Re: [Digital BW] Re: 1160 black blocked
2003-10-05 by Barry Kelsall
Do you know which black you are using? If it is the co-solvent black - that ink has a nasty habit of drying out, even inside tubing of a CFS/CIS. I tossed my co-solvent black & am now using the Eboni exclusively. You have to order it from the UltraTone inkset, or specify it when you phone MIS. Checking the 1160 with OEM Epson carts is good advice, too. Good luck, BK
2003-10-05 by frankg_photo
thanks for all the pointers folks. I have sucked the nozzle with the fat syringe and gottten the black ink flow. I have also tried epson carts with great success - printed the 4 col purge pattern properly. And also the regular test pattern. But when I reconnect the quadtone inkset - back to same problem. From what you've said it could be dry ink in the tubes ? But then why the flow when I pulled it through with a syringe ? ===================================================================== --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Barry Kelsall" <bktimes@h...> wrote: > Do you know which black you are using? If it is the co-solvent black - that > ink has a nasty habit of drying out, even inside tubing of a CFS/CIS. I > tossed my co-solvent black & am now using the Eboni exclusively. You have to > order it from the UltraTone inkset, or specify it when you phone MIS.
> > Checking the 1160 with OEM Epson carts is good advice, too. > > Good luck, > BK
actually, maybe I'm wrong about the 'flow' i just tried again and i think the ink is only from the cart not through the lines - I'm pulling like crazy on the syringe and cant see any movement in the line ================================================================--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo" <fh.gross@s...> wrote: > thanks for all the pointers folks. > > I have sucked the nozzle with the fat syringe and gottten the black > ink flow. > > I have also tried epson carts with great success - printed the 4 col > purge pattern properly. And also the regular test pattern. > > But when I reconnect the quadtone inkset - back to same problem. > > From what you've said it could be dry ink in the tubes ? But then why > the flow when I pulled it through with a syringe ? > > ===================================================================== > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Barry Kelsall"
> <bktimes@h...> wrote: > > Do you know which black you are using? If it is the co-solvent > black - that > > ink has a nasty habit of drying out, even inside tubing of a > CFS/CIS. I > > tossed my co-solvent black & am now using the Eboni exclusively. > You have to > > order it from the UltraTone inkset, or specify it when you phone > MIS. > > > > Checking the 1160 with OEM Epson carts is good advice, too. > > > > Good luck, > > BK
2003-10-05 by Bob Michaels
I never could clear my clogged line even after separating it from the cart. I just got another from MIS. They'll just send you a single tube and you tape it to the remaining other three. Maybe you could do a "roto rooter" job with a piece of fine wire You should be able to pull enough ink through there to completely change the ink by the cart and just recycle what you pulled out back into the bottle. Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo" <fh.gross@s...> wrote:
> > actually, maybe I'm wrong about the 'flow' i just tried again and i > think the ink is only from the cart not through the lines - I'm > pulling like crazy on the syringe and cant see any movement in the > line > ================================================================--- > In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo" > <fh.gross@s...> wrote: > > thanks for all the pointers folks. > > > > I have sucked the nozzle with the fat syringe and gottten the black > > ink flow. > > > > I have also tried epson carts with great success - printed the 4 > col > > purge pattern properly. And also the regular test pattern. > > > > But when I reconnect the quadtone inkset - back to same problem. > > > > From what you've said it could be dry ink in the tubes ? But then > why > > the flow when I pulled it through with a syringe ? > > > > > ===================================================================== > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Barry > Kelsall" > > <bktimes@h...> wrote: > > > Do you know which black you are using? If it is the co-solvent > > black - that > > > ink has a nasty habit of drying out, even inside tubing of a > > CFS/CIS. I > > > tossed my co-solvent black & am now using the Eboni exclusively. > > You have to > > > order it from the UltraTone inkset, or specify it when you phone > > MIS. > > > > > > Checking the 1160 with OEM Epson carts is good advice, too. > > > > > > Good luck, > > > BK
2003-10-05 by Mark Hahn
