There might be more to film vs. digital than specs. I have a friend
that only takes family pictures that said to me that her reason for not
going digital was because it was so wonderful NOT TO be able to se the
picture right after exposure. - I know, for a professional responsible
for the result of a photo-shoot that is not a good thing. But think
about it for a while, what does this statement contain?
For me it have something to do with "bonding" to the picture that Pete
talks about. As an "art photographer" that don't have to make a customer
happy I have experienced that pictures "grow" on me after a while. When
cloning away dust on exposures that I thought was -just- good enough not
to discard at once - I have seen new possibilities, new values. Its like
I have a chance to rediscover my pictures. And when I put more work into
getting to be able to see the results from my work with the camera
(=developing) - and some time have passed since the pictures were shot -
I become more interested in discovering ANY good values of each
exposure.
What I aim at here is that it might be a good thing to have to work
some with your pictures to be able to find their actual "value". With
digital its so easy to take thousands exposures - it doesn't cost you a
thing, you don't have to reflect before pushing the button. And when you
have pushed the button and see the result at once you only look for the
one thing that you have in mind in the moment of exposure. If that was
not successful you throw it away, you don't ever go back to it.
...Well, going for a digital camera might give you many benefits, but I
think you must act more disciplined- restrain yourself from pushing that
button all the time. With a medium format camera you know you have 12
exposures or less before you must stop for changing film. I think that
forces you to work in a bit more reflected way. And that is a good
thing.
MVH
FinnK
Finn Krogvig
-----Opprinnelig melding-----
Fra: DigitalBlackandWhiteThePrint@yahoogroups.com
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] På vegne av
petexp2
Sendt: 10. desember 2005 11:56
Til: DigitalBlackandWhiteThePrint@yahoogroups.com
Emne: [Digital BW] Re: Film vs Digital
The article in Luminous landscape (at a quick glance) seems to
highlight what in my opinion is the biggest drawback of digital
cameras -- ie. the limited dynamic range of the sensor. We can burn
down blown highlights (eg clouds) with negative film. In fact a C41
process b&w film gives us the ability to record detail in the
brightest highlights and deepest shadows. Blown highlights and
blocked shadows have no place in landscape photography and as such I
am not ready to make the digital leap.
I have 300 feet of Tech Pan in the freezer to use on lower contrast
subjects and teamed with my Zeiss lenses (35mm) and 5400dpi scanner I
have no worries about big enlargements. The only digicam files I have
handled came from the D70. I am impressed by the apparent sharpness
(down to acutance ie. in camera sharpening rather than resolution).
The out of focus areas are not as pretty as those recorded by my
Zeiss lenses and I am troubled by the plasticity of smooth blue skies
etc (I was brought up on grain). Blown highlights rear their nasty
head in most files I have handled.
The camera handling was awful compared to my Contax RX and AX bodies.
I am sure the day will come when I make the transition but I am not
ready yet by a long way. The biggest benefit will be being freed from
hours of cleaning dust (cloning) though I feel I bond with the
pictures during this lengthy process! I wonder if all those digital
files so easily recorded and filed away after a weekend's shooting
get another look!
I would be interested to know if I am talking garbage -- I admit I
have limited experience of the subject. I'll stick with film for now -
- "if it ain't broke don't fix it".
Pete.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "garethjolly"
<garethjolly@y...> wrote:
> Yes, it's a bit distressing to see the big names of the film world
> falling like flies. Have to find a replacement for Agfa FB. I'm
also
> conscious that Leica needs to get seriously into digital or go
under.
> I wasn't aware of the Epson. Interesting article on it here
> http://www.luminous-landscape.com/reviews/lenses/rd-1-lens.shtml
> Think I'll hold out a little longer - my golden rule on all things
> computer related is to never buy before you have to. I think I
could
> be tempted by a digilux with greater resolution than 5MP.
> In the meantime, though, I have to try to master my scanner and
R2400!
> And either find a decent source for Epson VFA in Sydney or work out
> how to use the Hahnmuele. And work out a way of presenting my Xpan
> images big...
> Thanks for all of the advice on the above, by the way.
> Regards
> Gareth
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Adam Maas
> <mykroft@m...> wrote:
> > Well, there's always the Epson RD-1, which is an M mount digital
> > rangefinder.
