PiezoTone Selenium 300 Hr Fade test
2002-09-01 by Paul Roark
Three PiezoTone test strips reached 300 hours (actually 304 hours) in my
fader Saturday.  They were PiezoTone Selenium (PT-S) on PhotoRag (PR), PT-S
on Epson Archival Matte (EAM), and, for comparison purposes, PiezoTone-Warm
Neutral (PT-WN) on EAM.
In general, there were no surprises.  The PT-S midtones performed extremely
well, with very minimal fade and virtually no midtone warming.
The black ink, however, showed substantial fade and warming, which, with the
cooler PT-S midtones, causes a significant neutral-to-warm cross-over
between 85% and 95%.  Whether this is a problem in your particular prints is
a subjective issue.  However, the resulting prints are not truly "selenium"
tone after the shadow tones have warmed up.  At least with my selenium-toned
silver prints the shadows get increasingly cool, not warm, as the density
increases.
A scan of the test strips can be seen in the Files section of this forum.
The files section is at:
Then following the links:  Files > Ink Sets > PiezoTones.  The file name is
"PT-Sel-PR & EAM PT-NW-EAM 304 Hr Fade.jpg."
Also, as expected, the black ink showed less fading and warming on EAM than
on PhotoRag.  The 100% patch droped from a density of 1.82 to 1.64 on PR; it
dropped from 1.71 to 1.62 on EAM.  The PR 100% patch warmed 0.11 units,
while the EAM 100% patch warmed 0.06 units.  (Warming is measured as the
change in the difference between the cyan and yellow readings.)
Note that these test strips were printed by Martin using a 1280 and CIS.  As
such, they appear to have been totally unaffected by the problems Jon Cone
described in his August 29 "PiezoTone News" posting on the Piezo 3000 forum.
See
http://groups.yahoo.com/group/piezography3000/message/19609
Also cross-posted by Julian at
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/18795
The problem Jon described appears to be ink separation caused by the sponge
material used in certain 1280 pre-loaded carts.  They are changeing carts,
but appear also to be changing the dispersion characteristics of the PT-S
inks.  As such, the final PT-S formula may be slightly different than this
one.
The X-Rite densitometer readings are below.
PT-S PR 50%	Control: c=0.69, m=0.71, y=0.72, visual=0.70;
		 304 Hr: c=0.68, m=0.70, y=0.71, visual=0.69;
	 100%	Control: c=1.82, m=1.81, y=1.80, visual=1.82;
		 304 Hr: c=1.61, m=1.68, y=1.70, visual=1.64;
	85% to 95% tone change (change in [c-y]):
		Control: 85% 0.01 unit cool to 95% 0.03 cool;
		304 Hr:  85% c=y (neutral) to 95% 0.08 warm.
PT-S EAM 50% Control: c=0.68, m=0.69, y=0.68, visual=0.69;
		  304 Hr: c=0.68, m=0.69, y=0.69, visual=0.69;
	  100% Control: c=1.71, m=1.72, y=1.72, visual=1.71;
		  304 Hr: c=1.60, m=1.65, y=1.67, visual=1.62;
		Control: 85% 0.01 cool to 95% c=y (neutral);
		 304 Hr: 85% 0.01 warm to 95% 0.07 warm.
PT-WN EAM 50% Control: c=0.64, m=0.65, y=0.67, visual=0.65;
		   304 Hr: c=0.66, m=0.67, y=0.70, visual=0.67;
	   100% Control: c=1.70, m=1.72, y=1.74, visual=1.71;
		   304 Hr: c=1.64, m=1.68, y=1.70, visual=1.66;
		Control: 85% 0.02 warm to 95% 0.02 warm
		 304 Hr: 85% 0.03 warm to 95% 0.06 warm.
http://www.PaulRoark.com
Re: [Digital BW] PiezoTone Selenium 300 Hr Fade test
2002-09-01 by Robert Morrison
Paul,
Forgive me if you have already answered this before...but what are the
wavelength characteristics of the light source in your fader?  I'm a little
confused as to why the Xenon lightsource fades that RIT are doing of these
same inks are not showing this same pattern of results.