The "roto rooter" job will buy you about 2 weeks... good enough if you need to print right now, but get new tubes from MIS... even my new tubes only last ~3months. Maybe I should try the eboni ink... any comparisons in output?? mark --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Michaels" <bob@b...> wrote: > I never could clear my clogged line even after separating it from the > cart. I just got another from MIS. They'll just send you a single tube > and you tape it to the remaining other three. > > Maybe you could do a "roto rooter" job with a piece of fine wire > > You should be able to pull enough ink through there to completely > change the ink by the cart and just recycle what you pulled out back > into the bottle. > > Bob Michaels > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo" > <fh.gross@s...> wrote: > > > > actually, maybe I'm wrong about the 'flow' i just tried again and i > > think the ink is only from the cart not through the lines - I'm > > pulling like crazy on the syringe and cant see any movement in the > > line > > ================================================================-- - > > In DigitalBlackandWhiteThePrint@yahoogroups.com, "frankg_photo" > > <fh.gross@s...> wrote: > > > thanks for all the pointers folks. > > > > > > I have sucked the nozzle with the fat syringe and gottten the black > > > ink flow. > > > > > > I have also tried epson carts with great success - printed the 4 > > col > > > purge pattern properly. And also the regular test pattern. > > > > > > But when I reconnect the quadtone inkset - back to same problem. > > > > > > From what you've said it could be dry ink in the tubes ? But then > > why > > > the flow when I pulled it through with a syringe ? > > > > > > > > ===================================================================== > > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Barry > > Kelsall" > > > <bktimes@h...> wrote: > > > > Do you know which black you are using? If it is the co- solvent > > > black - that > > > > ink has a nasty habit of drying out, even inside tubing of a > > > CFS/CIS. I > > > > tossed my co-solvent black & am now using the Eboni exclusively. > > > You have to > > > > order it from the UltraTone inkset, or specify it when you phone
> > > MIS. > > > > > > > > Checking the 1160 with OEM Epson carts is good advice, too. > > > > > > > > Good luck, > > > > BK
Pulling the ink through with a syringe means your tubes are not blocked, but that does not mean your cart is functional. I'd get a new cart & a new tube from MIS. Strip the old K tube from the CIS/CFS ribbon tubing - you can attach the new tube to the old tube ribbon with cable ties (not too tight) or cloth tape. I'd also use the bottom fill method for this new cart (less chance of introducing foam in the cart). This is also an opportunity to switch to the more reliable Eboni black. -BK ----- Original Message ----- From: "frankg_photo" <fh.gross@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Saturday, October 04, 2003 10:41 PM Subject: [Digital BW] Re: 1160 black blocked > thanks for all the pointers folks. > > I have sucked the nozzle with the fat syringe and gottten the black > ink flow. > > I have also tried epson carts with great success - printed the 4 col > purge pattern properly. And also the regular test pattern. > > But when I reconnect the quadtone inkset - back to same problem. > > From what you've said it could be dry ink in the tubes ? But then why > the flow when I pulled it through with a syringe ? > > ===================================================================== > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Barry Kelsall" > <bktimes@h...> wrote: > > Do you know which black you are using? If it is the co-solvent > black - that > > ink has a nasty habit of drying out, even inside tubing of a > CFS/CIS. I > > tossed my co-solvent black & am now using the Eboni exclusively. > You have to > > order it from the UltraTone inkset, or specify it when you phone > MIS. > > > > Checking the 1160 with OEM Epson carts is good advice, too. > > > > Good luck, > > BK > > > > Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at: > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. > > Please follow these basic guidelines: > - Include your full name with your message. > - Include the address of your website, if you have one. > - As threads develop, trim off excess portions of earlier messages to keep them short. > - As the topic of a thread changes remember to change the subject header. > - Good manners are required at all time. No personal attacks or flames > - Complete your Yahoo profile. > - Before posting a question, search the message archives and the various resources on the homepage.
> > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