> > -Adam
> > Kip Babington wrote:
> > > I too would have liked a digital M, but gave up hope several
years ago
> > > and bought into the digital Nikon SLR world (to keep using my
> > > accumulation of Nikon lenses.) There was considerable
discussion on
> > > some of the Leica forums I used to visit (before I sold all my
Leica,
> > > Nikon, Minox and Rollei film gear) that covered the
technological in
> > > feasibility of successfully (i.e., usefully) mounting a digital
sensor
> > > in a Leica-dimensioned body, given the current state of the
art.
> Epson
> > > made (still makes?) a digital rangefinder with a Leica mount but
> with a
> > > reduced-size sensor (smaller than 24x36mm) and so the delightful
> size of
> > > an M6 with a 35mm Summicron doesn't get you the same wide angle
of
> view
> > > in the Epson that your get with film Leica. The consensus of
> > > technically knowledgeable at the time was that the laws of
physics
> > > simply precluded the production of digital sensors in 24x36
size that
> > > would work with existing Leica lenses at the lens-to-film
> distances used
> > > in the Leica rangefinders. Sigh.
> > > As for the obsolescence point, remember that a camera that
takes fine
> > > pix today will take just as fine pix next year, even if there's
a
> > > "better" model available next year. Better models are announced
> > > continually in the digital world (who knows when, if ever, that
will
> > > end) and by the time they're actually available in stores there
> > > frequently are at least rumors of even better models right
around the
> > > corner. Again, if it would be a good tool today, it will be a
> good tool
> > > tomorrow. I paid full list for my Nikon D100 when it came out,
> and now
> > > I could buy it for half (if it's even still available) but I've
had
> > > several years of wonderful use from it so far, and have no
> intentions of
> > > replacing it in the near future as it does what I need it to do.
> > > I kept all of my film gear for more than a year after I got my
> D100, and
> > > after not taking a single frame of film in that time decided to
let it
> > > go. I was surprised that it didn't bother me in the least to
let
> it go
> > > (I had had one of them, a Leica IIIc, since the 1950s) and I
have not
> > > missed it in the years since. I had a fair bit of Leica gear,
> including
> > > an M6 with 7 lenses (2 of them for the Visoflex - hard core!)
and
> loved
> > > both having and using it, but the ease of MY getting better
> results with
> > > digital made it easy to let go. I used to go through about 250
> rolls of
> > > B&W film a year (and about 1 roll of color every 2 years) and
did
> all my
> > > own developing and printing. I now take MORE images digitally
each
> > > year, "process" them much more quickly (a dozen or more contact
sheets
> > > of a weekend's shooting hung up to dry within an hour or two of
> sitting
> > > down at the computer, and most of that time the software is
compiling
> > > the contacts while I'm reading email) and create better looking
> (to ME)
> > > prints faster and easier than I ever did in a wet darkroom.
> > > Of course, YMMV.
> > > Cheers,
> > > Kip
> > > garethjolly wrote, in part:
> > > >Thanks everyone
> > > >A couple of things
> > > >- like a few others on the list, obsolescence is an issue for
> me. I'd
> > > >like the technology to stabilise before investing. Top end
> digital is
> > > >also very expensive compared to top end 35mm
> > > >- I use a Leica M7 (and recently also an Xpan). I'd like to
get a
> > > >digilux, but at the moment, it's spec.s are well off the pace
(5
> > > >megapixel). Actually, ideally, I'd like a digital M where I
> could use
> > > >my existing lens. To be honest, I wouldn't go back to an
SLR. The
> > > >Leica Ms are beautiful camera's to use and suit my style of
> photography
> > > >- I love darkroom printing - both from an aesthetic point of
> view and
> > > >simply as a relaxant. Scanning film gives me the best of both
> worlds
> > > >for the moment.
> > > ><snip>
Please visit the Group Homepage to check the Files, and other resources
as they are often being updated.
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
membership without notice.
printing. Users who persistently make off-topic posts may be removed
from the membership.
guidelines, and to abide by the actions and decisions of the group Owner
and Moderators. See Group Topic, Rules and Guidelines in the Files
section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA;
(iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE PRINT YAHOO GROUP.
_____
YAHOO! GROUPS LINKS
* Visit your group "DigitalBlackandWhiteThePrint
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> " on the
web.
* To unsubscribe from this group, send an email to:
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject
=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
_____
