Trade away my 2200 for a 1280? Help!!!!
2004-11-09 by dinolini
I've mostly lurked on the site and let me thank all of you for the time,energy & advice you
so freely give.It's truly appreciated by those like me who might really benefit from your
efforts. Thanks,thanks,thanks.
my dillema:
I print 95+% b&w. I have a 2200 w/OEM inks and use the Wilkerson (Wilkinson?) profiles. I
consistently get a decided magenta cast and to estimate +green is inconsistent and paper/
ink costly. I'm (as you can guess) very frustrated and reluctant to spend another $500 for
RIP sw of the MIS or similar ink setup. Any advice to cure this situation and encourage me
to keep the 2200 is certainly welcome.
possible (logical?) workarounds:
1) spend $200 (the price of a used 1280 that I'd be willing to spend) and get Epson RIP
2) sell my 2200,get a 1280 and print BO
3) sell the 2200,get the 1280  and use Lyson Ink set
any other ideas?
your perspective on all this will be greatly appreciated. IE: what would *you* do?
Thanks again,
Robert
Re: [Digital BW] Trade away my 2200 for a 1280? Help!!!!
2004-11-09 by Ron Slaughter
Get a grip; buy a RIP. I have the Epson 2200, a
ColorBurst RIP ($495) and perfectly neutral prints,
under any light source. Don't go back in time. Onward
and upward! :-)
Ron
> my dillema:
> any other ideas?
> Thanks again,
> Robert
Re: Trade away my 2200 for a 1280? Help!!!!
2004-11-09 by Josh Freeman
1st thing I'd ask is how are you printing? Are you printing a
grayscale image rather than rgb mode? Are you printing from photoshop
using the epson driver using "print with preview"? Are you printing
black only or using the full ink spread? Are you using a proper paper
profile? An most importantly are you clicking the box marked "NO COLOR
ADJUSTMENT"? The last bit is big, if it's not checked the system does
double profiling and you will often get magenta prints. Other than
that have you tried Roy Harrington's Quad Tone Rip?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dinolini"
> my dillema:
> any other ideas?
would *you* do?
> Thanks again,
> Robert
OK Ron,
my deathgrip on the extra $300 is loosening as we speak,and after only two replies!.I
guess I figured that was where I'd be heading.
I went to the Colorburst site,though,and 1)all the SW for OSX is also $800 and not listed
for the 2200,so I'm a little confused. If you're working on a Mac,are you using OSX,or
printing in 9? 2) What program did you get for $495? That's the price for LE-4000,but
that's made  for OS9. X-Photo is at $700 and OSX but is listed for the 4000 only.
so...which one did you buy? ( I'll be working on a Mac,with Photoshop CS-requires
Postscript?)
I'm not as obsessed w/ price as it sounds-I'll probably spend the dough,but now to find
the "right" RIP to GRIP.
Robert
Steve's suggestion of imagePrint is an $800 solution-fair enough,but I'd rather not.--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, Ron Slaughter <slauter53@y...> wrote:
> and upward! :-)
> Ron
> > my dillema:
> > any other ideas?
> > Thanks again,
> > Robert
2004-11-09 by Tyler Boley
QTR for $50 shareware, same B&W results, cross platform, much help
right here on this list.
Tyler
Josh,
I've been trying to pay attn to what's been suggested here. Yup, RGB mode,Epson
Driver,Print w/Preview,Full Ink spread,right profile and NCA-and I *still* get a magenta
cast-really tough,because I'm trying to get neutral-ultra neutral,perhaps,as i like my prints
on the cool side...
I'll check out Harrington's....thanks (any tips for using it,other than what's on the site?)---
In DigitalBlackandWhiteThePrint@yahoogroups.com, "Josh Freeman" <quakewarning@y...>
> > my dillema:
> > any other ideas?
> would *you* do?
> > Thanks again,
> > Robert
Tyler,
got a web url for that RIP of which you speak?-(or is that Roy Harrington's?-I know his
address....)
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@t...> wrote:
> Tyler
2004-11-09 by Hans Van Rafelghem
>my dillema:
>any other ideas?
