KP65 Kick tower/- TP65s 3 zone snare pad
2003-05-01 by fxsran
Hi Guys, Just a quick check, I was thinking of buying the KP65 Kick tower and TP65s 3 zone snare pad, Do u guys think it would work on my Dtexpress kit. The guys at the Yamaha says that it would only work on the DTX2 module and not on DTX1.Is it true?? Need some advise.. Thanks Fx
2003-05-01 by liberatusvirus
Hi Fx, The kick should work, but the three-zone snare will only get you two voices on any DTXpress incarnation but the current one. Ed --- In DTXpress@yahoogroups.com, "fxsran" <fxsan@m...> wrote: > Hi Guys, > > Just a quick check, I was thinking of buying the KP65 Kick tower and > TP65s 3 zone snare pad, Do u guys think it would work on my Dtexpress > kit. The guys at the Yamaha says that it would only work on the DTX2
> module and not on DTX1.Is it true?? Need some advise.. > > Thanks > > Fx
Hi Ed, Thanks for the reply, So the kicktower would work on my Kit. I remember those guys at Yamaha was telling me that it wont work coz of the stereo signal from the Kicktower..? I just wanna get them coz i wanna try and play double pedals and i cant do that with my current single tower except by using my Hihat foot pedal.. Fx --- In DTXpress@yahoogroups.com, "liberatusvirus" <liberatusvirus@y...> wrote: > Hi Fx, > > The kick should work, but the three-zone snare will only get you two
> voices on any DTXpress incarnation but the current one. > > Ed > > --- In DTXpress@yahoogroups.com, "fxsran" <fxsan@m...> wrote: > > Hi Guys, > > > > Just a quick check, I was thinking of buying the KP65 Kick tower > and > > TP65s 3 zone snare pad, Do u guys think it would work on my > Dtexpress > > kit. The guys at the Yamaha says that it would only work on the > DTX2 > > module and not on DTX1.Is it true?? Need some advise.. > > > > Thanks > > > > Fx
2003-05-01 by moosetication
--- "fxsran" wrote: > I remember those guys at Yamaha was telling me that it wont > work coz of the stereo signal from the Kicktower..? You only need a stereo cable if you havea pad plugged into the secondary input on the kick tower. It'll work with a mono. > ...i wanna try and play double pedals and i > cant do that with my current single tower except > by using my Hihat foot pedal.. Actually, I have seen a photo of a modified double pedal where the beaters were arranged one over the other rather than side-by-side. That way, they can both fit on the pad. However, I can't now find the photo and I'm aware my credibility is now shot... Stewart
2003-05-01 by vai
hi dude, i have same problem. i had the old DTXpress set. i cannot play my double pedal on it... made me very sad. i called yamaha, they said the new pedal is not compatible with the old module... so i just wondering to replace the kick pad with a acoustic one and trigger it... but have to buy acoustic bass drum and mesh head and trigger.... so i just waiting... see if can come out with better idea.... the idea of modify double pedal, is it possible? i checked the kick pad, the trigger section is just in the center of the rubber pad... how? help ~~~ help~~~ i cannot sleep without playing double pedal~~~ kevin --- moosetication <moosetication@...> wrote: > --- "fxsran" wrote: > > I remember those guys at Yamaha was telling me > that it wont > > work coz of the stereo signal from the > Kicktower..? > > You only need a stereo cable if you havea pad > plugged into the > secondary input on the kick tower. It'll work with a > mono. > > > ...i wanna try and play double pedals and i > > cant do that with my current single tower except > > by using my Hihat foot pedal.. > > Actually, I have seen a photo of a modified double > pedal where the > beaters were arranged one over the other rather than > side-by-side. > That way, they can both fit on the pad. > > However, I can't now find the photo and I'm aware my > credibility is > now shot... > > Stewart > > __________________________________ Do you Yahoo!? The New Yahoo! Search - Faster. Easier. Bingo. http://search.yahoo.com
--- I wrote: > Actually, I have seen a photo of a modified double pedal where the > beaters were arranged one over the other rather than side-by-side. > That way, they can both fit on the pad. > > However, I can't now find the photo... Found it. Yamaha_DTX group, in the Files section, in the folder "yyz pictures". Stewart
