> From: rgb2bw <jnk0941@...>
> Date: Sat, 19 Feb 2005 14:44:58 -0000
> Subject: [Digital BW] Re: Understanding channel mixer
> Steve,
> To try and answer what happens when Channel Mixer settings are over
> 100 or less than zero, lets assume we have a single color image whose
> pixels have RGB values 113, 57, 179. In Photoshop, if you open up
> Curves and mouse over this image you will see it has a tonal value of
> 87. Curves calculated this as follows .30(113) + .59(57) + .11(179)
> = 87.
> If you then create a Channel Mixer adjustment layer and set it to
> monochrome, to retain the same luminance value, you will need to set
> the red slider to 30% and the green slider to 59% and the blue slider
> to 11%. Changing these sliders to anything else will change the
> resulting tone. Which is ok, because black and white is all about
> tone.
> Now, lets assume we change our Channel Mixer red slider to 200% and
> the green slider to -50% and the blue slider to -50%. This is how we
> are telling Photoshop to calculate our tone 2.0(113) - .50(57) - .50
> (179). Our resulting tone would be 108. Which would give us a
> lighter image since 108 is lighter than 87. You cannot make Channel
> Mixer calculate a tone greater than 255 or less than 0. Anything
> over 255 is collapsed to 255 and anything less than 0 becomes 0.
> Almost all the experts agree that when using Channel Mixer to keep
> the total percent as close to 100 as possible.
> Regarding constant, constant allows us to add or subtract black from
> the image. A negative constant adds black and a positive constant
> subtracts black.
> Now, the second half of this email is opinion. I personally do not
> like using the same adjustment layer to both convert my image to
> black and white and to adjust tone. I have several reasons for this
> but one of the major reasons is this forces the tonal change to be
> more of a global change (e.g. keep the channel mixer as close to 100%
> as possible, which means you change one, you need to change
> another). I usually like to selectively change tone. If you care to
> learn more about how I convert to black and white, you can go here,
> but be forwarned, it is a long read.
> http://www.zuberphotographics.com/page_TMSIntro.htm.
> Finally, we need to be conscious of what channel mixer does. Many of
> us look at our images and what to darken the sky or lighten the green
> foliage. So we open up Channel Mixer, Levels or Curves and start
> working on the channel level. What we need to be aware of is when we
> think blue sky or green foliage, we are thinking on the color range
> level. Whereas Channel Mixer works on the color channel level. In
> our example of the RGB image with values of 113, 57, 179. Its color
> range is blues. However, it has information in all three channels.
> So when we use Channel Mixer, or Levels or Curves to adjust channels,
> we are affected ANY pixel that has data in the channel being
> adjusted. When we work at the color range level, we are only
> affecting pixels whose dominant color is in that color range. The
> Hue/Saturation adjustment works on the color range level. But I
> rarely use it to adjust tone. Instead, I use Levels or Curves in a
> two step process that basically selects the color range and then
> applies the Levels or Curves adjustment. You can read more about it
> here.
> http://www.zuberphotographics.com/page_PSComparison.htm#ColorRange
> For the first half of this email, I hope it helped. For the second
> half, thanks for listening.
> Thomas
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See ³Group Topic, Rules and Guidelines² in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ³OWNER² AND
> ³MODERATORS² OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE ³OWNER² AND ³MODERATORS² OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