>Thanks again,
>Robert
Get QTR with the QTRgui, costs only 50$ and works like a charm.
Hans Van Rafelghem
http://www.vanrafelghem.com
2004-11-09 by Bob Michaels
Have you tried printing Black Only? It's the preferable method for
many. Many of us tried all the MIS inksets, and found we liked BO with
Eboni best. And, it sure is the easiest and cheapest option. It's not
liked by everyone, but I suspect some just believe it's too simple to
work well and believe they must have a more complex solution.
It's very well documented by Clayton Jones at
Bob Michaels
> my dillema:
> any other ideas?
would *you* do?
> Thanks again,
> Robert
2004-11-09 by ferdinand_paris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Hans Van
Rafelghem <hvr@a...> wrote:
> >profiles. I consistently get a decided magenta cast
> >another $500 for RIP sw of the MIS or similar ink setup. Any
> Hans Van Rafelghem
As always I agree with Hans.  I just answered a nearly identical
question in the Qimage group.  My answer was that I too thought about
IP at one stage for much the same reasons. I then discovered QTR &
QTRGui for B&W work, which solved the problem of getting neutral B&W
prints from a 2200 using UC inks.  When used in conjuntion with Qimage
for page layout, you've virtually got a B&W equivalent of IP for much
less.   Given this, I wasn't convinced that the extra money for IP was
worth it for my humble requirements.
By all means, if you need IP's functionality, buy it, but if your
interest is mostly in B&W, then personally I'd regard it as a little
crazy if you didn't at least try QTR(Gui) first.
F_P
2004-11-09 by John Vitollo
Download QTR at:
http://www.harrington.com/QuadToneRIP.html
QTR is excellent for B+W and toned images.
For color you still use the Epson driver.
sounds good-I've been to the site (Roy Harrington's) and found the QTR download. Where
(and what) is the GUI part of the equation.-I'm working in Panther and the Gimp-Print site
says I don't need it (Gimp-Print). Do I still need the EPS Ghostprint? A bit confusing as to
what's needed to make this work.
Thanks for your help..
Robert
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ferdinand_paris"
> > Hans Van Rafelghem
> F_P
site
The GUI part is only for windows...so you don't need it.
QTR will install all the Gimp files that you need.
After QTR is installed go Profiles folder and open 2200-UT Folder. Double cliick the
Install2200.
After that I'd recomend doing a Repair Disk Permissions via the Disk Utility app.
You don't need anything Roy's instructions don't say you need.
Read anthing and everything that comes with QTR.
Tyler
QTR download. Where
> Robert
> > > Hans Van Rafelghem
> > F_P
2004-11-09 by Roger L Sopher
> download. Where
> the Gimp-Print site
> Robert
> > > Hans Van Rafelghem
> > F_P
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
> AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> *Yahoo! Groups Sponsor*
> ADVERTISEMENT
> click here
> <http://us.ard.yahoo.com/SIG=1293t456c/M=294855.5468653.6549235.3001176/D=groups/S=1705019182:HM/EXP=1100107075/A=2376776/R=0/SIG=11ldm1jvc/*http://promotions.yahoo.com/ydomains2004/index.html>
> *Yahoo! Groups Links*
>     * To visit your group on the web, go to:
>     * To unsubscribe from this group, send an email to:
>       DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>       <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
You don't need the gui if you are using a Mac.
Roger
_______________________
Roger L Sopher
rlsopher@...
http://deCorrales.com
FYI New paper out at Wilhelm Research
2004-11-09 by Lynn
Just FYI:
New on the Wilhelm Research site
(top left corner of home page):
http://www.wilhelm-research.com/
(quoting their web site)
Three New WIR Articles from IS&T NIP20:  2004 International Conference
On Digital Printing Technologies.  Salt Lake City, Utah USA November 1,
2004
  "A Review of Accelerated Test Methods for Predicting the Image Life of
Digitally-Printed Photographs—Part II"  By Henry Wilhelm
(end quote)
Direct link to the PDF download:
http://www.wilhelm-research.com/ist_3of3_04/WIR_IST_2004_11_HW.pdf
