what do I need to switch to quadtone
2004-03-04 by jerdiakiw
I have been using eboni black only printing with my new epson 2200 . I amd using a pc MSxp pent 4, with PS CS and epson enhanced paper. I would like to try quadtone now . What do I need for software? What is the recommended route to go. I presume I get my inks from MIS but the software and cost will be a factor Jerry in Toronto
2004-03-04 by Paul Roark
Jerry, >I have been using eboni black only printing with my new epson >2200 . I amd using a pc MSxp pent 4, with PS CS and epson enhanced >paper. I would like to try quadtone now . What do I need for >software? What is the recommended route to go. I presume I get my >inks from MIS but the software and cost will be a factor MIS should have the UT7 inks on its web page very soon. (See http://www.inksupply.com/index.cfm?source=html/qn.html ) I have the inkset (which is like UT2 for the 1280) running in a 2200 with the Epson driver. No other software is needed. The UT7 inkset is a variable-tone B&W inkset that can be printed from any application and cover the tones medium warm through neutral just by adjusting the Epson driver sliders. With Photoshop or Picture Window, however, much more flexibility is available. With (free) image adjustment curves the inkset goes from sepia to cool. It also prints on gloss or matte paper when Eboni matte black is installed. So, the MIS UT7 inks are all you need to buy. MIS or I will supply curves. Paul www.PaulRoark.com For UT2 information, curves, and settings see: http://home1.gte.net/res09aij/
2004-03-04 by luisvcool
I read on MIS's website that if you use a CFS system, you should make a print every day to avoid problems with the CFS system. I do not make prints every day. I make 4 - 6 prints per week. Should I use a cartridge system instead or do MIS inks (including UT7) give more problems that Epson UC inks? Thanks. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote:
> Jerry, > > >I have been using eboni black only printing with my new epson > >2200 . I amd using a pc MSxp pent 4, with PS CS and epson enhanced > >paper. I would like to try quadtone now . What do I need for > >software? What is the recommended route to go. I presume I get my > >inks from MIS but the software and cost will be a factor > > MIS should have the UT7 inks on its web page very soon. > (See http://www.inksupply.com/index.cfm?source=html/qn.html ) > I have the inkset (which is like UT2 for the 1280) running in a 2200 with > the Epson driver. No other software is needed. > > The UT7 inkset is a variable-tone B&W inkset that can be printed from any > application and cover the tones medium warm through neutral just by > adjusting the Epson driver sliders. With Photoshop or Picture Window, > however, much more flexibility is available. With (free) image adjustment > curves the inkset goes from sepia to cool. It also prints on gloss or matte > paper when Eboni matte black is installed. > > So, the MIS UT7 inks are all you need to buy. MIS or I will supply curves. > > Paul > www.PaulRoark.com > > For UT2 information, curves, and settings see: > http://home1.gte.net/res09aij/
2004-03-05 by Bob Michaels
I use MIS inks in a MIS CFS and frequently go a week, sometimes two between printing sessions and have no problems. I don't even bother to turn the printer off. Some have problems, I don't. It may be humidity related. I live in FL where the RH seldom gets below 50% in the winter with the heat running. MIS does have a free software package that prints a purge test every day to alleviate problems. But I know nothing about it. Just buy prefilled carts until you're sure you like the inkset. Leaving 3oz. of ink in a 4 oz. bottle and buying new CFS carts can get expensive. (But you WILL like the UT2, assume UT7 is the same) Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "luisvcool" <lvictoria@t...> wrote: > I read on MIS's website that if you use a CFS system, you should make a print every day to > avoid problems with the CFS system. I do not make prints every day. I make 4 - 6 prints > per week. Should I use a cartridge system instead or do MIS inks (including UT7) give > more problems that Epson UC inks? > > Thanks. > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> > wrote: > > Jerry, > > > > >I have been using eboni black only printing with my new epson > > >2200 . I amd using a pc MSxp pent 4, with PS CS and epson enhanced > > >paper. I would like to try quadtone now . What do I need for > > >software? What is the recommended route to go. I presume I get my > > >inks from MIS but the software and cost will be a factor > > > > MIS should have the UT7 inks on its web page very soon. > > (See http://www.inksupply.com/index.cfm?source=html/qn.html ) > > I have the inkset (which is like UT2 for the 1280) running in a 2200 with > > the Epson driver. No other software is needed. > > > > The UT7 inkset is a variable-tone B&W inkset that can be printed from any > > application and cover the tones medium warm through neutral just by > > adjusting the Epson driver sliders. With Photoshop or Picture Window, > > however, much more flexibility is available. With (free) image adjustment > > curves the inkset goes from sepia to cool. It also prints on gloss or matte > > paper when Eboni matte black is installed. > > > > So, the MIS UT7 inks are all you need to buy. MIS or I will supply curves.
> > > > Paul > > www.PaulRoark.com > > > > For UT2 information, curves, and settings see: > > http://home1.gte.net/res09aij/
2004-03-07 by edrudolpho
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > Jerry, > > >> The UT7 inkset is a variable-tone B&W inkset that can be printed from any > application and cover the tones medium warm through neutral just by > adjusting the Epson driver sliders. With Photoshop or Picture Window, > however, much more flexibility is available. With (free) image adjustment > curves the inkset goes from sepia to cool. It also prints on gloss or matte > paper when Eboni matte black is installed. > > So, the MIS UT7 inks are all you need to buy. MIS or I will supply curves. > > Paul > www.PaulRoark.com Paul, will these curves be made available at the time that the UT7 inks are released? Ed Rudolph
2004-03-07 by Paul Roark
Ed, I suspect MIS will release UT7 when I have a chance to load and check the production UT7 inks, which I received last week. I have draft curves for EEM, PhotoRag, Ilford Galerie Smooth Pearl/Gloss, and Premium Semigloss/Gloss/Luster. I hope to check and finalize these next week. I'll probably add Epson's UltraSmooth and Glossy Photo papers soon also. Of course if there is a glitch in the inkset, it could be a few more weeks. Paul www.PaulRoark.com ________________________
-----Original Message----- From: edrudolpho [mailto:erudolph@...] Sent: Saturday, March 06, 2004 11:03 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] what do I need to switch to quadtone --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...> wrote: > Jerry, > > >> The UT7 inkset is a variable-tone B&W inkset that can be printed from any > application and cover the tones medium warm through neutral just by > adjusting the Epson driver sliders. With Photoshop or Picture Window, > however, much more flexibility is available. With (free) image adjustment > curves the inkset goes from sepia to cool. It also prints on gloss or matte > paper when Eboni matte black is installed. > > So, the MIS UT7 inks are all you need to buy. MIS or I will supply curves. > > Paul > www.PaulRoark.com Paul, will these curves be made available at the time that the UT7 inks are released? Ed Rudolph Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
