OT - controlling tech pan contrast
2004-06-25 by Richard Smallfield
I am in a situation which forces me to send my film out to the pro lab for processing.
I find that Tech Pan is only an option in the dullest of conditions (when it is fantastic); yet I've seen desert shots with Tech Pan, with a red filter, what's more.
In anything like sunny conditions, the highlights and shadows are totally lost.
Do you think that asking the lab to under-develop by 30% would be a good idea?
Any thoughts would be appreciated.
thanks,
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com
   "We don't see things as they are, we see things as we are."
   --Anais Nin
Re: [Digital BW] OT - controlling tech pan contrast
2004-06-25 by Mark Savoia
Not sure what you mean by this statement, there are plenty of b&w film
choices?
Mark
RE: [Digital BW] OT - controlling tech pan contrast
2004-06-26 by don.swanson
In order to control the contrast of Tech Pan you have to use a compensating
developer. Kodak suggests Technidol. I used to use 2 bath development. I
used Beutlers which was similar to Neofin Blue (which I could not afford
then).
Do a Google search on 'compensating developer', without the quotes, of
course. Your lab may have their own favorite.
Sent: Friday, June 25, 2004 4:05 PM
To: Digital BW Print
Subject: [Digital BW] OT - controlling tech pan contrast
processing.
what's more.
lost.
idea?
thanks,
Richard
   --Anais Nin
2004-06-26 by Richard Smallfield
>choices?
>Mark
Sorry, I meant that, if I'm using Tech Pan, only in dull conditions is the contrast kept at a manageable level.
Richard
   "A classic is something that everybody wants to have read and
   nobody wants to read."
   --Mark Twain
>then).
Thanks for your reply - the lab say they stick to Kodak instructions. It would be easier if I could do it myself, but I live in the country and use tank water, which is discoloured!
Richard
   --Mark Twain
Re: OT - controlling tech pan contrast
2004-06-26 by sandersnyc
Richard, greetings.
There are ways to get good midtones with Tech Pan, if your lab is willing to use
standard materials in slightly nonstandard ways.  Check out the "Massive Dev" chart
over on DigitalTruth.com, which is an indispensable resource for recipes for
developing B+W films.  The chart is at this URL:
http://www.digitaltruth.com/devchart.html
Select "Kodak Tech Pan" chart from the box in the left margin.  As you will see, the
Tech Pan chart is divvied up into three categories:  "High contrast," "High Contrast/
Continuous Tone," and "continuous Tone."  You want "Continuous Tone."  You will
find over 20 recipes there.  If your lab is even marginally competent, they should be
able to accommodate you wtih one of these.
As for me, I've shot Tech Pan and gotten really good results in sunny conditions,
shooting through neutral-density filters to get a 30-second exposure, and then
developing in Rodinal 1:100 for only four minutes.  (Yes, that's right, four minutes!)
For an example of the results, see my photo at this URL:
http://www.pbase.com/image/28736293
I hope this helps.  Good luck with your lab.
Sanders McNew
www.mcnew.net
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Smallfield
<r.smallfield@p...> wrote:
> Hi,
processing.
> thanks,
> Richard
>    --Anais Nin
2004-06-26 by Richard Corbett
Sent: 26 June 2004 00:05
processing.
what's more.
lost.
idea?
Rate the film speed at 15 ISO and reduce dev time by 25% then all will be
revealed, as they say in the trade.
Richard
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
2004-06-26 by deandadin@aol.com
Hello Richard, I own a pro B&W lab. I do a lot of tech pan film. It  depends
which developer is bieng used. Technidol is recomended. For less  contrast I
dilute the technidol to 1-1 and rate the film at 12. Most labs dont  do a god
job with tech pan because they dont use the right developer. also tech  pan
works best with a 5 minute pre soak before the developer is added. I hope  that
this is a help to you. Steve
Many thanks to you all for your contributions. I have forwarded your thoughts and the Massive Dev TP chart to the lab manager.
Richard
   "You can best serve civilization by being against what usually
   passes for it."