Robert
> increases.
> See
> one.
> Paul
Robert,
I use fluorescent light.  I'm aware that it has some spikes in the spectrum,
but I have not seen anything very convincing that these make a significant
difference.  Also, the light level I use is much less intense than some of
the Xenon light sources that are used to accelerate fading.  As such, I
think my procedure may suffer from less of the reciprocity effects.
At any rate, none of these fade tests is perfect, but I'm convinced they are
better than nothing.  I note that Wilhelm still appears to use a fluorescent
light source.
Have you seen any RIT results with the PiezoTone inksets?  I'd like to see
what they look like.  When I compare the graphs of the fading I get with my
fluorescent light source, they look similar to the RIT graphs of the MIS
Archival color inks that MIS has published on its website.
_________________________________________
PT-S
PiezoTone-Warm
extremely
is
"selenium"
selenium-toned
> increases.
is
than
> on PhotoRag.  The 100% patch dropped from a density of 1.82 to 1.64 on PR;
it
As
forum.
> See
sponge
> material used in certain 1280 pre-loaded carts.  They are changing carts,
> one.
> Paul
2002-09-02 by Robert Morrison
On 9/1/02 4:30 PM, "Paul Roark" <paul.roark@...> wrote:
> Robert,
> light source.
I don't know what Henry uses, but I know that Xenon is absolutely the
standard in the field.
Yes, but they are the same ones that we have all seen posted on the
piezo3000 list at 100 hours.  In speaking to Jon, I know that he is having
the full RIT testing done...and that the results are well out beyond 300
hours using their Xenon source and that the inks set hasn't failed yet...but
RIT standards.
> I'd like to see
Me too.
Robert
2002-09-02 by Martin Wesley
Sent: Sunday, September 01, 2002 6:07 PM
Subject: Re: [Digital BW] PiezoTone Selenium 300 Hr Fade test
(big snip)
yet...but
> RIT standards.
Robert,
That has always been the question. RIT standards or Wilhelm standard. From
the published info on the MIS tests in '99 they consider 65% retention to be
the fail point. That seems really low to me. I would much rather see the
CYMK density graphs than to get a "display life" value. I suspect a lot of
us would consider a 5% or 10% image loss a failure.
While Paul's tests don't give us a specific value for print life they do
give us very real head-to-head comparisons of the materials.
The results on the Selenium PiezoTone are pretty disappointing since I like
the inks so much. The failure of the black in the Warm Neutral PT set was
not so disturbing since no unpleasant crossover was created. I think that
this is a much more serious issue than the current blue separation in the
1280 cartridges Jon has been posting about.
Also thinking back to Jon's Xenon fade test of the prints compared to Paul's
fade test of the wedges I think the same warm/fade phenomenon is evident
although we do not have any sensitometry data from Jon.
As you and I have discussed off list, there may be issues of activation
energies in the warm/fade reactions. You have broader experience in the
coatings industry than I have, what do you think the basic reaction is in
the warm/fade? A simple oxidation of the pigments accelerated by photo
energy or something else?
At a guess the Xenon is more broad spectrum than Paul's fluorescent tubes.
Given the same flux I would expect the higher UV content source to be more
damaging.
Martin Wesley
I'm most certain that it is the "dyestuff" that they are adding that's
burning off.  This looks like what happens to the 25% dye in the Gen4 (Gen
Enhanced) black.  I was hoping for better technology than this...but I agree
it is disappointing.  The problem at this point is that we really do need a
failure point.  If Paul's 300hr equals 100 Wilhelm years we may not have a
problem...but if it doesn't...what does it equal?
> damaging.
Hard to say...my guess is that Paul's fader errs on the side of having too
much heat build up...this could greatly accelerate oxidation.  The
commerical fade-o-meters carefully manage heat through the use of constant
rotation and cooling fans.
