=
>ship to Logic now!)
>   _____
>Yahoo! Groups Links
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
RE: [xl7] Re: Timecode o Midiclock
2004-05-09 by Turby Schmidt
>o=
>r Cubase?
xx7 as master, i get allready told that that isnt possible
>MIDI
>MID=
>I
opa, i have a look on it
>i=
>t just
>Cu=
>base
>is set to?
i guess 30 or 25, where should it be set to?
Re: AW: [xl7] Re: Timecode o Midiclock
2004-05-10 by erik_magrini@Baxter.com
That's an option in the SX preferences too, you can change what Cubase
does when you hit stop...
rEalm
Von: wildstar_1701 [mailto:justinsamaha@...m]
trie=
d it >
i=
s
>set to match,
o=
r
Cubase?
to=
M=
IDI
i=
f you
lat=
er. this
up=
Clo=
ck
can work great.
MIDI
MID=
I
i=
t just
Cu=
base
jump=
ship to Logic now!)
  _____
Yahoo! Groups Links
of Service
Yahoo! Groups Links
The information transmitted is intended only for the person(s)or entity
to which it is addressed and may contain confidential and/or legally
privileged material. Delivery of this message to any person other than
the intended recipient(s) is not intended in any way to waive privilege
or confidentiality. Any review, retransmission, dissemination or other
use of , or taking of any action in reliance upon, this information by
entities other than the intended recipient is prohibited. If you
receive this in error, please contact the sender and delete the
material from any computer.
For Translation:
http://www.baxter.com/email_disclaimer
2004-05-10 by Turby Schmidt
feels like the only order that the XX7 accepts from Cubase is start/stop,
once that XX7 runs it feels like the clocks of XX7 and Cubase run on their
own, there is no exact sync, could that be like this?
>From: erik_magrini@...
>rEalm
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
Cubase has had some issues with the stability of it's midi clock since SX
came out.  Do a search on the Steinberg.net site for "emulated midi ports"
and you'll find a whole bunch of information that might help you out here.
rEalm
"Turby Schmidt" <trabantmusic@...>
05/10/2004 10:40 AM
Please respond to xl7
        cc:
        Subject:        Re: AW: [xl7] Re: Timecode o Midiclock
>rEalm
would
Yahoo! Groups Links
use of, or taking of any action in reliance upon, this information by
For Translation:
AW: AW: [xl7] Re: Timecode o Midiclock
2004-05-10 by Frodo
Oh ... good =)
Von: erik_magrini@Baxter.com [mailto:erik_magrini@...]
Gesendet: Montag, 10. Mai 2004 15:06
Betreff: Re: AW: [xl7] Re: Timecode o Midiclock
rEalm
Von: wildstar_1701 [mailto:justinsamaha@yahoo.com]
trie=
d it >
i=
s
>set to match,
o=
r
Cubase?
to=
M=
IDI
i=
f you
lat=
er. this
up=
Clo=
ck
can work great.
MIDI
MID=
I
i=
t just
Cu=
base
jump=
ship to Logic now!)
  _____
Yahoo! Groups Links
of Service
Yahoo! Groups Links
For Translation:
  _____
Yahoo! Groups Links
RE: AW: AW: [xl7] Re: Timecode o Midiclock
i found the information at steinbergs, thanx...
gonna tell you if i have sucsess or not >?/.
>Oh ... good =)
>Von: erik_magrini@... [mailto:erik_magrini@...]
>rEalm
>trie=
>d it >
>i=
>s
> >set to match,
>o=
>r
>Cubase?
>to=
>M=
>IDI
>i=
>f you
>lat=
>er. this
>up=
>Clo=
>ck
>can work great.
>MIDI
>MID=
>I
>i=
>t just
>Cu=
>base
>jump=
>ship to Logic now!)
>   _____
>Yahoo! Groups Links
>of Service
>Yahoo! Groups Links
>For Translation:
>   _____
>Yahoo! Groups Links
