Before I get started...
2004-02-01 by Radimus
Greetings.  I am about to order an Epson printer for quadtone B&W
printing.  I already have a decent enough inkjet for color, and an
Epson 2200 with ImagePrint RIP is outside of my budget.  I'm stuck
with Windows for the duration, so the free RIP's are not an option.
My plan as it stands is to order an Epson 1280 and a set of preloaded
MIS UT2 cartridges.  If all goes well with those, then I was planning
on getting a set of virgin empty carts, a set of inks in 4oz bottles,
and the various accessories (syringes, chip resetter, etc) for
refilling them.  I think I would like to avoid the extra complexity of
a CFS system for the time being.
Anyhow, I am interested in hearing comments related your experiences
with this combination, and with refilling cartridges, both good and
bad.  Also, does anyone have any experiences, both good and bad, with
refurbished printers direct from Epson?  They have a nice deal going
on refurbished 1280's at the moment.
Rad
Re: [Digital BW] Before I get started...
2004-02-01 by D. Hill
Rad,
> extra complexity of
I've done both - I used a continuous ink supply from
MIS for my 860.  It really wasn't difficult and set up
in about 20 minutes.  It was very convenient for
printing a large series of 7x17 inch images.  It was
also nice when I did not need to swap cartridges for a
year.
Currently I am refilling cartridges for my 1280, I
would say that it is much more of a hassle and time
consuming than using a CIS (and messy if you
accidentally drop your syringe).  However, I have been
using the printer to experiment with different inks to
find the right B&W combination for me, as well as
dropping in color cartridges if need be.
Bottom line, if you are going to use one inkset only,
use the CIS.  I would suggest starting with a
preloaded UT2 cart.  It gives a great amount of
flexibility and the quality is amazing.  If you like
the output, the extra cost of a CIS is no big deal.
> your experiences
> good and bad, with
> nice deal going
> Rad
I received a replcement 1280 which is in the same
category as a refurb directly from Epson.
Unfortuately, it was much worse off than the one it
was meant to replace.  From an outward look, it
appeared to be heavily used.  I loaded and printed a
few images with the Piezography driver and it was not
up to the tolerances of the Plug-in.  In a bit of
inspiration, I used the OEM inks provided in the
refurb as cleaning carts for my original printer - and
that solved all of my problems.
My biggest problem was this, I purchased a brand new
printer and babied it.  I used a total of 1.5 color
cartridges in it and it started mis-firing in the
black position.  To fix the problem, Epson sent me a
tired, old, and used printer to replace it.  It may be
a good deal from epson, but...
Don
Do you Yahoo!?
Yahoo! SiteBuilder - Free web site building tool. Try it!
http://webhosting.yahoo.com/ps/sb/
Re: Before I get started...
2004-02-01 by Tom Husband
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Radimus"
preloaded
planning
bottles,
of
with
> Rad
Hi Rad,
First off you'll love the UT2 inkset.  The choices from cool to sepia
are great and the ability to tweak the red and green curve for the
neutral is lots of fun.  Paul's instructions are very easy to follow.
http://home1.gte.net/res09aij/  I've been refilling 1280 carts with
VM, UT and UT2 for a while and, until recently, the process has gone
smoothly.  Lately I've had problems with bad nozzle checks.  I
wouldn't classify them as clogs as Epson Cartridges don't show that
same problem.  I believe something has changed in my process which
introduces air into the chambers.  A couple of messages prior I asked
Paul Roark about refilling and he had some good advice.
http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/411
56  Once you do it a few times it's not bad at all.  Just get
organized, go slow and put the right ink in the right chamber.  I
have the 30cc size bottom fill syringes from MIS and they work well.
The chip resetter from MIS doesn't fit the color carts like it's
supposed to using the notched guides but you can eyeball the position
of the contacts and make it work.  Reset the carts before you refill
as you have to turn the cart upside down to see the LED easily on the
resetter.  I gave up using the carts more than a few times as the
foam removal procedure is a real hassle in my opinion.  I believe
I've finally settled on the UT2 inkset so I'll save up for a CFS.