I guess the appropriate issue to resurrect is what was the most fade
resistant black again?  MIS FS...or was it MIS VM...and what exactly is the
difference?  It would be easy to sub that black into a set of the Selenium
Piezotones and give up dmax...but get the fade resistance and color of the
rest of the Piezotones...remember Cone simply uses the same black across all
the sets...so it shouldn't matter whose you use.  I know when I have talked
to Bill and Jon about this they have mentioned that they have considered
offering an all pigment black for those who are really set on having the
best longevity.
Robert
Sent: Sunday, September 01, 2002 10:02 PM
in
agree
a
Exactly. Paul has some 2200 wedges to test against a couple of the quad
sets. This will give us a data point compared to an ink with some "Wilhelm
years" attached to it but even then I am uncomfortable in drawing real life
conclusions since Wilhelm and his customers are not showing us "before" and
"after" images of the aged prints or test targets or data. I think that MIS
was the only exception in their sharing of their RIT data.
tubes.
more
> > damaging.
> commercial fade-o-meters carefully manage heat through the use of constant
Good point. The heat factor could make Paul's test a much more brutal one
which would speak highly of the inks that faired well but would not
necessarily reflect so badly on those that did not.
> difference?
I believe the FS and VM black are the same at this point and only the MIS
original quads K is different.
all
The problem is that the FS/VM black is very neutral and the PT black is red
warm so if you made that substitution you would have the best of both worlds
as far as warm/fade but I suspect you would have an ink set closer to
FS-Neutral than Selenium PT in hue. I have both on hand and some empty carts
for the 1280 so I should give it a try. I mixed some PT and VM blacks
together tonight to see if there are any obvious adverse reactions since Jon
was explicit about purging between original Piezo and PiezoTone. Even though
the inks would be in separate chambers and nozzles Tyler pointed out to me
that he had lost a head due to parking pad contamination between
incompatible inks a few years ago. In smelling the two inks the VM k has
that familiar heavy molecular weight alcohol or perhaps a glycol smell while
the PT k smells more like IPA or ethanol. Miss having a lab handy!
> best longevity.
Well I think that they really ought to do that. They would really only need
to offer it in bottles as I think most of the heavy users are working with
CIS or hand filling. This then raises the problems of the software. We
already have reports of poor profile matches with some printer/paper
combinations with the Selenium PT and changing the black would add to the
problems. Obviously from the way Jon is burning his bridges with Sundance on
his list I don't expect any new profiles for the Piezo driver and the
PiezoTones. ImagePrint is not a solution for the desktop unless they want to
greatly increase the number of profiles, supported printers and slash the
price.
I suggested to Hiram French that it might be to his benefit and the benefit
of the end users to profile the MIS-FS and PiezoTone inks for the R9 plugin
as well as the Sundance inks. I think that from a software point of view
Sundance may be in a position to respond more quickly than anyone else. I
certainly would be willing to pay for an upgrade or a whole new version that
had 40 paper profiles for 6 different inks and 7 desktop printers.
We seem to be in a bit of a new ink/software gap.
Martin Wesley
Media Street Black + FS-N was PiezoTone Selenium 300 Hr Fade test
2002-09-02 by janishilesh
Martin,
As you and I discussed on the phone a few days back, I am interested
in the deeper blacks of the new PT inks. I do not have at hand, but I
do have MediaStreet Generations Black (MS-GK). These inks also
supposedely have dye content in it to give the deeper black. I used
this ink with FS-N (vacuum filled virgin carts, not CIS). The prints
were very, very nice once I created a new curves adjustment layer.
However, within a few prints, one a 12 x 18 print, the color cart
started to leak like crazy (!). I dont know why, but it certainly
made a mess of my b/w 1280.
Not wanting to give up completely, I played around the kitchen sink
with FS-NK and the MS-GK. It is incredible how these inks are
different. I took two very white porcelin cups filled with water, and
put a drop of each of these inks in them each. Even the first
interaction with water is very different. But the most obvious
difference is that FS-NK is very neutral, and single hued. The MS-GK,
on the otherhand, separates out into a dye (very purple/red/magenta)
content and more or less masks any native pigment color. So is the PT-
K the same as MS-GK? And was my cartridge dripping caused by
incompatibilities between FS-N and MS-GK when on the parking pad? Or
was it just a bad fill job?
