On 12/10/02 9:59 AM, "Paul Roark" <paul.roark@...> wrote:
> Robert wrote:
>> Hydrocote is a polyurethane that is already polymerized!...
>> that's why it is called "poly". There are coatings which you
>> add a cross-linker to but they are not available in
>> water-based formula.
> My understanding is that the water-based, single-component polyurethanes do
> cross-link after application, whereas the acrylics do not. Both are (I've
> been told) soft "golf balls" in suspension. While the best cross-linking is
> with the 2-component, solvent-based polyurethanes, the single-component
> water-borne version is said to be about half way between the acrylics and
> the industrial-strength PURs.
> As I understand it, the importance of the cross-linking is that without it
> the coating is porous and cannot achieve as high hardness relative to
> brittleness. Many seem to recommend that a water-borne acrylic be coated
> with a solvent-based polymer to seal it and reduce the "tackiness" of the
> surface. My hope with the PUR is to get a single-step coating procedure
> that is tough enough to withstand some abuse.
> For a tough, durable coating, the aliphatic PURs are the standard, as far as
> I can tell. The 2-component, solvent-borne versions just seem like they'd
> be too much of a hassle to use.
> One company has said it will send a formula to me/us that will make a
> 2-component water-based PUR. This is the next step even for industrial
> PURs, in part due to the pressure on VOCs. This would probably be the
> strongest water-based coating possible today, but I have yet to receive the
> materials.
> Paul
> http://www.PaulRoark.com
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;quot;flames.&amp;quot;
> resources on the homepage.