I've had one on an old 870 printer with color dye ink and it's been
trouble free for over two years.  The "No More Carts' version is the
one I'll probably go with.  I'm not an expert by any means but let me
know if I can help.
Good luck!
Tom
RE: [Digital BW] Before I get started...
2004-02-01 by Paul Roark
Rad,
The 1280 and UT2 with empty carts is exactly what I use.
(Be aware that some ink will get on your fingers and the work area.  About
10% of chips are defective.  A few might not stay in place -- I just use a
piece of tape over the top half.  Be sure to rinse the parking pad if dyes
have ever been in the printer.  In fact, I think this might be a good idea
with any pigmented inkset as a regular maintenance procedure.  Get a small
tube to put on the end of a syringe to get Windex down to the pad.  Rotate
the geared wheel on the left to release the head lock and move the head to
out from over the pad.)
My old refurbished 1160 is still going.  The only problems it has had
related to re-using old CIS units -- they cost me a head replacement.
I'd go for the refurbished 1280.
Enjoy.
For UT2 information and settings see:
_______________________________________
Sent: Sunday, February 01, 2004 7:17 AM
Subject: [Digital BW] Before I get started...
Rad
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
To visit your group on the web, go to:
Your use of Yahoo! Groups is subject to:
 http://docs.yahoo.com/info/terms/
2004-02-02 by Radimus
Thanks a bunch D, Tom, and Paul.
Another question regarding the CFS.  I've read through MIS's
instructions on installation and it looks quite doable.  However, on
occasion I've read reports of clogs from people who do not print all
that often.  Has this been the experience of others here?  I am
specifically insterested in experiences with CFS using MIS inks, UT
and UT2 in particular.  I've heard many gripes about the CIS system
for Piezo, but I don't plan to implement a Piezo system.
Rad
<paul.roark@v...> wrote:
> Rad,
 About
use a
if dyes
good idea
small
Rotate
head to
> Enjoy.
> Paul
> www.PaulRoark.com
> From: Radimus [mailto:radimus@p...]
> Rad
resources as
this same
> page.
to keep
> them short.
from
> the membership.
Owner and
section:
LIABLE TO YOU
EXEMPLARY
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
2004-02-02 by D. Hill
Rad,
So far, my UT2 has never clogged, but I only use
carts.  Previously I used MIS Full Spectrum in a CIS
that never clogged either - but that is a different
beast than UT2.
Don
> through MIS's
> doable.  However, on
> do not print all
> here?  I am
> using MIS inks, UT
> the CIS system
> system.
> Rad
Do you Yahoo!?
Thanks, Don.  How often do you print and how long have you left the
printer sit idle, both with UT2 and your old FS CFS rig?
Rad
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "D. Hill"
<hill14701@y...> wrote:
> Rad,
> beast than UT2.
> Don
> > through MIS's
> > doable.  However, on
> > do not print all
> > here?  I am
> > using MIS inks, UT
> > the CIS system
> > system.
> > Rad
> Do you Yahoo!?
It depends - the UT2 I've only had for a few weeks.
Other than getting it to fire correct when it was
first installed (it took three cleanings), I haven't
had to clean it yet.  However, I have gone a week
without printing with no ill effect.
The old full spectrum cis for my 860 was bulletproof -
up to a month without clogging.  However those prints
have already started fading...
Don
> have you left the
> rig?
> Rad
Do you Yahoo!?
Thanks, Alan.  Does anyone happen to know what the shelf life is for
MIS UT2 inks?  I don't print that much now, but after thinking about
it I think most of the reason for that is cost.  With the HP printer I
have supplies cost a lot more.  So how knows.  I might print a lot
more with a CFS and when I'm using Epson EEM paper at less than half
the cost of HP Premium Photo.
