For Paul/creating a gamma curve for soft proofing
2005-02-08 by Marcus
Paul, I recently came across your article on softproofing using a gamma curve for black
and white.  I have been getting superb results and finally not waisting paper.   THANK
YOU.  You have no idea how excited I was to find this bit of information.  I do have a few
questions though.  In your article you state this for step 7....
7.    Now you are back at the image file you had originally opened. Go to View, Proof
Setup, Custom.  The new curve you made should be in the list, probably at the bottom –
Select it.  Then check "Preserve Color Numbers."  The image on the monitor should then
look like it did while you were making the curve.  Hit OK.
My questions is, I am unable to check "preserve color number" because it is grayed out.
Am I doing something wrong?  Also, what should the intent be set to...perceptual,
absolute colorimetric or one of the other?
If my image is in rgb and I go to convert it to the softproof gamma curve, I get a message
that says, "could not load the proof set up because the source and destination have
different color modes".  So what I have been doing is changing it to grayscale and then
converting to the sooftproof.  I have a feeling I am not doing this the way it is supposed to
be done.  After converting to the soft proof, I make any necessary changes to the image
and then convert back to rgb and print using the carbon curve you created.  The prints are
looking great but I feel like I am missing a step or something.
Does this sound correct to you or am I doing something out of order?
Any help would be appreciated.  And thanks again for the advice you provide to all of us.
P.S.  I hope I made some sort of sense out of this mess.
RE: [Digital BW] For Paul/creating a gamma curve for soft proofing
2005-02-08 by Paul Roark
The procedure for profiling the monitor is at
http://home1.gte.net/res09aij/Monitor-Profiling.htm .
Marcus, I have not had time to look at the questions you asked.  It does not
work with RGB files, however.  I always edit my images in grayscale and save
them before converting to RGB for printing through a curve.
Re: [Digital BW] For Paul/creating a gamma curve for soft proofing
Great, that answers my biggest concern.  Now I just need to know about this one for step
# 7.
Instructions read.....7.    Now you are back at the image file you had originally opened. Go
to View, Proof Setup, Custom.  The new curve you made should be in the list, probably at
the bottom –Select it.  Then check "Preserve Color Numbers."  The image on the monitor
should then look like it did while you were making the curve.  Hit OK.
grayed out.
to...perceptual,
And for anyone that has not tried this profiling method, you should try it because it is
saving me from buying an expensive calibration device and I am not waisting paper any
more.  THANK YOU PAUL FOR GIVING US THIS VALUABLE PIECE OF INFORMATION.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@v...>
> Paul
> www.PaulRoark.com
2005-02-09 by Paul Roark
I just changed #7 to indicate that it is the Profiles list where you'll find
the new custom dot gain curve.  After you select that, the "Preserve Color
Numbers" should be able to be checked.  You have to select the new profile
before the box becomes active.
___________________________
Sent: Tuesday, February 08, 2005 2:42 PM
Subject: Re: [Digital BW] For Paul/creating a gamma curve for soft proofing
one for step
# 7.
probably at
the monitor
grayed out.
to...perceptual,
because it is
paper any
<paul.roark@v...>
not
save
> Paul
> www.PaulRoark.com
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
Re: For Paul/creating a gamma curve for soft proofing
2005-02-10 by Marcus
thanks Paul.  Everything is working great now.
> Paul
> www.PaulRoark.com
> From: Marcus [mailto:marcus@l...]
> one for step
> # 7.
> probably at
> the monitor
> grayed out.
> to...perceptual,
> because it is
> paper any
> <paul.roark@v...>
> not
> save
> > Paul
> > www.PaulRoark.com
> page.
> them short.
> the membership.
> Moderators. See "Group Topic, Rules and Guidelines" in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU
> GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
ANY
RE: [Digital BW] To Paul Roark
2005-02-12 by Hans & Chia
Hi Paul,
Have tried several times the last ten days to send you some email off list.
Regarding Ink sep (part two) and some thoughts about clogging, CFS etc.
The emails come back all the time, "can't deliver
email"  "address has permanent fatal errors".
Have you changed your address?
Hans
Atelier Pictoform
Chia N-Löfqvist & Hans Nohlberg
Hedåsgatan 5
SE-412 53 Göteborg
SWEDEN
+46  (0)31181414
Mobile: 073 974 44 24
(Besök/visit Hedåsgatan 6)
http://www.pictoform.nu
http://www.etsabild.se
http://www.artphotocollection.com
2005-02-12 by Paul Roark
Hans,
At least some in England are also being blocked from reaching my main
e-mail.  It must be some new filter my e-mail provider has started.  Try my
Yahoo e-mail address.  I'll e-mail you off-list from this address now.  The
Yahoo address seems to work for England.
Sent: Saturday, February 12, 2005 6:30 AM
Subject: RE: [Digital BW] To Paul Roark
Hi Paul,
Hans
Atelier Pictoform
Hedåsgatan 5
SE-412 53 Göteborg
SWEDEN
+46  (0)31181414
page.
them short.
the membership.
Yahoo! Groups Links
Selling my Epson 3000
2005-02-12 by hill14701
I've finished a project making large BO prints with my Epson 3000.  Instead of letting it
collect dust, I'm offering it to any of you who may need it before listing it you know where.
The carts are about 3/4 full.
$160 + FedEx Ground.
Please contact off-list if interested:
hill14701(at) yahoo.com
Re: [Digital BW] To Paul Roark
2005-02-12 by Walt Farrell
Yes, there's been a lot of news and complaining lately about Verizon
blocking all mail from the UK and some other European locations to avoid
spam.
	Walt
Re: Selling my Epson 3000 - Sold.
Thanks for the interest everyone - the printer has been sold.
Don
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "hill14701" <hill14701@y...>
where.
2005-02-12 by Andre
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Walt Farrell
avoid
> spam.
Blocking all mail from a particular country denotes the use of aging
technologies. But you would never guess that from their tv commercials.
My ISP installed, free of charge to its subscribers, anti-spam
blocking last year. Instead of receiving up to 50 spam email a day I
now get 3 or 4. But I do get the legitimate mails, wherever they
originate in the world.
André Moreau
2005-02-13 by Hans & Chia
Thanks Paul
I hope you have something from me now in your Yahoo box.
Hans
>Hans,
Atelier Pictoform
Hedåsgatan 5
SE-412 53 Göteborg
SWEDEN
+46  (0)31181414