Fx, One of the selling points of the KP65 is its ability to accommodate two pedals, and from the looks of it, I'd say that it could. But as Stewart has aptly pointed out about the DTXpress II in another regard, the advertising doesn't always hold true. This time, though, it seems okay. Have you explored other kick pedal options? Ed --- In DTXpress@yahoogroups.com, "moosetication" <moosetication@y...> wrote: > --- "fxsran" wrote: > > I remember those guys at Yamaha was telling me that it wont > > work coz of the stereo signal from the Kicktower..? > > You only need a stereo cable if you havea pad plugged into the > secondary input on the kick tower. It'll work with a mono. > > > ...i wanna try and play double pedals and i > > cant do that with my current single tower except > > by using my Hihat foot pedal.. > > Actually, I have seen a photo of a modified double pedal where the > beaters were arranged one over the other rather than side-by-side. > That way, they can both fit on the pad. > > However, I can't now find the photo and I'm aware my credibility is
Did I say pedals? I meant beaters. It must be Stewart's befuddling sun, although it must be on the wane in England by now. --- In DTXpress@yahoogroups.com, "liberatusvirus" <liberatusvirus@y...> wrote: > Fx, > > One of the selling points of the KP65 is its ability to accommodate > two pedals, and from the looks of it, I'd say that it could. But as > Stewart has aptly pointed out about the DTXpress II in another > regard, the advertising doesn't always hold true. This time, though, > it seems okay. Have you explored other kick pedal options? > > Ed > > --- In DTXpress@yahoogroups.com, "moosetication" > <moosetication@y...> wrote: > > --- "fxsran" wrote: > > > I remember those guys at Yamaha was telling me that it wont > > > work coz of the stereo signal from the Kicktower..? > > > > You only need a stereo cable if you havea pad plugged into the > > secondary input on the kick tower. It'll work with a mono. > > > > > ...i wanna try and play double pedals and i > > > cant do that with my current single tower except > > > by using my Hihat foot pedal.. > > > > Actually, I have seen a photo of a modified double pedal where the > > beaters were arranged one over the other rather than side-by- side.
> > That way, they can both fit on the pad. > > > > However, I can't now find the photo and I'm aware my credibility > is > > now shot... > > > > Stewart
2003-05-01 by Creighton Higgins
-----Original Message-----hi dude,
Sent: Thursday, May 01, 2003 1:02 PM
To: DTXpress@yahoogroups.com
Subject: Re: [DTXpress] Re: KP65 Kick tower/- TP65s 3 zone snare pad
double pedal~~~
kevin
--- moosetication wrote:
> that it wont
> Kicktower..?
> plugged into the
> mono.
> pedal where the
> side-by-side.
> credibility is
> now shot...
> Stewart
Do you Yahoo!?
Community email addresses:
Post message: DTXpress@onelist.com
Subscribe: DTXpress-subscribe@onelist.com
Unsubscribe: DTXpress-unsubscribe@onelist.com
List owner: DTXpress-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/DTXpress
--- I have not explored other options yet, but there are some interesting ideas here, Anyway i might just bring my Dtxpress brain to Yamaha store and try to hook the KP65 and see for myself if it works before buying it or maybe try the DIY option.. Thanks for all the advise guys.. Fx In DTXpress@yahoogroups.com, "liberatusvirus" <liberatusvirus@y...> wrote: > Fx, > > One of the selling points of the KP65 is its ability to accommodate > two pedals, and from the looks of it, I'd say that it could. But as > Stewart has aptly pointed out about the DTXpress II in another > regard, the advertising doesn't always hold true. This time, though, > it seems okay. Have you explored other kick pedal options? > > Ed > > --- In DTXpress@yahoogroups.com, "moosetication" > <moosetication@y...> wrote: > > --- "fxsran" wrote: > > > I remember those guys at Yamaha was telling me that it wont > > > work coz of the stereo signal from the Kicktower..? > > > > You only need a stereo cable if you havea pad plugged into the > > secondary input on the kick tower. It'll work with a mono. > > > > > ...i wanna try and play double pedals and i > > > cant do that with my current single tower except > > > by using my Hihat foot pedal.. > > > > Actually, I have seen a photo of a modified double pedal where the > > beaters were arranged one over the other rather than side-by- side.
