Bus Address Error
2004-12-31 by groakes2000
Hi folks I just picked up an MP7 and so far I reallllly like it except for one B I G thing.... ...evry now and again it locks up with the following error: Error! Code = 001 Fatal: Bus address error anyone got any ideas???? cheers Greg
--- In xl7@yahoogroups.com, "groakes2000" <groakes@i...> wrote: > > Hi folks > > I just picked up an MP7 and so far I reallllly like it except for > one B I G thing.... > > ...evry now and again it locks up with the following error: > > Error! Code = 001 > Fatal: Bus address error > > anyone got any ideas???? > > cheers > Greg Forgot to mention - I'm running V2.00 sw with the base (MP7) chipset. and it happens when I'm not connected to any other MIDI device... cheers greg
2004-12-31 by Bob S.
Have you opened the unit to make sure all cables and ROM(s) are seated properly ? The ROMs use a similar type socket to PC memory and sometimes either need contacts cleaned or reseating..... If this unit was recently shipped it could be a possibility....... Bob Corona/Riverside, CA
To: xl7@yahoogroups.com
Sent: Friday, December 31, 2004 1:12 AM
Subject: [xl7] Re: Bus Address Error
> Hi folks
> one B I G thing....
> Error! Code = 001
> cheers
> Greg
device...
cheers
greg
Yahoo! Groups Sponsor
ADVERTISEMENT
Yahoo! Groups Links
http://groups.yahoo.com/group/xl7/
[Non-text portions of this message have been removed]2005-01-02 by groakes2000
Well, I pulled it apart and checked all the ribbon cables and they were fine. I cleaned the contacts on the ROM with isopropyl alcohol and reseated it. But still no joy! :( I lodged a case with EMU but I don't hold too much hope there. Anybody got any more ideas? cheers Greg --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > Have you opened the unit to make sure all cables and ROM(s) are seated properly ? The ROMs use a similar type socket to PC memory and sometimes either need contacts cleaned or reseating..... > > If this unit was recently shipped it could be a possibility....... > > Bob > Corona/Riverside, CA > Intro Stuff deleted
> > Error! Code = 001 > > Fatal: Bus address error > > > Forgot to mention - I'm running V2.00 sw with the base (MP7) > chipset. and it happens when I'm not connected to any other MIDI > device... > > cheers > greg > [Non-text portions of this message have been removed]
2005-01-02 by Bob S.
Good work ! Sorry it didn't work but we have to rule out simple things first. So let's dig deeper. How often does it occur and does it happen only during certain actions/activities? Will the original owner confess to this being a problem when he had it? Or did it start happening after it was shipped to you ? How stable your power (dropouts or noise/glitches)? We are basically taking about an address error in the imbedded computer system. Bob Corona/Riverside, CA
Sent: Saturday, January 01, 2005 8:42 PM
and reseated it.
cheers
Greg
> Bob
Intro Stuff deleted
> > Error! Code = 001
> device...
> cheers
> greg
Yahoo! Groups Links
[Non-text portions of this message have been removed]2005-01-03 by groakes2000
Thanks Bob, I haven't heard back from the original owner yet - Xmas and all... The unit appears to be in excellant physical condition. The fault appears to happen after the unit has been in operation for a while (heat? - I have noticed the machine runs warmish...). It can happen when sitting idle (not playing) or any other given moment.... cheers Greg --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > Good work ! Sorry it didn't work but we have to rule out simple things first. > > So let's dig deeper. How often does it occur and does it happen only during certain actions/activities? Will the original owner confess to this being a problem when he had it? Or did it start happening after it was shipped to you ? How stable your power (dropouts or noise/glitches)? We are basically taking about an address error in the imbedded computer system. > > Bob > Corona/Riverside, CA > > > ----- Original Message ----- > From: groakes2000 > To: xl7@yahoogroups.com > Sent: Saturday, January 01, 2005 8:42 PM > Subject: [xl7] Re: Bus Address Error > > > > Well, I pulled it apart and checked all the ribbon cables and they > were fine. I cleaned the contacts on the ROM with isopropyl alcohol > and reseated it. > > But still no joy! :( > > I lodged a case with EMU but I don't hold too much hope there. > Anybody got any more ideas? > > cheers > Greg > --- In xl7@yahoogroups.com, "Bob S." <tttsystems@e...> wrote: > > Have you opened the unit to make sure all cables and ROM(s) are > seated properly ? The ROMs use a similar type socket to PC memory > and sometimes either need contacts cleaned or reseating..... > > > > If this unit was recently shipped it could be a possibility....... > > > > Bob > > Corona/Riverside, CA > > > > Intro Stuff deleted > > > > Error! Code = 001 > > > Fatal: Bus address error > > > > > > Forgot to mention - I'm running V2.00 sw with the base (MP7) > > chipset. and it happens when I'm not connected to any other MIDI > > device... > > > > cheers > > greg > > [Non-text portions of this message have been removed] > > > > > > ------------------------------------------------------------------- ----------- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/xl7/ > > b.. To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
The other error tha appears is: Bad Instruction I have tried reloading the OS but to no avail.... cheers greg --- In xl7@yahoogroups.com, "groakes2000" <groakes@i...> wrote: > > Thanks Bob, > > I haven't heard back from the original owner yet - Xmas and all... > > The unit appears to be in excellant physical condition. The fault > appears to happen after the unit has been in operation for a while > (heat? - I have noticed the machine runs warmish...). It can happen
> when sitting idle (not playing) or any other given moment.... > > cheers > Greg >
2005-01-03 by realm619
Might want to open it up and make sure all the connectors are seated properly. Sometimes they get lose in shipping and that can cause problems. rEalm --- In xl7@yahoogroups.com, "groakes2000" <groakes@i...> wrote:
> > --- In xl7@yahoogroups.com, "groakes2000" <groakes@i...> wrote: > > > > Hi folks > > > > I just picked up an MP7 and so far I reallllly like it except for > > one B I G thing.... > > > > ...evry now and again it locks up with the following error: > > > > Error! Code = 001 > > Fatal: Bus address error > > > > anyone got any ideas???? > > > > cheers > > Greg > > Forgot to mention - I'm running V2.00 sw with the base (MP7) > chipset. and it happens when I'm not connected to any other MIDI > device... > > cheers > greg