   --Wendell Berry
2004-06-28 by jnhugo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sandersnyc"
<sandersm@a...> wrote:
> Richard, greetings.
willing to use
This a good example of why you should avoid short developement times-
 the uneven edges as seen in this shot are certain to occur.
Most commercial labs have never been good at black and white
negative development-color is much easier to control and maintain
chemistry- for tech pan you need a compensating type of developer
that loses energy in the higher exposed regions as the lower tones
keep developing. Simply under developing in standard developer won't
work. With all the limitations of tech pan besides development-you
would be much better off shooting a standard slow speed film and
processing at a lab that uses xtol as the solution.
me too
jack
2004-06-29 by sandersm@aol.com
Jack, I was the original poster -- two quick replies.   First, I processed
the film myself -- I didn't send it out to a lab.   Second, I prefer the way the
film develops a bit unevenly at short times (and yes, four minutes for
Rodinal is very short) -- what you consider a flaw, I consider a virtue.   In fact,
everything about how I shot that image is "flawed," right down to using a 1910
Kodak Model 3A with 120 roll film in place of the original 122 film (giving a
6x14 negative) and hand-holding a stack of Hasselblad neutral-density filters
in front of the lens during the exposure.   It's not a perfect negative -- it
wasn't meant to be.
Sanders McNew
www.mcnew.net
In a message dated 6/29/04 8:15:56 AM, Jack writes:
> chemistry-
2004-06-29 by jnhugo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, sandersm@a...
processed
prefer the way the
for
virtue.   In fact,
using a 1910
No offense intended-it is an interesting subject-as you know not
everyone tries to make photos as worse as they can- it is usually
the other way around
RE: [Digital BW] Re: OT - controlling tech pan contrast
2004-06-29 by Paul Roark
Just for the record, I currently use Tech Pan in my Bronica 645 RF.  I think
the medium format rangefinder, TP, a light tripod, and a Nikon 8000 scanner
make a great information capture system.
I've used TP off and on for years.  I even mixed my own POTA before Kodak
made their version (the original dry TP chemistry) and then the liquid
Technidol developer.  I was never really satisfied with the film until
scanning came along and I stopped using the enlarger with the TP negatives.
My current solution for TP is to develop it to a higher contrast than would
be suitable for enlarging.  A good scanner, however, is made to handle slide
film contrast/dynamic range.  This is great for TP because it is made for
high contrast and a wide dynamic range.  I set the scanner on "positive"
"grayscale" to get the full range to show on the histogram.
I now soup the film in Technidol for 9 min. at 75 F. degrees.  I test the
film and scanner together and find that I can capture 12 stops in a single
frame.  I've tried dozens of developers and just could not, overall, beat
the (over priced) Kodak solution.
Evenness is a huge problem with this film, especially with medium format.  I
agitate at 1 min. intervals, alternating between 20 vertical shakes (10 as
fast as possible, rotate 1/4 turn, 10 more) and 4 inversions (rather a
standard agitation).  I tested my process by looking at frames that were
even midtones (shot of a ground glass).
With the Nikon and GEM enabled, the MF negs enlarge to 22 x 28 with
virtually no grain -- very nice indeed.
For UT2 & UT7 information, curves, and settings see:
http://home1.gte.net/res09aij/
2004-06-29 by Andre
RF.....
Paul,
Were you able to make those enlargment sizes with 100Tmx and Xtol ?
Andre
Andre,
The short answer is that I don't know how Tmax with Xtol will do.  I intend
to give that a try at some point.
Tmax 100 in was my standard film for years, but I always emphasized the
sharpness in development to offset the softening of the enlarger, etc.
However, I found my Tmax negatives were grainier than I liked when I started
with digital.  I never liked Xtol with Tmax when using the enlarge due to
its lack of sharpness (even if the resolution is there).
I do think Xtol gives the softest grain for the speed.  So, it'll be an
interesting experiment to see how it does with Tmax 100 and a scanner.
