Carl,
>I'm getting a dmax of about 2.1 with the MIS PK and UT1 inkset for the
>2200 on Epson Photo paper
Have you tried going into the "Ink Config" area (bottom left of the 2200
Properties box) and increasing the "Color Density" 20%? It increased the
dmax for me with Epson Glossy Photo paper and the Glossy HW paper. I'm not
sure what you'd get with the UT1 and PK.
>I really like the appearance of these prints and wish that Epson or
>some other company would put the same coating on a thicker, acid free paper
>base.
I agree. I'm going to test the spray buffer to see if that works. That
would take care of half of the problem.
__________
On Wednesday, March 24, 2004, at 01:45 PM, Paul Roark wrote:
> Carl,
>> I wonder why Epson does not recommend either the glossy HW or epson
>> photo paper for use with pigment inks. These are the only two soft
>> gloss papers I know of that yield prints without bronzing and gloss
>> differential artifacts with the UT and UT2 inks.
> I believe I tested the Epson Glossy Photo paper with Epson UltraChrome
> Photo
> black and got a dmax of only 1.4. This is as opposed to the 1.9 - 2.0
> that
> I can get with the UT2/7 with the "Eboni-glossy" curves that use the
> midtone
> gray inks. So, I think there may be something about the Epson coated
> black
> pigment that limits the dmax. Note that with the C84 that uses a
> hybrid
> black, Glossy Photo Paper is back on the list of papers.
>> I assume that both of
>> these papers have cast coated surfaces as opposed to the newer
>> microporus ceramic coatings that are recommended for pigment inks.
>> Although the latter technology may improve print longevity the
>> bronzing
>> these papers exhibit is too distracting.
> I have both the old and new glossy paper types in the fader now, so
> we'll
> see in a month or so whether the microporous coating aids longevity.
> It's strange that the Glossy Paper Heavy Weight interior paper
> initially
> tested neutral and now tests as acidic. What may be going on is that
> the
> alkaline coating kept the whole roll neutral when it was in a roll,
> but the
> paper actually has no buffering in it. So, after being unrolled for a
> while
> the residual lignin turned the paper (not the surface) acidic. This
> may
> also suggest that the paper is thin enough that the non-penetrating
> deacidification spray from Preservation Technologies on the back would
> keep
> the lignin in check and make the paper archival. However, unless the
> paper
> does much better in the fade test, I'm not sure I want to bother with
> more
> processing.
> Paul
> www.PaulRoark.com
> ____________________
> On Wednesday, March 24, 2004, at 10:57 AM, Paul Roark wrote:
>> After further testing with the Abbey acid test pen, I no longer
>> believe this
>> Epson paper is archival. While the surface is acid-free the interior
>> fibers
>> do not appear to be. Too bad.
>> Paul
>> www.PaulRoark.com
>> __________________________
>> -----Original Message-----
>> From: Paul Roark [mailto:paul.roark@...]
>> Sent: Friday, March 19, 2004 6:14 PM
>> To: DigitalB&WPrint
>> Subject: [Digital BW] Glossy Paper Heavy Weight
>> Epson "Glossy Paper Heavy Weight" is a paper that has some interesting
>> characteristics. It is said to be archival, prints artifact-free (no
>> bronzing or differential reflect characteristics) with UT7. As such
>> it does
>> not need spraying. While spraying would protect the surface, the
>> Glossy HW
>> surface appears to be much tougher than, for example, the Premium
>> Semigloss;
>> the Glossy HW does not show every little scratch. Glossy HW looks
>> much like
>> the cheaper Epson Glossy Photo Paper.
>> At $98 for a 65.5 foot roll it is more expensive than the Premium
>> Semimatte,
>> which goes for about that same amount for 100 feet at www.Atlex.com
>> <http://www.atlex.com/> . Neither paper is available in cut sheets.
>> I'm printing it with the 2200. Using an "Eboni-glossy" curve that
>> allows
>> the Eboni to stay installed in the printer, I'm getting dmax of 1.9+.
>> To
>> do this, however, requires the 2200's "color density" driver
>> adjustment.
>> The 7600 also has such an adjustment. Hopefully the 4000 will also.
>> (I'm finding the 2200's unique abilities are very helpful. I've found
>> with
>> both Arches Hot Press, which greatly benefits from the light black,
>> and this
>> paper, which benefits from the ability to vary the ink load, I could
>> not get
>> equal quality from my older printers.)
>> Epson's statements about the product include the following:
>> "EPSON Glossy Paper Heavyweight is the best media for users requiring
>> a
>> longer lasting non yellowing print with photographic image quality.
>> Applications include photographs, promotional pieces, layouts,
>> portfolio
>> images, proofs, indoor displays and posters."
>> "Non-yellowing coating for long lasting bright whites"
>> "Good Archivability"
>> At only 190 gsm & 9 mil it is not what I'd call "heavy weight," but
>> it's all
>> relative. Premium Semigloss is 10 mil.
>> This roll paper was designed for the 7000 and 9000. Epson does not
>> recommend it for its pigments, but it appears to work extremely well
>> with
>> the Ultra Tone pigs. It is one of the papers I'll be fade testing for
>> the
>> next month of so. It'll be interesting to see how it does compared to
>> Premium Semigloss and others.
>> Paul
>> www.PaulRoark.com <http://www.paulroark.com/>
>> For UT2 information, curves, and settings see:
>> http://home1.gte.net/res09aij/
>> [Non-text portions of this message have been removed]
>> Please visit the Group Homepage to check the Files, and other
>> resources as
>> they are often being updated.
>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>> If you wish to receive no emails or just a daily digest, or you wish
>> to
>> unsubscribe, please edit your Membership preferences by visiting this
>> same
>> page.
>> Please follow these basic guidelines:
>> - As threads develop, trim off excess portions of earlier messages to
>> keep
>> them short.
>> - Good manners are required at all time. No personal attacks or
>> flames.
>> Hostile, aggressive or argumentative users may be removed from the
>> membership without notice.
>> - Keep your posts and threads related to the group topic of digital
>> B&W
>> printing. Users who persistently make off-topic posts may be removed
>> from
>> the membership.
>> - By posting on this forum you agree to abide by the group rules and
>> guidelines, and to abide by the actions and decisions of the group
>> Owner and
>> Moderators. See Group Topic, Rules and Guidelines in the Files
>> section:
>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
>> PRINT
>> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
>> MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE
>> TO YOU
>> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
>> EXEMPLARY
>> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS,
>> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER
>> AND
>> MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF
>> THE
>> POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE
>> INABILITY
>> TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS
>> TO OR
>> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT
>> OF ANY
>> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY
>> OTHER
>> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
>> Yahoo! Groups Links
>> resources as they are often being updated.
>> to unsubscribe, please edit your Membership preferences by visiting
>> this same page.
>> keep them short.
>> flames. Hostile, aggressive or argumentative users may be removed from
>> the membership without notice.
>> B&W printing. Users who persistently make off-topic posts may be
>> removed from the membership.
>> Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
>> Files section:
>> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
>> AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
>> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
>> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
>> LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
>> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
>> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
>> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
>> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
>> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
>> Yahoo! Groups Links
> resources as
> same
> page.
> keep
> them short.
> from
> the membership.
> Owner and
> Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> PRINT
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE
> TO YOU
> EXEMPLARY
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER"
> AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF
> THE
> INABILITY
> TO OR
> OF ANY
> THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark
> Printer at MyInks.com. Free s/h on orders $50 or more to the US &
> Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/ucIolB/TM
> this same page.
> keep them short.
> Files section:
page.
them short.
the membership.
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
Yahoo! Groups Links