Rad
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Alan Zinn
<AZinn@n...> wrote:
> Rad,
> I had CIS on both a hex and quad machine. They worked fairly well with
> intermittent use without clogs for a year or so - then I started
having a
> lot of "mystery" clogs on the hex K. Turns out the ink had gone bad and
> formed a goo blob inside the bottle.  The lesson for me was that ALL
ink
> systems can have goo problems if not used with fresh inks - that is
within
> their recommended shelf life.  I decided that for the amount of inks
I use
> re-filling was not a big deal and I would be more attentive to the
> condition of the carts and the inks.  Follow Paul's excellent hints for
> refilling below and it is a snap.  I tend to get in a hurry and
sloppy and
> get air bubbles. I fill two sets of carts to have one in reserve
that has
> rested.  There is a top-off refill system on my web page that may be an
> acceptable compromise: http://www.panoramacamera.us/m_topoff.html
> AZ
> >Rad
> > > Rad,
> >  About
> >use a
> >if dyes
> >good idea
> >small
> >Rotate
> >head to
has had
replacement.
> > > Enjoy.
> > > Paul
> > > www.PaulRoark.com
> Build a Lookaround!
> The Lookaround Book, 2nd ed.
> NOW SHIPPING
Thanks, Don.
Rad
> Don
> > have you left the
> > rig?
> > Rad
> Do you Yahoo!?
I have another question regarding inks.  I've noticed from following
the list that Eboni seems to be the preferred ink for the black
position.  I am curious what the consensous is here regarding MIS
Photo Black instead of Eboni in the UT2 ink set.  At this point I have
no strong preference towards printing matte over glossy, or vice
versa.  I currently run mostly all glossy through my DeskJet for the
simple fact that HP Premium Photo glossy costs less than their Premium
Plus Matte.
Would there be any downside to going with Photo Black instead of Eboni
and print glossy and semi-gloss?
Rad
2004-02-02 by Thomas Keesling
Rad,
I'm using the original CIS, not the CFS, in my 1280. Actually, I've got two
of them and just rotate between the two when I install new bottles. I've
been doing this for three years now, I believe. It saves a little time and I
haven't had any problems with installation other than the tubing getting
caught under the printhead in the beginning, but that was easily solved and
I suspect the design has been changed to alleviate this possibility.
I went through two sets of 4-ounce bottles of the MIS VM inks before
switching to the UT2 inks nearly a month ago. I had only occasional minor
problems with the VM inks clogging. So far the UT2 inks have been entirely
trouble-free with a moderate amount of printing--the ink levels are down
about 1/8-inch if that gives you any idea of how much I've printed since
installing the UT2 inks. I normally just leave the printer on all the time
and there have been periods of a few days when it wasn't used at all. I
haven't had to run a cleaning cycle yet.
So far, my impression of the UT2 inks is that they're fantastic. Definitely
an improvement over the VM inks.
Good luck!
[Thank you, Paul!]
Tom Keesling
Intelligent Design, Inc.
2004-02-02 by Alan Zinn
Rad,
intermittent use without clogs for a year or so - then I started having a
formed a goo blob inside the bottle.  The lesson for me was that ALL ink
systems can have goo problems if not used with fresh inks - that is within
their recommended shelf life.  I decided that for the amount of inks I use
refilling below and it is a snap.  I tend to get in a hurry and sloppy and
get air bubbles. I fill two sets of carts to have one in reserve that has
AZ
>Rad
> > Rad,
>  About
>use a
>if dyes
>good idea
>small
>Rotate
>head to
> > Enjoy.
> > Paul
> > www.PaulRoark.com
Build a Lookaround!
NOW SHIPPING
Thanks a bunch for your input, Tom.
Rad
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Thomas Keesling"
<tom.keesling@a...> wrote:
> Rad,
got two
time and I
solved and
minor
entirely
the time
Definitely
> Good luck!
> [Thank you, Paul!]
> Tom Keesling