Best.
Shilesh
--- In DigitalBlackandWhiteThePrint@y..., "Martin Wesley"
<mwesley250@e...> wrote:
> From: "Robert Morrison" <rmorrison@p...>
> To: <DigitalBlackandWhiteThePrint@y...>
activation
experience in the
reaction is
> in
by photo
that's
Gen4 (Gen
this...but I
> agree
do need
> a
not have a
quad
some "Wilhelm
real life
us "before" and
that MIS
fluorescent
> tubes.
to be
> more
> > > damaging.
having too
constant
brutal one
fade
exactly is
> the
> > difference?
the MIS
color of the
across
> all
black is red
both worlds
to
empty carts
blacks
since Jon
Even though
out to me
k has
smell while
considered
having the
> > best longevity.
only need
working with
We
to the
Sundance on
they want to
slash the
> price.
benefit
R9 plugin
view
else. I
version that
> Martin Wesley
> the
>> difference?
Paul just confirmed that...but the MIS DD K is a different beast.  The FS
and VM is best on EAM and Hahnemuhle...but as I recall the MIS DD K does
better on Museo and Eclipse...complete reversal.
> all
Why don't you...I'll try the MIS DD the same way.
> price.
Imageprint profiles are free for Imageprint...they will profile anything you
like...and in addition there is talk about them making their profiling
software available for free...all you need is a densitometer.
It seems to me that it would certainly be to his benefit...but this market
is somewhat irrational...people get mad and stay mad at each other...but
obviously not forever...Colorbyte and Cone are back together again!
Robert
Sent: Monday, September 02, 2002 11:51 AM
>(snip)
That's the alternate black from their archival color inks. Hadn't considered
that one. Is it a neutral or war/neutral black.
(snip)
red
worlds
carts
That should be interesting. maybe we can both send wedges to Paul and he
will be kind enough to stick them in his fader when he has time.
(snip)
want to
> > price.
you
Do you have a test target I can print out and send them? The profiling
software would be great! Especially if we are allowed to share the profiles.
There are enough of us with spectrophotometers at this point that we could
very rapidly cover just about everything out there in the way of paper and
ink combinations which would make IP very attractive with limited
development cost to ColorByte.
As it currently stands though I would not recommend it for the 1280 due to
the lack of profiles, they don't even have the MIS-VM profiles although the
website says they are supported, and the high cost. Lots of great features
that really are of little use to someone doing quad printing on a 1280. The
dither is on a par with the Piezo/R9 plugin but no better.
benefit
plugin
I
that
Well, Hiram didn't sound very interested, but perhaps if some other people
would write him and make our wishes know he might get interested. I gather
they do not have the huge collection of printers that ConeTech does but I am
sure there would be many users who would be willing to work with Sundance
for free and provide test patch printouts to get the PiezoTone and FS inks
profiled in the plugin.
Martin
R9 & Imageprint was PiezoTone Selenium 300 Hr Fade test
2002-09-03 by tboleyyh
snip
due to
although the
features
1280. The
I take it you've had the chance to try it then. Somewhere I thought I
saw a comment from you that you were getting no increase in Dmax from
it. That comment along with this are of interest. I think any
experiences you have with it would be of great interest here, we have
very little variety of reports so far.
> benefit
> plugin
They would be very well advised to do so. Conetech's sales of the
plugin actually went up with the arrival of the alternative MIS
inkset. Many have migrated from the Sundance inks, they'd sell far
more plugins if they supported other inksets. If you are famliliar
with the plugin, you know that there is a dropdown selection box for
inksets, as well as the other one for paper profiles. It seems ready
to go, they should just do it, particularly since it sounds like they
are going to continue to develope it for future OS's.
I think I read they have a forum on their site, interested people
should inundate them with requests for this.
Tyler
