aron you're a freakin genious!
i just set the track to both. wich is good anyway cause i will be
recording midi into the tracl later for live use to trigger the
loops in my external sequencer.
i find it better to do anything in the mp7.
if i could wrote a score in a text editor i'd make a song for you
now! :P
thanks!
--- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@y...> wrote:
> Hmm, that sounds like it might be a bug. Is the track that you're
> currently on (and therefore getting rechannelized/reported to) an
> "internal" track? If it's not, that might be your problem (as that
> would theoretically cause the sysex to get reported out the back
> instead of to the internal synth.)
> -Aaron x 32.
> --- malik <malik_martin@h...> wrote:
> > dug this thread back up. new problem.
> > it seems that when i have rechannelize inputs set to always my
mp7
> > wont receive sysex. it recievs the message just never actualy
> > changes the multisetup(thats what i have the sysex set to do).
> > but if i have it off then it does work.
> > any ideas?
> > --- In xl7@yahoogroups.com, "malik" <malik_martin@h...> wrote:
> > > lol was a cheer!!
> > > thanks!
> > wrote:
> > > > Um, yes?
> > > > > AARON! AARON! AARON! AARON! AARON! AARON! AARON! AARON!
<synthesis77@y...>
> > > wrote:
> > > > > > You forgot the all-important "RECHANNELIZE INPUT To
Track
> > > Dest:
> > > > > always"
> > > > > > parameter in the MIDI menu. Make sure it's
> > always "always".
> > > > > Turn
> > > > > > keyboard and knobs transmit MIDI to off. Let the
sequencer
> > > reroute
> > > > > > stuff.
> > > > > > -Aaron
> > > > > > > hmm no it doesnt matter if i have it set to internal
or
> > > external
> > > > > it
> > > > > > > still sends a messagee. whats going on here
<malik_martin@h...>
> > > wrote:
> > > > > > > > hmm well it seems that if i want the keyboard to
send
> > midi
> > > out
> > > > > i
> > > > > > > > will always have to have keyboart utputs midi to
> > transmit
> > > and
> > > > > use
> > > > > > > > the channel assign feature to filter whats goin on
> > > internaly.
> > > > > > > > bummer
<malik_martin@h...>
> > > wrote:
> > > > > > > > > contollers menu
> > > > > > > > > keyboard channel = basic
> > > > > > > > > local control = on
> > > > > > > > > midi menu
> > > > > > > > > keyboard outputs midi = dont transmit
> > > > > > > > > knobs = dont transmit(just the quick edit knobs)
> > > > > > > > > midi enable = on for all channels
> > > > > > > > > midi mode = multi
> > > > > > > > > pattern menu
> > > > > > > > > channel assign = 1a ext(all others int)
> > > > > > > > > but i cant get it to transmit midi.
> > > > > > > > > i was trying to make a new multisetup lemme just
trash
> > > it
> > > > > and
> > > > > > > look
> > > > > > > > > at a multisetup i use to control live.
> > > > > > > > > ok my normal setup
> > > > > > > > > controllers menu
> > > > > > > > > local = on
> > > > > > > > > midi menu
> > > > > > > > > keyboard outputs midi = transmit(hmmmm)
> > > > > > > > > lnobs = dont transmit
> > > > > > > > > midi mode = multi
> > > > > > > > > pattern menu
> > > > > > > > > wierd why did this setup work before? even all the
> > > channels
> > > > > set
> > > > > > > to
> > > > > > > > > internal still send ext messages when i play on
them.
> > > > > > > > > what's going on here...
> > > > > > > > > also i had searched but i couldnt find that thread
> > where
> > > you
> > > > > and
> > > > > > > > > aaron had displayed all the sysex mapping.
> > > > > > > > > --- In xl7@yahoogroups.com, "steve_the_composer"
<smw-
> > > > > mail@p...>
> > > <malik_martin@h...>
> > > > > wrote:
> > > > > > > > > > [snip]
> > > > > > > > > > > does this mean that i can turn it off and just
use
> > a
> > > > > preset
> > > > > > > > > > setting?
> > > > > > > > > > What do you mean in the above sentence when you
> > > say "it"?
> > > > > > > > > > If you mean "all that non-knob midi data going
to
> > > external
> > > > > > > > gear,"
> > > > > > > > > > the answer is yes. However, I am not sure this
is
> > > > > what "it"
> > > > > > > > really
> > > > > > > > > > means.
> > > > > > > > > > If I am right, I hope the following helps:
> > > > > > > > > > If all that data is not routed to port A or port
B,
> > > your
> > > > > built-
> > > > > > > > in
> > > > > > > > > > controllers only affect the internal synth
engine,
> > but
> > > if
> > > > > your
> > > > > > > > > > sequencer is setup to go out port A or port B,
it
> > will
> > > > > still
> > > > > > > go
> > > > > > > > > out
> > > > > > > > > > to external gear.
> > > > > > > > > > You have the options to (1) transmit/not
transmit
> > > keyboard
> > > > > and
> > > > > > > > > other
> > > > > > > > > > non-knob on-board controller data and (2)
> > transmit/not
> > > > > > > transmit
> > > > > > > > > knob
> > > > > > > > > > controller data.
> > > > > > > > > > There's another function--locaL ON/OFF. Well,
think
> > > of
> > > > > > > KEYBOARD
> > > > > > > > > > OUTPUTS MIDI as LOCAL ONLY (if you have
KEYBOARDS
> > [and
> > > the
> > > > > > > other
> > > > > > > > > > local non-knob controllers] OUTPUTS MIDI = don't
> > > transmit.
> > > > > > > > > > Same thing with KNOBS MIDI OUT. Think of it as
> > LOCAL
> > > ONLY
> > > > > for
> > > > > > > > the
> > > > > > > > > > knobs.
> > > > > > > > > > BOTTOM LINE: I think of it as: I got my tunes
going
> > > to
> > > > > > > internal
> > > > > > > > > and
> > > > > > > > > > external gear and I want to play along, but I
don't
> > > want
> > > > > the
> > > > > > > > built-
> > > > > > > > > > in stuff (other than the sequencer) going to the
> > > external
> > > > > gear
> > > > > > > > > > connected to midi ports a and b.
> > > > > > > > > > Hope this helps.
> > > > > > > > > > --Steve
> > > > __________________________________
> > > > Yahoo! Mail - PC Magazine Editors' Choice 2005
> > > > http://mail.yahoo.com
> > ------------------------ Yahoo! Groups Sponsor
> > Get fast access to your favorite Yahoo! Groups. Make Yahoo! your
home
> > page
> > http://us.click.yahoo.com/dpRU5A/wUILAA/yQLSAA/pWZylB/TM
> > Yahoo! Groups Links
> Yahoo! FareChase: Search multiple travel sites in one click.
> http://farechase.yahoo.com