______________________
Sent: Tuesday, June 29, 2004 3:25 PM
Subject: [Digital BW] Re: OT - controlling tech pan contrast
RF.....
Paul,
Andre
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2004-07-01 by sandersnyc
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jnhugo" <jacknadelle@h...>
> processed
> prefer the way the
> for
> virtue.   In fact,
> using a 1910
Jack, fair enough -- I'm sorry if I sounded defensive.  But I would disagree with you
about what is "usual," at least in the world of fine art B+W photography, which is the
concern of most here.  B+W is a level of abstraction beyond ordinary color
photography, and I'm betting most here "usually" break the rules of focusing and
exposure and processing in the pursuit of more creative avenues of expression.
Witness, for example, the toy camera enthusiasts -- the Holgas and Dianas.  I have an
especial fondness for uncoated lenses with a lot of spherical aberrations, like my
1911 Goerz Dagor -- and judging from the prices they fetch on eBay, I'm not alone.
Or diffuse-focusing lenses.
I could go on with more examples, but the point should be obvious.  In photographs
as in people, it is often their asymmetries and imperfections that make them
memorable.
Sanders McNew
www.mcnew.net
Re: OT - Tech Pan contrast
2004-07-01 by Andre
Paul,
Interesting. I see that you are using Nikon Scan as your scanning
software. Do you use a fix number for digital GEM or are you able to
judge before hand what level of grain reduction will be needed ?
Also, is Nikon Scan Unsharp Masking worth using for early
post-processing of b&w negatives and if so what level of unsharp
masking    would be a good starting point ?
Andre
RE: [Digital BW] Re: OT - Tech Pan contrast
2004-07-02 by Paul Roark
Andre,
I scan the negative twice.  With one scan GEM is turned off.  With the
second scan GEM is set to the maximum.  When the negative has not been
moved, it's easy then to clone over the sharp or grain-reduced (and a bit
softer) information as appropriate (the sky for GEM, in general).
>post-processing of b&w negatives ...
I never sharpen until I get into Photoshop.  I want the best raw scan
information as a starting point.  However, I've found GEM does a better job
than I could do in PS.  On the other hand, some of the 3rd party programs,
like Neat Image, are quite good and may even be used in addition to GEM.
2004-07-25 by Paul Roark
Andre,
Contrary to my original response, I found that I had done the comparisons
between Tmax 100 in Xtol and Tech Pan in Technidol (the results were on my
old computer).
I can't say whether one would see a major difference in an enlargement, but
the TP image quality was significantly better on the monitor when scanned
images of my standardized test targets were viewed.  The straighter curve of
TP in Technidol scanned better in my workflow, which includes scanning
negatives as positives.  The grain of TP was somewhat finer, but this is not
where the big difference was.  The resolution was about the same for the
scanned images.  However, the most noticeable difference was the sharpness
and clarity of the fine detail of the TP.
_____________________________
RF.....
Paul,
Andre
page.
them short.
the membership.
Yahoo! Groups Links
page.
them short.
the membership.
Moderators. See Group Topic, Rules and Guidelines in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
2004-07-25 by Andre
Paul,
Thanks for sharing your findings. My previous experience (several
years ago) with TP were with Rodinal (maybe not the best choice for
scanning) and FG-7 plus Sodium Sulfite with which I was able to get
better tonality than Rodinal.
Maybe I should take a look at TP with Technidol.
Andre
> Andre,
comparisons
on my
> old computer).
enlargement, but
scanned
curve of
this is not
sharpness
> Paul
> www.PaulRoark.com
Andre,
I have tried dozens of developers with TP, and I think Kodak has the others
beat when all the various factors are taken into account.  I'm usually not
inclined to pay a big company monopoly rent, but in this case, I gave up and
think it is worth it to use Technidol.
Sent: Sunday, July 25, 2004 10:34 AM
Paul,
Andre
> Andre,
comparisons
on my
> old computer).
enlargement, but
scanned
curve of
this is not
sharpness
> Paul
> www.PaulRoark.com
page.
them short.
the membership.
Yahoo! Groups Links
